ECO2425SEO-D05V014
ECO2425SEO-D05V014
    TDK(东电化)
    TRANSFORMERS FOR AC/DC FLYBACK C
ECO2425SEO-D05V014 数据手册
T R A N S F O R M E R S Transformers for switching power supplies Pin terminal type Pb RoHS REACH SVHC-Free Lead Free ECO2425SEO-D05V014 ■ FEATURES ○Downsized yet compliant with worldwide safety standards. ○Supports automatic winding. ○Considerably reduced characteristic variations. ■ APPLICATION ○Isolation type Single-output power supplies ○Input : 90 to 264Vac ○1Output : 24V/1.0A ○Circuit type : PWM flyback ○frequency : 100kHz ■ REFERENCE TEST BOARD ○TEST BOARD ECO30W-24 (TDK) Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/10) 20200824 data sheet_eco2425seo-d05v014_en.fm T R A N S F O R M E R S ECO2425SEO-D05V014 ■ SHAPE & DIMENSIOS 28.5max. 25.0max. 6 7 5 8 4 9 3 10 2 11 1 12 3.5±0.8 31.5max. 9-ø0.8 Dimensions in mm ■ RECOMMENDED BASE MATERIAL OPENING SIZE 5.0±0.1 9-ø1.3 1 12 6 7 17.5±0.1 Dimensions in mm [Top View] ■ SCHEMATICS Vin 6 7 NP2 Tap 5 8 24V/1A NS1 NP1 P-GND 4 9 NB Vcc 3 10 Drain 2 11 S-GND 1 12 Pri. Sec. [Bottom View] Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/10) 20200824 data sheet_eco2425seo-d05v014_en.fm T R A N S F O R M E R S ECO2425SEO-D05V014 ■ WINDING SPECIFICATIONS No. 1 2 3 4 5 6 7 8 9 10 1 2 Coil NP1 NS1 NP2 NB Terminal 2-5 8 - 11 5-6 3-4 Turns 20 20 37 13 Wire UEW 0.37 UEW 0.32 x 2 UEW 0.37 UEW 0.23 Rdc(m)1 133 95.7 305 309 Note2 Clock wise (NP1 + NP2 =57Ts) Clock wise Clock wise Clock wise Rdc value is a reference. Clockwise direction is an order direction when see a transformer from the upper part. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/10) 20200824 data sheet_eco2425seo-d05v014_en.fm T R A N S F O R M E R S ECO2425SEO-D05V014 ■ ELECTRICAL CHARACTERISTICS Inductance1 NP (µH) Tolerance Leakage inductance1 NP(NB,NS all shorted) (µH)max. 640 7.6 1 2 ±10% Withstanding voltage2 Pri. - Sec. Coil - Core Insulation resistance Pri. - Sec. Coil - Core AC3.0kVrms 1min or AC 3.6kVrms 1s AC1.5kVrms 1min or AC 1.8kVrms 1s DC500V 100M min. DC500V 100M min. Measurement Condition : 100kHz, 1V Measurement Condition : Sense 1.0mA, f=50 or 60Hz ■ SAFETY DISTANCE Pri.-Sec. Coil-Core Creepage distance 4.0mm min. (CTI Ⅰ) 6.0mm min. (CTI Ⅲ) 2.0mm min. (CTI Ⅰ) 3.0mm min. (CTI Ⅲ) Air clearance 4.0mm min. 2.0mm min. ■ INDUCTANCE CHANGE VS. BIAS CHARACTERISTICS 25°C (µH) 650 626 619 610 598 584 566 543 513 477 100°C (µH) 692 665 657 645 629 603 561 506 447 356 800 700 600 25°C Inductance (µH) Idc (A) 0 1.3 1.4 1.5 1.6 1.7 1.8 1.9 2.0 2.1 500 100°C 400 300 200 100 00 0.5 1 1.5 2 2.5 DC current (A) Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/10) 20200824 data sheet_eco2425seo-d05v014_en.fm T R A N S F O R M E R S ECO2425SEO-D05V014 ■ RELIABILITY TESTS Item Standards Sweep 1.5mm amplitude and 10-to-55-to-10Hz in 1min in X, Y, and Z directions for 2h respectively. Vibration resistance Heat resistance Cold resistance Humidity resistance Test methods Measure in normal temperature after leaving in 100±2°C for 96h. Standard of inductance, insulation resistance, withstand voltage must be satisfied. Temperature cycle Terminal strength 9.8N min. Solderability Solder covers more than 90%. Measure in normal temperature after leaving in –40±2°C for 96h. Measure in normal temperature after leaving in 60±2°C and 90 to 95(%)RH for 96h. One cycle is –25°C for 30min, normal temperature for 30min, and 85°C for 30min; measure after 10 cycles of the test have been performed. Apply 9.8N load in the direction of terminal axis for 30±5s. Any terminal must not be pulled out or chatter. Dip in solder with the temperature of 245±2°C for 3±0.5s. ■ NOTE □ Operation Range after the assembly Temperature : –25°C to +115°C (Including self temperature rise.) Humidity : 10 to 95%RH (Maximum wet-bulb temperature is 38°C, without dewing) □ Storage Range after the assembly Temperature : -25°C to +80°C Humidity : 10 to 95%RH (Maximum wet-bulb temperature is 38°C, without dewing) □ Applicable Safety Standard IEC600335-1, IEC61558-1 (Basic Insulation) Electrical Appliance and Material Safety Act /Japan (Basic Insulation) IEC62368-1 (Reinforced Insulation) *Working voltage ≦ 300Vrms, Pollution degree 2 *Product is not approved to the above standard. But construction and materials are designed in accordance with safety considerations. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (5/10) 20200824 data sheet_eco2425seo-d05v014_en.fm T R A N S F O R M E R S ECO2425SEO-D05V014 ■ INPUT / OUTPUT OVERVIEW Description Input Output Voltage Frequency Power Factor No Load Input Power Voltage Current Ripple Voltage Efficiency Symbol Vin fac PF Pnl Vout Iout Vripple Eff Min. 90 47 — — 22.8 0 — — Typ. 50 / 60 0.54 — 24.0 1.0 — 85 / 87 Max. 264 63 — 172 25.2 1.0 150 — Unit Vac Hz mW Vdc A mV % Condition 90 to 264Vac, Pomax 100Vac / 230Vac 20MHz Bandwidth,90 to 264Vac, Pomax 100Vac / 230Vac, Pomax ■ TEMPERATURE RISE No. Component 1 2 3 4 5 6 7 8 9 10 Ambient L1 D1 R1 C5 IC T1 (wire) T1 (core) D51 C51 90Vac (°C) 25.0 39.7 34.6 54.8 32.6 41.0 43.1 40.8 38.0 37.7 T (°C) — 14.7 9.6 29.8 7.6 16.0 18.1 15.8 13.0 12.7 100Vac (°C) 25.0 38.3 34.0 51.8 33.1 38.2 43.2 41.6 35.0 37.1 T (°C) — 13.3 9.0 26.8 8.1 13.2 18.2 16.6 10.0 12.1 230Vac (°C) 25.0 33.4 31.8 41.3 34.1 40.2 46.3 45.8 36.0 35.6 T (°C) — 8.4 6.8 16.3 9.1 15.2 21.3 20.8 11.0 10.6 264Vac (°C) 25.0 33.2 31.5 40.3 32.8 40.7 46.6 45.8 33.0 35.1 T (°C) — 8.2 6.5 15.3 7.8 15.7 21.6 20.8 8.0 10.1 Note: Test transformer was away from PWB surface about 3cm. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (6/10) 20200824 data sheet_eco2425seo-d05v014_en.fm T R A N S F O R M E R S ECO2425SEO-D05V014 ■ LOAD REGULATION Input voltage (Vac) 90 100 230 264 24V Output current (%) 0% 5% 10% 25% 50% 75% 100% 0% 5% 10% 25% 50% 75% 100% 0% 5% 10% 25% 50% 75% 100% 0% 5% 10% 25% 50% 75% 100% Input power (W) 0.110 1.590 2.990 7.023 13.960 21.090 28.280 0.114 1.579 2.993 6.980 13.930 20.930 27.960 0.172 1.726 3.273 7.251 14.160 20.890 27.600 0.196 1.859 3.490 7.398 14.256 21.050 27.830 (A) 0.00 0.05 0.10 0.25 0.50 0.75 1.00 0.00 0.05 0.10 0.25 0.50 0.75 1.00 0.00 0.05 0.10 0.25 0.50 0.75 1.00 0.00 0.05 0.10 0.25 0.50 0.75 1.00 Input current (A) 0.008 0.041 0.071 0.149 0.273 0.397 0.513 0.008 0.038 0.066 0.137 0.253 0.368 0.479 0.016 0.028 0.042 0.080 0.143 0.201 0.253 0.018 0.029 0.041 0.073 0.128 0.181 0.223 Power factor 0.16 0.43 0.47 0.53 0.57 0.59 0.62 0.14 0.41 0.45 0.51 0.55 0.57 0.59 0.05 0.27 0.33 0.40 0.43 0.46 0.48 0.04 0.24 0.31 0.38 0.42 0.44 0.45 24V Voltage (Vdc) 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 23.89 Efficiency (%) 0.0 75.1 79.9 85.0 85.6 85.0 84.5 0.0 75.6 79.8 85.6 85.8 85.6 85.4 0.0 69.2 73.0 82.4 84.4 85.8 86.6 0.0 64.3 68.5 80.7 83.8 85.1 85.8 100 95 90 Efficiency (%) 85 80 100Vac 90Vac 75 230Vac 70 65 264Vac 60 55 50 0 10 20 30 40 50 60 Output current (%) 70 80 90 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 100 (7/10) 20200824 data sheet_eco2425seo-d05v014_en.fm T R A N S F O R M E R S ECO2425SEO-D05V014 ■ REFERENCE WAVEFORM 100Vac, 24V/1A 230Vac, 24V/1A Idrain Vds Vcc Winding Output Voltage 24V/1A Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (8/10) 20200824 data sheet_eco2425seo-d05v014_en.fm T R A N S F O R M E R S ECO2425SEO-D05V014 ■ REFERENCE SCHEMATIC DIAGRAM 250V/3.15A 1 F1 R1 3.9mH/1A 10ohm R2 1M 0.5W J2 1 1 L1 4 1000pF Y1 C2 ECO2425SEO-D05V014 3A/600V T1 2 3 R3 200K 0.25W C3 2200pF Y1 C4 0.1uF50V 1 10 0.25W 470uF 35V 470uF 35V 2.2uF 50V C52 + C53 + C54 100pF50V R57 120K 3 1K 0.1W R58 9.1K 0.125W 3 R6 n.c. C58 0.22uF50V R56 4 2 C10 CS 1 0.033uF 50V C8 FBB BBA FG K 22K 0.1W 2 IC51 5.1 0.5W 3 uPC1093TA R59 15K 0.125W D3 1A200V 33uF50V A 20V1W + C9 5.1 0.5W 330pF 50V 4 6 1 PC817X2N R7 FG R55 0.125W 5 Drain 7 VCC GND 8 IC2A 4.7 0.25W J1 1 0.047uF630V C57 C7 R8 1 C56 R54 2.2K 0.1W IC1 J1 1 R52 R53 100pF630V PC817X2N D4 C55 1 10K 10K 0.25W 0.25W D2 ICE3A2065ELJ IC2B 2.2uF 50V C51 R4 200K 0.25W + C5 220pF630V C6 400V120uF 1A600V J2 1 10A300V D51 R51 C1 1000pF Y1 1 D1 0.22uF X2 1 J1 1 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (9/10) 20200824 data sheet_eco2425seo-d05v014_en.fm T R A N S F O R M E R S An attention matter on use Please read this specifications before using this product by all means. An attention matter on security I undertake use with this product, and it is paid attention enough, and please design an attention matter safely. Attention on a design When you designs a base of an electric circuit. Please use size of the hole or pad which we recommend. Magnetic flux to leak out occurs. Please confirm it about influence of magnetic flux beforehand. There is fear to cause false movement of machinery. In a design of a base of an electric circuit, Please consider the next contents. In an applied safe standard. The trans and distance with other parts The product is not quakeproof structure. Accordingly please do not add vibration and a shock to it. There is fear to lose a function. Attention on the handling Please do not use it when you let a product drop. The product produces possibility to lose a function Please pay attention to the pin which had it pointed keenly. There is danger to injure. Please avoid the next place. The place that receives a drop of water, trash, the dust, foggy influence. The place where direct rays of the sun hits. There is fear to cause false movement of machinery. Please prohibit safekeeping and use at the next place. Environment to be accompanied with gas corrosion, salt, acid, alkali. There is fear to lose a function. When you carry the product on a base of an electric circuit. Please do not use a metal tool. Because impossible power is added to a product. There is fear to lose a function. Attention I considered the next matter, and we designed a product. Safe standard and power supply voltage and circuit drive condition, drive frequency and Duty ON-TIME. By those conditions, we decided structure and the turns number. Please avoid use in designed condition outside. There are destruction of a circuit part and fear of ignition. This product considered a characteristic of a component and a self temperature rise, and it was made. We select range of humidity as use temperature already. Please avoid use by range more than this. There are the damage and fear of ignition. Please avoid use in the environment next. The environment that trash and the dust stick to a product. There is fear to cause a fire. The products listed on this specification sheet are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in this catalog, please contact us. (1) Aerospace/Aviation equipment (2)Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipmentapplications (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (10/10) 20200824 data sheet_eco2425seo-d05v014_en.fm
ECO2425SEO-D05V014 价格&库存
很抱歉,暂时无法提供与“ECO2425SEO-D05V014”相匹配的价格&库存,您可以联系我们找货
ECO2425SEO-D05V014
  • 40+63.0415940+8.14449
