EDLC262520-501-2F-40
    TDK(东电化)
    SMD-3P,26x20mm
    0.5F 4.2V
EDLC262520-501-2F-40 数据手册
C A P A C I T O R S June 2021 Electric Double Layer Capacitor (EDLC/Super Capacitor) EDLC262520 series EDLC262520-501-2F-40 500mF (2/4) C A P A C I T O R S Product compatible with RoHS directive Electric Double Layer Capacitor (EDLC/Super Capacitor) Overview of EDLC262520 series FEATURES High capacitance and low impedance. Thin small size. Long-life. Clean materials. Safety. APPLICATION Battery assistance Storage element of energy harvesting Strong LED flash Backup application for instantaneous power failures PART NUMBER CONSTRUCTION EDLC 26 25 20 Series name Thickness dimensions t Width dimensions W Vertical dimensions L (Not including the lead length) - 501 Data capacity (mF) 501 L + - 2F Number of series and voltage - 40 Impedance 500 BAL ###### X X X X X X W t RoHS Directive Compliant Product: See the following for more details. https://product.tdk.com/info/en/environment/rohs/index.html Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210616 / edlc_edlc262520_en.fm (3/4) C A P A C I T O R S EDLC262520 series PRODUCT INDICATION + terminal – terminal + BAL Polarity Lot No. Solid recognition No. ###### X X X X X X Two-dimensional code SHAPE & DIMENSIONS 25.5±0.5 20±0.5 6.25 + 3.0 BAL ###### X X X X X X 26max. 2.7max. Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210616 / edlc_edlc262520_en.fm (4/4) C A P A C I T O R S EDLC262520 series ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLES Part No. Nominal capacitance EDLC262520-501-2F-40 (mF)typ. 500 Nominal Impedance [AC 1kHz] (m)typ. 35 Operating voltage continuous (V) 4.2 peak (V) 5.5 200 500 180 450 160 400 Imp. rate vs Imp.@25°C (%) Cap. rate vs Cap.@25°C (%) EXAMPLE OF THERMAL CHARACTERISTICS 140 120 100 80 60 40 20 0 –40 350 300 250 200 150 100 50 –20 0 20 40 Temperature (°C) 60 80 100 0 –40 –20 0 20 40 Temperature (°C) 60 80 100 ・The graph of THERMAL CHARACTERISTICS mentioned above shows the typical behavior of the product, and does not show the guarantee values. ・It is a value for standard temperature 25°C. TEMPERATURE RANGE Part No. EDLC262520-501-2F-40 Temperature range Operating temperature (°C) –40 to +70°C Storage temperature (°C) –40 to +85°C Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20210616 / edlc_edlc262520_en.fm
EDLC262520-501-2F-40 价格&库存
很抱歉,暂时无法提供与“EDLC262520-501-2F-40”相匹配的价格&库存,您可以联系我们找货
