DPX165950DT-8018A1
DPX165950DT-8018A1
    TDK(东电化)
    适用于2400-2500MHZ/4900-5950MHZ的多层双工器
DPX165950DT-8018A1 数据手册
The products in this catalog are not recommended for new design R F C o m p o n e n t s July 2015 Multilayer Diplexer For 2400-2500MHz / 4900-5950MHz DPX165950DT-8018A1 1.6x0.8mm [EIA 0603]* * Dimensions Code JIS[EIA] The products in this catalog are not recommended for new design RF Components Multilayer Diplexer Conformity to RoHS Directive For 2400-2500MHz / 4900-5950MHz DPX165950DT-8018A1 SHAPES AND DIMENSIONS [Top view] 1.60±0.10 0.60max. (1) (3) (2) Marking 0.30+0.10 –0.15 0.30+0.10 –0.15 0.15±0.10 [Bottom view] 0.80+0.20 –0.10 (4) 0.65±0.15 0.15±0.10 Terminal functions 1 Low-band 2 Common 3 High-band 4 GND Dimensions in mm RECOMMENDED LAND PATTERN EVALUATION BOARD 0.30 1.10 0.60 0.50 Dimensions in mm 0.20 1.20 0.15 0.70 0.40 0.30 0.50 0.45 0.15 0.30 Land Dimensions in mm Solder resist Line width should be designed to match 50Ω characteristic impedance, depending on PCB material and thickness. RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx165950dt-8018a1_en.fm The products in this catalog are not recommended for new design RF Components DPX165950DT-8018A1 ELECTRICAL CHARACTERISTICS LOW-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Frequency Range (MHz) Min. Typ. Max. 2400 to 2500 2400 to 2500 4800 to 6000 7200 to 7500 — 9.54 20 20 0.57 13.8 24.4 26.4 50 (Nominal) 0.80 — — — Frequency Range (MHz) Min. Typ. Max. 4900 to 5950 4900 to 5950 1800 to 2500 9800 to 11900 — 9.54 20 20 0.67 12.4 26.3 32.1 50 (Nominal) 0.90 — — — Characteristic Impedance (:) ・Ta: +25±5°C HIGH-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Characteristic Impedance (:) ・Ta: +25±5°C TEMPERATURE RANGE Operating temperature (°C) –40 to +85 Storage temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx165950dt-8018a1_en.fm The products in this catalog are not recommended for new design RF Components DPX165950DT-8018A1 FREQUENCY CHARACTERISTICS HIGH-BAND Insertion Loss 0.0 0.0 0.5 0.5 1.0 1.0 Insertion Loss (dB) Insertion Loss (dB) LOW-BAND Insertion Loss 1.5 2.0 2.5 2.0 2.5 3.0 1000 1500 2000 2500 3000 Frequency (MHz) 3500 3.0 4000 4000 Return Loss 4500 0 0 10 10 20 30 50 1000 7000 7500 8000 5000 5500 6000 6500 Frequency (MHz) 7000 7500 8000 20 30 1500 2000 2500 Frequency (MHz) 3000 3500 50 4000 4000 4500 Attenuation 0 0 10 10 Attenuation (dB) Attenuation Attenuation (dB) 5500 6000 6500 Frequency (MHz) 40 40 20 30 20 30 40 40 50 5000 Return Loss Return Loss(dB) Return Loss(dB) 1.5 50 2000 4000 6000 8000 10000 Frequency (MHz) 12000 14000 2000 4000 6000 8000 10000 Frequency (MHz) 12000 14000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx165950dt-8018a1_en.fm The products in this catalog are not recommended for new design RF Components DPX165950DT-8018A1 FREQUENCY CHARACTERISTICS Isolation 0 0 10 10 20 20 Isolation (dB) Return Loss(dB) COMMON Return Loss 30 40 50 30 40 2000 4000 6000 8000 10000 Frequency (MHz) 12000 14000 50 2000 4000 6000 8000 10000 Frequency (MHz) 12000 14000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx165950dt-8018a1_en.fm The products in this catalog are not recommended for new design RF Components RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 150°C T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. Peak Temp. T4 240 to 260°C Time t3 30sec max. The products in this catalog are not recommended for new design RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx165950dt-8018a1_en.fm
DPX165950DT-8018A1 价格&库存
很抱歉,暂时无法提供与“DPX165950DT-8018A1”相匹配的价格&库存,您可以联系我们找货
DPX165950DT-8018A1
  • 1+5.990241+0.77721
  • 10+5.1737710+0.67128
  • 25+4.8795925+0.63311
  • 100+4.46635100+0.57949
  • 250+4.21866250+0.54736
  • 500+4.04358500+0.52464
  • 1000+3.878141000+0.50317
库存:3346
DPX165950DT-8018A1
  • 4000+3.574874000+0.46383
  • 8000+3.436128000+0.44582
  • 12000+3.3586712000+0.43578
  • 20000+3.2648820000+0.42361
库存:3346
