DPX205850DT-4054B1
DPX205850DT-4054B1
    TDK(东电化)
    SMD-6P,1.2x2mm
DPX205850DT-4054B1 数据手册
R F C o m p o n e n t s July 2015 Multilayer Diplexer For 800-2170MHz / 2400-5850MHz DPX205850DT-4054B1 2.0x1.25mm [EIA 0805]* * Dimensions Code JIS[EIA] RF Components Multilayer Diplexer Conformity to RoHS Directive For 800-2170MHz / 2400-5850MHz DPX205850DT-4054B1 SHAPES AND DIMENSIONS 2.00±0.15 [Top view] 0.90±0.10 (5) (4) (1) (2) (3) Marking 1.25±0.15 (6) 0.65±0.10 0.30±0.20 Terminal functions 1 GND 2 Common 3 GND 4 High-band 5 GND 6 Low-band 0.20±0.20 [Bottom view] 0.20±0.20 0.35±0.20 Dimensions in mm RECOMMENDED LAND PATTERN EVALUATION BOARD Thru hole 0.32 Metal pattern (Cu) Land pattern Diplexer Dimensions in mm 630 350 900 PCB material: Teflon 50 0.33 High-band port Common port 0.89 0.77 Low-band port Dimensions in um Line width should be designed to match 50Ω characteristic impedance, depending on PCB material and thickness. RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx205850dt-4054b1_en.fm RF Components DPX205850DT-4054B1 ELECTRICAL CHARACTERISTICS LOW-BAND Frequency Range (MHz) Min. Typ. Max. 800 to 960 1710 to 1990 1990 to 2170 800 to 960 1710 to 1990 1990 to 2170 800 to 960 1710 to 2170 2400 to 2500 5150 to 5850 — — — — — — 10 10 10 25 0.23 0.53 0.98 — — — 16 17 15 36 50 (Nominal) 0.50 0.80 1.30 0.60 (–40 to +85°C) 1.00 (–40 to +85°C) 1.55 (–40 to +85°C) — — — — Frequency Range (MHz) Min. Typ. Max. 2400 to 2500 5150 to 5850 2400 to 2500 5150 to 5850 2400 to 2500 5150 to 5850 800 to 960 1710 to 2170 — — — — 10 10 18 12 1.27 0.27 — — 23 14 24 15 50 (Nominal) 1.70 0.50 2.00 (–40 to +85°C) 0.60 (–40 to +85°C) — — — — Item Frequency Range (MHz) Min. Typ. Max. Isolation (dB) 800 to 960 1710 to 2170 2400 to 2500 5150 to 5850 18 12 10 25 23 15 17 35 50 (Nominal) — — — — Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Characteristic Impedance (:) ・Ta: +25±5°C HIGH-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Characteristic Impedance (:) ・Ta: +25±5°C COMMON Characteristic Impedance (:) ・Ta: +25±5°C TEMPERATURE RANGE Operating temperature (°C) –40 to +85 Storage temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx205850dt-4054b1_en.fm RF Components DPX205850DT-4054B1 FREQUENCY CHARACTERISTICS HIGH-BAND Insertion Loss 0.0 0.0 0.5 0.5 1.0 1.0 Insertion Loss(dB) Insertion Loss(dB) LOW-BAND Insertion Loss 1.5 2.0 2.5 1000 1500 Frequency(MHz) 2000 3.0 2000 2500 Return Loss 0 10 10 20 30 3000 3500 4000 4500 Frequency(MHz) 5000 5500 6000 3000 3500 4000 4500 Frequency(MHz) 5000 5500 6000 2000 3000 4000 5000 Frequency(MHz) 6000 7000 8000 20 30 40 40 50 500 1000 1500 Frequency(MHz) 2000 50 2000 2500 Attenuation 2500 Attenuation 0 10 10 Attenuation(dB) 0 20 30 40 50 2500 Return Loss 0 Return Loss(dB) Return Loss(dB) 2.0 2.5 3.0 500 Attenuation(dB) 1.5 20 30 40 0 1000 2000 3000 4000 5000 Frequency(MHz) 6000 7000 8000 50 0 1000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx205850dt-4054b1_en.fm RF Components DPX205850DT-4054B1 FREQUENCY CHARACTERISTICS Isolation 0 0 10 10 20 20 Isolation(dB) Return Loss(dB) COMMON Return Loss 30 40 40 50 30 0 1000 2000 3000 4000 5000 Frequency(MHz) 6000 7000 8000 50 0 1000 2000 3000 4000 5000 Frequency(MHz) 6000 7000 8000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx205850dt-4054b1_en.fm RF Components RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 150°C T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. Peak Temp. T4 240 to 260°C Time t3 30sec max. RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx205850dt-4054b1_en.fm
DPX205850DT-4054B1 价格&库存
很抱歉,暂时无法提供与“DPX205850DT-4054B1”相匹配的价格&库存,您可以联系我们找货
DPX205850DT-4054B1
  • 2000+3.013522000+0.39175
  • 4000+2.892954000+0.37608
  • 6000+2.825636000+0.36733
  • 10000+2.7440510000+0.35672
  • 14000+2.6922314000+0.34998
  • 20000+2.6389020000+0.34305
库存:229
DPX205850DT-4054B1
  • 1+4.884961+0.63503
  • 10+4.2002110+0.54602
  • 25+3.9583125+0.51457
  • 100+3.62276100+0.47095
  • 250+3.42032250+0.44463
  • 500+3.27674500+0.42597
  • 1000+3.141331000+0.40837
库存:229
