S E N S O R S
December 2023
Surface Potential Sensors
EFS series
(2/5)
S E N S O R S
Product compatible with RoHS directive
Overview of the EFS series
FEATURES
A new feedback surface voltage sensor that supports the improved image quality color copiers and next generation color printers with a
reliability of ±0.05V or below. This voltage sensor is constructed using TDK’s unique, high precision, highly stable detection circuit which
feeds the detected photosensitive drum surface potential back to the electrical field line control chopper and probe shield cover. While
completely eliminating the effects of the causes of disturbances in the electric field intervening between the photosensitive drum and the
detection electrode, it shows extremely stable and precise output performance where the adverse effects of temperature fluctuations and
detection distance (probe positioning) are greatly reduced.
A unique optimized structure and circuit design have achieved the world’s smallest class of miniaturization and weight reduction, as well
as greater performance in response to market needs.
Extremely stable output performance is maintained for long periods of time through accurate driving made possible with the unique
structural design and superelastic alloy chopper consisting of the piezoelectric element with optimized conversion efficiency.
Quick responsiveness to high-speed and high image quality needs.
APPLICATION
Surface potential measurements in photosensitive drums for copiers and paper for PPCs as well as applications for laser beam printers
and various equipment.
PRODUCT LINEUP
ASSEMBLY
Power supply
voltage
Power consumption
current
Detector voltage
range
Vcc
(V)
24±10%
24±10%
Idc
(mA)
150max.
150max.
Ve
(V)
–1000 to 0
0 to +1000
Part No.
EFS22D67-03
EFS31D57-03
Detector voltage
guaranteed
accuracy range
(V)
–900 to 0
0 to +900
Output voltage
V0
(V)
0 to 4.5±0.05
0 to 4.5±0.05
Response time Detector
distance
(ms)
20max.
20max.
(mm)
2.0 to 3.0
2.0 to 3.0
Outputs –1/200 of Ve.
Outputs 1/200 of Ve.
RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
20231211 / sensor_surface-potential_efs_en.fm
(3/5)
S E N S O R S
Assembly・Minus Electric potential detection
EFS22D67-03
SHAPE & DIMENSIONS
60 0.5
Probe
Lead wire
Insulating tube
CN2
Surface mounted with parts
40 0.2
Pin No.
4
3
2
1
CN1
6.0
5
50 0.2
50 0.5
6 0.2
5
CN1
S4B-PH-KLC-H(LF)(SN) JST
Connector (I/O pins)
670 15
2
1 : GND(Vcc)
2 : GND(SIGNAL)
3 : SIGNAL OUT
4 : Vcc
3.5 max.
50 1
Dimensions in mm
※CN1 connector is reverse type.
Please be careful when making connections.
1
Parts domain
18 max.
6 0.2
4- 4
ELECTRICAL CHARACTERISTICS
Power supply
voltage
Power consumption
current
Detector voltage
range
Vcc
(V)
24±10%
Idc
(mA)
150max.
Ve
(V)
–1000 to 0
Part No.
EFS22D67-03
Detector voltage
guaranteed
accuracy range
Output voltage
V0
(V)
0 to 4.5±0.05
(V)
–900 to 0
distance
(ms)
20max.
(mm)
2.0 to 3.0
OUTPUT VOLTAGE VS. DETECTOR VOLTAGE
MEASURING CIRCUIT
CHARACTERISTICS (TYPICAL)
High voltage
DC power supply
Electrode
5.0
Probe
Pin No.
1
2
3
4
Fixed block
CN1
Output voltage(V)
Detector distance: 2.5mm
Fixed substrate
4.0
10kΩ
3.0
Output
Vcc Edc 24V
2.0
A
10kΩ
Multi-meter
or Oscilloscope
DC power supply
1.0
0.0
-400 -600 -800
Detector voltage(V)
-1000
(4/5)
S E N S O R S
Assembly・Plus Electric potential detection
EFS31D57-03
SHAPE & DIMENSIONS
70 0.5
5
5
60 0.2
Probe
Lead wire
Insulating tube
CN2
50 0.2
6.0
60 0.5
6 0.2
CN1
575 15
2
CN1
DF1BZ-4P-2.5DSA HRS
3.5 max.
50 1
1 : Vcc
2 : SIGNAL OUT
3 : GND(SIGNAL)
4 : GND( Vcc)
1
Parts domain
18 max.
6 0.2
4- 4
Dimensions in mm
Power supply
voltage
Power consumption
current
Detector voltage
range
Vcc
(V)
24±10%
Idc
(mA)
150max.
Ve
(V)
0 to +1000
Part No.
EFS31D57-03
Detector voltage
guaranteed
accuracy range
Output voltage
V0
(V)
0 to 4.5±0.05
(V)
0 to +900
distance
(ms)
20max.
(mm)
2.0 to 3.0
MEASURING CIRCUIT
High voltage
DC power supply
Electrode
5.0
Probe
Pin No.
4
3
2
1
Fixed block
CN1
Output voltage(V)
Fixed substrate
4.0
10kΩ
3.0
Output
Vcc Edc 24V
2.0
A
10kΩ
Multi-meter
or Oscilloscope
DC power supply
1.0
0.0
400
600
800
Detector voltage(V)
1000
(5/5)
S E N S O R S
EFS series
Handling Precautions
Please request a delivery specification form containing more detailed information on characteristics and specifications so as to ensure correct and
safe use of the products.
[Storage Environment]
Check the standards concerning the storage conditions described in the delivery specifications of the products, and store them in accordance with
the standards.
[Usage Environment/Operating Conditions]
As for usage environment conditions and operating conditions of the products, check the standards concerning the usage environment conditions
and operating conditions described in the delivery specifications, and use the products in accordance with the standards.
[Handling]
The voltage in the circuit board and probe is high during operation. Take sufficient care to avoid electrical shock.
Do not change the settings of the variable resistance mounted on the circuit board.
Do not apply excessive mechanical shock such as dropping to the products.
The circuit board and probe are adjusted at a 1:1 ratio. Do not change the configuration that it comes in.
Other Requests/Notices
We do not assume any responsibility for any damage caused by the use of our products exceeding the scope or conditions defined in the delivery
specifications.
Specifications of the products in this catalog are subject to change without notice due to improvements or other reasons. In addition, supply of the
products may be cancelled without notice.
很抱歉,暂时无法提供与“EFS31D57-03”相匹配的价格&库存,您可以联系我们找货
