R F
C o m p o n e n t s
September 2016
Multilayer Diplexer
For 2400-2500MHz / 4900-5950MHz
DPX105950DT-6012A1
1.0x0.5mm [EIA 0402]*
* Dimensions Code JIS[EIA]
RF Components
Multilayer Diplexer
Conformity to RoHS Directive
DPX105950DT-6012A1
SHAPES AND DIMENSIONS
[Top view]
1.00±0.05
0.33max.
(3)
(1)
(2)
Marking
0.50±0.05
(4)
[Bottom view]
0.20±0.10
0.12±0.07
Terminal functions
1 Common
2 GND
3 High-band
4 Low-band
0.10±0.10
0.30±0.10
Dimensions in mm
RECOMMENDED LAND PATTERN
0.20
EVALUATION BOARD
Marking
0.30
0.60
0.20 0.20
Thru hole
Resist
5G port
Com port
Surface Pattern
2.4G Port
Dimensions in mm
Material, Layer
Top Resist
Copper Surface Pattern
FR-4
Copper Inner GND
FR-4
Copper Bottom GND
Thickness
Resist
0.035mm
0.10mm
0.018mm
0.30mm
0.035mm
Line width should be designed to match 50Ω characteristic impedance,
depending on PCB material and thickness.
RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20160901 / rf_dpx_dpx105950dt-6012a1_en.fm
RF Components
DPX105950DT-6012A1
ELECTRICAL CHARACTERISTICS
LOW-BAND
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Frequency Range
(MHz)
Min.
Typ.
Max.
2400
2400
2400
4800
7200
10
23
23
0.37
22
29
29
50 (Nominal)
0.50
0.60 (–40 to +85°C)
Frequency Range
(MHz)
Min.
Typ.
Max.
4900
4900
4900
30
2400
2500
9800
10
25
27
23
15
29
41
29
30
50 (Nominal)
0.80
1.00 (–40 to +85°C)
Min.
Typ.
Max.
10
10
22
15
50 (Nominal)
1
to
to
to
to
to
2500
2500
2500
6000
7500
Characteristic Impedance ()
・Ta: +25±5°C
HIGH-BAND
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
to 5950
to 5950
to 5950
to 2400
to 2500
to 2690
to 11900
・Ta: +25±5°C
COMMON
Item
Frequency Range
(MHz)
Return Loss (dB)
2400 to 2500
4900 to 5950
Power Handling (W)
・Ta: +25±5°C
TEMPERATURE RANGE
Temperature range
Operating temperature
Storage temperature
(°C)
(°C)
–40 to +85
–40 to +85
RF Components
DPX105950DT-6012A1
FREQUENCY CHARACTERISTICS
HIGH-BAND
Insertion Loss
0.0
0.0
0.5
0.5
1.0
1.0
Insertion Loss (dB)
Insertion Loss (dB)
LOW-BAND
Insertion Loss
1.5
2.0
2.0
2.5
2.5
3.0
1000
1500
2000
2500
3000
Frequency (MHz)
3500
3.0
4000
4000
10
Return Loss (dB)
50
1000
5500
6000
Frequency (MHz)
6500
7000
4500
5000
5500
6000
Frequency (MHz)
6500
7000
1500
2000
2500
3000
Frequency (MHz)
3500
50
4000
4000
Attenuation
10
Attenuation (dB)
Attenuation
Attenuation (dB)
5000
40
40
40
50
4500
Return Loss
Return Loss
Return Loss (dB)
1.5
40
2000
4000
6000
8000
Frequency (MHz)
10000
12000
50
2000
4000
6000
8000
Frequency (MHz)
10000
12000
RF Components
DPX105950DT-6012A1
COMMON
Return Loss
Isolation
Isolation (dB)
Return Loss (dB)
10
30
40
40
50
60
1000
2000
3000
4000
5000
Frequency (MHz)
6000
7000
50
2000
4000
6000
8000
Frequency (MHz)
10000
12000
RF Components
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
150°C
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
t3
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
RF Components
REMINDERS FOR USING THESE PRODUCTS
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DPX105950DT-6012A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.55220
- 100+0.38170
- 500+0.34650
- 2500+0.32120
- 5000+0.29920
- 10000+0.27500
- 国内价格 香港价格
- 1+2.823281+0.36702
- 10+2.4056510+0.31273
- 25+2.2697025+0.29506
- 100+2.07303100+0.26949
- 250+1.95516250+0.25417
- 500+1.87165500+0.24331
- 1000+1.792891000+0.23307
- 5000+1.626715000+0.21147
- 国内价格 香港价格
- 10000+1.5617510000+0.20303
- 20000+1.5005120000+0.19506
- 30000+1.4663230000+0.19062
- 50000+1.4249050000+0.18524
