ECO2230SEO-D04V016
ECO2230SEO-D04V016
    TDK(东电化)
    回扫转换器 用于 用于 AC/DC 转换器 SMPS 变压器 隔离 50kHz 通孔
ECO2230SEO-D04V016 数据手册
T R A N S F O R M E R S Transformers for switching power supplies Pin terminal type Pb RoHS REACH SVHC-Free Lead Free ECO2230SEO-D04V016 ■ FEATURES ○Downsized yet compliant with worldwide safety standards. ○Supports automatic winding. ○Considerably reduced characteristic variations. ■ APPLICATION ○Isolation type Single-output power supplies ○Input : 90 to 264Vac ○1Output : 12V/2.0A ○Circuit type : PWM flyback ○frequency : 100kHz ■ REFERENCE TEST BOARD ○AN-EVAL-ICE3AR1080VJZ (infineon) Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/10) 20200816 data sheet_eco2230seo-d04v016_en.fm T R A N S F O R M E R S ECO2230SEO-D04V016 ■ SHAPE & DIMENSIOS 24.0max. 23.0max. 6 7 5 8 4 9 3 10 2 11 1 12 3.5±0.8 36.0max. 11-ø0.8 Dimensions in mm ■ RECOMMENDED BASE MATERIAL OPENING SIZE 4.0±0.1 11-ø1.3 1 12 6 7 17.5±0.1 Dimensions in mm [Top View] ■ SCHEMATICS Vin Tap Drain 6 7 NP2 NS1 NP1 NS2 5 8 4 12V2A 9 NS3 3 10 P-GND 2 11 S-GND NB Vcc 1 12 Pri. Sec. [Bottom View] Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/10) 20200816 data sheet_eco2230seo-d04v016_en.fm T R A N S F O R M E R S ECO2230SEO-D04V016 ■ WINDING SPECIFICATIONS No. 1 2 3 4 5 6 7 8 9 10 1 2 Coil NP1 NB NS1 NS2 NS3 NP2 Terminal 4-5 1-2 7 - 10 8 - 11 9 - 12 5-6 Turns 28 12 10 10 10 28 Wire UEW 0.25X2 UEW 0.25X2 UEW 0.40X2 UEW 0.40X2 UEW 0.40X2 UEW 0.25X2 Rdc(m)1 172 85.9 31.0 33.0 35.5 251 Note2 Clock wise (NP1 + NP2 =56Ts) Clock wise Clock wise Clock wise Clock wise Clock wise Rdc value is a reference. Clockwise direction is an order direction when see a transformer from the upper part. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/10) 20200816 data sheet_eco2230seo-d04v016_en.fm T R A N S F O R M E R S ECO2230SEO-D04V016 ■ ELECTRICAL CHARACTERISTICS Inductance1 NP (µH) Tolerance Leakage inductance1 NP(NB,NS all shorted) (µH)max. 250 6.8 1 2 ±10% Withstanding voltage2 Pri. - Sec. Coil - Core Insulation resistance Pri. - Sec. Coil - Core AC3.0kVrms 1min or AC 3.6kVrms 1s AC1.5kVrms 1min or AC 1.8kVrms 1s DC500V 100M min. DC500V 100M min. Measurement Condition : 100kHz, 1V Measurement Condition : Sense 1.0mA, f=50 or 60Hz ■ SAFETY DISTANCE Pri.-Sec. Coil-Core Creepage distance 4.0mm min. (CTI Ⅰ) 6.0mm min. (CTI Ⅲ) 2.0mm min. (CTI Ⅰ) 3.0mm min. (CTI Ⅲ) Air clearance 4.0mm min. 2.0mm min. ■ INDUCTANCE CHANGE VS. BIAS CHARACTERISTICS 25°C (µH) 253 251 250 248 246 243 238 221 206 184 100°C (µH) 264 263 262 260 259 255 246 209 136 89 300 250 25°C 200 Inductance (µH) Idc (A) 0 1.5 1.8 2.1 2.4 2.7 3.0 3.6 3.9 4.2 150 100°C 100 50 0 0 1 2 3 4 5 DC current (A) Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/10) 20200816 data sheet_eco2230seo-d04v016_en.fm T R A N S F O R M E R S ECO2230SEO-D04V016 ■ RELIABILITY TESTS Item Standards Sweep 1.5mm amplitude and 10-to-55-to-10Hz in 1min in X, Y, and Z directions for 2h respectively. Vibration resistance Heat resistance Cold resistance Humidity resistance Test methods Measure in normal temperature after leaving in 100±2°C for 96h. Standard of inductance, insulation resistance, withstand voltage must be satisfied. Temperature cycle Terminal strength 9.8N min. Solderability Solder covers more than 90%. Measure in normal temperature after leaving in –40±2°C for 96h. Measure in normal temperature after leaving in 60±2°C and 90 to 95(%)RH for 96h. One cycle is –25°C for 30min, normal temperature for 30min, and 85°C for 30min; measure after 10 cycles of the test have been performed. Apply 9.8N load in the direction of terminal axis for 30±5s. Any terminal must not be pulled out or chatter. Dip in solder with the temperature of 245±2°C for 3±0.5s. ■ NOTE □ Operation Range after the assembly Temperature : –25°C to +115°C (Including self temperature rise.) Humidity : 10 to 95%RH (Maximum wet-bulb temperature is 38°C, without dewing) □ Storage Range after the assembly Temperature : -25°C to +80°C Humidity : 10 to 95%RH (Maximum wet-bulb temperature is 38°C, without dewing) □ Applicable Safety Standard IEC600335-1, IEC61558-1 (Basic Insulation) Electrical Appliance and Material Safety Act /Japan (Basic Insulation) IEC62368-1 (Reinforced Insulation) *Working voltage ≦ 300Vrms, Pollution degree 2 *Product is not approved to the above standard. But construction and materials are designed in accordance with safety considerations. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (5/10) 20200816 data sheet_eco2230seo-d04v016_en.fm T R A N S F O R M E R S ECO2230SEO-D04V016 ■ INPUT / OUTPUT OVERVIEW Description Input Output Voltage Frequency Power Factor No Load Input Power Voltage Current Ripple Voltage Efficiency Symbol Vin fac PF Pnl Vout Iout Vripple Eff Min. 90 47 — 11.4 0 — — Typ. 50 / 60 0.45 12.0 2.0 — 82 / 84 Max. 264 63 — 89 12.6 2.0 100 — Unit Vac Hz mW Vdc A mV % Condition 90 to 264Vac, Pomax 100Vac / 230Vac 20MHz Bandwidth,90 to 264Vac, Pomax 100Vac / 230Vac, Pomax ■ TEMPERATURE RISE No. Component 1 2 3 4 5 6 7 8 9 10 11 12 13 Ambient CM choke BR1 VAR C3 IC D1 TR1 (wire) TR1 (core) D3 L2 C8 C9 90Vac (°C) 24.0 47.6 41.6 35.7 41.1 51.5 56.1 49.2 42.4 51.9 40.2 42.0 43.0 T (°C) — 23.6 17.6 11.7 17.1 27.5 32.1 25.2 18.4 27.9 16.2 18.0 19.0 100Vac (°C) 24.0 40.2 39.4 34.8 37.8 52.5 53.5 49.6 42.7 52.3 37.0 39.0 40.0 T (°C) — 16.2 15.4 10.8 13.8 28.5 29.5 25.6 18.7 28.3 13.0 15.0 16.0 230Vac (°C) 23.0 32.6 33.7 28.1 34.8 51.4 50.8 52.9 45.6 52.3 35.1 41.3 41.4 T (°C) — 9.6 10.7 5.1 11.8 28.4 27.8 29.9 22.6 29.3 12.1 18.3 18.4 264Vac (°C) 23.0 31.6 33.2 29.1 36.5 52.4 50.1 53.7 47.0 55.9 34.6 40.0 41.0 T (°C) — 8.6 10.2 6.1 13.5 29.4 27.1 30.7 24.0 32.9 11.6 17.0 18.0 Note: Test transformer was away from PWB surface about 3cm. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (6/10) 20200816 data sheet_eco2230seo-d04v016_en.fm T R A N S F O R M E R S ECO2230SEO-D04V016 ■ LOAD REGULATION Input voltage (Vac) 90 100 230 264 12V Output current (%) 0% 5% 10% 25% 50% 75% 100% 0% 5% 10% 25% 50% 75% 100% 0% 5% 10% 25% 50% 75% 100% 0% 5% 10% 25% 50% 75% 100% Input power (W) 0.044 1.530 2.986 7.310 14.510 21.870 29.380 0.046 1.532 2.940 7.260 14.480 21.690 29.060 0.089 1.600 3.200 7.650 14.670 21.580 28.530 0.109 1.620 3.220 7.700 14.620 21.630 28.600 (A) 0.00 0.10 0.20 0.50 1.00 1.50 2.00 0.00 0.10 0.20 0.50 1.00 1.50 2.00 0.00 0.10 0.20 0.50 1.00 1.50 2.00 0.00 0.10 0.20 0.50 1.00 1.50 2.00 Input current (A) 0.013 0.044 0.082 0.171 0.308 0.439 0.566 0.015 0.042 0.073 0.161 0.294 0.418 0.537 0.034 0.041 0.052 0.094 0.161 0.223 0.285 0.039 0.044 0.056 0.087 0.145 0.201 0.255 Power factor 0.04 0.37 0.42 0.47 0.52 0.55 0.57 0.03 0.36 0.40 0.45 0.49 0.51 0.54 0.01 0.17 0.26 0.35 0.39 0.42 0.43 0.01 0.14 0.25 0.33 0.38 0.40 0.42 12V Voltage (Vdc) 12.05 12.05 12.05 12.05 12.05 12.05 12.04 12.05 12.05 12.05 12.05 12.05 12.05 12.05 12.05 12.05 12.05 12.05 12.05 12.05 12.04 12.05 12.05 12.05 12.05 12.05 12.05 12.04 Efficiency (%) 0.0 78.7 80.7 82.4 83.0 82.6 82.0 0.0 78.7 82.0 83.0 83.2 83.3 82.9 0.0 75.3 75.3 78.7 82.1 83.7 84.4 0.0 74.4 74.8 78.2 82.4 83.5 84.2 100 95 90 Efficiency (%) 85 100Vac 80 90Vac 230Vac 75 264Vac 70 65 60 55 50 0 10 20 30 40 50 60 Output current (%) 70 80 90 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 100 (7/10) 20200816 data sheet_eco2230seo-d04v016_en.fm T R A N S F O R M E R S ECO2230SEO-D04V016 ■ REFERENCE WAVEFORM 100Vac, 12V/2A 230Vac, 12V/2A Idrain Vds Vcc Winding Output Voltage 12V/2A Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (8/10) 20200816 data sheet_eco2230seo-d04v016_en.fm T R A N S F O R M E R S ECO2230SEO-D04V016 ■ REFERENCE SCHEMATIC DIAGRAM C16 R18 NC C19 NC 3n3 2 PGND SHORT 16V 4U7 C10 CN2 25V 330uF C18 D3 V20100C D1 UF407 16V 4U7 C2 305V 220nF NTC C14 630V 1nF 16V 1000uF C20 C3 450V 120uF C1 VAR S07K460 305V 220nF 1 R16 33k 2 C8 3 1 2 SGND C11 50V 22uF SG2 NC R1 1R0 R2 C4 NC 1R0 R9 75k R14 1K1 7 2 R8 3R3 R10 1.4k VCC R5 3.01M 8 1 ICE3AR1080VJZ FBB R4 3.01M 5 3 CS Drain D2 IN485B R19 3.01M BV GND N 3 16V 4U7 C9 2 1 4 L1 30mH/0.8A L2 1uH TR1 16V 1000uF C17 CN1 250V 2A 4 F1 L ECO2230SEO -D04V016 1 BR1 D2SB60A SG1 NC R6 43.2K PGND R11 0R FBB R7 0R R17 0R C5 C6 C7 220n 470p 100n C12 1n IC2 SFH617 A3 FBB 4 ZD1 3 NC C E A K 1 2 C13 220n R13 820R R15 330K IC3 AZ431 R12 20K PGND R20 NC SGND Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (9/10) 20200816 data sheet_eco2230seo-d04v016_en.fm T R A N S F O R M E R S An attention matter on use Please read this specifications before using this product by all means. An attention matter on security I undertake use with this product, and it is paid attention enough, and please design an attention matter safely. Attention on a design When you designs a base of an electric circuit. Please use size of the hole or pad which we recommend. Magnetic flux to leak out occurs. Please confirm it about influence of magnetic flux beforehand. There is fear to cause false movement of machinery. In a design of a base of an electric circuit, Please consider the next contents. In an applied safe standard. The trans and distance with other parts The product is not quakeproof structure. Accordingly please do not add vibration and a shock to it. There is fear to lose a function. Attention on the handling Please do not use it when you let a product drop. The product produces possibility to lose a function Please pay attention to the pin which had it pointed keenly. There is danger to injure. Please avoid the next place. The place that receives a drop of water, trash, the dust, foggy influence. The place where direct rays of the sun hits. There is fear to cause false movement of machinery. Please prohibit safekeeping and use at the next place. Environment to be accompanied with gas corrosion, salt, acid, alkali. There is fear to lose a function. When you carry the product on a base of an electric circuit. Please do not use a metal tool. Because impossible power is added to a product. There is fear to lose a function. Attention I considered the next matter, and we designed a product. Safe standard and power supply voltage and circuit drive condition, drive frequency and Duty ON-TIME. By those conditions, we decided structure and the turns number. Please avoid use in designed condition outside. There are destruction of a circuit part and fear of ignition. This product considered a characteristic of a component and a self temperature rise, and it was made. We select range of humidity as use temperature already. Please avoid use by range more than this. There are the damage and fear of ignition. Please avoid use in the environment next. The environment that trash and the dust stick to a product. There is fear to cause a fire. The products listed on this specification sheet are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in this catalog, please contact us. (1) Aerospace/Aviation equipment (2)Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipmentapplications (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (10/10) 20200816 data sheet_eco2230seo-d04v016_en.fm
ECO2230SEO-D04V016 价格&库存
很抱歉,暂时无法提供与“ECO2230SEO-D04V016”相匹配的价格&库存,您可以联系我们找货
