DPX165950DT-8060C1
DPX165950DT-8060C1
    TDK(东电化)
    SMD-6P,0.8x1.6mm
    多层双工器,适用于2400 - 2496MHZ/5150 - 5950MHZ
DPX165950DT-8060C1 数据手册
R F C o m p o n e n t s April 2017 Multilayer Diplexer For 2400-2496MHz / 5150-5950MHz DPX165950DT-8060C1 1.6x0.8mm [EIA 0603]* * Dimensions Code JIS[EIA] RF Components Multilayer Diplexer Conformity to RoHS Directive For 2400-2496MHz / 5150-5950MHz DPX165950DT-8060C1 SHAPES AND DIMENSIONS [Top view] 1.60±0.15 0.57max. (5) (4) (1) (2) (3) Marking 0.80±0.15 (6) [Bottom view] 0.55±0.10 0.30±0.10 0.25±0.10 Terminal functions 1 GND 2 Common 3 GND 4 High-band 5 GND 6 Low-band 0.25±0.10 0.10±0.10 Dimensions in mm RECOMMENDED LAND PATTERN 0.30 0.30 0.30 0.25 Dimensions in mm RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20170412 / rf_dpx_dpx165950dt-8060c1_en.fm RF Components DPX165950DT-8060C1 ELECTRICAL CHARACTERISTICS LOW-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Frequency Range (MHz) Min. Typ. Max. 2400 to 2496 2400 to 2496 4800 to 5000 7200 to 7500 — 10 32 15 0.50 16 43 24 50 (Nominal) 0.65 — — — Frequency Range (MHz) Min. Typ. Max. 5150 to 5950 5150 to 5950 70 to 2000 2400 to 2690 7200 to 7800 10300 to 11700 15000 to 18000 — 10 35 35 18 26 10 1.04 17 45 39 24 32 29 50 (Nominal) 1.35 — — — — — — Characteristic Impedance () ・Ta: +25±5°C HIGH-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Characteristic Impedance () ・Ta: +25±5°C TEMPERATURE RANGE Operating temperature (°C) –40 to +85 Storage temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20170412 / rf_dpx_dpx165950dt-8060c1_en.fm RF Components DPX165950DT-8060C1 FREQUENCY CHARACTERISTICS HIGH-BAND Insertion Loss 0.0 0.0 0.5 0.5 1.0 1.0 Insertion Loss(dB) Insertion Loss(dB) LOW-BAND Insertion Loss 1.5 2.0 3.0 500 1000 1500 2000 2500 Frequency (MHz) 3000 3500 3.0 3500 4000 4000 4500 5000 5500 6000 Frequency (MHz) 6500 7000 7500 4500 5000 5500 6000 Frequency (MHz) 6500 7000 7500 Return Loss Return Loss 0 0 10 10 Return Loss(dB) Return Loss(dB) 2.0 2.5 2.5 20 30 40 20 30 40 50 500 1000 1500 2000 2500 Frequency (MHz) 3000 3500 50 3500 4000 4000 Attenuation Attenuation 0 0 10 10 Attenuation (dB) Attenuation (dB) 1.5 20 30 20 30 40 40 50 50 0 2000 4000 6000 8000 10000 12000 Frequency (MHz) 14000 16000 18000 0 2000 4000 6000 8000 10000 12000 Frequency (MHz) 14000 16000 18000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20170412 / rf_dpx_dpx165950dt-8060c1_en.fm RF Components DPX165950DT-8060C1 FREQUENCY CHARACTERISTICS Isolation 0 0 10 10 20 20 Isolation(dB) Return Loss(dB) COMMON Return Loss 30 30 40 40 50 50 0 2000 4000 6000 8000 10000 12000 Frequency (MHz) 14000 16000 18000 0 2000 4000 6000 8000 10000 12000 Frequency (MHz) 14000 16000 18000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20170412 / rf_dpx_dpx165950dt-8060c1_en.fm RF Components DPX165950DT-8060C1 RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 150°C T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec Peak Temp. T4 240 to 260°C Time t3 30sec max. t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20170412 / rf_dpx_dpx165950dt-8060c1_en.fm RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20170412 / rf_dpx_dpx165950dt-8060c1_en.fm
DPX165950DT-8060C1 价格&库存
很抱歉,暂时无法提供与“DPX165950DT-8060C1”相匹配的价格&库存,您可以联系我们找货
DPX165950DT-8060C1
  • 1+2.828671+0.36641
  • 10+2.4102410+0.31221
  • 25+2.2740425+0.29457
  • 100+2.07699100+0.26905
  • 250+1.95889250+0.25375
  • 500+1.87523500+0.24291
  • 1000+1.796311000+0.23269
库存:521
DPX165950DT-8060C1
  • 1+2.802901+0.36330
  • 10+2.3956010+0.31060
  • 25+2.2638025+0.29350
  • 100+2.07220100+0.26860
  • 250+1.95240250+0.25310
  • 500+1.84460500+0.23910
  • 1000+1.653001000+0.21430
  • 4000+1.569104000+0.20340
  • 8000+1.533208000+0.19880
库存:288
DPX165950DT-8060C1
  • 1+0.66990
  • 200+0.46200
  • 2000+0.42020
  • 4000+0.39270
库存:2385
