December 2013
Transformers for Switching Power Supplies
Pin terminal type (For multiple outputs)
ECO series
ECO20XXSEO(Vertical/Horizontal types)
ECO22XXSEO(Vertical/Horizontal types)
ECO24XXSEO(Vertical/Horizontal types)
ECO24XXSLD(Vertical/Horizontal types)
(2/113)
REMINDERS FOR USING THESE PRODUCTS
g these p
q
y specifications.
p
Before using
products, be sure to request
the delivery
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
○ The storage period is less than 12 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH
or less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
○ Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
○ Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated
overheated, a short circuit
circuit, performance deterioration
deterioration, or lifespan shortening may occur
occur.
○ Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
○ Use a wrist band to discharge static electricity in your body through the grounding wire.
○ Do not expose the products to magnets or magnetic fields.
○ Do not use for a purpose outside of the contents regulated in the delivery specifications.
○ The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications
equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement
equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog
catalog, please contact us
us.
(1) Aerospace/Aviation equipment
(8) Public information-processing equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(9) Military equipment
(3) Medical equipment
(10) Electric heating apparatus, burning equipment
(4) Power-generation control equipment
(11) Disaster prevention/crime prevention equipment
(5) Atomic energy-related equipment
(12) Safety equipment
(6) Seabed equipment
(13) Other applications that are not considered general-purpose
(7) Transportation control equipment
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
transformer_dk1_eco_en
(3/113)
Switching Power Supply Transformers
ECO Series
Conformity to RoHS Directive
Halogen-free
Compatible with lead-free solders
Overview of the ECO Series
Development Concept
The ECO series is compliant with worldwide safety standards∗. It is a pin-compatible, newly developed transformer that can be downsized and thinned.
∗ Applicable as of April 2007: UL/IEC/J 60065 Ver.7 (TV, DVD, STB), UL/IEC/60950 Ver.3 (printer), UL/IEC 60335-1 Ver.4 (home appliance)
■ MATERIAL
Optimum materials and core shape have been developed. No insulation-supporting material is used, and this secures the insulating distance.
While optimizing materials, TDK has further improved its proprietary core shape to develop a new-type ECO core.
TDK has downsized the product considerably in order to securing the necessary creepage distance.
■ MANUFACTURING METHOD
Since the ECO Series supports automatic winding, the product is of a high quality and can be manufactured stably.
It is designed to support automatic winding, which enables a remarkable reduction in the loss generated to achieve a proficient in
manual winding until stable production.
In addition
addition, the characteristic variations of the winding wire and creepage tape have largely been removed
removed, stabilizing the transformer's characteristics
characteristics.
■ OPTIMIZATION DESIGN
Using design tools developed with TDK's comprehensive know-how, high-precision design has been achieved in a short period of time.
1) For optimization design and high-quality stable production, customers can use a specification request form.
If you provide the necessary information in the form, you will receive the optimization design in a short time.
2) We have prepared an individual specifications request document for the home appliance market.
3) TDK recommends design with a standard core gap (AL-value) for optimization and shorter trial and mass production lead time.
4) Plans for standard winding connection (patterns of recommended pin arrangement and winding structure) are available.
These help to speed up the design process, support automatic winding, and prevent deterioration in quality.
■ ENVIRONMENT
The ECO series is RoHS directive-compliant and halogen-free product.
· Ferrite cores, bobbins, cases, etc. are not sold individually.
· Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based
flame retardants, PBB and PBDE, have not been used, except for exempted ópìr.
· All specifications
f
are subject to change without notice.
Please read the precautions before using this catalog.
(4/113)
Replacement Parts List
We have made a new lineup of replacement parts for products with different shapes that meet our customers’ needs for smaller products.
We can also provide different transformer shapes not shown in the catalog
catalog, so feel free to contact us
us.
■ REPLACEMENT PARTS LIST
General-purpose
shaped core
Existing
*1
EGG
Maximum external
size DxWxH
(mm)max.
Reference
output
*3
power (W)
New ECO
Bobbin
*2
type
ECO2017
VI
19.5x22.5x24.0
12
ECO2020
VI
19.5x22.5x27.0
ECO2023
VI
19.5x22.5x30.0
26
VI
23.0x28.5x25.0
ECO2219
VII
23.0x24.0x25.0
VIII
VI
*1
Switching
frequency
fsw(kHz)
Bobbin terminal
Cross-sectional
center leg area Ae Pin pitch Lead
2
space F
(mm )
(mm)
(mm)
50
36.3
50
46.4
Number
of pins
Vertical type
EI22
EE25/19
EGG2017
EGG2420
EGG2420
EED2820
EER28
ECO2225
EGG2425
EGG2425
ECO2230
ECO2420
ECO2425
EER28L
EGG2430
ECO2430
EER32
EER35
EGG2625
EGG2833
3.75
15.0
12
5.0
17.5
12
4.0
17.5
12
23.0x30.0x25.0
3.75
17.5
14
23.0x28.5x31.0
5.0
17.5
12
12
25
VII
23.0x24.0x31.0
4.0
17.5
VIII
23.0x30.0x31.0
36
3.75
17.5
14
VI
23.0x28.5x36.0
5.0
17.5
12
VII
23.0x24.0x36.0
VI
24.0x28.5x26.5
VII
25 0 31 5 26 5
25.0x31.5x26.5
VI
24.0x28.5x31.5
VII
25.0x35.5x31.5
VI
24.0x28.5x36.5
VII
25.0x35.5x36.5
48
35
50
68
Under
development*4
VI
Under
*4
development
p
VI
Under
development*4
VI
ECO2017
HI
24.5x23.5x20.0
5
ECO2020
HI
27.0x23.5x20.0
14
ECO2023
HI
29.5x23.5x20.0
HI
25.0x29.0x24.0
HII
25.0x26.0x24.0
50
50
50
50
46.4
46.4
63.8
63.8
50
63.8
50
36.3
4.0
17.5
12
5.0
17.5
12
40
4.0
20 0
20.0
14
5.0
17.5
12
4.0
20.0
16
5.0
17.5
12
4.0
20.0
16
VII
VII
VII
Horizontal type
EE25/19
NEW
ECO2219
EER2820
NEW
ECO2225
ECO2230
EER28
EGG2425
ECO2425
EER28L
EGG2430
ECO2430
EER35
EGG2833
Under
development*4
HI
30.5x29.0x24.0
HII
30.5x26.0x24.0
HI
35.5x29.0x24.0
HII
35.5x26.0x24.0
HI
30.5x30.0x25.0
HII
30.5x27.0x25.0
HI
36.0x30.0x25.0
HII
36.0x27.0x25.0
18
50
46.4
30
50
46.4
42
50
46.4
41
50
63.8
59
50
63.8
3.75
20.0
12
3.75
22.5
12
3.75
25.0
12
5.0
20.0
12
4.0
20.0
12
5.0
25.0
12
4.0
25.0
12
5.0
30.0
12
4.0
30.0
12
5.0
25.0
12
4.0
25.0
12
5.0
30.0
12
4.0
30.0
12
HI
*1
Ferrite cores, bobbin are not sold separately.
*2
The bobbin is made from phenol with a flame resistance grade of 94V-2 or higher.
*3
The reference output was obtained under conditions where the frequency was 50kHz and creepage distance was 4mm. (See the relevant page for details of each
shape.) The reference output differs depending on the switching device, switching frequency, transformer temperature, conditions, etc. Use this output for reference.
*4
Scheduled to be supported from April 2010 onwards (prior to that date, it is supported by the EGG type)
f
(5/113)
Lineup of ECO Series
40.0
35.0
Height from substrate(mm)
ECO
2430
ECO
2230
ECO
2225
ECO
2023
30.0
ECO
2020
ECO
2420
ECO
ECO ECO 2219ECO
2017 2219
2225
25.0
ECO
2017
20.0
ECO
2425
ECO
2230
ECO
2425
ECO
2430
ECO ECO
2020 2023
15.0
0.0
20.0
40.0
60.0
Handling power(W)
80.0
100.0
Vertical type
Horizontal type
f
(6/113)
Composition of appellation for ECO Series
■ SCOPE
This standard applies insulation transformer for switching power supply and choke-coil for Power-factor circuit of the ECO series that Magnetics Business
Group takes part in the design, production, and sales.
■ COMPOSITION OF APPELLATION FOR ECO SERIES
○ Insulation transformer for switching power supply
ECO
1
2
3
4
5
6
7
8
9
ex) ECO2225SEO-201V018
1. Core Size
ex) 2017, 2020, 2219, 2425 etc.
2. Usage
ex) Switching : S, PFC : P
3. Core Shape
ex) Core of ECO type : EO, Core of LQD type : LD, etc.
4. Number of Bobbin sections(Nothing if 1 section)
ex) 2, 5, 9 etc.
5. Serial number at each design site
Japan : 2xx, Taiwan : Txx, Xiamen : Xxx, Malaysia : Mxx, US : Uxx, Europe :
Exx
6. Bobbin construction
Vertical type : V, Horizontal type : H, SMD type : S
7. Shielding method
Non : 0, Copper foil on the coil : 1, Wire shiled : 2, Copper foil on the core : 3
※Not include a shield winding
8. Applicable Safety regulation
No : 0, Yes : 1
9. Number of windings
ex) 2, 5, 12 etc.
f
(7/113)
Product Line-Up
■ PRODUCT LINE-UP
TDK Part No.
Core Size
Vertical type
Vin
50
100
150
200
250
300
350
Switching
frequency
fsw(kHz)
Out1
Out2
Out3
Application
400
ECO2017SEO-D01V017
75Vdc-326Vdc
12.8V/0.6A
12V/0.09A
15.2V/0.05A
Air Con(Outdoor)
ECO2017SEO-D02V016
110Vac
100KHz PWM
12V/0.62A(1.6Ap)
Blu-Ray Player
85Vac~264Vac
12V /1A typ/ 1.3A Max
Refrigerator
ECO2017SEO-D04V015
160Vac~288Vac
100KHz PWM
12V/0.3A
Refrigerator
ECO2017SEO-D05V016
169Vac~312Vac
5V/0.25A
15V/0.2A
Washing Machine
ECO2020SEO-D01V016
70Vac~265Vac
50KHz PWM
12.5V/0.8A
15V/0.1A
Air Con(Indoor)
ECO2020SEO-D03V016
85Vac-276Vac
124KHz PWM
12V/0.85A
17V/0.15A
17V/0.1
Air Con(Outdoor)
154Vac~312Vac
12V/0.5A
15/0.1A
Refrigerator
ECO2020SEO-D10V017
96Vac~276Vac
15V/0.4A
18V/0.4A
5V/0.1A
Washing Machine
ECO2219SEO-D01V018
85Vac-276Vac
12V/0.32A
8V/0.3A
8V/0.3A
Air Con(Indoor)
264Vdc-373Vdc
100KHz PWM
12.4V/0.3A
5V/0.09A
19V/0.14
Air Con(Indoor)
170Vdc-400Vdc
12V/0.54A
5V/0.11A
19V/0.02
Air Con(Outdoor)
220Vac
41KH ~
41KHz
12 3V/3 2A(5 0A )
12.3V/3.2A(5.0Ap)
Bl R R
d
Blu-Ray
Recorder
ECO2420SEO-D01V019
200Vdc-300Vdc
12V/0.8A
17V/0.17A
17V/0.02A
Air Con(Outdoor)
ECO2420SEO-D02V019
110Vac
33KHz ~
12.3V/3.3A
Blu-Ray Recorder
ECO2017SEO-D03V014
ECO2020SEO-D09V015
ECO2219SEO-D02V016
ECO2017
ECO2020
ECO2219
ECO2219SEO-D03V017
ECO2225SEO D02V0112
ECO2225SEO-D02V0112
ECO2420SEO-D03V018
ECO2225
ECO2420
169Vac~312Vac
60KHz PWM
12V/2.7A
5V/0.3A
Refrigerator
ECO2420SEO-D04V0110
214Vdc~404Vdc
12V/1.2A
14V/0.5A
7V/0.05A
Refrigerator
ECO2425SEO-D01V019
264Vdc-373Vdc
100KHz PWM
12.7V/1.18A
5V/0.14A
20V/0.07A
Air Con(Outdoor)
ECO2425SEO-D02V016
96Vac~276Vac
20V/0.2A
18V/0.5A
3.3V/0.7A
Washing Machine
170Vac~230Vac
30KHz ~
36.5V/0.9A Max
Washing Machine
169Vac~312Vac
169Vac
312Vac
65KHz PWM
22.0V/1.5Atyp/2.0Ap
15V/0.5A
7V/0.2A
Washing Machine
ECO2020SEO-D02H015
75Vdc-326Vdc
12.7V/0.6A
18.5V/0.06A
Air Con(Indoor)
ECO2020SEO-D04H015
110Vac
67KHz PWM
12V/1.5A(2.4Ap)
Blu-Ray Player
WW
80KHz ~
19.7V/0.267A(0.35Ap)
LED Lamp
ECO2020SEO-D07H016
WW
65KHz PWM
21.5V/0.465A(1.4Ap)
Printer
ECO2020SEO-D08H016
WW
65KHz PWM
30.0V/0.333A(1.0Ap)
Printer
ECO2425SEO-D03V014
ECO2425
ECO2425SEO-D04V017
ECO2425SEO
D04V017
Horizontal type
ECO2020SEO-D06H015
ECO2020
ECO2023SEO-D01H016
ECO2023
WW
100KHz PWM
12V/1.3A(2.2Ap)
Blu-Ray Player
ECO2225SEO-D01H016
ECO2225
WW
67KHz PWM
12V/1.5A(2.4Ap)
-12V/50mA(70mAp)
Blu-Ray Player
390Vdc PFC
100KHz PWM
12V/2.0A(2.75Ap)
17V/0.5A(1.74p)
Flat-TV
220Vac
67KHz PWM
5V/1A
24V/2A
Printer
100Vdc-370Vdc
12.7V/2.33A
16V/0.05A
Air Con(Indoor)
WW
67KHz PWM
5V/2.2A(4.7Ap)
12V/0.2A(1.5Ap)
Blu-Ray Player
ECO2430SEO-D01H0110
ECO2430SEO-D03H016
ECO2425SLD-D01H017
ECO2425SLD-D02H0111
ECO2430
LQD2425
f
(8/113)
General Specifications
■ OPERATING TEMPERATURE RANGE
Temperature Range
Humidity Range
Operating
-30 to +120°C[including self-heating]
Storage
-40 to +85°C
Operating
10 to 95(%)RH[Maximum wet-bulb temperature 38°C, without dewing]
Storage
■ PACKAGE QUANTITY, PRODUCT WEIGHT
Package quantity
Individual
weight
(pieces/box)
(g)
ECO2017SEO-D01V017
210
13.8
ECO2017SEO-D02V016
210
13.8
210
13.1
ECO2017SEO-D04V015
210
13.2
ECO2017SEO-D05V016
210
12.0
ECO2020SEO-D01V016
225
14.9
TDK Part No.
Core Size
Vertical type
ECO2017SEO-D03V014
ECO2017
180
16.9
225
15.2
ECO2020SEO-D10V017
225
15.1
ECO2219SEO-D01V018
210
18.9
210
19.8
ECO2020SEO-D03V016
ECO2020SEO-D09V015
ECO2219SEO-D02V016
ECO2020
ECO2219
210
18.7
150
32.0
150
28 2
28.2
150
26.6
120
26.5
ECO2420SEO-D04V0110
120
26.5
ECO2425SEO-D01V019
135
34.8
ECO2425SEO-D02V016
150
33.5
150
31.7
135
33.2
ECO2020SEO-D02H015
200
14.7
ECO2020SEO-D04H015
200
16.2
205
14.6
ECO2020SEO-D07H016
300
15.8
ECO2020SEO-D08H016
300
15.6
ECO2219SEO-D03V017
ECO2225SEO-D02V0112
ECO2225
ECO2420SEO D01V019
ECO2420SEO-D01V019
ECO2420SEO-D02V019
ECO2420SEO-D03V018
ECO2425SEO-D03V014
ECO2420
ECO2425
ECO2425SEO-D04V017
Horizontal type
ECO2020SEO-D06H015
ECO2020
ECO2023SEO-D01H016
ECO2023
180
17.3
ECO2225SEO-D01H016
ECO2225
120
22.7
90
35.4
90
37.8
192
23.9
192
22.3
ECO2430SEO-D01H0110
ECO2430SEO-D03H016
ECO2425SLD-D01H017
ECO2425SLD-D02H0111
ECO2430
LQD2425
f
(9/113)
ECO20 Series for Multiple Outputs (Vertical Type)
■ SHAPES AND DIMENSIONS(BOBBIN TYPE: VⅠ)
■ RECOMMENDED BASE MATERIAL OPENING SIZE
Dimensions in mm
Default Tolerance : ±0.1
■ ITEMS APPLICABLE
Series
Bobbin Type
Part No.
ECO2017SEO-D01V017
ECO2017SEO-D02V016
ECO2017
ECO2017SEO-D03V014
ECO2017SEO-D04V015
VI
ECO2017SEO-D05V016
ECO2017SEO
D05V016
ECO2020SEO-D01V016
ECO2020
ECO2020SEO-D03V016
ECO2020SEO-D09V015
ECO2020SEO-D10V017
· Compatible ferrite materials for this product are the PC47 family.
f
(10/113)
SPECIFICATIONS
/ ECO2017SEO-D01V017
■ SCHEMATICS
⑥ NP3
⑤
Drain
③ NP1
② NP2
GND
DC5.7V/0.2A(F.B.)
DC12V/0.09A
DC15.2V/0.05A
GND
DC12.8V/0.6A
NS1 ⑦
NS2 ⑧
NS3 ⑨
GND
NS4
Vin
⑩
⑪
SEC
SEC.
PRI
PRI.
● Dot mark:Polarity.
[BOTTOM VIEW]
■ SAFETY STANDARDS
SAFETY STANDARDS
Over Surface & Air Spacings
PRI. - SEC.
2.5mm MIN.
PRI. - CORE
1.3mm MIN.
SEC. - CORE
1.3mm MIN.
■ WINDING SPECIFICATIONS
No.
Order
1
1
N P1
coil
terminal
2
2
N P3
6
3
3
N S4
12
4
4
N S3
10
5
5
N S2
9
6
6
N S1
7
7
N P2
3
turns
wire
note
2
30
UEW
0.16
NP1+NP2=91ts
5
11
UEW
0.23
×2
11
11
UEW
0.23
×2
9
2
UEW
0.26
8
5
UEW
0.26
8
7
6
UEW
0.26
2
1
61
UEW
0.16
f
(11/113)
SPECIFICATIONS
■ ELECTRICAL CHARACTERISTICS
T t Conditions
C diti
(Test
(Temperature)
(Relative Humidity)
Parameter
4.1
25±10℃
25~75%RH
Test
Terminal
3-1
Specification
Conditions
1.49mH ± 10%
10 kHz 1Vrms
Inductance
42
4.2
Leakage
Inductance
4.3
DC. Resistance
4.4
Insulation
Resistance
4.5
Withstanding
Voltage
46
4.6
3-1
(6,5,SEC.
short)
2-1
3-2
6-5
8-7
9-8
10 - 9
12 - 11
PRI.-SEC.
PRI.,SEC.
-CORE
PRI.-SEC.
Polarity &
Turns Ratio
X-X / 3 - 1
±15%
±20%
±30%
±30%
±30%
±30%
±30%
MIN.
Milli ohm meter
ADEX : AX-114N
or Equivalent
DC 500V
PRI.-CORE
SEC.-CORE
3-1
AC 1.0kVrms 1min
Sense:2mA
Without Breakdown
2-1
6-5
10 - 9
9-8
8-7
12 - 11
Meg Ohm Meter
Toa : SM-5E
or Equivalent
AC 1.5kVrms 1min
Without Breakdown
Impulse Test
4.7
LCR Meter
Agilent : 4263B
or Equivalent
35 0 uH MAX
35.0
2.238Ω
0.744Ω
74.5mΩ
79.3mΩ
65.3mΩ
30.1mΩ
81.1mΩ
100 MΩ
Test Instruments
STD(0.6807)±2.0%
STD(0.1178)±5.5%
STD(0.0214)±15%
STD(0.0537)±10%
STD(0.0660)±10%
STD(0.1189)±5.5%
Pulse
P
l 600V
600Vo-p
1s
Puncture Tester
Kikusui : TOS8650
or Equivalent
I
Impulse
l T
Tester
t
ECG : DWS-05
or Equivalent
f=10kHz
Ratio Meter
Ryowa : TRM-101A
or Equivalent
f
(12/113)
SPECIFICATIONS
■ MATERIAL LIST AND INSULATING CONSTRUCTION
ITEM & MATERIAL
MIN.THICKNESS
MIN
THICKNESS
OF LAYER
① CORE
Ferrite 20.9mm x17.6mm x7.7mm
② BOBBIN
Phenol Resin
PM-9820
1318 or
③ INSULATION TAPE
Polyester
1350F
Color : YELLOW
④ FIXING TAPE FOR WIRE 44 or 44D or
(Barrier Tape)
44-18MIL or
Polyester
673F or
673A
⑤ WINDING WIRE
Polyurethane Enameled Copper Wire
0.16 mm DIAx1 :NP1,NP2
0.23 mm DIAx2 :NP3
⑥ WINDING WIRE
0.26 mm DIAx1 :NS1,NS2,NS3
0.23 mm DIAx2 :NS4
UL T
T.II
MANUFACTURER
UL FILE
NO.
TDK Corporation
150 SUMITOMO BAKELITE CO.,LTD.
94V-0
130 3M COMPANY
ELECTRICAL MARKETS DIV (EMD)
0.65 mm
MIN.
0.05 mm
130
130
3M COMPANY
TERAOKA SEISAKUSHO CO.,LTD.
E17385
E17385
E56086
E196072
PROSPERITY ELECTRIC
WIRE & CABLE CO.
XIAMEN HUNG'S
ENTERPRISE CO.,LTD.
HANGZHOU WEIFENG
ELECTRONIC CO
CO.,LTD.
LTD
E219154
E229341
SHENZHEN FUJI FINE FACTORY
⑦ ADHESIVE
Acrylic , Urethane or Epoxy
⑧ TERMINAL PIN
E41429
E303260
Optional
Optional
Copper Clad Steel WireΦ0.8(Soldered)
Under Coating(Copper)25% Weight Ratio.
(Ref)Surface Plating(Sn100%)3μm or More.
⑨ SOLDER
(For junction of a wire and aterminal)
Lead-Free Sn-Ag-Cu
⑩ ADHESIVE
Polyestel, Urethane or Epoxy
Optional
Optional
p Min. Thickness shows the total value. ((Tape
p Base and Adhesive))
※ 1. Tape
※ 2. Insulation Tape shall be able to withstand for 1 minute of 3000 Volts (r.m.s) Potential with 2 layers.
☆BOBBIN UL94:94V-0 ,CTI(IEC112):175~250V (UL Level 3)
③→
④→
LAYERS OF INSULATION TAPE
1.3mm MIN.
NP2
NS1 NS2 NS3
NS4
NP3
NP1
2.5mm MIN.
⑩
⑨
①
Insulation
No. Coil
②
⑦
0 Inner Layer
1 NP1
2 NP3
3 NS4
2Ts
2Ts
4 NS3
5 NS2
2Ts
6 NS1
2Ts
7 NP2
2Ts
⑧
f
(13/113)
SPECIFICATIONS
/ ECO2017SEO-D02V016
■ SCHEMATICS
Dot Mark : Polarity
Vcc
⑥
NPB
⑤
NS12-3
NS12-2
④
IC:FSL116HR
NS12-1
③
NP1
②
Vin=AC80~144V→
fsw=90-110kHz
NS12-5,6
NP2
①
PRI.
⑦
GND.
⑧
⑨
⑩
⑪
⑫
SEC.
+12V : 0.62A (Peak 1.6A)
Po=7.44W (19.2W Peak)
[BOTTOM VIEW]
Star Mark : Print pattern is connected here. (Contact with solder is acceptable.)
■ SAFETY STANDARDS
SAFETY STANDARDS
*UL60065-Ed.7, *IEC60065-Ed.7
Between Pri. and Sec.
Between Pri. and Core
Between Sec. and Core
Inside of Coil
4.8mm MIN.
2.4mm MIN.
2.4mm MIN.
Outside of Coil
8.0mm MIN.
4.0mm MIN.
4.0mm MIN.
Coil
巻組名
N S12
S12-1
1
Terminal
端子番号
9 - 11
Turns
巻数
13
Wire
線材
UEW 0.25
0 25
1
Order
順序
1
2
2
N P1
2
- 3
42
UEW 0.23
3
3
N S12-2
8
- 10
13
UEW 0.25
4
4
N P2
1
- 2
29
UEW 0.23
5
5
N S12-3
7
- 12
13
UEW 0.25
6
6
N PB
5
- 6
17
UEW 0.20
No.
Note
備考
NP1+NP2=71Ts.
f
(14/113)
SPECIFICATIONS
Temperature
T
t
Relative Humidity
T t Conditions
Test
C diti
4.1
4.2
4.3
Parameter
Inductance
电感值 (L値 )
Leakage
Inductance
Test Terminal
1-3
Specification
712 μH ±
25±10℃
25~75%RH
Conditions
10%.
10 kHz 1Vrms
1-3
泄漏电感值 (Le値 )
DC. Resistance
15.0 μH
MAX.
100 kHz 1Vrms
1.12 Ω
20%.
Milli ohm meter
5-6
0.462 Ω ±
0.149 Ω ±
20%.
ADEX : AX-114
or Equivalent
9 - 11
8 - 10
PRI.-SEC.
Resistance
PRI.,SEC.
0.184 Ω ±
20%.
20%.
0.217 Ω ±
20%.
100 MΩ MIN.
或相等儀器
DC 500V
4.6
Impulse Test
PRI.-SEC.
Without Breakdown
AC 3.0kVrms 1min
or AC 3.6kVrms 1s
或相等儀器
Puncture Tester
Kikusui : TOS8650
PRI.-CORE
无异常
Sense:1mA
AC 1.5kVrms 1min
or AC 1.8kVrms 1s
或相等儀器
SEC.-CORE
PRI.-PRI.
SEC.-SEC.
1-3
f=50or60Hz
Without Breakdown
层间耐压
Polarity &
Turns Ratio
or AC 0.6kVrms 1s
Pulse 0.8kVo-p
极性及卷数比
X-X / 1 - 3
无异常
5-6
9 - 11
(0.2402) ±
(0.1744) ±
4.7%.
6.1%.
8 - 10
7 - 12
(0.1822) ±
(0.1835) ±
6.1%.
6.1%.
1-2
(0.4085) ±
1.7%.
or Equivalent
AC 0.5kVrms 1min
3--5 Pulse
4.7
Meg Ohm Meter
Toa : SM-5E
or Equivalent
-CORE
耐电压
或相等儀器
1-3
Insulation
絕緣阻抗
Withstanding
Voltage
LCR Meter
(7~12 short)
7 - 12
4.5
Test Instruments
Agilent : 4263B
or Equivalent
直流阻抗
4.4
f=10kHz
Impulse Tester
ECG : DWS-05
or Equivalent
或相等儀器
Ratio Meter
Ryowa : TRM-101A
or Equivalent
或相等儀器
f
(15/113)
SPECIFICATIONS
ITEM & MATERIAL
MIN THICKNESS
MIN.THICKNESS
OF 1 LAY ER
① CORE
Ferrite
20.9mmx17.6mmx7.7mm
PM-9820
0.65 mm
② BOBBIN
Phenol Resin
T375J
1318-1 or
0.05 mm
③ INSULATION TAPE
Polyester
1350F-1
CT with suffixes
Material group ⅡMIN.
(400V
