DPX205925DT-4213A4
DPX205925DT-4213A4
    TDK(东电化)
    SMD-6P,2x1.3mm
DPX205925DT-4213A4 数据手册
May.2021 Ver.2.0a TDK Corporation Multilayer Diplexer For LTE DPX Series P/N: 2.0x1.25mm [EIA 0805] TYPE DPX205925DT-4213A4 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May.2021 Ver.2.0a TDK Corporation   DPX205925DT-4213A4 ■ SHAPES AND DIMENSIONS [Top View] [Bottom View] (6) (5) (4) (4) (5) (6) (1) (2) (3) (3) (2) (1) ■ Dimensions (mm) L W T a b c d p 2.00 1.25 0.60 0.35 0.30 0.60 0.275 0.65 +/-0.10 +/-0.10 Max +/-0.10 +/-0.15 +/-0.10 Terminal functions GND (1) Common Port (2) GND (3) +/-0.10 (4) (5) (6) +/-0.10 High-Band Port GND Low-Band Port ■ TERMINATION FINISH Material Ag All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May.2021 Ver.2.0a TDK Corporation   DPX205925DT-4213A4 ■ ELECTRICAL CHARACTERISTICS ( Measurement ) Low-Band Parameter Insertion Loss (dB) Insertion Loss (dB) ( –40 to +85 °C ) VSWR (Low-Band Port) Attenuation (dB) Frequency (MHz) 617 1427 1710 2300 2496 617 1427 1710 2300 2496 617 1427 1710 2170 3300 3400 4400 5150 to to to to to to to to to to to to to to to to to to 960 1511 2170 2496 2690 960 1511 2170 2496 2690 960 1710 2170 2690 3400 4200 5000 5925 Characteristic Impedance (ohm) TDK Spec. Min. Typ. Max. 0.17 0.35 0.23 0.45 0.40 0.55 0.58 0.75 0.73 0.90 0.45 0.55 0.65 0.85 1.05 1.19 1.5 1.23 1.5 1.30 1.67 1.37 1.67 18.0 26.8 23.0 26.7 23.0 30.6 30.0 39.9 50 (Nominal) Ta = +25+/-5°C High-Band Parameter Insertion Loss (dB) Insertion Loss (dB) ( –40 to +85 °C ) VSWR (High-Band Port) Attenuation (dB) Characteristic Impedance (ohm) Frequency (MHz) 3300 3400 4400 5150 3300 3400 4400 5150 3300 3400 4400 5150 617 1427 1710 2170 10300 15450 to 3400 to 4200 to 5000 to 5925 to 3400 to 4200 to 5000 to 5925 to 3400 to 4200 to 5000 to 5925 to 960 to 1511 to 2170 to 2690 to 11850 to 17775 TDK Spec Min. Typ. Max. 0.85 1.30 0.73 1.00 0.27 0.70 0.20 0.50 1.40 1.10 0.80 0.60 1.27 1.67 1.41 1.67 1.24 1.67 1.24 1.5 30.0 37.1 30.0 43.1 25.0 29.9 22.0 25.7 25.0 42.5 5.0 13.1 50 (Nominal) Ta = +25+/-5°C All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May.2021 Ver.2.0a TDK Corporation   DPX205925DT-4213A4 ■ ELECTRICAL CHARACTERISTICS ( Measurement ) Common Parameter VSWR (Common Port) Isolation (dB) Frequency (MHz) 617 1427 1710 2170 3300 3400 4400 5150 617 1427 1710 2170 3300 3400 3800 4400 5150 to to to to to to to to to to to to to to to to to 960 1710 2170 2690 3400 4200 5000 5925 960 1511 2170 2690 3400 3800 4200 5000 5925 TDK Spec Min. Typ. Max. 1.15 1.5 1.17 1.5 1.31 1.67 1.40 1.67 1.23 1.67 1.42 1.67 1.21 1.67 1.24 1.5 30.0 36.6 30.0 42.6 23.0 31.5 23.0 28.6 20.0 26.4 23.0 27.6 23.0 26.4 23.0 30.5 28.0 39.3 - Ta = +25+/-5°C ■ MAXIMUM RATINGS Parameter Operating temperature (°C) Storage temperature (°C) Power Handling (W) *1 Low-Band TDK Spec Conditions –40 to +85 °C –40 to +85 °C Frequency (MHz) GSM signal Duty 50% 4 617 to 960 CW   1 1427 to 2690 CW   1 High-Band 3300 to 5925 Human Body Model : HBM @Each Port (V) +/-1000 100pF / 1500ohm +/-150 200pF / 0ohm Machine Model : MM @Each Port (V) +/-500 Humidity : 60%RH max Charged Device Model : CDM @Each Port (V) *1 : Refer to 3GPP TS 38.101-1 V15.2.0 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies   May.2021 Ver.2.0a TDK Corporation DPX205925DT-4213A4 ■ FREQUENCY CHARACTERISTICS ANT - LOW All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies   May.2021 Ver.2.0a TDK Corporation DPX205925DT-4213A4 ■ FREQUENCY CHARACTERISTICS ANT - HIGH All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies   May.2021 Ver.2.0a TDK Corporation DPX205925DT-4213A4 ■ FREQUENCY CHARACTERISTICS COMMON ISOLATION All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May.2021 Ver.2.0a TDK Corporation   DPX205925DT-4213A4 ■ RECOMMENDED LAND PATTERN Unit [mm] ■ EVALUATION BOARD Material & Layer Copper Surface Pattern FR-4 Inner GND FR-4 Copper Bottom GND Thickness 0.035 mm 0.10 mm 0.018 mm 0.30 mm 0.035 mm unit : mm * Line width should be designed to match 50 ohm characteristic impedance depending on PCB material and thickness. ** The position of the throuh hole which have possibility of influence to the prerformance are indicated by dimension line. ■ ENVIRONMENT INFORMATION RoHS Statement RoHS Compliance All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies TDK Corporation ■ RECOMMENDED REFLOW PROFILE 3oC/sec or lower Preheating Temp. T1 T2 Time t1 150°C 200°C 60 to 120sec 6oC/sec or lower Soldering Critical zone (T3 to T4) Peak Temp. Time Temp. Time T3 t2 T4 t3 * 217°C 60 to 120sec 240 to 260°C 30 sec Max * t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. Note: Lead free solder is recommended. Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry) All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May.2021 Ver.2.0a TDK Corporation   DPX205925DT-4213A4 ■ PACKAGING STYLE Reel Dimensions Carrier Tape Sprocket hole K Loading Direction E J C D A B B t H Dimensions (mm) A B C 1.45 2.2 8.0 D 3.5 +/-0.05 +/-0.05 +0.3/-0.1 +/-0.05 G F E 1.75 F 4.0 G 2.0 H 4.0 J 1.5 K 0.8 t 0.25 +/-0.1 +/-0.1 +/-0.05 +/-0.1 +0.1/-0 MAX +/-0.05 STANDARD PACKAGE QUANTITY ( pieces/reel ) 2,000 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this specification sheet are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. Aerospace/Aviation equipment Transportation equipment (cars, electric trains, ships, etc.) Medical equipment Power-generation control equipment Atomic energy-related equipment Seabed equipment Transportation control equipment Public information-processing equipment Military equipment Electric heating apparatus, burning equipment Disaster prevention/crime prevention equipment Safety equipment Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/equipment or providing backup circuits, etc., to ensure higher safety. All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies
DPX205925DT-4213A4 价格&库存
很抱歉,暂时无法提供与“DPX205925DT-4213A4”相匹配的价格&库存,您可以联系我们找货
DPX205925DT-4213A4
  • 5+0.61290
  • 50+0.50970
  • 150+0.42990
  • 500+0.38590
  • 2000+0.35860
库存:1870
DPX205925DT-4213A4
  • 2000+1.827142000+0.23618
  • 4000+1.718714000+0.22217
  • 6000+1.658326000+0.21436
  • 10000+1.5852210000+0.20491
  • 14000+1.5388214000+0.19891
  • 20000+1.4910920000+0.19274
库存:348
DPX205925DT-4213A4
  • 1+0.60170
  • 50+0.40150
  • 2000+0.36300
库存:2034
DPX205925DT-4213A4
    • 5+0.52305
    • 50+0.40900
    • 150+0.35198
    • 500+0.30921
    库存:855
    DPX205925DT-4213A4
    • 1+2.61434
    • 100+2.22758
    • 2000+1.09129
    库存:1240
    DPX205925DT-4213A4
    • 1+3.703951+0.47878
    • 10+3.0101310+0.38909
    • 25+2.7718825+0.35830
    • 50+2.6057950+0.33683
    • 100+2.45133100+0.31686
    • 250+2.26012250+0.29215
    • 500+2.12575500+0.27478
    • 1000+1.999531000+0.25846
    库存:348
