DPX165950DT-8045A1
DPX165950DT-8045A1
    TDK(东电化)
    DPX165950DT-8045A1
DPX165950DT-8045A1 数据手册
Jul. 2016 Ver.3.0N TDK Corporation Multilayer Diplexer For 2.4GHz W-LAN & Bluetooth / 5GHz W-LAN DPX Series P/N: 1.6x0.8mm [EIA 0603] TYPE DPX165950DT-8045A1 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies Jul. 2016 Ver.3.0N TDK Corporation DPX165950DT-8045A1 ■ SHAPES AND DIMENSIONS Dimensions (mm) L W T a b c d e 1.60 0.80 0.60 0.10 0.30 0.25 0.55 0.15 +/-0.15 +/-0.15 Max +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10 Terminal functions GND (1) Common Port (2) GND (3) (4) (5) (6) ■ TEMPERATURE RANGE Operating temperature Storage temperature –40 to +90 °C –40 to +90 °C High-Band Port GND Low-Band Port ■ TERMINATION FINISH Material Sn plate All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies Jul. 2016 Ver.3.0N TDK Corporation DPX165950DT-8045A1 ■ ELECTRICAL CHARACTERISTICS ( Measurement ) Low-Band Parameter Insertion Loss (dB) VSWR Attenuation (dB) Isolation (dB) Ta = +25+/-5°C Frequency (MHz) 2400 2400 4800 7200 4900 to to to to to 2500 2500 5000 7500 5950 TDK Spec Min. Typ. Max. 0.35 0.55 1.20 2.0 30 37 30 33 28 30 - High-Band Parameter Insertion Loss (dB) VSWR Attenuation (dB) Isolation (dB) Ta = +25+/-5°C Frequency (MHz) 4900 4900 30 9800 14700 30 to 5950 to 5950 to 2700 to 11900 to 17850 to 2700 TDK Spec Min. Typ. Max. 0.60 0.80 1.52 2.0 32 36 15 19 11 15 32 36 - Common Parameter VSWR TDK Spec Min. Typ. Max. 2500 1.27 2.0 5950 1.43 2.0 Frequency (MHz) 2400 to 4900 to Ta = +25+/-5°C All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies Jul. 2016 Ver.3.0N TDK Corporation DPX165950DT-8045A1 ■ FREQUENCY CHARACTERISTICS Insertion Loss (Low-Band) Insertion Loss (High-Band) Return Loss (Low-Band) Return Loss (high-Band) Attenuation (Low-Band) Attenuation (High-Band) Isolation Common port Return Loss All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies Jul. 2016 Ver.3.0N TDK Corporation DPX165950DT-8045A1 ■ RECOMMENDED LAND PATTERN ■ ENVIRONMENT INFORMATION RoHS Statement RoHS Compliance All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies Jul. 2016 Ver.3.0N TDK Corporation DPX165950DT-8045A1 ■ RECOMMENDED REFLOW PROFILE Pb free solder Soaking Temp. Time t1 T1 T2 150°C 180°C 60 to 120sec Working Temp. Time T3 t2 230°C more than 30sec Soldering Temp. Time T4 t3 Peak Temp. T5 247 to 253°C within 10sec 260°C Max. All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this specification sheet are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. Aerospace/Aviation equipment Transportation equipment (cars, electric trains, ships, etc.) Medical equipment Power-generation control equipment Atomic energy-related equipment Seabed equipment Transportation control equipment Public information-processing equipment Military equipment Electric heating apparatus, burning equipment Disaster prevention/crime prevention equipment Safety equipment Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/equipment or providing backup circuits, etc., to ensure higher safety. All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies
DPX165950DT-8045A1 价格&库存
很抱歉,暂时无法提供与“DPX165950DT-8045A1”相匹配的价格&库存,您可以联系我们找货
DPX165950DT-8045A1
  • 4000+1.648864000+0.21394
  • 8000+1.582648000+0.20535
  • 12000+1.5456912000+0.20056
  • 20000+1.5008920000+0.19474
  • 28000+1.4724228000+0.19105
  • 40000+1.4431440000+0.18725
库存:3957
DPX165950DT-8045A1
  • 1+2.824001+0.36641
  • 10+2.4062610+0.31221
  • 25+2.2702825+0.29457
  • 100+2.07356100+0.26905
  • 250+1.95566250+0.25375
  • 500+1.87213500+0.24291
  • 1000+1.793351000+0.23269
库存:3957
