DPX202690DT-4060A1
DPX202690DT-4060A1
    TDK(东电化)
    多层双工器,适用于699 - 960MHZ/1427 - 2690MHZ
DPX202690DT-4060A1 数据手册
R F C o m p o n e n t s July 2018 Multilayer Diplexer For 699-960MHz / 1427-2690MHz DPX202690DT-4060A1 2.0x1.25mm [EIA 0805]* * Dimensions Code JIS[EIA] RF Components Multilayer Diplexer Conformity to RoHS Directive For 699-960MHz / 1427-2690MHz DPX202690DT-4060A1 SHAPES AND DIMENSIONS 2.00±0.15 [Top view] 0.90±0.10 (5) (4) (1) (2) (3) Marking 1.25±0.15 (6) 0.65±0.15 0.30±0.15 Terminal functions 1 GND 2 Common 3 GND 4 High-band 5 GND 6 Low-band 0.20±0.15 [Bottom view] 0.20±0.15 0.35±0.15 Dimensions in mm 0.89 0.77 RECOMMENDED LAND PATTERN 0.33 0.32 Dimensions in mm RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20180712 / rf_dpx_dpx202690dt-4060a1_en.fm RF Components DPX202690DT-4060A1 ELECTRICAL CHARACTERISTICS LOW-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Characteristic Impedance () Frequency Range (MHz) Min. Typ. Max. 699 to 960 699 to 960 1427 to 2690 — 10 25 0.59 22 27 50 (Nominal) 0.70 — — Frequency Range (MHz) Min. Typ. Max. 1427 to 2690 1427 to 2690 699 to 915 915 to 960 3420 to 3820 — 10 20 17 3 0.63 13 24 20 7 50 (Nominal) 0.75 — — — — Frequency Range (MHz) Min. Typ. Max. 20 17 25 10 10 — 26 21 27 22 14 — 50 (Nominal) — — — — — 3 ・Ta: +25±5°C HIGH-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Characteristic Impedance () ・Ta: +25±5°C COMMON Item Isolation (dB) Return Loss (dB) 699 to 915 915 to 960 1427 to 2690 699 to 960 1427 to 2690 Power Handling (W) Characteristic Impedance () ・Ta: +25±5°C TEMPERATURE RANGE Operating temperature (°C) –40 to +85 Storage temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20180712 / rf_dpx_dpx202690dt-4060a1_en.fm RF Components DPX202690DT-4060A1 FREQUENCY CHARACTERISTICS HIGH-BAND Insertion Loss 0.0 0.0 0.5 0.5 1.0 1.0 Insertion Loss(dB) Insertion Loss(dB) LOW-BAND Insertion Loss 1.5 2.0 600 700 800 900 1000 1100 Frequency(MHz) 1200 1300 3.0 1000 1400 0 10 10 Return Loss(dB) 0 20 30 40 50 500 3000 3500 1500 2000 2500 Frequency(MHz) 3000 3500 1000 2000 3000 Frequency(MHz) 4000 5000 30 40 600 700 800 900 1000 1100 Frequency(MHz) 1200 1300 50 1000 1400 0 0 10 10 Attenuation(dB) Attenuation Attenuation(dB) 2000 2500 Frequency(MHz) 20 Attenuation 20 30 20 30 40 40 50 0 1500 Return Loss Return Loss Return Loss(dB) 2.0 2.5 2.5 3.0 500 1.5 50 1000 2000 3000 Frequency(MHz) 4000 5000 0 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20180712 / rf_dpx_dpx202690dt-4060a1_en.fm RF Components DPX202690DT-4060A1 FREQUENCY CHARACTERISTICS Isolation 0 0 10 10 20 20 Isolation(dB) Return Loss(dB) COMMON Return Loss 30 40 40 50 30 0 1000 2000 3000 Frequency(MHz) 4000 5000 50 0 1000 2000 3000 Frequency(MHz) 4000 5000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20180712 / rf_dpx_dpx202690dt-4060a1_en.fm RF Components DPX202690DT-4060A1 RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 150°C T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec Peak Temp. T4 240 to 260°C Time t3 30sec max. t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20180712 / rf_dpx_dpx202690dt-4060a1_en.fm RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20180712 / rf_dpx_dpx202690dt-4060a1_en.fm
DPX202690DT-4060A1 价格&库存
很抱歉,暂时无法提供与“DPX202690DT-4060A1”相匹配的价格&库存,您可以联系我们找货
DPX202690DT-4060A1
  • 1+7.147601+0.92898
  • 10+6.1384010+0.79781
  • 25+5.7863525+0.75205
  • 100+5.29850100+0.68865
  • 250+5.00579250+0.65061
  • 500+4.79864500+0.62368
  • 1000+4.603221000+0.59828
库存:1854
DPX202690DT-4060A1
  • 2000+4.418812000+0.57431
  • 4000+4.244894000+0.55171
  • 6000+4.147826000+0.53909
  • 10000+4.0302110000+0.52381
  • 14000+3.9555014000+0.51410
  • 20000+3.8786420000+0.50411
库存:1854
DPX202690DT-4060A1
  • 2000+3.765422000+0.48939
  • 4000+3.592764000+0.46695
  • 6000+3.536906000+0.45969
  • 10000+3.3947110000+0.44121
  • 14000+3.3498614000+0.43538
  • 20000+3.2940020000+0.42812
库存:4000
DPX202690DT-4060A1
  • 2000+3.768802000+0.48983
  • 4000+3.595304000+0.46728
  • 6000+3.539446000+0.46002
  • 10000+3.3981010000+0.44165
  • 14000+3.3524014000+0.43571
  • 20000+3.2965420000+0.42845
库存:4000
DPX202690DT-4060A1
    • 10+1.09426
    • 100+0.84824
    • 300+0.74283
    库存:1205
