EV1412-0600-A
EV1412-0600-A
    TDK(东电化)
    FS1412 µPOL™ DC/DC 转换器 1,非隔离 输出评估板
EV1412-0600-A 数据手册
EV1412-0600-A EV1412-0600-A EVALUATION BOARD USER GUIDE Page 1 Rev 1.0, Jan 4, 2022 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright © 2021–22 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. EV1412-0600-A Introduction This user guide describes the evaluation board provided for the FS1412 µPOL™ product. The board generates an output voltage (VOUT) of 1V for loads of 0–12A from an input voltage (PVIN) of 12V. Specifications        Input voltage (PVIN) = +12V Output voltage (VOUT) = +1V Output load (IO) = 0–12A Switching frequency (FSW) = 1.0MHz Output capacitance (CO) = 4x47µF (MLCC) Input capacitance (CIN) = 3x22µF (MLCC) Dimensions (width x length x thickness) = 61mm x 89mm x 1.6mm Connections Name PVIN PGnd VOUT PGnd VIN VCC PGnd En PGood SCL SDA SALERT SYNC Load Output voltage selector Output transient ripple voltage Identifier J1 J4 J3 J2 VIN VCC PGnd TP11 PGood J5 J5 SALERT J6 J7 J8 J9 Description Input voltage (+12V) Ground for input voltage Output voltage (+1V) Ground for output voltage LDO input voltage Internal supply (VCC) – output of an LDO regulator Power ground Enable Power Good I2C/PMBUS clock line I2C/PMBUS data line SMBALERT# External sync signal Used to connect load: 20-pin Intel Mini Slammer connector Used to select output voltage before power up Used for measurement: 50Ω ultra-miniature coaxial connector The board is configured for a single input supply. An internal low drop-out regulator generates the internal supply (VCC) from VIN. The Enable (En) input is connected to PVIN through a resistor divider, so that no external Enable signal is needed. Operation To use the evaluation board: 1. Connect a well-regulated +12V input supply to PVIN (J1) and Gnd (J4). 2. Connect a load of 0–12A to VOUT (J3) and Gnd (J2). Page 2 Rev 1.0, Jan 4, 2022 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright © 2021–22 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. EV1412-0600-A Description The evaluation board consists of a 4-layer PCB made from FR4 glass-reinforced epoxy laminate material. All layers use 2oz copper (equating to a thickness of 0.0694mm). The major power components, including the FS1412, are mounted on the top side of the board. Figure 1 View of board (top) Figure 2 View of board (bottom) Page 3 Rev 1.0, Jan 4, 2022 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright © 2021–22 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. EV1412-0600-A Figure 3 to Figure 6 show the layout of the board layers and Figure 7 shows a schematic of the electrical circuit. Figure 3 Board layout – layer 1 Figure 4 Board layout – layer 2 Page 4 Rev 1.0, Jan 4, 2022 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright © 2021–22 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. EV1412-0600-A Figure 5 Board layout – layer 3 Figure 6 Board layout – layer 4 Page 5 Rev 1.0, Jan 4, 2022 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright © 2021–22 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. EV1412-0600-A Figure 7 Schematic Page 6 Rev 1.0, Jan 4, 2022 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright © 2021–22 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. EV1412-0600-A Part reference C1 C10,C11,C12 C14,C15,C17,C19 C2,C3 C20 C21 C4 J1 J2,J4 J3 J5 J6 J7 J8 Quantity 1 3 4 2 1 1 1 1 2 1 1 1 1 1 Value 1µF 22µF 47µF 2.2µF 68µF 0.1µF 220pF 108-0902-001 108-0903-001 108-0904-001 68000-103HLF 68000-102HLF Not inserted M20-9760442 J9 1 U.FL-R-SMT(10) R1 R12 R13 R14,R15,R16 R17 R18 R20 R3,R7 R4,R9,R11 R5 R6 U1 VIN, EN, PGND, VCC, PVIN, PGND, VOUT, PGND, SALERT, PGOOD 1 1 1 3 1 1 1 2 3 1 1 1 10 2.7Ω 4.12kΩ 5.90kΩ 4.99kΩ 10kΩ 1.91kΩ 49.9Ω 49.9kΩ 0 100Ω 12.7kΩ FS1412 5018 Description 0603, 25V, X5R 0805, 25V, X5R 0805, 6.3V, X5R 0402, 10V, X7S 25V, tantalum 0402, 25V, X7R 0603, COG, 50V PVIN banana connector, red Gnd banana connector, black VOUT banana connector, green 3 pin header, 0.1" pitch 2 pin header, 0.1" pitch Mini Slammer connector, 20-pin Through-board connector, 8-pin, two-row, 0.1" pitch 50Ω ultra-miniature coaxial connector 0805 0805, 1% 0805, 1% 0402 0805, 1% 0805, 1% 0402, 1% 0805 0805 0805 0805 Main IC Test points Manufacturer Part number Johnson (Cinch Connectivity Solutions) Intel Harwin 108-0902-001 108-0903-001 108-0904-001 68000-103HLF 68000-102HLF Q6UJ9A00MS25 M20-9760442 Hirose Electric U.FL-R-SMT(10) TDK Keystone 5018 Amphenol Page 7 Rev 1.0, Jan 4, 2022 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright © 2021–22 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. EV1412-0600-A Typical performance Figure 8 to Figure 18 show typical operating waveforms for the evaluation board, while Figure 19 shows a thermal image of the board in operation. In all cases, the board is operating at room temperature with no airflow; PVIN is 12V, VOUT is 1V and IO is 0–12A. Figure 8 Startup with no load (Ch2:PVIN, Ch5:VCC, Ch6: VOUT, Ch7: PGood, Ch8: Enable) Figure 9 Startup with 12A load (Ch2:PVIN, Ch5:VCC, Ch6: VOUT, Ch7: PGood, Ch8: Enable) Page 8 Rev 1.0, Jan 4, 2022 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright © 2021–22 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. EV1412-0600-A Figure 10 Shutdown with Enable de-assertion at 12A load (Ch2:PVIN, Ch5:VCC, Ch6: VOUT, Ch7: PGood, Ch8: Enable) Figure 11 Soft turn off at no load (Ch2:PVIN, Ch5:VCC, Ch6: VOUT, Ch7: PGood, Ch8: Enable) Page 9 Rev 1.0, Jan 4, 2022 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright © 2021–22 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. EV1412-0600-A Figure 12 Switch node waveforms at no load Figure 13 Switch node waveforms at 12A Page 10 Rev 1.0, Jan 4, 2022 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright © 2021–22 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. EV1412-0600-A Figure 14 VO ripple at 12A (Ch1:IO, Ch8: VOUT), peak-peak VO ripple = 4.6mV Figure 15 Transient response 0A to 6A (Ch6: VOUT, Ch8:IO), peak-peak deviation = 53mV, load slew rate = 40A/µs Page 11 Rev 1.0, Jan 4, 2022 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright © 2021–22 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. EV1412-0600-A Figure 16 Efficiency Figure 17 Power loss Page 12 Rev 1.0, Jan 4, 2022 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright © 2021–22 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. EV1412-0600-A Figure 18 Load regulation (IO = 0–12A) Figure 19 Thermal image at PVIN = 12V, VOUT = 1.0V, IO = 12A, room temperature, no airflow, FS1412 maximum temperature rise = 55.5°C Page 13 Rev 1.0, Jan 4, 2022 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright © 2021–22 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. EV1412-0600-A Disclaimer IMPORTANT NOTICE AND DISCLAIMER TDK PROVIDES THIS POWER DESIGN USER GUIDE (“Resources”) “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS. ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These Resources are intended for skilled developers designing with TDK products. You are solely responsible for (1) selecting the appropriate TDK products for your application, (2) designing, validating and testing your application, (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements, and (4) ensuring your application complies with all applicable laws and regulations. These Resources are subject to change without notice and TDK assumes no responsibility for any notices or lack thereof. TDK grants you permission to use these Resources solely for development of an application that uses the TDK products described in the Resource. This permission may be revoked at any time by TDK or any of its affiliates. Your use of these Resources shall be in compliance with all applicable laws and regulations including applicable export/import controls. Reproduction and display of these Resources is prohibited. No license is granted to any other TDK intellectual property right or to any third party intellectual property right. TDK disclaims responsibility for, and you agree to fully indemnify TDK, its affiliates and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these Resources. REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. The products listed on this specification sheet are intended for use in general electric equipment (AV equipment, telecommunication equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal condition and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to sociality, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. Aerospace/Aviation equipment Transportation equipment (cars, electric trains, ships, etc.) Medical equipment Power-generation control equipment Atomic energy related equipment Seabed equipment Transportation control equipment Public Information-processing equipment Military equipment Electric heating apparatus, burning equipment Disaster prevention/crime prevention equipment Safety equipment Other applications that are not considered general-purpose applications When using this product in general-purpose application, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. This product is subject to a license from Power One, Inc. related to digital power technology patents owned by Power One, Inc. Power One, Inc. technology is protected by patents including: AU 3287379M 3287437AA 3290643AA 3291357AA CN 10371856C 10452610C 10458656C 10459360C 10465848C 1069332A 11124619A 11346682A 1685299A 1685459A 1685582A 1685583A 1698023A 1802619A EP 1561156A1 1561268A2 1576710A1 1576711A1 1604254A4 1604264A4 1714369A2 1745536A4 1769382A4 1899789A2 1984801A2 US 20040246754 2004090219A1 2004093533A1 2004123164A1 2004123167A1 2004178780A1 2004179382A1 20050200344 20050223252 2005209373A1 20060061214 2006015619A1 20060174145 20070226526 20070234095 20070240000 20080052551 20080072080 20080186006 6741099 6788036 6936999 6949916 7000125 7049798 7069021 7080265 7249267 7266709 7315156 7372682 7373527 7394445 7456617 7459892 7493504 7526660 WO 04044718A1 04045042A3 04045042C1 04062061A1 04062062A1 04070780A3 04084390A3 04084391A3 05079227A3 05081771A3 06019569A3 2007001584A3 2007094935A3 Page 14 Rev 1.0, Jan 4, 2022 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright © 2021–22 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice.
EV1412-0600-A 价格&库存
很抱歉,暂时无法提供与“EV1412-0600-A”相匹配的价格&库存,您可以联系我们找货
EV1412-0600-A
  • 1+1079.779791+140.17297
  • 10+893.1448810+115.94473
库存:11
