DPX202690DT-4075J1
DPX202690DT-4075J1
    TDK(东电化)
    DPX202690DT-4075J1
DPX202690DT-4075J1 数据手册
SPECIFICATION SPEC NO. TFA9NAA00664 DATE : May 31st, 2018 To XIANGGAO CUSTOMER'S PRODUCT NAME TDK'S PRODUCT NAME DPX202690DT-4075J1 DPX202690DT-4075J1 RECEIPT CONFIRMATION DATE : YEAR MONTH DAY TDK Corporation Sales Engineering Electronic Components Sales & Marketing Group Electronic Components Business Company Communication Devices Business Group APPROVED PERSON IN CHARGE APPROVED CHECKED PERSON IN CHARGE N.Harada K.Tsukamoto H.Ashida No. Page 2/13 May 31st, 2018 TDK Corporation TFA9NAA00664 Specification Change History Customer's Product Name: TDK Product Name : DPX202690DT-4075J1 DPX202690DT-4075J1 Ver Date Person in charge Change Item Note - May 31st, 2018 H.Ashida Initial issue (1.5) No. Page 3/13 May 31st, 2018 TDK Corporation TFA9NAA00664 Diplexer Specification ( TDK Part Number : DPX202690DT-4075J1 ) 1.Marking Direction Mark 2.Mechanical Outline 2-1 Package Package: Delivery Medium: Soldering Method: Size: Height: Surface mount package Tape on reel IR-reflow 2.00 x 1.25mm typ. 0.70 mm typ. Mechanical Dimensions [Top View] [Bottom View]  (6) (5) (4) (4) (4) (5)(5) (6)(6) (1) (2) (3) (3) (3) (2)(2) (1)(1) Dimensions (mm) L W T a b c d e f 2.00 1.25 0.70 0.40 0.25 0.65 0.35 0.30 0.125 +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.05 Terminal functions GND (1) Common Port (2) GND (3) (4) (5) (6) High-Band Port GND Low-Band Port No. Page 4/13 May 31st, 2018 TDK Corporation TFA9NAA00664 2-2 Coplanarity 0.05 mm max. difference in Z-direction as follows Z Coplanarity measurement method Coplanarity = T1-T2 2.0 mm 0.05 mm max. Each terminal extends the full of the product. Hence any coplanarity deviation between terminals is due to curvature in the substrate. TDK guarantees that the edge of each terminal is within 0.05 mm of the horizontal plane. 3. Environment (Temperature & Humidity) 3-1 Operating & Storage Condition Storage Temperature Range : -40 ~ +85 oC Operating Temperature Range : -40 ~ +85 oC Humidity : 0 ~ 90 % R.H. (Max. wet bulb temperature 38 oC) 3-2 Storage Condition before Soldering Temperature Humidity Term of Storage : +5 ~ +30 oC : 20 ~ 70 % RH : Within 12 months (After the delivery) * : Within 1 month (After peeling off top tape) Baking : Unnecessary * For the products stored longer than 12 months, confirm their terminals and solderability before they are used. 3-3 Moisture Sensitivity Level Equal to Level 1 No. Page 5/13 May 31st, 2018 TDK Corporation TFA9NAA00664 4. Electrical Specification 4-1 Electrical Characteristics Low-Band Parameter Insertion Loss (dB) Insertion Loss (dB) ( –40 to +85 °C) Return Loss (dB) Attenuation (dB) Frequency (MHz) 699 699 699 1559 1648 1710 2400 5150 to to to to to to to to to 960 960 960 1606 1698 2200 2690 5850 Characteristic Impedance (ohm) Specification Min. Typ. Max. 0.40 0.45 0.50 20 25.2 10 19.0 15 27.7 25 30.9 30 39.3 20 25.4 50 (Nominal) Ta = +25+/-5°C High-Band Parameter Insertion Loss (dB) Insertion Loss (dB) ( –40 to +85 °C) Return Loss (dB) Attenuation (dB) Frequency (MHz) 1710 1805 2300 1710 1805 2300 1710 699 915 5150 to to to to to to to to to to 1785 2200 2690 1785 2200 2690 2690 915 960 5850 Characteristic Impedance (ohm) Specification Min. Typ. Max. 0.42 0.52 0.37 0.47 0.38 0.48 0.62 0.57 0.58 15 18.7 29 30.6 25 26.9 24 27.9 50 (Nominal) Ta = +25+/-5°C Common Parameter Isolation (dB) Return Loss (dB) Characteristic Impedance (ohm) Ta = +25+/-5°C Frequency (MHz) 699 915 1710 699 1710 to 915 to 960 to 2690 to 960 to 2690 Specification Min. Typ. Max. 30 31.5 25 27.6 30 32.0 20 24.1 15 19.1 50 (Nominal) No. Page 6/13 May 31st, 2018 TDK Corporation TFA9NAA00664 4-2 Maximum Ratings Parameter TDK Spec Min. Max. Conditions Human Body Model : HBM @Each Port (V) -1000 1000 100pF / 1500ohm Machine Model : MM @Each Port (V) -150 150 200pF / 0ohm Charged Device Model : CDM @Each Port (V) -500 500 Relative humidity : 51%RH max Ambient temperature : +25+/-5°C No. TFA9NAA00664 5. Typical Electrical Characteristics Insertion Loss (Low-Band) Attenuation (Low-Band) Insertion Loss (High-Band) Page 7/13 May 31st, 2018 TDK Corporation No. TFA9NAA00664 Attenuation (High-Band) Common port Return Loss Isolation Page 8/13 May 31st, 2018 TDK Corporation No. Page 9/13 May 31st, 2018 TDK Corporation TFA9NAA00664 6. Test Circuit Network Analyser Network Analyzer Note 1: Actual calibration Actual calibration plane plane Actual Actual calibration calibration plane plane Test Fixture Fixture Test PCB DUT The Port Extension function on the Network Analyzer is used to extend the calibration plane to the DUT terminals. Note 2: Loss in the PCB traces is compensated for by measurement data taken on a PCB Thru’ line. Extended calibration plane Extended calibration plane 7. Recommended Land Pattern Unit[mm] No. Page 10/13 May 31st, 2018 TDK Corporation TFA9NAA00664 8. Environmental and Quality Proposal This product satisfies the electrical specification after the following tests. (When measured after two hours in normal conditions) Temperature Characteristics All data initially taken at +25°C, then repeated at -40°C and again at +85°C. Heat Proof +85+/-2 °C for 1000 hours Cold Proof -40+/-2 °C for 500 hours Moisture Proof Heat Shock Vibration +60+/-2 °C, 90~95% R.H. for 1000 hours -40 ~ +85 °C for 350 cycles each cycle being 30 min 10-500Hz vibration frequency (10G Max.) with 1.52mmp-p amplitude for two hours in x,y,z directions 1.Acceleration 1000m/s2 Mechanical Shock 2.Direction X, Y, Z ,X’,Y’,Z’,axes 3.Time 6ms duration and 3 times in each direction The dipped surface of the terminal shall be at least 75% covered with Solderability solder after dipped in solder bath of 245+/-3 °C for 3+/-0.5 sec. Remark solder: Sn-3.0Ag-0.5Cu Remark flux: Rosin 25%, Alcohol 75% Solder Heat Shock Drop Shock It shall be possible to hot air reflow the components three times with a temperature profile shown below. Dropped onto steel plate or concrete from 100cm height three times. Solder specimen components on the test printed circuit board(L:100 R230 1 x w:40 x t:0.8mm) in appended Bending Test recommended PCB pattern. Apply the load in direction of the gap+/-1 arrow until bending reaches 1mm 45 45 for 5+/-1 sec. Unit:mm Solder specimen components on PCB the test printed circuit board(L:100 x w:40 x t:0.8mm) in appended Board Adhesion (Push Test) recommended PCB pattern. Apply the load in direction of the arrow until 5N for 5+/-1 sec. DUT 5N No. Page 11/13 May 31st, 2018 TDK Corporation TFA9NAA00664 9. Recommended Reflowing Temperature Profile 3oC/sec or lower Soldering Preheating Temp. 6oC /sec or lower Critical zone (T3 to T4) Peak Time Temp. Time Temp. Time t2 T4 t3 * T1 T2 t1 T3 150°C 200°C 60 to 120sec 217°C 60 to 120sec 240 to 260°C 30 sec Max * t3 : Time within 5°C of actual peak temperature. The maximum number of reflow is 3. Note: Lead free solder is recommended. Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry) No. Page 12/13 May 31st, 2018 TDK Corporation TFA9NAA00664 10. Packing 10-1 Carrier Tape K Sprocket hole Loading Direction E J B t G H F (Unit:mm) A B C D E F G H J K t 1.45 2.25 8.0 3.5 1.75 4.0 2.0 4.0 1.55 1.05 0.25 +/-0.1 +/-0.1 Max +/-0.05 +/-0.2 +/-0.05 +/-0.1 10-2. Reel Dimensions 10-3. Standard Reel Packaging Quantities 2000pcs./reel +/-0.1 +/-0.05 +/-0.1 +/-0.05 C D A No. TFA9NAA00664 Page 13/13 May 31st, 2018 TDK Corporation 11. Other 11-1 Notice The products listed on this specification sheet are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. - Aerospace/Aviation equipment - Transportation equipment (cars, electric trains, ships, etc.) - Medical equipment - Power-generation control equipment - Atomic energy-related equipment - Seabed equipment - Transportation control equipment - Public information-processing equipment - Military equipment - Electric heating apparatus, burning equipment - Disaster prevention/crime prevention equipment - Safety equipment - Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 11-2 Product Origin 1. TDK Akita Corporation, Akita, Japan 2. TDK Dalian Corporation, Dalian, China
DPX202690DT-4075J1 价格&库存
很抱歉,暂时无法提供与“DPX202690DT-4075J1”相匹配的价格&库存,您可以联系我们找货
