DPX205925DT-4226A2
DPX205925DT-4226A2
    TDK(东电化)
    射频双工器 双工器 3.3GHz ~ 3.8GHz / 4.4GHz ~ 5.925GHz 0805(2012 公制),6 PC 板
DPX205925DT-4226A2 数据手册
May. 2021 Ver.5.0a TDK Corporation   Multilayer Diplexer For LTE DPX Series P/N: 2.0x1.25mm [EIA 0805] TYPE DPX205925DT-4226A2 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.5.0a TDK Corporation   DPX205925DT-4226A2 ■ SHAPES AND DIMENSIONS [Top View] [Bottom View] (6) (5) (4) (4) (5) (6) (1) (2) (3) (3) (2) (1) Dimensions (mm) L W T a b c d p 2.00 1.25 0.65 0.35 0.30 0.60 0.275 0.65 +/-0.10 +/-0.10 Max +/-0.10 +/-0.15 +/-0.10 +/-0.10 +/-0.10 Terminal functions GND (1) Common Port (2) GND (3) (4) (5) (6) High-Band Port GND Low-Band Port ■ TERMINATION FINISH Material Au plate All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.5.0a TDK Corporation   DPX205925DT-4226A2 ■ ELECTRICAL CHARACTERISTICS ( Measurement ) Low-Band Parameter Insertion Loss (dB) Insertion Loss (dB) ( –40 to +85 °C ) Return Loss (dB) ( Low-Band Port ) Attenuation (dB) Frequency (MHz) 3300 to to 3300 to to 3300 to to 4400 to 4900 to 5150 to 3800 3800 3800 4900 5000 5925 Characteristic Impedance (ohm) Ta = +25+/-5°C TDK Spec. Min. Typ. Max. 0.72 0.95 1.15 10 24.8 15 18.0 15 17.9 15 17.9 50 (Nominal) High-Band Parameter Insertion Loss (dB) Insertion Loss (dB) ( –40 to +85 °C ) Return Loss (dB) ( High-Band Port ) Attenuation (dB) Characteristic Impedance (ohm) Ta = +25+/-5°C Frequency (MHz) 4400 4900 5150 4400 4900 5150 4400 4900 5150 3300 3400 to to to to to to to to to to to 4900 5000 5925 4900 5150 5925 4900 5000 5925 3400 3800 TDK Spec. Min. Typ. Max. 0.70 0.95 0.29 0.55 0.30 0.55 1.00 0.65 0.65 10 23.6 10 23.2 10 14.8 14 16.1 15 17.7 50 (Nominal) All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.5.0a TDK Corporation   DPX205925DT-4226A2 ■ ELECTRICAL CHARACTERISTICS ( Measurement ) Common Parameter Isolation (dB) Return Loss (dB) ( Common Port ) Frequency (MHz) 3300 3400 4400 4900 5150 3300 4400 4900 5150 to to to to to to to to to Characteristic Impedance (ohm) Ta = +25+/-5°C 3400 3800 4900 5000 5925 3800 4900 5000 5925 TDK Spec. Min. Typ. Max. 14 16.9 15 18.4 15 18.7 15 18.6 15 18.7 10 25.8 10 17.6 10 23.4 10 16.7 50 (Nominal) ■ MAXIMUM RATINGS TDK Spec Min. Max. Parameter –40 to +85 °C –40 to +85 °C 2 2 2 Human Body Model : HBM @Each Port (V) -1000 1000 Machine Model : MM @Each Port (V) -150 150 Charged Device Model : CDM @Each Port (V) -500 500 Operating temperature (°C) Storage temperature (°C) Power Handling (W) Common Port Low-Band Port High-Band Port Conditions CW CW CW 100pF / 1500ohm 200pF / 0ohm Relative humidity : 60%RH max *1 : Refer to 3GPP TS 38.101-1 V15.2.0 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies   May. 2021 Ver.5.0a TDK Corporation DPX205925DT-4226A2 ■ FREQUENCY CHARACTERISTICS All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies   May. 2021 Ver.5.0a TDK Corporation DPX205925DT-4226A2 ■ FREQUENCY CHARACTERISTICS   All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.5.0a TDK Corporation   DPX205925DT-4226A2 ■ RECOMMENDED LAND PATTERN Unit: mm ■ EVALUATION BOARD 0 0 5 0 85 08 5 5 0 unit : mm Material & Layer Copper Surface Pattern FR-4 Inner GND FR-4 Copper Bottom GND Thickness 0.035 mm 0.10 mm 0.018 mm 0.30 mm 0.035 mm * Line width should be designed to match 50 ohm characteristic impedance depending on PCB material and thickness. ** The position of the throuh hole which have possibility of influence to the prerformance are indicated by dimension line. *** Inner GND of under the signal lines are removed for keeping line impedance. ■ ENVIRONMENT INFORMATION RoHS Statement RoHS Compliance All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.5.0a TDK Corporation   DPX205925DT-4226A2 ■ RECOMMENDED REFLOW PROFILE 3oC/sec or lower Preheating Temp. T1 T2 Time t1 150°C 200°C 60 to 120sec 6oC/sec or lower Soldering Critical zone (T3 to T4) Peak Temp. Time Temp. Time T3 t2 T4 t3 * 217°C 60 to 120sec 240 to 260°C 30 sec Max * t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. Note: Lead free solder is recommended. Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry) All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies May. 2021 Ver.5.0a TDK Corporation   DPX205925DT-4226A2 ■ PACKAGING STYLE Reel Dimensions Carrier Tape Sprocket hole K Loading Direction E J C D A B B t H Dimensions (mm) A B C 1.45 2.2 8.0 +/-0.05 D 3.5 +/-0.05 +0.3/-0.1 +/-0.05 G F E 1.75 F 4.0 G 2.0 H 4.0 J 1.5 K 0.8 t 0.25 +/-0.1 +/-0.1 +/-0.05 +/-0.1 +0.1/-0 MAX +/-0.05 STANDARD PACKAGE QUANTITY ( pieces/reel ) 2,000 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this specification sheet are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. Aerospace/Aviation equipment Transportation equipment (cars, electric trains, ships, etc.) Medical equipment Power-generation control equipment Atomic energy-related equipment Seabed equipment Transportation control equipment Public information-processing equipment Military equipment Electric heating apparatus, burning equipment Disaster prevention/crime prevention equipment Safety equipment Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/equipment or providing backup circuits, etc., to ensure higher safety. All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies
DPX205925DT-4226A2 价格&库存
很抱歉,暂时无法提供与“DPX205925DT-4226A2”相匹配的价格&库存,您可以联系我们找货
DPX205925DT-4226A2
  • 5+1.24839
  • 50+0.98569
  • 150+0.87318
  • 500+0.73273
  • 2000+0.67019
  • 4000+0.63261
库存:1574
DPX205925DT-4226A2
  • 1+3.944701+0.51040
  • 10+3.2026710+0.41439
  • 25+2.9493525+0.38161
  • 50+2.7730250+0.35880
  • 100+2.60851100+0.33751
  • 250+2.40507250+0.31119
  • 500+2.26210500+0.29269
  • 1000+2.127781000+0.27531
库存:2380
DPX205925DT-4226A2
  • 2000+1.944332000+0.25158
  • 4000+1.828954000+0.23665
  • 6000+1.764686000+0.22833
  • 10000+1.6868910000+0.21827
  • 14000+1.6375214000+0.21188
  • 20000+1.5867420000+0.20531
库存:2380
