DPX165850DT-8085D3
DPX165850DT-8085D3
    TDK(东电化)
    射频双工器 双工器 698MHz ~ 2.69GHz / 5.15GHz ~ 5.85GHz 0603(1608 公制),6 PC 板
DPX165850DT-8085D3 数据手册
May. 2021 Ver.3.0 TDK Corporation   Multilayer Diplexer For 2.4GHz W-LAN & Bluetooth / 5GHz W-LAN DPX Series P/N: 1.6x0.8mm [EIA 0603] TYPE DPX165850DT-8085D3 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.3.0 TDK Corporation   DPX165850DT-8085D3 ■ SHAPES AND DIMENSIONS [Top View] [Bottom View] (6) (5) (4) (4) (5) (6) (1) (2) (3) (3) (2) (1) Dimensions (mm) L W T 1.60 0.80 +/-0.10 +/-0.10 0.60 Max a b c d e f 0.30 0.20 0.25 0.20 0.15 0.05 +/-0.05 +/-0.05 +/-0.05 +/-0.05 +/-0.05 +/-0.05 Terminal functions GND (1) Common Port (2) GND (3) (4) (5) (6) High-Band Port GND Low-Band Port ■ TERMINATION FINISH Material Au plate All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.3.0 TDK Corporation   DPX165850DT-8085D3 ■ ELECTRICAL CHARACTERISTICS ( Measurement ) Low-Band Parameter Insertion Loss (dB) Insertion Loss (dB) ( –40 to +85 °C ) VSWR VSWR ( –40 to +85 °C ) Attenuation (dB) Attenuation (dB) ( –40 to +85 °C ) Frequency (MHz) 698 1427 2400 2500 698 1427 2400 2500 698 698 4800 5000 7200 7500 4800 5000 7200 7500 to to to to to to to to to to to to to to to to to to 960 2400 2500 2690 960 2400 2500 2690 2690 2690 5000 5950 7500 8070 5000 5950 7500 8070 Characteristic Impedance (ohm) TDK Spec Min. Typ. Max. 0.14 0.35 0.31 0.45 0.35 0.60 0.45 0.60 0.17 0.43 0.34 0.53 0.38 0.68 0.48 0.68 1.1 1.8 1.1 2.0 35 39.0 35 41.0 20 25.0 19 23.0 34 39.0 34 41.0 19 25.0 18 23.0 50 (Nominal) Ta = +25+/-5°C High-Band Parameter Frequency (MHz) Insertion Loss (dB) 5150 Insertion Loss (dB) ( –40 to +85 °C ) VSWR VSWR ( –40 to +85 °C ) Attenuation (dB) 5150 Attenuation (dB) ( –40 to +85 °C ) Characteristic Impedance (ohm) 5150 5150 696 1805 1950 2400 2500 10300 15450 696 1805 1950 2400 2500 10300 15450 to to to to to to to to to to to to to to to to to to to to 5850 5850 5850 5850 1805 1950 2400 2500 2690 11700 17550 1805 1950 2400 2500 2690 11700 17550 TDK Spec Min. Typ. Max. 0.39 0.70 0.43 0.78 1.2 1.8 1.2 2.0 32 36.0 32 36.0 34 37.0 40 43.0 32 35.0 25 31.0 17 21.0 31 36.0 31 36.0 31 37.0 39 42.0 31 34.0 23 30.0 15 20.0 50 (Nominal) Ta = +25+/-5°C All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.3.0 TDK Corporation   DPX165850DT-8085D3 ■ ELECTRICAL CHARACTERISTICS ( Measurement ) Common Parameter Isolation (dB) Isolation (dB) ( –40 to +85 °C ) VSWR VSWR ( –40 to +85 °C ) Frequency (MHz) 698 1805 1950 2400 2500 3400 3600 5150 698 1805 1950 2400 2500 3400 3600 5150 698 5150 698 5150 Characteristic Impedance (ohm) Ta = +25+/-5°C to to to to to to to to to to to to to to to to to to to to 1805 1950 2400 2500 2690 3600 3800 5950 1805 1950 2400 2500 2690 3600 3800 5950 2690 5850 2690 5850 TDK Spec Min. Typ. Max. 32 35 32 35 34 36 40 47 32 35 15 19 15 19 35 41 31 35 31 35 31 36 39 45 31 34 14 19 14 19 34 41 1.2 1.8 1.1 1.8 1.2 2 1.1 2 50 (Nominal) ■ MAXIMUM RATINGS Parameter Operating temperature (°C) Storage temperature (°C) Power Handling (W) *1 Common Port Low-Band High-Band Human Body Model : HBM Machine Model : MM Charged Device Model : CDM TDK Spec Conditions –40 to +85 °C –40 to +85 °C Frequency (MHz) CW Duty 100% 1 698 to 2690 CW Duty 100% 1 5150 to 5850 CW Duty 100% 1 698 to 2690 CW Duty 100% 1 5150 to 5850 @Each Port (V) +/-1000 100pF / 1500ohm +/-150 200pF / 0ohm @Each Port (V) +/-500 Humidity : 60%RH max @Each Port (V) *1 : Refer to 3GPP TS 38.101-1 V15.2.0 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.3.0 TDK Corporation   DPX165850DT-8085D3 ■ FREQUENCY CHARACTERISTICS Insertion Loss (Low-Band) Insertion Loss (High-Band) Attenuation (Low-Band) Attenuation (High-Band) Isolation All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.3.0 TDK Corporation   DPX165850DT-8085D3 ■ FREQUENCY CHARACTERISTICS VSWR (Common Port) Smith Chart (Common Port) VSWR (Low-Band Port) All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.3.0 TDK Corporation   DPX165850DT-8085D3 ■ RECOMMENDED LAND PATTERN unit : mm ■ EVALUATION BOARD Material & Layer Copper Surface Pattern FR-4 Inner GND FR-4 Copper Bottom GND Thickness 0.035 mm 0.10 mm 0.018 mm 0.30 mm 0.035 mm unit : mm * Line width should be designed to match 50 ohm characteristic impedance depending on PCB material and thickness. ** The position of the throuh hole which have possibility of influence to the prerformance are indicated by dimension line. ■ ENVIRONMENT INFORMATION RoHS Statement RoHS Compliance All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies TDK Corporation ■ RECOMMENDED REFLOW PROFILE 3oC/sec or lower Preheating Temp. T1 T2 Time t1 150°C 200°C 60 to 120sec 6oC/sec or lower Soldering Critical zone (T3 to T4) Peak Temp. Time Temp. Time T3 t2 T4 t3 * 217°C 60 to 120sec 240 to 260°C 30 sec Max * t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. Note: Lead free solder is recommended. Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry) All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.3.0 TDK Corporation   DPX165850DT-8085D3 ■ PACKAGING STYLE Reel Dimensions Carrier Tape Sprocket hole Loading Direction J E K C D A B B H t Dimensions (mm) A B C 1.0 1.8 8.0 +/-0.05 +/-0.05 +/-0.2 G F D 3.5 E 1.75 F 4.0 G 2.0 H 4.0 J 1.5 K 0.8 t 0.25 +/-0.05 +/-0.1 +/-0.1 +/-0.05 +/-0.1 +0.1/-0 MAX +/-0.05 STANDARD PACKAGE QUANTITY ( pieces/reel ) 4,000 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this specification sheet are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. Aerospace/Aviation equipment Transportation equipment (cars, electric trains, ships, etc.) Medical equipment Power-generation control equipment Atomic energy-related equipment Seabed equipment Transportation control equipment Public information-processing equipment Military equipment Electric heating apparatus, burning equipment Disaster prevention/crime prevention equipment Safety equipment Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/equipment or providing backup circuits, etc., to ensure higher safety. All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies
DPX165850DT-8085D3 价格&库存
很抱歉,暂时无法提供与“DPX165850DT-8085D3”相匹配的价格&库存,您可以联系我们找货
DPX165850DT-8085D3
    DPX165850DT-8085D3
    • 4000+1.486754000+0.19324
    • 8000+1.398538000+0.18177
    • 12000+1.3493912000+0.17538
    • 20000+1.2898820000+0.16765
    • 28000+1.2521128000+0.16274
    • 40000+1.2132640000+0.15769
    库存:2791
    DPX165850DT-8085D3
    • 1+3.201701+0.41613
    • 10+2.6051110+0.33859
    • 25+2.3995725+0.31187
    • 50+2.2548550+0.29307
    • 100+2.12048100+0.27560
    • 250+1.95513250+0.25411
    • 500+1.83891500+0.23901
    • 1000+1.729641000+0.22480
    库存:2791
