R F
C o m p o n e n t s
July 2015
Multilayer Diplexer
For 806-941MHz / 1574.42-1576.42MHz
DPX161576DT-8011B1
1.6x0.8mm [EIA 0603]*
* Dimensions Code JIS[EIA]
Caution
The products in this catalog will be or have been
stopped production
Discontinue Issue Date
Apr. 28, 2021
Last Purchase Order Date
Dec. 31, 2022
Last Shipment Date
Mar. 31, 2023
Please refer to our Web site about replacement information.
RF Components
Multilayer Diplexer
Conformity to RoHS Directive
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
DPX161576DT-8011B1
SHAPES AND DIMENSIONS
1.60±0.10
0.60±0.10
(1)
(2)
(3)
(6)
(5)
(4)
Marking
0.80±0.10
[Top view]
0.15±0.10
[Bottom view]
0.55±0.10
0.30±0.10
Terminal functions
1 Low-band
2 GND
3 High-band
4 GND
5 Common
6 GND
0.25±0.10
0.10±0.10
Dimensions in mm
RECOMMENDED LAND PATTERN
EVALUATION BOARD
0.70
0.70
0.10
0.80
0.40
Low-band
High-band
0.
70
ø0.15 Through-hole
Dimensions in mm
Th
e
0.15
0.15 0.40
Common
Dimensions in mm
Line width should be designed to match 50Ω characteristic impedance,
depending on PCB material and thickness.
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20150701 / rf_dpx_dpx161576dt-8011b1_en.fm
RF Components
DPX161576DT-8011B1
ELECTRICAL CHARACTERISTICS
Item
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
LOW-BAND
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Frequency Range
(MHz)
Min.
Typ.
Max.
806 to 941
806 to 941
806 to 941
1575
1612 to 1648
1792 to 1856
2000 to 3000
14
16
18
14
5
0.40
16.8
21.7
25.2
18.9
10.1
50 (Nominal)
0.60
0.70 (–30 to +85°C)
Frequency Range
(MHz)
Min.
Typ.
Max.
1574.42 to 1576.42
1574.42 to 1576.42
1574.42 to 1576.42
806
to 928
14
22.8
30.5
50 (Nominal)
0.70
0.80 (–30 to +85°C)
Frequency Range
(MHz)
Min.
Typ.
Max.
806
to 928
1575
1612
to 1648
1792
to 1856
806
to 941
1574.42 to 1576.42
18
14
14
14
30.8
22.3
26.0
21.5
17.6
16.7
50 (Nominal)
Characteristic Impedance (:)
・Ta: +25±5°C
HIGH-BAND
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
・Ta: +25±5°C
COMMON
Item
Isolation (dB)
Return Loss (dB)
・Ta: +25±5°C
TEMPERATURE RANGE
Th
e
Operating temperature
(°C)
–30 to +85
RF Components
DPX161576DT-8011B1
FREQUENCY CHARACTERISTICS
0.0
0.0
0.5
Insertion Loss(dB)
1.0
1.5
2.0
2.5
600
Return Loss
30
600
Attenuation
1100
1200
3.0
1200
1300
700
800
900
1000
Frequency(MHz)
1100
1200
1400
1500
1600
1700
Frequency(MHz)
1800
1900
2000
1400
1500
1600
1700
Frequency(MHz)
1800
1900
2000
50
1200
1300
1300
Attenuation
30
40
50
500
1300
Return Loss
Th
e
Attenuation(dB)
800
900
1000
Frequency(MHz)
40
40
Return Loss(dB)
Return Loss(dB)
2.0
10
10
500
1.0
2.5
Attenuation(dB)
Insertion Loss(dB)
0.5
3.0
500
HIGH-BAND
Insertion Loss
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
LOW-BAND
Insertion Loss
1000
40
1500
2000
Frequency(MHz)
2500
3000
50
500
1000
1500
2000
Frequency(MHz)
2500
3000
RF Components
DPX161576DT-8011B1
Return Loss(dB)
10
40
40
1000
1500
2000
Frequency(MHz)
2500
3000
50
500
1000
1500
2000
Frequency(MHz)
2500
3000
Th
e
50
500
Isolation
Isolation(dB)
COMMON
Return Loss
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
RF Components
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T1
t1
T3
t3
t2
t: Time
Preheating
Temp.
T1
150°C
t3
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
Th
e
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
RF Components
REMINDERS FOR USING THESE PRODUCTS
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
Th
e
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DPX161576DT-8011B1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7.322181+0.95171
- 10+6.3199210+0.82144
