DPX205950DT-9008A1
DPX205950DT-9008A1
    TDK(东电化)
    DPX205950DT-9008A1
DPX205950DT-9008A1 数据手册
R F C o m p o n e n t s July 2015 Multilayer Diplexer For 2300-2500MHz / 4900-5950MHz DPX205950DT-9008A1 2.0x1.25mm [EIA 0805]* * Dimensions Code JIS[EIA] Caution The products in this catalog will be or have been stopped production Discontinue Issue Date Jun. 3, 2022 Last Purchase Order Date Mar. 31, 2023 Last Shipment Date Mar. 31, 2024 Please refer to our Web site about replacement information. RF Components Multilayer Diplexer Conformity to RoHS Directive For 2300-2500MHz / 4900-5950MHz pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en DPX205950DT-9008A1 SHAPES AND DIMENSIONS 2.00±0.15 0.95±0.10 (6) (5) (4) (1) (2) (3) Marking 1.25±0.15 [Top view] 0.65±0.20 0.30±0.20 Terminal functions 1 GND 2 Common 3 GND 4 High-band 5 GND 6 Low-band 0.25±0.20 [Bottom view] 0.20±0.20 0.35±0.20 Dimensions in mm RECOMMENDED LAND PATTERN 0.30 EVALUATION BOARD 3.40 0.35 1.40 0.35 ø0.3 Through-hole 0.80 0.60 0.932 Th e 0.80 0.60 Dimensions in mm 1.00 0.80 0.60 0.60 0.80 0.30 0.15 0.50 0.594 0.932 Land 3.032 Solder resist Dimensions in mm Line width should be designed to match 50Ω characteristic impedance, depending on PCB material and thickness. RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx205950dt-9008a1_en.fm RF Components DPX205950DT-9008A1 ELECTRICAL CHARACTERISTICS Item pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en LOW-BAND Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Frequency Range (MHz) Min. Typ. Max. 2300 to 2500 2300 to 2500 2400 to 2500 4600 to 5000 6900 to 7500 — — 10 20 20 0.37 — 16.4 22.3 29.7 50 (Nominal) 0.65 0.80 (–40 to +85°C) — — — Frequency Range (MHz) Min. Typ. Max. 4900 to 5950 4900 to 5950 4900 to 5950 2300 to 2500 9800 to 11900 — — 9 20 13 1.03 — 11.4 26.2 18.8 50 (Nominal) 1.40 1.60 (–40 to +85°C) — — — Frequency Range (MHz) Min. Typ. Max. 2300 to 2500 4900 to 5950 10 9 15.4 13.0 50 (Nominal) — — Characteristic Impedance (:) ・Ta: +25±5°C HIGH-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Characteristic Impedance (:) ・Ta: +25±5°C COMMON Item Return Loss (dB) Characteristic Impedance (:) ・Ta: +25±5°C TEMPERATURE RANGE Storage temperature (°C) –40 to +85 Th e Operating temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx205950dt-9008a1_en.fm RF Components DPX205950DT-9008A1 FREQUENCY CHARACTERISTICS 0.0 0.0 0.5 Insertion Loss(dB) 1.0 1.5 2.0 2.5 3.0 1500 2000 Return Loss 2.0 2500 Frequency (MHz) 3000 3.0 4000 3500 4500 5000 5500 Frequency (MHz) 6000 6500 7000 4500 5000 5500 Frequency (MHz) 6000 6500 7000 Return Loss 10 Return Loss(dB) 10 Return Loss (dB) 1.5 0 0 20 30 20 30 40 40 50 1500 2000 Attenuation 0 2500 Frequency (MHz) 3000 50 4000 3500 Attenuation 0 10 10 20 Th e 30 40 50 1.0 2.5 Attenuation (dB) Insertion Loss(dB) 0.5 Attenuation (dB) HIGH-BAND Insertion Loss pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en LOW-BAND Insertion Loss 2000 4000 20 30 40 6000 8000 Frequency (MHz) 10000 12000 50 2000 4000 6000 8000 Frequency (MHz) 10000 12000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx205950dt-9008a1_en.fm RF Components DPX205950DT-9008A1 COMMON Return Loss 0 10 20 Isolation (dB) Return Loss (dB) Isolation 0 10 30 40 20 30 40 2000 4000 6000 8000 Frequency (MHz) 10000 12000 50 2000 4000 6000 8000 Frequency (MHz) 10000 12000 Th e 50 pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en FREQUENCY CHARACTERISTICS • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx205950dt-9008a1_en.fm RF Components pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T1 t1 T3 t3 t2 t: Time Preheating Temp. T1 150°C t3 T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec Th e : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. Peak Temp. T4 240 to 260°C Time t3 30sec max. RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications Th e When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150701 / rf_dpx_dpx205950dt-9008a1_en.fm
DPX205950DT-9008A1 价格&库存
很抱歉,暂时无法提供与“DPX205950DT-9008A1”相匹配的价格&库存,您可以联系我们找货
DPX205950DT-9008A1
  • 1+6.151451+0.71052
  • 10+5.2952810+0.61163
  • 25+4.9897525+0.57634
  • 100+4.56850100+0.52769
库存:240
DPX205950DT-9008A1
  • 1+7.734271+0.89335
  • 10+5.8900410+0.68033
  • 25+5.2952825+0.61163
  • 100+4.53972100+0.52436
  • 250+4.12840250+0.47685
  • 500+3.85846500+0.44567
库存:240
DPX205950DT-9008A1
  • 2000+2.804352000+0.32392
  • 6000+2.664136000+0.30772
  • 10000+2.5539610000+0.29500
库存:240
