DPX252690DT-5031A1
DPX252690DT-5031A1
    TDK(东电化)
    多层双工器,用于698-960MHz和1710-2690MHz频段,符合RoHS指令
DPX252690DT-5031A1 数据手册
R F C o m p o n e n t s October 2015 Multilayer Diplexer For 698-960MHz / 1710-2690MHz DPX252690DT-5031A1 2.5x2.0mm [EIA 1008]* * Dimensions Code JIS[EIA] RF Components Multilayer Diplexer Conformity to RoHS Directive For 698-960MHz / 1710-2690MHz DPX252690DT-5031A1 SHAPES AND DIMENSIONS [Top view] 2.50±0.15 1.00max. (7) (6) ( 5) (1) (2) (3) (4) 2.00±0.15 (8) Marking 0.50±0.15 [Bottom view] 0.20±0.15 Terminal functions 1 GND 2 GND 3 Common 4 GND 5 High-band 6 GND 7 GND 8 Low-band 0.25±0.15 Dimensions in mm 0.25±0.15 0.40 1.60 RECOMMENDED LAND PATTERN 0.30 0.20 Dimensions in mm RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20151018 / rf_dpx_dpx252690dt-5031a1_en.fm RF Components DPX252690DT-5031A1 ELECTRICAL CHARACTERISTICS LOW-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Frequency Range (MHz) Min. Typ. Max. 698 to 960 698 to 960 698 to 960 1574 to 1605 1648 to 1698 1760 to 1830 2472 to 2494 2495 to 2547 2640 to 2745 3296 to 3396 3520 to 3660 4120 to 4245 4400 to 4575 4944 to 5094 5280 to 5490 5768 to 5943 6160 to 6405 6592 to 6792 7040 to 7320 7416 to 7641 7920 to 8235 — — 20 12 16 21 28 13 18 16 21 26 28 35 28 25 22 22 15 12 4 0.28 — 25 28 30 26 31 31 31 25 26 30 33 48 35 33 36 27 18 14 10 50 (Nominal) 0.36 0.45 (–40 to +85°C) — — — — — — — — — — — — — — — — — — — Frequency Range (MHz) Min. Typ. Max. 1710 to 1980 2025 to 2690 1710 to 1980 2025 to 2690 1710 to 2690 698 to 960 815 to 894 3296 to 3396 3420 to 3570 3700 to 3820 3840 to 3960 4120 to 4245 4400 to 4575 4944 to 5094 5130 to 5335 5550 to 5730 5760 to 5845 5846 to 5940 6160 to 6405 — — — — 14 24 30 0 13 12 15 14 14 21 30 30 34 17 4 0.42 0.57 — — 16 27 33 10 18 22 20 20 22 34 48 43 44 39 25 50 (Nominal) 0.60 0.70 0.70 (–40 to +85°C) 0.80 (–40 to +85°C) — — — — — — — — — — — — — — — Characteristic Impedance (:) ・Ta: +25±5°C HIGH-BAND Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Characteristic Impedance (:) ・Ta: +25±5°C • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20151018 / rf_dpx_dpx252690dt-5031a1_en.fm RF Components DPX252690DT-5031A1 ELECTRICAL CHARACTERISTICS COMMON Item Frequency Range (MHz) Min. Typ. Max. Isolation (dB) 698 to 915 915 to 960 1710 to 2690 2112 to 2148 25 24 25 25 27 27 27 28 50 (Nominal) — — — — Characteristic Impedance (:) ・Ta: +25±5°C TEMPERATURE RANGE Operating temperature (°C) –40 to +85 Storage temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20151018 / rf_dpx_dpx252690dt-5031a1_en.fm RF Components DPX252690DT-5031A1 FREQUENCY CHARACTERISTICS HIGH-BAND Insertion Loss 0.0 0.0 0.5 0.5 1.0 1.0 Insertion Loss(dB) Insertion Loss(dB) LOW-BAND Insertion Loss 1.5 2.0 2.0 2.5 2.5 3.0 500 600 700 800 900 1000 Frequency(MHz) 1100 1200 1300 3.0 1600 1400 Return Loss 0 10 10 20 30 40 2200 2400 Frequency(MHz) 2600 2800 3000 2000 2200 2400 Frequency(MHz) 2600 2800 3000 20 30 600 700 800 900 1000 Frequency(MHz) 1100 1200 1300 50 1600 1400 Attenuation 0 0 10 10 Attenuation(dB) Attenuation Attenuation(dB) 2000 40 50 500 20 30 1800 20 30 40 40 50 1800 Return Loss 0 Return Loss(dB) Return Loss(dB) 1.5 50 0 2000 4000 6000 8000 Frequency(MHz) 10000 12000 0 2000 4000 6000 8000 Frequency(MHz) 10000 12000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20151018 / rf_dpx_dpx252690dt-5031a1_en.fm RF Components DPX252690DT-5031A1 FREQUENCY CHARACTERISTICS Isolation 0 0 10 10 20 20 Isolation(dB) Return Loss(dB) COMMON Return Loss 30 40 40 50 500 30 1000 1500 2000 Frequency(MHz) 2500 3000 50 500 1000 1500 2000 Frequency(MHz) 2500 3000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20151018 / rf_dpx_dpx252690dt-5031a1_en.fm RF Components RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 150°C T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. Peak Temp. T4 240 to 260°C Time t3 30sec max. RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20151018 / rf_dpx_dpx252690dt-5031a1_en.fm
DPX252690DT-5031A1 价格&库存
很抱歉,暂时无法提供与“DPX252690DT-5031A1”相匹配的价格&库存,您可以联系我们找货
DPX252690DT-5031A1
  • 5+1.11197
  • 50+0.97902
  • 150+0.92200
  • 500+0.85094
库存:1629
DPX252690DT-5031A1
  • 2000+4.563892000+0.59309
  • 4000+4.385034000+0.56985
  • 6000+4.285226000+0.55688
  • 10000+4.1642810000+0.54116
  • 14000+4.0874714000+0.53118
  • 20000+4.0084320000+0.52091
库存:6111
DPX252690DT-5031A1
  • 1+7.406961+0.96256
  • 10+6.3369510+0.82351
  • 25+5.9682025+0.77559
  • 100+5.46858100+0.71066
  • 250+5.16774250+0.67156
  • 500+4.95463500+0.64387
  • 1000+4.753511000+0.61773
库存:6111
DPX252690DT-5031A1
    • 100+0.86930
    库存:9961
