R F
C o m p o n e n t s
July 2015
Multilayer Diplexer
For 700-1990MHz / 2400-5850MHz
DPX205850DT-4055A1
2.0x1.25mm [EIA 0805]*
* Dimensions Code JIS[EIA]
Downloaded From Oneyac.com
RF Components
Multilayer Diplexer
Conformity to RoHS Directive
DPX205850DT-4055A1
SHAPES AND DIMENSIONS
2.00±0.15
[Top view]
0.90±0.10
(5)
(4)
(1)
(2)
(3)
Marking
1.25±0.15
(6)
0.65±0.15
0.30±0.15
Terminal functions
1 GND
2 Common
3 GND
4 High-band
5 GND
6 Low-band
0.20±0.15
[Bottom view]
0.20±0.15
0.35±0.15
Dimensions in mm
RECOMMENDED LAND PATTERN
EVALUATION BOARD
Thru hole
0.32
Metal pattern (Cu)
Land pattern
Diplexer
Dimensions in mm
630
350
900
PCB material: Teflon
50
0.33
High-band port
Common port
0.89
0.77
Low-band port
Dimensions in um
Line width should be designed to match 50Ω characteristic impedance,
depending on PCB material and thickness.
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20150701 / rf_dpx_dpx205850dt-4055a1_en.fm
RF Components
DPX205850DT-4055A1
ELECTRICAL CHARACTERISTICS
LOW-BAND
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Frequency Range
(MHz)
Min.
Typ.
Max.
700 to 960
1560 to 1610
1710 to 1990
700 to 960
1560 to 1610
1710 to 1990
700 to 960
1560 to 1610
1710 to 1990
2400 to 2500
2500 to 2700
5150 to 5850
9.54
9.54
9.54
13
12
0.38
0.67
27.1
29.5
22.2
18
15
28
50 (Nominal)
0.30
0.60
1.00
0.40 (–40 to +85°C)
0.75 (–40 to +85°C)
1.20 (–40 to +85°C)
Frequency Range
(MHz)
Min.
Typ.
Max.
2400 to 2500
2500 to 2700
5150 to 5850
2400 to 2500
2500 to 2700
5150 to 5850
2400 to 2500
2500 to 2700
5150 to 5850
700 to 960
1560 to 1610
1710 to 1990
9.54
9.54
9.54
15
12
12
0.54
0.45
0.15
23.3
20.9
18.4
21
15
15
50 (Nominal)
0.80
0.80
0.50
1.00 (–40 to +85°C)
1.00 (–40 to +85°C)
0.65 (–40 to +85°C)
Characteristic Impedance (:)
・Ta: +25±5°C
HIGH-BAND
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
・Ta: +25±5°C
TEMPERATURE RANGE
Operating temperature
(°C)
–40 to +85
Storage temperature
(°C)
–40 to +85
RF Components
DPX205850DT-4055A1
FREQUENCY CHARACTERISTICS
HIGH-BAND
Insertion Loss
0.0
0.0
0.5
0.5
1.0
1.0
Insertion Loss(dB)
Insertion Loss(dB)
LOW-BAND
Insertion Loss
1.5
2.0
2.0
2.5
2.5
3.0
600
800
1000
1200
1400
1600
Frequency(MHz)
1800
2000
3.0
2000
2200
Return Loss
2500
10
40
5000
5500
6000
3000
3500
4000
4500
Frequency(MHz)
5000
5500
6000
2000
3000
4000
5000
Frequency(MHz)
6000
7000
8000
600
800
1000
1200
1400
1600
Frequency(MHz)
1800
2000
50
2000
2200
2500
Attenuation
10
Attenuation(dB)
Attenuation
Attenuation(dB)
3500
4000
4500
Frequency(MHz)
40
50
40
40
50
3000
Return Loss
Return Loss(dB)
Return Loss(dB)
1.5
50
2000
3000
4000
5000
Frequency(MHz)
6000
7000
8000
RF Components
DPX205850DT-4055A1
Isolation
10
Isolation(dB)
Return Loss(dB)
COMMON
Return Loss
30
40
40
50
30
50
2000
3000
4000
5000
Frequency(MHz)
6000
7000
8000
2000
3000
4000
5000
Frequency(MHz)
6000
7000
8000
RF Components
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
150°C
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
Peak
Temp.
T4
240 to 260°C
t3
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Time
t3
30sec max.
RF Components
REMINDERS FOR USING THESE PRODUCTS
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DPX205850DT-4055A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.16198
- 50+0.92243
- 150+0.81983
- 500+0.69174
- 国内价格 香港价格
- 2000+4.417892000+0.57431
- 4000+4.244024000+0.55171
- 6000+4.146966000+0.53909
- 10000+4.0293810000+0.52381
- 14000+3.9546814000+0.51410
- 20000+3.8778420000+0.50411
- 国内价格
- 1+0.86191
- 30+0.83318
- 100+0.77572
- 500+0.71826
- 1000+0.68953
- 国内价格 香港价格
- 1+7.146121+0.92898
- 10+6.1371310+0.79781
- 25+5.7851525+0.75205
- 100+5.29741100+0.68865
- 250+5.00476250+0.65061
- 500+4.79765500+0.62368
- 1000+4.602271000+0.59828
