DPX205850DT-9038A1-H
    TDK(东电化)
    DIPLEXER WLAN 2.4GHZ, 5GHZ 2012
DPX205850DT-9038A1-H 数据手册
The products in this catalog are not recommended for new design R F C o m p o n e n t s July 2015 Multilayer Diplexer For 2400-2500MHz / 5150-5850MHz DPX205850DT-9038A1-H 2.0x1.25mm [EIA 0805]* * Dimensions Code JIS[EIA] The products in this catalog are not recommended for new design RF Components Multilayer Diplexer Conformity to RoHS Directive For 2400-2500MHz / 5150-5850MHz DPX205850DT-9038A1-H SHAPES AND DIMENSIONS 2.00±0.20 [Top view] 0.80max. (2) (1) (4) (5) (6) Marking 1.25±0.20 (3) 0.65±0.10 0.30±0.10 Terminal functions 1 GND 2 Common 3 GND 4 High-band 5 GND 6 Low-band 0.25±0.20 [Bottom view] 0.20±0.20 0.35±0.10 Dimensions in mm 0.72 0.63 RECOMMENDED LAND PATTERN 0.38 0.27 Dimensions in mm RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx205850dt-9038a1-h_en.fm The products in this catalog are not recommended for new design RF Components DPX205850DT-9038A1-H ELECTRICAL CHARACTERISTICS LOW-BAND Frequency Range (MHz) Min. Typ. Max. 2400 to 2500 2400 to 2500 824 to 915 1545 to 1610 1710 to 1990 2110 to 2170 3200 to 3600 3700 to 3900 4800 to 5000 7200 to 7500 — — 30 30 30 25 15 12 28 25 2.00 — 38 34 35 30 17 25 36 29 50 (Nominal) 2.20 2.40 (–40 to +85°C) — — — — — — — — Frequency Range (MHz) Min. Typ. Max. 5150 to 5850 5150 to 5850 1545 to 1610 1710 to 1990 2110 to 2170 2400 to 2500 3450 to 3900 7250 to 7800 9800 to 11700 — — 20 20 20 23 8 8 20 0.77 — 38 29 25 26 10 26 31 50 (Nominal) 1.20 1.50 (–40 to +85°C) — — — — — — — Item Frequency Range (MHz) Min. Typ. Max. Return Loss (dB) 2400 to 2500 5150 to 5850 9.54 9.54 16.8 13.3 50 (Nominal) — — Item Insertion Loss (dB) Attenuation (dB) Characteristic Impedance (:) ・Ta: +25±5°C HIGH-BAND Item Insertion Loss (dB) Attenuation (dB) Characteristic Impedance (:) ・Ta: +25±5°C COMMON Characteristic Impedance (:) ・Ta: +25±5°C TEMPERATURE RANGE Operating temperature (°C) –40 to +85 Storage temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx205850dt-9038a1-h_en.fm The products in this catalog are not recommended for new design RF Components DPX205850DT-9038A1-H FREQUENCY CHARACTERISTICS HIGH-BAND Insertion Loss 0 0 1 1 Insertion Loss(dB) Insertion Loss(dB) LOW-BAND Insertion Loss 2 3 5 2000 2200 2400 2600 Frequency (MHz) 2800 5 4000 3000 Return Loss 0 0 10 10 20 30 40 5000 5500 Frequency (MHz) 6000 6500 7000 20 30 40 50 2000 2200 2400 2600 Frequency (MHz) 2800 50 4000 3000 Attenuation 10 10 20 20 Attenuation (dB) 0 30 5000 5500 Frequency (MHz) 6000 6500 7000 30 40 40 50 50 1000 4500 Attenuation 0 60 4500 Return Loss Return Loss(dB) Return Loss (dB) 3 4 4 Attenuation (dB) 2 2000 3000 4000 5000 6000 Frequency (MHz) 7000 8000 9000 60 2000 4000 6000 8000 Frequency (MHz) 10000 12000 14000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx205850dt-9038a1-h_en.fm The products in this catalog are not recommended for new design RF Components DPX205850DT-9038A1-H FREQUENCY CHARACTERISTICS COMMON Return Loss Isolation 0 0 10 20 20 Isolation(dB) Return Loss(dB) 10 30 30 40 40 50 50 1000 2000 3000 4000 5000 6000 Frequency (MHz) 7000 8000 9000 60 1000 2000 3000 4000 5000 6000 Frequency (MHz) 7000 8000 9000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx205850dt-9038a1-h_en.fm The products in this catalog are not recommended for new design RF Components RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 150°C T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. Peak Temp. T4 240 to 260°C Time t3 30sec max. The products in this catalog are not recommended for new design RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx205850dt-9038a1-h_en.fm
DPX205850DT-9038A1-H 价格&库存
很抱歉,暂时无法提供与“DPX205850DT-9038A1-H”相匹配的价格&库存,您可以联系我们找货
