DPX165850DT-8033B1
DPX165850DT-8033B1
    TDK(东电化)
    应用:AV设备。电信设备。家用电器。娱乐设备。计算机设备。个人设备。办公设备。测量设备。工业机器人
DPX165850DT-8033B1 数据手册
The products in this catalog are not recommended for new design R F C o m p o n e n t s August 2015 Multilayer Diplexer For 704-1610MHz / 2400-5900MHz DPX165850DT-8033B1 1.6x0.8mm [EIA 0603]* * Dimensions Code JIS[EIA] The products in this catalog are not recommended for new design RF Components Multilayer Diplexer Conformity to RoHS Directive For 704-1610MHz / 2400-5900MHz DPX165850DT-8033B1 SHAPES AND DIMENSIONS [Top view] 1.60±0.15 0.60±0.10 (5) (4) (1) (2) (3) Marking 0.80±0.15 (6) 0.55±0.10 0.30±0.15 Terminal functions 1 GND 2 Common 3 GND 4 High-band 5 GND 6 Low-band 0.15±0.15 [Bottom view] 0.25±0.15 0.10±0.15 Dimensions in mm RECOMMENDED LAND PATTERN 0.30 0.60 0.30 0.25 Dimensions in mm RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150801 / rf_dpx_dpx165850dt-8033b1_en.fm The products in this catalog are not recommended for new design RF Components DPX165850DT-8033B1 ELECTRICAL CHARACTERISTICS LOW-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Frequency Range (MHz) Min. Typ. Max. 704 to 960 1572 to 1578 1570 to 1610 704 to 960 1572 to 1578 1570 to 1610 704 to 960 1572 to 1578 1570 to 1610 2400 to 2500 2500 to 2690 4900 to 5150 5150 to 5850 5850 to 5900 — — — — — — 10 10 10 15 13 18 20 20 0.35 0.52 0.61 — — — 13.5 19.1 16.1 24 19 23 28 28 50 (Nominal) 0.50 0.75 0.85 0.70 (–40 to +85°C) 0.95 (–40 to +85°C) 1.05 (–40 to +85°C) — — — — — — — — Frequency Range (MHz) Min. Typ. Max. 2400 to 2500 2500 to 2690 4900 to 5150 5150 to 5850 5850 to 5900 2400 to 2500 2500 to 2690 4900 to 5150 5150 to 5850 5850 to 5900 2400 to 2500 2500 to 2690 4900 to 5150 5150 to 5850 5850 to 5900 704 to 960 1572 to 1578 1570 to 1610 — — — — — — — — — — 10 10 10 10 10 25 20 20 0.64 0.70 0.24 0.22 0.36 — — — — — 19.7 12.6 17.0 15.4 14.7 32 37 30 50 (Nominal) 0.75 0.85 0.55 0.55 0.55 0.95 (–40 to +85°C) 1.05 (–40 to +85°C) 0.75 (–40 to +85°C) 0.75 (–40 to +85°C) 0.75 (–40 to +85°C) — — — — — — — — Characteristic Impedance (:) ・Ta: +25±5°C HIGH-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Characteristic Impedance (:) ・Ta: +25±5°C TEMPERATURE RANGE Operating temperature (°C) –40 to +85 Storage temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150801 / rf_dpx_dpx165850dt-8033b1_en.fm The products in this catalog are not recommended for new design RF Components DPX165850DT-8033B1 FREQUENCY CHARACTERISTICS HIGH-BAND Insertion Loss 0.0 0.0 0.5 0.5 1.0 1.0 Insertion Loss(dB) Insertion Loss(dB) LOW-BAND Insertion Loss 1.5 2.0 2.5 3.0 2.0 2.5 600 800 1000 1200 1400 Frequency(MHz) 1600 1800 3.0 2000 2000 Return Loss 0 10 10 20 30 40 50 2500 5000 5500 6000 3000 3500 4000 4500 Frequency(MHz) 5000 5500 6000 7000 8000 30 40 600 800 1000 1200 1400 Frequency(MHz) 1600 1800 50 2000 2000 2500 0 0 10 10 Attenuation(dB) Attenuation Attenuation(dB) 3500 4000 4500 Frequency(MHz) 20 Attenuation 20 30 20 30 40 40 50 3000 Return Loss 0 Return Loss(dB) Return Loss(dB) 1.5 1000 2000 3000 4000 5000 Frequency(MHz) 6000 7000 8000 50 1000 2000 3000 4000 5000 Frequency(MHz) 6000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150801 / rf_dpx_dpx165850dt-8033b1_en.fm The products in this catalog are not recommended for new design RF Components DPX165850DT-8033B1 FREQUENCY CHARACTERISTICS Isolation 0 0 10 10 20 20 Isolation(dB) Return Loss(dB) COMMON Return Loss 30 40 40 50 30 50 1000 2000 3000 4000 5000 Frequency(MHz) 6000 7000 8000 1000 2000 3000 4000 5000 Frequency(MHz) 6000 7000 8000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150801 / rf_dpx_dpx165850dt-8033b1_en.fm The products in this catalog are not recommended for new design RF Components RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 150°C T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. Peak Temp. T4 240 to 260°C Time t3 30sec max. The products in this catalog are not recommended for new design RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150801 / rf_dpx_dpx165850dt-8033b1_en.fm
DPX165850DT-8033B1 价格&库存
很抱歉,暂时无法提供与“DPX165850DT-8033B1”相匹配的价格&库存,您可以联系我们找货
DPX165850DT-8033B1
  • 1+11.129741+1.44169
  • 10+9.5478610+1.23679
  • 25+9.0093225+1.16703
  • 100+8.26399100+1.07048
  • 250+7.81487250+1.01230
  • 500+7.49796500+0.97125
  • 1000+7.198721000+0.93249
库存:3123
DPX165850DT-8033B1
  • 5+0.91692
  • 50+0.73343
  • 150+0.64174
  • 500+0.57294
  • 2500+0.51797
  • 4000+0.49043
