Oct. 2016 Ver.1.3a
TDK Corporation
Multilayer Diplexer
DPX Series
P/N:
1.6x0.8mm [EIA 0603] TYPE
DPX165950DT-8044A1
All specifications are subject to change without notice.
TDK Technology - Proprietary and Confidential Information of TDK Group Companies
Oct. 2016 Ver.1.3a
TDK Corporation
DPX165950DT-8044A1
■ SHAPES AND DIMENSIONS
[Top View]
[Bottom View]
(6)
(5)
(4)
(1)
(2)
(3)
Dimensions (mm)
L
W
T
A
B
C
D
E
1.60 0.80 0.60 0.30 0.10 0.15 0.25 0.55
+/-0.15 +/-0.15 +/-0.10 +/-0.15
Terminal functions
GND
(1)
Common Port
(2)
GND
(3)
+0.15
/-0.10
(4)
(5)
(6)
■ TEMPERATURE RANGE
Operating temperature Storage temperature
–40 to +85 °C
–40 to +85 °C
High-Band Port
GND
Low-Band Port
■ TERMINATION FINISH
Material
Sn plate
Oct. 2016 Ver.1.3a
TDK Corporation
DPX165950DT-8044A1
■ ELECTRICAL CHARACTERISTICS
( Measurement )
Low-Band
Parameter
Insertion Loss (dB)
Insertion Loss (dB)
( –40 to +85 °C )
VSWR
Attenuation (dB)
Frequency (MHz)
704
1572
1570
704
1572
1570
704
1572
1570
2400
2500
4900
5150
5850
to
to
to
to
to
to
to
to
to
to
to
to
to
to
960
1578
1610
960
1578
1610
960
1578
1610
2500
2690
5150
5850
5950
TDK Spec
Min. Typ. Max.
0.29 0.40
0.35 0.40
0.37 0.45
0.60
0.60
0.65
1.11 1.92
1.19 1.92
1.20 1.92
15
19
10
14
17
29
17
21
16
Ta = +25+/-5°C
High-Band
Parameter
Insertion Loss (dB)
Insertion Loss (dB)
( –40 to +85 °C )
VSWR
Attenuation (dB)
Frequency (MHz)
2400
2500
4900
5150
5850
2400
2500
4900
5150
5850
2400
2500
4900
5150
5850
704
1572
1570
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
2500
2690
5150
5850
5950
2500
2690
5150
5850
5950
2500
2690
5150
5850
5950
960
1578
1610
TDK Spec
Min. Typ. Max.
0.39 0.55
0.48 0.55
0.24 0.50
0.23 0.50
0.25 0.50
0.75
0.75
0.70
0.70
0.70
1.12 1.92
1.26 1.92
1.47 1.92
1.37 1.92
1.19 1.92
12
14
Ta = +25+/-5°C
Common
Parameter
Power Handling (W) 50% Duty
TDK Spec
Min. Typ. Max.
4
Oct. 2016 Ver.1.3a
TDK Corporation
DPX165950DT-8044A1
■ FREQUENCY CHARACTERISTICS
High-Band Port Insertion Loss
Insertion Loss[dB]
704 MHz
960 MHz
0.5
0.21
0.29
dB
dB
1
1.5
2
2.5
Insertion Loss[dB]
Low-Band Port Insertion Loss
0.5
1
700
800
900
1000
1100
1200
1300
2200
2300
2400
2500
2600
2700
0.24
0.21
0.23
0.25
dB
dB
dB
dB
704
960
1572
1578
1570
1610
MHz
MHz
MHz
MHz
MHz
MHz
15.9
14.4
23.1
23.3
22.9
24.5
dB
dB
dB
dB
dB
dB
2800
Frequency[MHz]
1578
1570
1610
0.5
1
1.5
MHz
MHz
MHz
MHz
0.35
0.35
0.35
0.37
dB
dB
dB
dB
2
2.5
Insertion Loss[dB]
Insertion Loss[dB]
MHz
MHz
MHz
MHz
2
2.5
2100
1400
1
1.5
2
2.5
3
3
1500
1600
1700
1800
1900
2000
2100
4600
2200
4800
5000
5200
10
15
30
35
40
45
50
2400
2500
2690
4900
5150
5850
5950
1000
2000
3000
5600
5800
6000
High-Band Port Attenuation
4000
5000
6000
7000
MHz
MHz
MHz
MHz
MHz
MHz
MHz
22.4
19.0
13.5
28.9
39.8
21.4
20.1
dB
dB
dB
dB
dB
dB
dB
Attenuation[dB]
Low-Band Port Attenuation
Frequency[MHz]
Frequency[MHz]
Attenuation[dB]
4900
5150
5850
5950
1.5
Frequency[MHz]
10
15
30
35
40
45
50
1000
2000
3000
4000
5000
6000
7000
8000
Frequency[MHz]
Frequency[MHz]
Low-Band Port VSWR
High-Band Port VSWR
Frequency[MHz]
704
960
1572
1578
1570
1610
2.5
2
MHz
MHz
MHz
MHz
MHz
MHz
Frequency[MHz]
3
1.05
1.08
1.19
1.19
1.19
1.20
2400
2500
2690
4900
5150
5850
5950
2.5
VSWR
3
VSWR
0.39 dB
0.37 dB
0.48 dB
3
3
1.5
2
MHz
MHz
MHz
MHz
MHz
MHz
MHz
1.02
1.10
1.26
1.46
1.38
1.19
1.18
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
16.0
14.4
25.8
26.4
25.3
33.6
41.7
21.6
14.5
28.1
34.7
21.3
20.2
1.5
1
1
2000
3000
1000
Common Port VSWR
2.5
2
1.5
1
1000
2000
3000
4000
5000
6000
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
1.07
1.11
1.19
1.19
1.19
1.19
1.07
1.12
1.23
1.47
1.37
1.12
1.09
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
Isolation[dB]
704
960
1572
1578
1570
1610
2400
2500
2690
4900
5150
5850
5950
3000
4000
5000
6000
Isolation (Low - High)
Frequency[MHz]
3
VSWR
2400 MHz
2500 MHz
2690 MHz
10
15
30
35
40
45
50
704
960
1572
1578
1570
1610
2400
2500
2690
4900
5150
5850
5950
2000
3000
4000
5000
6000
7000
8000
Frequency[MHz]
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
Oct. 2016 Ver.1.3a
TDK Corporation
DPX165950DT-8044A1
■ RECOMMENDED LAND PATTERN
■ ENVIRONMENT INFORMATION
RoHS Statement
RoHS Compliance
Oct. 2016 Ver.1.3a
TDK Corporation
DPX165950DT-8044A1
■ RECOMMENDED REFLOW PROFILE
Pb free solder
Soaking
Temp.
Time
t1
T1
T2
150°C 180°C 60 to 120sec
Temp.
T3
230°C
Working
Time
t2
more than 30sec
Soldering
Temp.
Time
T4
t3
Peak
Temp.
T5
247 to 253°C within 10sec 260°C Max.
Oct. 2016 Ver.1.3a
TDK Corporation
DPX165950DT-8044A1
■ PACKAGING STYLE
Reel Dimensions
13.0+/-1.0
13+/-0.2
Label
2.0+/-0.5
60+1.0/-0
Label
21+/-0.8
180 +0/-1.5
Unit : mm
9.0 +1.0/-0
Carrier Tape
Sprocket hole
Loading
J
E
K
B
H
Dimensions (mm)
A
B
C
0.97 1.8 8.0
+/-0.05
+/-0.05
+/-0.2
G
F
Unit : mm
D
3.5
E
1.75
F
4.0
G
2.0
H
4.0
J
1.5
K
0.8
+/-0.05
+/-0.1
+/-0.1
+/-0.05
+/-0.1
+0.1/-0
MAX
STANDARD PACKAGE QUANTITY
( pieces/reel )
4,000
C
D
A
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this specification sheet are intended for use in general electronic equipment
(AV equipment, telecommunications equipment, home appliances, amusement equipment,
computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed
below, whose performance and/or quality require a more stringent level of safety or reliability,
or whose failure, malfunction or trouble could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the
products in any of the applications below or for any other use exceeding the range or
conditions set forth in this specification sheet.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
Aerospace/Aviation equipment
Transportation equipment (cars, electric trains, ships, etc.)
Medical equipment
Power-generation control equipment
Atomic energy-related equipment
Seabed equipment
Transportation control equipment
Public information-processing equipment
Military equipment
Electric heating apparatus, burning equipment
Disaster prevention/crime prevention equipment
Safety equipment
Other applications that are not considered general-purpose applications
When using this product in general-purpose applications, you are kindly requested to take into
consideration securing protection circuit/equipment or providing backup circuits, etc.,
to ensure higher safety.
很抱歉,暂时无法提供与“DPX165950DT-8044A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4000+1.345844000+0.17500
- 8000+1.265998000+0.16462
- 12000+1.2214912000+0.15883
- 20000+1.1676320000+0.15183
- 28000+1.1334528000+0.14738
- 40000+1.0982940000+0.14281
- 国内价格 香港价格
- 1+2.912251+0.37868
- 10+2.3596710+0.30683
- 25+2.1732025+0.28258
- 50+2.0415650+0.26546
- 100+1.91931100+0.24957
- 250+1.76967250+0.23011
- 500+1.66457500+0.21644
- 1000+1.565701000+0.20359
