DPX105950DT-6012A2
DPX105950DT-6012A2
    TDK(东电化)
DPX105950DT-6012A2 数据手册
May. 2021 Ver.4.0 TDK Corporation   Multilayer Diplexer For LTE / 5GHz DPX Series P/N: 1.0x0.5mm [EIA 0402] TYPE DPX105950DT-6012A2 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies   May. 2021 Ver.4.0 TDK Corporation DPX105950DT-6012A2 ■ SHAPES AND DIMENSIONS Dimensions (mm) L W T a b c d 1.00 0.50 0.33 0.30 0.20 0.10 0.12 +/-0.05 +/-0.05 Max +/-0.10 +/-0.10 +/-0.10 +/-0.07 Terminal functions Common Port (1) GND (2) High-Band Port (3) Low-Band Port (4) ■ TERMINATION FINISH Material Sn plate All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.4.0 TDK Corporation   DPX105950DT-6012A2 ■ ELECTRICAL CHARACTERISTICS ( Measurement ) Low-Band Parameter Insertion Loss (dB) Insertion Loss (dB) ( –40 to +85 °C ) Return Loss@Low-Band (dB) Attenuation (dB) 2400 to 2400 to TDK Spec Min. Typ. Max. 2500 0.37 0.50 2500 0.60 2400 to 4800 to 7200 to 2500 6000 7500 Frequency (MHz) Characteristic Impedance (ohm) Ta = +25+/-5°C 10 22 23 29.0 23 29.0 50 (Nominal) High-Band Parameter Insertion Loss (dB) Insertion Loss (dB) ( –40 to +85 °C ) Return Loss@High-Band (dB) Attenuation (dB) Characteristic Impedance (ohm) Ta = +25+/-5°C TDK Spec Min. Typ. Max. 5950 0.56 0.80 5950 1.00 Frequency (MHz) 4900 to 4900 to 4900 30 2400 2500 9800 to 5950 to 2400 to 2500 to 2690 to 11900 10 15 25 29 32 41 23 29 20 30 50 (Nominal) All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.4.0 TDK Corporation   DPX105950DT-6012A2 ■ ELECTRICAL CHARACTERISTICS ( Measurement ) Common Parameter Return Loss (dB) ( Common Port ) Characteristic Impedance (ohm) Ta = +25+/-5°C TDK Spec Min. Typ. Max. 2500 10 22 5950 10 15 50 (Nominal) Frequency (MHz) 2400 to 4900 to ■ MAXIMUM RATINGS Parameter Operating temperature (°C) Storage temperature (°C) Power Handling (W) *1 Common Port Low-Band High-Band Human Body Model : HBM Machine Model : MM Charged Device Model : CDM TDK Spec Conditions –40 to +85 °C –40 to +85 °C Frequency (MHz) CW 1 2400 to 2500 CW 1 4900 to 5950 CW 1 2400 to 2500 CW 1 4900 to 5950 @Each Port (V) +/-1000 100pF / 1500ohm +/-150 200pF / 0ohm @Each Port (V) +/-500 Humidity : 60%RH max @Each Port (V) *1 : Refer to 3GPP TS 38.101-1 V15.2.0 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.4.0 TDK Corporation   DPX105950DT-6012A2 ■ FREQUENCY CHARACTERISTICS Low band-Port S21 High band-Port Attenuation 0 Insertion Loss (Low-Band) 5 4800 5000 6000 7200 7500 10 30 29 34 29 29 dB dB dB dB dB 5 20 25 30 35 S31 Insertion Loss (High-Band) 10 15 Attenuation[dB] Attenuation[dB] 15 MHz MHz MHz MHz MHz 0 20 25 30 35 50 32 30 29 29 30 35 55 41 29 30 34 dB dB dB dB dB dB dB dB dB dB dB 50 500 2500 4500 6500 8500 10500 12500 500 2500 4500 Frequency[MHz] Low band-Port 6500 8500 10500 12500 Frequency[MHz] S21 High band-Port Insertion Loss 2400 MHz 0.32 2500 MHz 0.37 0 S31 Insertion Loss 4900 MHz 5950 MHz 0 dB dB 0.54 dB 0.56 dB 0.5 Insertion Loss[dB] 0.5 Insertion Loss[dB] MHz MHz MHz MHz MHz MHz MHz MHz MHz MHz MHz 45 45 1 1.5 2 Attenuation (Low-Band) 1 1.5 2 Attenuation (High-Band) 2.5 2.5 3 3 1000 1500 2000 2500 3000 3500 4000 4000 4500 5000 Common Port Return Loss 5500 6000 6500 7000 Frequency[MHz] Frequency[MHz] S11 Isolation S23 0 0 5 10 15 20 25 30 35 40 45 50 55 60 2400 2500 4900 5950 MHz MHz MHz MHz 26 22 20 15 dB dB dB dB 2400 2500 4900 5950 5 10 15 Isolation[dB] Return Loss[dB] 700 960 1560 1610 1710 2170 2400 2500 2690 9800 11900 40 40 MHz MHz MHz MHz 40 38 32 35 dB dB dB dB 20 25 30 35 40 45 50 500 1000 1500 2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 7000 2500 4500 Low band-Port Return Loss S22 Isolation 6500 8500 10500 12500 Frequency[MHz] Frequency[MHz] High band-Port Return Loss 0 2400 MHz 2500 MHz 5 10 15 15 25 30 35 4900 MHz 5950 MHz 5 10 20 S33 0 26 dB 22 dB Return Loss[dB] Return Loss[dB] Attenuation 20 25 30 35 40 40 45 45 50 50 1000 1500 2000 2500 3000 Frequency[MHz] 3500 4000 4000 4500 5000 5500 6000 6500 7000 Frequency[MHz] All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies 23 dB 15 dB May. 2021 Ver.4.0 TDK Corporation   DPX105950DT-6012A2 ■ RECOMMENDED LAND PATTERN unit : mm ■ EVALUATION BOARD unit : mm Material & Layer Copper Surface Pattern FR-4 Inner GND FR-4 Copper Bottom GND Thickness 0.035 mm 0.10 mm 0.018 mm 0.30 mm 0.035 mm * Line width should be designed to match 50 ohm characteristic impedance depending on PCB material and thickness. ** The position of the throuh hole which have possibility of influence to the prerformance are indicated by dimension line. ■ ENVIRONMENT INFORMATION RoHS Statement RoHS Compliance All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies TDK Corporation ■ RECOMMENDED REFLOW PROFILE 3oC/sec or lower Preheating Temp. T1 T2 Time t1 150°C 200°C 60 to 120sec 6oC/sec or lower Soldering Critical zone (T3 to T4) Peak Temp. Time Temp. Time T3 t2 T4 t3 * 217°C 60 to 120sec 240 to 260°C 30 sec Max * t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. Note: Lead free solder is recommended. Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry) All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.4.0 TDK Corporation   DPX105950DT-6012A2 ■ PACKAGING STYLE Reel Dimensions Carrier Tape K J Loading Direction B D A C E Sprocket hole B t G H Dimensions (mm) A B C 0.62 1.12 8.0 +/-0.05 +/-0.05 +/-0.2 D 3.5 E 1.75 +/-0.05 +/-0.1 F 2.0 G 2.0 F H 4.0 Unit : mm J 1.5 +/-0.05 +/-0.05 +/-0.05 +0.1/-0 K 0.37 t 0.2 MAX +/-0.05 STANDARD PACKAGE QUANTITY ( pieces/reel ) 10,000 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this specification sheet are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. Aerospace/Aviation equipment Transportation equipment (cars, electric trains, ships, etc.) Medical equipment Power-generation control equipment Atomic energy-related equipment Seabed equipment Transportation control equipment Public information-processing equipment Military equipment Electric heating apparatus, burning equipment Disaster prevention/crime prevention equipment Safety equipment Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/equipment or providing backup circuits, etc., to ensure higher safety. All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies
DPX105950DT-6012A2 价格&库存
很抱歉,暂时无法提供与“DPX105950DT-6012A2”相匹配的价格&库存,您可以联系我们找货
DPX105950DT-6012A2
  • 1+2.561241+0.33290
  • 10+2.0564710+0.26729
  • 25+1.8919125+0.24591
  • 50+1.7792150+0.23126
  • 100+1.67324100+0.21748
  • 250+1.54264250+0.20051
  • 500+1.45103500+0.18860
  • 1000+1.364801000+0.17739
  • 5000+1.184105000+0.15391
库存:8997
DPX105950DT-6012A2
  • 10000+1.0820210000+0.14064
  • 20000+1.0178220000+0.13230
  • 30000+0.9820230000+0.12764
  • 50000+0.9386850000+0.12201
  • 70000+0.9111870000+0.11843
库存:8997
