R F
C o m p o n e n t s
April 2019
Multilayer Diplexer
For 698-2690MHz / 3400-5850MHz
DPX165850DT-8086A1
1.6x0.8mm [EIA 0603]*
* Dimensions Code JIS[EIA]
RF Components
Multilayer Diplexer
Conformity to RoHS Directive
DPX165850DT-8086A1
SHAPES AND DIMENSIONS
1.60±0.10
[Top view]
0.65max.
(5)
(4)
(1)
(2)
(3)
0.80±0.10
(6)
0.22±0.05
[Bottom view]
0.22±0.05
(1)
(6)
(2)
(5)
(3)
(4)
0.225±0.05
Marking
0.35±0.05
Terminal functions
1 GND
2 Common Port
3 GND
4 High-Band Port
5 GND
6 Low-Band Port
Dimensions in mm
RECOMMENDED LAND PATTERN
EVALUATION BOARD
ø0.2
0.22
0.976
Thru Hole
Resist
Surface Pattern
0.61
0.22
0.225
0.35
Dimensions in mm
0.978
Dimensions in mm
Material, Layer
Top resist
Copper Surface Pattern
FR-4
Copper Inner GND
FR-4
Copper Bottom GND
Thickness
Resist
0.035mm
0.10mm
0.018mm
0.30mm
0.035mm
Line width should be designed to match 50Ω characteristic impedance,
depending on PCB material and thickness.
RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20190402 / rf_dpx_dpx165850dt-8086a1_en.fm
RF Components
DPX165850DT-8086A1
ELECTRICAL CHARACTERISTICS
LOW-BAND
Frequency Range
(MHz)
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Min.
Typ.
Max.
9.54
13
18.2
16.4
23.8
50 (Nominal)
0.80
0.91 (–40 to +85°C)
2.0
Min.
Typ.
Max.
9.54
9.54
14
18
0.77
0.45
19.4
21.2
16.6
23.4
50 (Nominal)
0.89
0.54
0.96 (–40 to +85°C)
0.64 (–40 to +85°C)
2.0
Frequency Range
(MHz)
Min.
Typ.
Max.
698 to 2690
3400 to 3800
5150 to 5850
698 to 2690
3400 to 3800
5150 to 5850
14
13
9.54
9.54
15.8
16.6
23.6
16.8
20.1
22.1
50 (Nominal)
698 to 2690
698 to 2690
698 to 2690
3400 to 3800
5150 to 5850
Power Handling (W)
Characteristic Impedance ()
・Ta: +25±5°C
HIGH-BAND
Frequency Range
(MHz)
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
3400 to 3800
5150 to 5850
3400 to 3800
5150 to 5850
3400 to 3800
5150 to 5850
698 to 2690
10300 to 11700
Power Handling (W)
・Ta: +25±5°C
COMMON
Item
Isolation (dB)
Return Loss (dB)
・Ta: +25±5°C
TEMPERATURE RANGE
Operating temperature
(°C)
–40 to +85
Storage temperature
(°C)
–40 to +85
RF Components
DPX165850DT-8086A1
FREQUENCY CHARACTERISTICS
HIGH-BAND
Insertion Loss
0.0
0.0
0.5
0.5
1.0
1.0
Insertion Loss(dB)
Insertion Loss(dB)
LOW-BAND
Insertion Loss
1.5
2.0
2.5
2.0
2.5
3.0
500
1000
1500
2000
Frequency (MHz)
2500
3000
3.0
2500
3500
3000
10
Return Loss(dB)
40
4500
5000
Frequency (MHz)
5500
6000
6500
7000
3500
4000
4500
5000
Frequency (MHz)
5500
6000
6500
7000
4000
6000
8000 10000 12000
Frequency (MHz)
14000
16000
18000
1000
1500
2000
Frequency (MHz)
2500
3000
50
2500
3500
3000
Attenuation
10
Attenuation(dB)
Attenuation
Attenuation(dB)
4000
40
50
500
40
50
3500
Return Loss
Return Loss
Return Loss(dB)
1.5
40
4000
6000
8000 10000 12000
Frequency (MHz)
14000
16000
18000
50
RF Components
DPX165850DT-8086A1
Isolation
10
Isolation(dB)
Return Loss(dB)
COMMON
Return Loss
30
40
50
30
40
4000
6000
8000 10000 12000
Frequency (MHz)
14000
16000
18000
50
4000
6000
8000 10000 12000
Frequency (MHz)
14000
16000
18000
RF Components
DPX165850DT-8086A1
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
150°C
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
t3
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
RF Components
REMINDERS FOR USING THESE PRODUCTS
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DPX165850DT-8086A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.999451+0.38962
- 10+2.4454610+0.31766
- 25+2.2526925+0.29262
- 50+2.1167050+0.27495
- 100+1.99053100+0.25856
- 250+1.83533250+0.23840
- 500+1.72621500+0.22423
- 1000+1.623661000+0.21091
- 国内价格 香港价格
- 4000+1.395644000+0.18129
- 8000+1.312858000+0.17054
- 12000+1.2667012000+0.16454
- 20000+1.2108420000+0.15729
- 28000+1.1753828000+0.15268
- 40000+1.1389240000+0.14794
- 国内价格
- 1+1.48500
- 1000+1.02850
- 2000+0.75570
- 国内价格
- 2+1.12234
- 20+0.89100
- 60+0.79186
- 200+0.66809
- 1000+0.61301
