Jul. 2016
Ver.2.0N
TDK Corporation
Multilayer Diplexer
For 2.4GHz W-LAN & Bluetooth / 5GHz W-LAN
DPX Series
P/N:
1.0x0.5mm [EIA 0402] TYPE
DPX105950DT-6112A1
All specifications are subject to change without notice.
TDK Technology - Proprietary and Confidential Information of TDK Group Companies
Jul. 2016
Ver.2.0N
TDK Corporation
DPX105950DT-6112A1
■ SHAPES AND DIMENSIONS
Dimensions (mm)
L
W
T
a
b
c
d
1.00 0.50 0.33 0.10 0.30 0.20 0.12
+/-0.05 +/-0.05
Max
+/-0.10 +/-0.10 +/-0.10 +/-0.07
Terminal functions
GND
(1)
Common Port
(2)
Low-Band Port
(3)
High-Band Port
(4)
■ TEMPERATURE RANGE
Operating temperature Storage temperature
–40 to +90 °C
–40 to +90 °C
■ TERMINATION FINISH
Material
Sn plate
Jul. 2016
Ver.2.0N
TDK Corporation
DPX105950DT-6112A1
■ ELECTRICAL CHARACTERISTICS
( Measurement )
Low-Band
Parameter
Insertion Loss (dB)
Insertion Loss (dB)
( –40 to +90 °C )
Return Loss (dB)
Attenuation (dB)
2400 to
2400 to
TDK Spec
Min. Typ. Max.
2500 0.37 0.50
2500 0.60
2400 to
4800 to
7200 to
2500
6000
7500
Frequency (MHz)
Power Handling (W)
Ta = +25+/-5°C
10
23
23
22
29
29
1.0
High-Band
Parameter
Insertion Loss (dB)
Insertion Loss (dB)
( –40 to +90 °C )
Return Loss (dB)
Attenuation (dB)
TDK Spec
Min. Typ. Max.
5950 0.56 0.80
5950 1.00
Frequency (MHz)
4900 to
4900 to
4900
30
2400
2500
9800
to 5950
to 2400
to 2500
to 2690
to 11900
Power Handling (W)
Ta = +25+/-5°C
10
25
27
23
29
41
29
30
1.0
Common
Parameter
Return Loss (dB)
TDK Spec
Min. Typ. Max.
2500 10
22
5950 10
15
Frequency (MHz)
2400 to
4900 to
Ta = +25+/-5°C
Jul. 2016
Ver.2.0N
TDK Corporation
DPX105950DT-6112A1
■ FREQUENCY CHARACTERISTICS
Insertion Loss (Low-Band)
Insertion Loss (High-Band)
Return Loss (Low-Band)
Return Loss (high-Band)
Attenuation (Low-Band)
Attenuation (High-Band)
Isolation
Common port Return Loss
Jul. 2016
Ver.2.0N
TDK Corporation
DPX105950DT-6112A1
■ RECOMMENDED LAND PATTERN
200
300
200
600
200
Unit : um
■ EVALUATION BOARD
Direction
Thru hole
Com port
Resist
Surface
■ ENVIRONMENT INFORMATION
RoHS Statement
RoHS Compliance
Jul. 2016
Ver.2.0N
TDK Corporation
DPX105950DT-6112A1
■ RECOMMENDED REFLOW PROFILE
Pb free solder
Soaking
Temp.
Time
t1
T1
T2
150°C 180°C 60 to 120sec
Working
Temp.
Time
T3
t2
230°C
more than 30sec
Soldering
Temp.
Time
T4
t3
Peak
Temp.
T5
247 to 253°C within 10sec 260°C Max.
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this specification sheet are intended for use in general electronic equipment
(AV equipment, telecommunications equipment, home appliances, amusement equipment,
computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed
below, whose performance and/or quality require a more stringent level of safety or reliability,
or whose failure, malfunction or trouble could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the
products in any of the applications below or for any other use exceeding the range or
conditions set forth in this specification sheet.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
Aerospace/Aviation equipment
Transportation equipment (cars, electric trains, ships, etc.)
Medical equipment
Power-generation control equipment
Atomic energy-related equipment
Seabed equipment
Transportation control equipment
Public information-processing equipment
Military equipment
Electric heating apparatus, burning equipment
Disaster prevention/crime prevention equipment
Safety equipment
Other applications that are not considered general-purpose applications
When using this product in general-purpose applications, you are kindly requested to take into
consideration securing protection circuit/equipment or providing backup circuits, etc.,
to ensure higher safety.
很抱歉,暂时无法提供与“DPX105950DT-6112A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.61175
- 50+0.53431
- 150+0.49559
- 500+0.46655
- 2500+0.43171
- 5000+0.42009
- 国内价格
- 1+0.52920
- 100+0.49392
- 300+0.45864
- 500+0.42336
- 2000+0.40572
- 5000+0.39513
