R F
C o m p o n e n t s
July 2015
Multilayer Diplexer
For 2300-2500MHz / 4900-5950MHz
DPX205950DT-9108A1
2.0x1.25mm [EIA 0805]*
* Dimensions Code JIS[EIA]
Caution
The products in this catalog will be or have been
stopped production
Discontinue Issue Date
Jun. 3, 2022
Last Purchase Order Date
Mar. 31, 2023
Last Shipment Date
Mar. 31, 2027
Please refer to our Web site about replacement information.
RF Components
Multilayer Diplexer
Conformity to RoHS Directive
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
DPX205950DT-9108A1
SHAPES AND DIMENSIONS
2.00±0.15
0.95±0.10
(6)
(5)
(4)
(1)
(2)
( 3)
Marking
1.25±0.15
[Top view]
0.25±0.20
[Bottom view]
0.65±0.20
0.30±0.20
Terminal functions
1 GND
2 Common
3 GND
4 Low-band
5 GND
6 High-band
0.20±0.20
0.35±0.20
Dimensions in mm
RECOMMENDED LAND PATTERN
0.30
EVALUATION BOARD
3.40
0.35
1.40
0.35
ø0.3 Through-hole
0.80
0.60
0.932
Th
e
0.80
0.60
Dimensions in mm
1.00
0.80
0.60
0.60
0.80
0.30
0.15
0.50
0.594
0.932
Land
3.032
Solder resist
Dimensions in mm
Line width should be designed to match 50Ω characteristic impedance,
depending on PCB material and thickness.
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20150701 / rf_dpx_dpx205950dt-9108a1_en.fm
RF Components
DPX205950DT-9108A1
ELECTRICAL CHARACTERISTICS
Item
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
LOW-BAND
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Frequency Range
(MHz)
Min.
Typ.
Max.
2300 to 2500
2300 to 2500
2400 to 2500
4600 to 5000
6900 to 7500
10
14.5
22.9
27.7
50 (Nominal)
0.65
0.80 (–40 to +85°C)
Frequency Range
(MHz)
Min.
Typ.
Max.
4900 to 5950
4900 to 5950
4900 to 5950
2300 to 2500
9800 to 11900
9
0.98
12.2
26.3
22.4
50 (Nominal)
1.40
1.60 (–40 to +85°C)
Frequency Range
(MHz)
Min.
Typ.
Max.
2300 to 2500
4900 to 5950
10
9
13.3
12.1
50 (Nominal)
Characteristic Impedance (:)
・Ta: +25±5°C
HIGH-BAND
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
・Ta: +25±5°C
COMMON
Item
Return Loss (dB)
・Ta: +25±5°C
TEMPERATURE RANGE
Storage temperature
(°C)
–40 to +85
Th
e
Operating temperature
(°C)
–40 to +85
RF Components
DPX205950DT-9108A1
FREQUENCY CHARACTERISTICS
0.0
0.0
0.5
Insertion Loss(dB)
1.0
1.5
2.0
3.0
1500
2000
Return Loss
Frequency (MHz)
3000
2.0
3.0
4000
3500
4500
5000
5500
Frequency (MHz)
6000
6500
7000
4500
5000
5500
Frequency (MHz)
6000
6500
7000
Return Loss
10
Return Loss(dB)
Return Loss (dB)
1.5
40
40
50
1500
2000
Attenuation
Frequency (MHz)
3000
50
4000
3500
Attenuation
10
Th
e
30
40
50
1.0
2.5
2.5
Attenuation (dB)
Insertion Loss(dB)
0.5
Attenuation (dB)
HIGH-BAND
Insertion Loss
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
LOW-BAND
Insertion Loss
2000
4000
40
6000
8000
Frequency (MHz)
10000
12000
50
2000
4000
6000
8000
Frequency (MHz)
10000
12000
RF Components
DPX205950DT-9108A1
COMMON
Return Loss
Isolation (dB)
Return Loss (dB)
Isolation
30
40
40
2000
4000
6000
8000
Frequency (MHz)
10000
12000
50
2000
4000
6000
8000
Frequency (MHz)
10000
12000
Th
e
50
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
RF Components
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T1
t1
T3
t3
t2
t: Time
Preheating
Temp.
T1
150°C
t3
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
Th
e
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
RF Components
REMINDERS FOR USING THESE PRODUCTS
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
Th
e
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DPX205950DT-9108A1”相匹配的价格&库存,您可以联系我们找货
