DPX105950DT-6112A2
DPX105950DT-6112A2
    TDK(东电化)
DPX105950DT-6112A2 数据手册
R F C o m p o n e n t s August 2018 Multilayer Diplexer For 2400-2500MHz / 4900-5950MHz DPX105950DT-6112A2 1.0x0.5mm [EIA 0402]* * Dimensions Code JIS[EIA] RF Components Multilayer Diplexer Conformity to RoHS Directive For 2400-2500MHz / 4900-5950MHz DPX105950DT-6112A2 SHAPES AND DIMENSIONS [Top view] 1.00±0.05 0.33max. (3) (1) (2) Marking 0.50±0.05 (4) [Bottom view] 0.20±0.10 0.12±0.07 Terminal functions 1 GND 2 Common Port 3 Low-band Port 4 High-band Port 0.10±0.10 0.30±0.10 Dimensions in mm RECOMMENDED LAND PATTERN 0.20 EVALUATION BOARD 0.30 Direction Marking 0.60 0.20 0.20 Thru hole Resist Com port 5G port Surface Pattern 2.4G Port Dimensions in mm Material, Layer Top Resist Copper Surface Pattern FR-4 Copper Inner GND FR-4 Copper Bottom GND Thickness Resist 0.035mm 0.10mm 0.018mm 0.30mm 0.035mm Line width should be designed to match 50Ω characteristic impedance, depending on PCB material and thickness. RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20180827 / rf_dpx_dpx105950dt-6112a2_en.fm RF Components DPX105950DT-6112A2 ELECTRICAL CHARACTERISTICS LOW-BAND Frequency Range (MHz) Min. Typ. Max. 2400 to 2500 2400 to 2500 2400 to 2500 4800 to 6000 7200 to 7500 — — 10 23 23 0.37 — 22 29 29 50 (Nominal) 0.50 0.60 (–40 to +85°C) — — — Frequency Range (MHz) Min. Typ. Max. 4900 to 5950 4900 to 5950 4900 to 5950 30 to 2400 2400 to 2500 2500 to 2690 9800 to 11900 — — 10 25 32 23 20 0.56 — 15 29 41 29 30 50 (Nominal) 0.80 1.00 (–40 to +85°C) — — — — — Item Frequency Range (MHz) Min. Typ. Max. Return Loss (dB) 2400 to 2500 4900 to 5950 10 10 — 22 15 — 50 (Nominal) — — 1 Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Characteristic Impedance () ・Ta: +25±5°C HIGH-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Characteristic Impedance () ・Ta: +25±5°C COMMON Power Handling (W) Characteristic Impedance () ・Ta: +25±5°C TEMPERATURE RANGE Operating temperature (°C) –40 to +85 Storage temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20180827 / rf_dpx_dpx105950dt-6112a2_en.fm RF Components DPX105950DT-6112A2 FREQUENCY CHARACTERISTICS HIGH-BAND Insertion Loss 0.0 0.0 0.5 0.5 1.0 1.0 Insertion Loss(dB) Insertion Loss(dB) LOW-BAND Insertion Loss 1.5 2.0 1000 1500 2000 2500 Frequency (MHz) 3000 3500 0 10 10 20 30 40 50 500 5000 6000 Frequency (MHz) 7000 8000 4000 5000 6000 Frequency (MHz) 7000 8000 20 30 40 1000 1500 2000 2500 Frequency (MHz) 3000 3500 50 3000 4000 Attenuation Attenuation 0 10 10 Attenuation(dB) 0 20 30 20 30 40 40 50 4000 Return Loss 0 Return Loss(dB) Return Loss(dB) 3.0 3000 4000 Return Loss Attenuation(dB) 2.0 2.5 2.5 3.0 500 1.5 50 0 2000 4000 6000 Frequency (MHz) 8000 10000 12000 0 2000 4000 6000 Frequency (MHz) 8000 10000 12000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20180827 / rf_dpx_dpx105950dt-6112a2_en.fm RF Components DPX105950DT-6112A2 FREQUENCY CHARACTERISTICS Isolation 0 0 10 10 20 20 Isolation(dB) Return Loss(dB) COMMON Return Loss 30 40 40 50 30 50 0 2000 4000 6000 Frequency (MHz) 8000 10000 12000 0 2000 4000 6000 Frequency (MHz) 8000 10000 12000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20180827 / rf_dpx_dpx105950dt-6112a2_en.fm RF Components DPX105950DT-6112A2 RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 150°C T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec Peak Temp. T4 240 to 260°C Time t3 30sec max. t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20180827 / rf_dpx_dpx105950dt-6112a2_en.fm RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20180827 / rf_dpx_dpx105950dt-6112a2_en.fm
DPX105950DT-6112A2 价格&库存
很抱歉,暂时无法提供与“DPX105950DT-6112A2”相匹配的价格&库存,您可以联系我们找货
DPX105950DT-6112A2
    库存:290000
    DPX105950DT-6112A2
      • 5+0.78020
      • 50+0.62409
      • 150+0.54604
      • 500+0.48756
      • 2500+0.44073
      • 5000+0.41732
      库存:5264
      DPX105950DT-6112A2
      • 10000+1.5621510000+0.20308
      • 20000+1.5008820000+0.19511
      • 30000+1.4666930000+0.19067
      • 50000+1.4252550000+0.18528
      库存:14324
      DPX105950DT-6112A2
      • 1+2.823991+0.36711
      • 10+2.4062510+0.31281
      • 25+2.2702725+0.29513
      • 100+2.07355100+0.26956
      • 250+1.95565250+0.25423
      • 500+1.87212500+0.24337
      • 1000+1.793341000+0.23313
      • 5000+1.627125000+0.21152
      库存:14324
      DPX105950DT-6112A2
      • 1+0.64900
      • 100+0.44770
      • 500+0.40700
      • 2500+0.37620
      • 5000+0.35200
      • 10000+0.32340
      库存:15687
