R F
C o m p o n e n t s
July 2015
Multilayer Diplexer
For 2400-2500MHz / 5100-5900MHz
DPX165900DT-8025A1
1.6x0.8mm [EIA 0603]*
* Dimensions Code JIS[EIA]
RF Components
Multilayer Diplexer
Conformity to RoHS Directive
DPX165900DT-8025A1
SHAPES AND DIMENSIONS
[Top view]
1.60±0.15
0.60±0.10
(5)
(4)
(1)
(2)
(3)
Marking
0.80±0.15
(6)
[Bottom view]
0.55±0.10
0.30±0.10
0.15±0.10
Terminal functions
1 High-band
2 GND
3 Low-band
4 GND
5 Common
6 GND
0.25±0.10
0.10±0.10
Dimensions in mm
RECOMMENDED LAND PATTERN
0.30
0.60
0.30
0.25
Dimensions in mm
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20150701 / rf_dpx_dpx165900dt-8025a1_en.fm
RF Components
DPX165900DT-8025A1
ELECTRICAL CHARACTERISTICS
LOW-BAND
Frequency Range
(MHz)
Min.
Typ.
Max.
2400 to 2500
4800 to 5000
7200 to 7500
18
18
0.36
23.4
25.9
50 (Nominal)
0.60
Frequency Range
(MHz)
Min.
Typ.
Max.
5100 to 5900
1800 to 2500
3700 to 3900
9800 to 11900
0.83
30.8
29.5
26.2
50 (Nominal)
1.40
Item
Frequency Range
(MHz)
Min.
Typ.
Max.
Return Loss (dB)
2400 to 2500
5100 to 5900
9.54
8.09
22.1
11.6
50 (Nominal)
Item
Insertion Loss (dB)
Attenuation (dB)
Characteristic Impedance (:)
・Ta: +25±5°C
HIGH-BAND
Item
Insertion Loss (dB)
Attenuation (dB)
・Ta: +25±5°C
COMMON
・Ta: +25±5°C
TEMPERATURE RANGE
Operating temperature
(°C)
–40 to +85
Storage temperature
(°C)
–40 to +85
RF Components
DPX165900DT-8025A1
FREQUENCY CHARACTERISTICS
HIGH-BAND
Insertion Loss
0.0
0.0
0.5
0.5
1.0
1.0
Insertion Loss (dB)
Insertion Loss (dB)
LOW-BAND
Insertion Loss
1.5
2.0
2.5
2.0
2.5
3.0
2000
2500
3000
Frequency (MHz)
3500
3.0
4000
Return Loss
4000
4500
10
40
7000
7500
8000
5000
5500
6000
6500
Frequency (MHz)
7000
7500
8000
2500
3000
Frequency (MHz)
3500
50
4000
4000
4500
Attenuation
10
Attenuation (dB)
Attenuation
Attenuation (dB)
5500
6000
6500
Frequency (MHz)
40
50
2000
40
50
5000
Return Loss
Return Loss(dB)
Return Loss(dB)
1.5
40
2000
4000
6000
8000
10000
Frequency (MHz)
12000
14000
50
2000
4000
6000
8000
10000
Frequency (MHz)
12000
14000
RF Components
DPX165900DT-8025A1
Isolation
10
Isolation(dB)
Return Loss(dB)
COMMON
Return Loss
30
40
50
30
40
2000
4000
6000
8000
10000
Frequency (MHz)
12000
14000
50
2000
4000
6000
8000
10000
Frequency (MHz)
12000
14000
RF Components
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
150°C
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
t3
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
RF Components
REMINDERS FOR USING THESE PRODUCTS
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DPX165900DT-8025A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4000+3.580054000+0.46314
- 8000+3.441098000+0.44516
- 12000+3.3635312000+0.43513
- 20000+3.2696120000+0.42298
- 国内价格 香港价格
- 1+5.998901+0.77605
- 10+5.1812610+0.67028
- 25+4.8866525+0.63217
- 100+4.47281100+0.57863
- 250+4.22477250+0.54654
- 500+4.04943500+0.52386
- 1000+3.883751000+0.50243
- 国内价格 香港价格
- 4000+0.846504000+0.11000
- 国内价格
- 1+1.72323
- 10+1.54147
- 100+1.26355
- 1000+1.18644
- 2000+1.05488
- 4000+0.83177
- 国内价格
- 1+0.64900
- 200+0.41910
- 2000+0.36410
- 4000+0.32230
- 国内价格
- 5+0.77087
- 50+0.59133
- 800+0.40974
- 1600+0.37358
- 4000+0.34790
- 国内价格
- 1+1.11730
- 30+1.03760
- 100+0.95770
- 500+0.87800
- 1000+0.79810
