DPX205850DT-9043B1BR
    TDK(东电化)
    MULTILAYER DIPLEXER FOR 2400 - 2
DPX205850DT-9043B1BR 数据手册
The products in this catalog are not recommended for new design R F C o m p o n e n t s April 2019 Multilayer Diplexer For 2400-2500MHz / 5150-5850MHz DPX205850DT-9043B1BR 2.0x1.25mm [EIA 0805]* * Dimensions Code JIS[EIA] The products in this catalog are not recommended for new design RF Components Multilayer Diplexer Conformity to RoHS Directive For 2400-2500MHz / 5150-5850MHz DPX205850DT-9043B1BR SHAPES AND DIMENSIONS 2.00±0.20 [Top view] 0.40max. (5) (4) (1) (2) (3) Marking 1.25±0.20 (6) 0.65±0.20 0.30±0.20 0.20±0.20 [Bottom view] 0.20±0.20 Terminal functions 1 GND 2 Common 3 GND 4 High-Band 5 GND 6 Low-Band 0.35±0.20 Dimensions in mm RECOMMENDED LAND PATTERN 0.60 0.73 0.65 0.30 0.35 Dimensions in mm RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190402 / rf_dpx_dpx205850dt-9043b1br_en.fm The products in this catalog are not recommended for new design RF Components DPX205850DT-9043B1BR ELECTRICAL CHARACTERISTICS LOW-BAND Item Insertion Loss (dB) Attenuation (dB) Frequency Range (MHz) Min. Typ. Max. 2400 to 2500 4800 to 5000 7200 to 7500 — 23 20 0.27 29.6 39.1 50 (Nominal) 0.45 — — Frequency Range (MHz) Min. Typ. Max. 5150 to 5850 2400 to 2500 10300 to 11700 15450 to 17550 — 25 20 18 0.31 31.8 28.0 31.2 50 (Nominal) 0.50 — — — Frequency Range (MHz) Min. Typ. Max. 2400 to 2500 5150 to 5850 2400 to 2500 5150 to 5850 20 20 10 10 32.4 26.5 20.8 23.1 50 (Nominal) — — — — Characteristic Impedance () ・Ta: +25±5°C HIGH-BAND Item Insertion Loss (dB) Attenuation (dB) Characteristic Impedance () ・Ta: +25±5°C COMMON Item Isolation (dB) Return Loss (dB) Characteristic Impedance () ・Ta: +25±5°C TEMPERATURE RANGE Operating temperature (°C) –40 to +85 Storage temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190402 / rf_dpx_dpx205850dt-9043b1br_en.fm The products in this catalog are not recommended for new design RF Components DPX205850DT-9043B1BR FREQUENCY CHARACTERISTICS HIGH-BAND Insertion Loss 0.0 0.0 0.5 0.5 1.0 1.0 Insertion Loss(dB) Insertion Loss(dB) LOW-BAND Insertion Loss 1.5 2.0 2.0 2.5 2.5 3.0 2000 2500 3000 Frequency (MHz) 3500 3.0 4000 4000 4500 0 10 10 Return Loss(dB) 0 20 30 40 7000 7500 8000 5000 5500 6000 6500 Frequency (MHz) 7000 7500 8000 16000 18000 20 30 2500 3000 Frequency (MHz) 3500 50 4000 4000 4500 Attenuation 0 0 10 10 Attenuation(dB) Attenuation Attenuation(dB) 5500 6000 6500 Frequency (MHz) 40 50 2000 20 30 20 30 40 40 50 5000 Return Loss Return Loss Return Loss(dB) 1.5 50 2000 4000 6000 8000 10000 12000 Frequency (MHz) 14000 16000 18000 2000 4000 6000 8000 10000 12000 Frequency (MHz) 14000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190402 / rf_dpx_dpx205850dt-9043b1br_en.fm The products in this catalog are not recommended for new design RF Components DPX205850DT-9043B1BR FREQUENCY CHARACTERISTICS Isolation 0 0 10 10 20 20 Isolation(dB) Return Loss(dB) COMMON Return Loss 30 40 40 50 30 50 2000 4000 6000 8000 10000 12000 Frequency (MHz) 14000 16000 18000 2000 4000 6000 8000 10000 12000 Frequency (MHz) 14000 16000 18000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190402 / rf_dpx_dpx205850dt-9043b1br_en.fm The products in this catalog are not recommended for new design RF Components DPX205850DT-9043B1BR RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T3 t3 T1 t1 t2 t: Time Soaking Temp. T1 150°C T2 180°C Time t1 60 to 120s Working Temp. T3 230°C Time t2 more than 30s Soldering Peak Temp. T4 247 to 253°C Time t3 within 10s Temp. T5 260°C max. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190402 / rf_dpx_dpx205850dt-9043b1br_en.fm The products in this catalog are not recommended for new design RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20190402 / rf_dpx_dpx205850dt-9043b1br_en.fm
DPX205850DT-9043B1BR 价格&库存
很抱歉,暂时无法提供与“DPX205850DT-9043B1BR”相匹配的价格&库存,您可以联系我们找货
  • 1+5.046391+0.63151
  • 10+4.0915210+0.51201
  • 25+3.7708125+0.47188
  • 50+3.5474150+0.44392
  • 100+3.33563100+0.41742
  • 250+3.07589250+0.38492
  • 500+2.89311500+0.36205
  • 1000+2.721511000+0.34057
库存:1477
  • 2000+2.611232000+0.32677
  • 4000+2.456314000+0.30738
  • 6000+2.369986000+0.29658
  • 10000+2.2654710000+0.28350
  • 14000+2.1991214000+0.27520
  • 20000+2.1308920000+0.26666
库存:1477
