DPX165950DT-8126A1
DPX165950DT-8126A1
    TDK(东电化)
    2400-2496MHz/4900-5950MHz多层双工器
DPX165950DT-8126A1 数据手册
R F C o m p o n e n t s July 2015 Multilayer Diplexer For 2400-2496MHz / 4900-5950MHz DPX165950DT-8126A1 1.6x0.8mm [EIA 0603]* * Dimensions Code JIS[EIA] RF Components Multilayer Diplexer Conformity to RoHS Directive For 2400-2496MHz / 4900-5950MHz DPX165950DT-8126A1 SHAPES AND DIMENSIONS [Top view] 1.60±0.15 0.60±0.10 (5) (4) (1) (2) (3) Marking 0.80±0.15 (6) 0.55±0.10 0.30±0.10 Terminal functions 1 GND 2 Common 3 GND 4 Low-band 5 GND 6 High-band 0.15±0.10 [Bottom view] 0.25±0.10 0.10±0.10 Dimensions in mm RECOMMENDED LAND PATTERN EVALUATION BOARD 0.30 0.25 0.55 0.70 0.30 0.60 0.30 Dimensions in mm 0.55 0.70 Line width should be designed to match 50Ω characteristic impedance, depending on PCB material and thickness. Dimensions in mm RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx165950dt-8126a1_zh.fm RF Components DPX165950DT-8126A1 ELECTRICAL CHARACTERISTICS LOW-BAND Item Insertion Loss (dB) Return Loss (dB) Power Handling (W) Characteristic Impedance (:) Frequency Range (MHz) Min. Typ. Max. 2400 to 2496 2400 to 2500 2400 to 2496 — 9.54 — 0.39 21.7 — 50 (Nominal) 0.60 — 3 Frequency Range (MHz) Min. Typ. Max. 4900 to 5950 4900 to 5950 30 to 2700 9800 to 11900 14700 to 17850 4900 to 5950 — 9.54 28 10 5 — 0.78 16.5 34.9 21.6 14.4 — 50 (Nominal) 1.40 — — — — 2 Frequency Range (MHz) Min. Typ. Max. 30 to 2700 4900 to 5950 2400 to 2500 4900 to 5950 28 26 9.54 9.54 34.2 32.9 21.7 20.4 50 (Nominal) — — — — ・Ta: +25±5°C HIGH-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Power Handling (W) Characteristic Impedance (:) ・Ta: +25±5°C COMMON Item Isolation (dB) Return Loss (dB) Characteristic Impedance (:) ・Ta: +25±5°C TEMPERATURE RANGE Operating temperature ˄°C˅ –40 to +85 Storage temperature ˄°C˅ –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx165950dt-8126a1_zh.fm RF Components DPX165950DT-8126A1 FREQUENCY CHARACTERISTICS HIGH-BAND Insertion Loss 0.0 0.0 0.5 0.5 1.0 1.0 Insertion Loss(dB) Insertion Loss(dB) LOW-BAND Insertion Loss 1.5 2.0 3.0 1500 2000 2500 Frequency (MHz) 3000 3.0 3500 3500 Return Loss 0 0 10 10 20 30 40 4500 5000 5500 6000 Frequency (MHz) 6500 7000 7500 4500 5000 5500 6000 Frequency (MHz) 6500 7000 7500 16000 18000 20 30 40 50 1500 2000 2500 Frequency (MHz) 3000 50 3500 3500 Attenuation 4000 Attenuation 0 10 10 Attenuation (dB) 0 20 30 40 50 4000 Return Loss Return Loss(dB) Return Loss(dB) 2.0 2.5 2.5 Attenuation (dB) 1.5 20 30 40 0 2000 4000 6000 8000 10000 Frequency (MHz) 12000 14000 50 0 2000 4000 6000 8000 10000 12000 Frequency (MHz) 14000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx165950dt-8126a1_zh.fm RF Components DPX165950DT-8126A1 FREQUENCY CHARACTERISTICS Isolation 0 0 10 10 20 20 Isolation(dB) Return Loss(dB) COMMON Return Loss 30 40 50 30 40 0 2000 4000 6000 8000 10000 Frequency (MHz) 12000 14000 50 0 2000 4000 6000 8000 10000 Frequency (MHz) 12000 14000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx165950dt-8126a1_zh.fm RF Components DPX165950DT-8126A1 RECOMMENDED REFLOW PROFILE Soaking Working Soldering Peak T: Temperature T4 T5 T3 T2 T4 T3 t3 T1 t1 t2 t: Time Soaking Temp. T1 150°C T2 180°C Time t1 60 to 120s Working Temp. T3 230°C Time t2 more than 30s Soldering Peak Temp. T4 247 to 253°C Time t3 within 10s Temp. T5 260°C max. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx165950dt-8126a1_zh.fm RF Components ໪ቂ᎙ሃ໳ჵ ኷໪ቂׁٛ൰෇ˈขႚ‫ࢆࣙࢭتࡒཱུכ‬༚ȃ ՗ภ᎙ሃ໳ჵ ໪ቂׁٛ൰໢ˈข᎙ሃ՗ภ໳ჵȃ ᎙ ሃ ׁٛ൰಼௽፩৔ኵܿٛ൰໸ፑ኷࿳ቂ‫׭‬Ꮃቂဉሃሆຢ໪ቂ቙ᇜֈ‫ݢ‬Ꮚົֻ ˄AV ົֻˈ࿳ᄪົֻˈয়‫ݢ‬ٛ൰ˈቨ୛ົֻˈ৓ི঩ົֻˈࢋ เົֻˈ֑࢞ົֻˈ৓‫ࢗˈֻົك‬ᇖ঩ධเ˅ˈ‫؃‬෩ࡘᇜֈ‫ݢ‬Ꮚົֻᇋ኷࿳٢ܿ‫غ‬Ꮾञ໪ቂߴߟ჉໪ቂȃ ޭ቙ᅍᇋࡴ‫ޡ‬՗ภᄹञ૰૦ᄹܿˈডጚົֻܿࢽጊˈႜ‫ވ‬ᏮˈከᎡ‫؜‬ட૰೙ঐࢍเܿໍಛˈເ࿒ঽ‫ا‬ٛ݃ዉ‫ڈ‬ཿࣷˈᇵঽ቏૰೙ٛໍಧ‫ܐ‬ ຺ঐሯჳܿᇵ჉ቂဉ ˄ᇵ჉‫ ‘ څ‬࿅‫ށ‬ቂဉ ’˅፩ܿ໻ቂᄹˈᄹ೙ߙংˈ൰፣ˈׁ࢞ཌྷ‫؜‬ቧ֦ጽȃ ٛ൰‫־‬኷ׁٛ൰಼௽ܿ߭ၐȂ࿢਋ፇိˈডጚ኷࿅‫ށ‬ቂဉ፩໪ቂ໢ˈׁ࢞ཌྷޭྋዉ‫ܿڈ‬ཿࣷञᄪ଺ᄹ‫ܞڏ؜‬ใटውใȃ (1) ऎ࿙ऎૼົֻ (2) ਦ࿳ከ༕ົֻ ˄ප‫ވݢˈٴ‬ট‫˅݃ؑۉˈٴ‬ (3) ᇞனົֻ (4) ߙ‫૿ݢ‬፟ົֻ (5) ኊᏊ೙ኑყ࣋ົֻ (6) ࣴ‫ֻົݒ‬ (7) ਦ࿳૿፟ົֻ (8) ࢞ࢥᄪႩ‫ֻົ୲ۃ‬ (9) ૅ໳ົֻ (10) ‫ݢ‬ৠ฽ົֻȂัຨົֻ (11) ߷ኳ / ኁ߷߯Ꮶົֻ (12) ՗ภົֻ (13) ඝྊ‫־؜‬༄ၓ٢ࣙቂဉܿቂဉ ၓம೙ࢮ࢑՗ภ‫ݓ‬໪ቂٛ൰ˈޭ໪ቂׁٛ൰಼௽፩ྈ৔ኵٛ൰ܿົֻ੣ᄵົ৓໢ˈขฬ֦࠲ठࡘົֻܿ໪ቂቂဉঽᎫྙ֦ܿ॓ই௸ञᎧ ፜ˈ‫ົ؃‬፜ֻቂই௸݃ȃ • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx165950dt-8126a1_zh.fm
DPX165950DT-8126A1 价格&库存
很抱歉,暂时无法提供与“DPX165950DT-8126A1”相匹配的价格&库存,您可以联系我们找货
DPX165950DT-8126A1
    • 1+0.76212
    • 10+0.72398
    • 100+0.69247
    • 200+0.58724
    • 4000+0.47555
    库存:3200
    DPX165950DT-8126A1
    • 1+0.63838
    • 10+0.45648
    • 30+0.35214
    DPX165950DT-8126A1
      • 1+0.65780
      • 200+0.45320
      • 2000+0.41140
      • 4000+0.38500
