EVS36-8R4
EVS36-8R4
    TDK(东电化)
    36V 8.4A AC-DC电源模块
EVS36-8R4 数据手册
EVS Series www.emea.tdk-lambda.com/evs ,QGXVWULDO &RPP 5HQHZDEOH 300 and 600W Constant Current Power Supplies $XWRPDWLRQ Features Benefits • 300W Convection cooled and 600W fan model • CC (constant current) mode • CV (constant voltage) mode • 5 Year warranty • Silent fanless chargers • Quick recharge, avoid battery overcharging • Supports charging of 12, 24 and 48V batteries • Provides high reliability for battery charger and electrical storage system Specification Model Input Voltage Input Current Inrush Current (100/200VAC) Power Factor (100/200VAC) PFHC Leakage Current Temperature Coefficient Constant Current Setting Accuracy Overvoltage Protection Hold Up Time (Typ) Efficiency (100/200VAC) Remote On/Off Series & Parallel Operation Operating Temperature (No external airflow) Operating Temperature External airflow (1.4m/s) Storage Temperature Humidity (non condensing) Cooling Withstand Voltage Isolation Resistance Vibration (non operating) Shock Safety Agency Certifications Conducted & Radiated EMI Immunity Weight (Typ) Size (WxHxD) Warranty EVS300 EVS600 V 85-265VAC (47-63Hz) 85-265VAC (47-63Hz) A 3.6 / 1.8 7.2 / 4.0 A 15 / 30 20 / 40 - 0.97/0.93 0.95/0.9 - Meets EN61000-3-2 mA < 0.5mA < 0.75mA %/°C 100MΩ at 25°C & 70%RH, Output to Ground 500VDC - 10 - 55Hz (1 minute sweep), 19.6m/s2 constant, X, Y, Z 1 hour each - < 196.1 m/s2 - UL60950-1, CSA60950-1, EN60950-1, CE Mark - EN55011/EN55022-B, FCC Class B, VCCI-B - EN61000-4-2, -3, -4, -5, -6, -8, -11; EN61000-6-2 g 540g (open frame) 1600g mm 84 x 42 x 180mm 120 x 61 x 190mm yrs 5 EVS Series 1 Model Selector Model Nominal Voltage Output Adjust Range (V) Max Current (100VAC) EVS18-16R7 18V 12 - 18V 16.7A EVS36-8R4 36V 24 - 36V 8.4A EVS36-16R7 36V 24 - 36V EVS57-5R3 57V 48 - 57V EVS57-10R6 57V 48 - 57V 15.3A Max Current (200VAC) 16.7A Current Adjust Range (100VAC) 5.3A 9.7A 10.6A Description None Cover & L Bracket (Standard on EVS600) Remote On/Off EVS57-5R3/RA * Note: * without suffix 2 Ripple & Noise (mV) 8.35 - 16.70A 72 144 200 4.20 - 8.40A 144 252 250 144 288 200 228 285 250 228 456 200 5.30 - 9.70A Options - /A /R Example CV Load Reg (mV) 8.35 - 16.70A 2.65 - 5.30A Outline Drawing EVS300W Series Suffix CV Line Reg (mV) 8.35 - 15.30A Current Adjust Range (200VAC) EVS Series 5.30 - 10.60A Outline Drawing EVS600W Series I.ADJ H H +V OUTPUT : 36 V V.ADJ +V 16.7 A -V EVS 36 - 16R7 N EHFP INPUT : 100-240VAC 7.0 A 50-60Hz 16.7 A OUTPUT : 36 V L Max. surrounding air temperature : 70°C Use wires rating at least 75°C Pollution Degree : 2 -V Accessory Model Description RP-60-20 RP-60-20/L 20A Reverse current Prevention module for battery charging use (PCB type) * 20A Reverse current Prevention module for battery charging use (on L bracket) * * The Reverse current Protection modules RP can also be used as replacement for Diode-modules (as e.g. DLP-PU) - For power up in parallel operation - For Back-up diode (N + I redundant operation) (Note: as from April 1st 2018 the EVS-RP6020 has been renamed RP-60-20) Outline Drawing RP-60-20 (Open frame) EVS -RP6020/L INPUT VOLTAGE : 7 - 60 VDC INPUT CURRENT : 0 - 20 A EHFP EVS Series 3 Outline Drawing RP-60-20/L Series EVS -RP6020/L INPUT VOLTAGE : 7 - 60 VDC INPUT CURRENT : 0 - 20 A EHFP Notes: A: M3 embossed tapped and countersink holes (6) are for customer’s chassis mounting B: Dia 3.5mm holes (2) and R1.75 slot holes (2) are for customer’s chassis mounting holes C: Model name, input range and input current are shown here in accordance with the specifications EVS -RP6020/L D: Country of manufacture will be shown here INPUT VOLTAGE : 7 - 60 VDC INPUT CURRENT : 0 - 20 A Accessories: * Terminal cover for barrier terminal strip –––2 (attached on terminal TB1 and TB2 at shipment) EHFP 4 EVS Series TDK-Lambda France SAS TDK-Lambda Americas Tel: +33 1 60 12 71 65 tlf.fr.powersolutions@tdk.com Tel: +1 800-LAMBDA-4 or 1-800-526-2324 tla.powersolutions@tdk.com www.us.lambda.tdk.com www.emea.lambda.tdk.com/fr Italy Sales Office Tel: +39 02 61 29 38 63 tlf.it.powersolutions@tdk.com www.emea.lambda.tdk.com/it TDK Electronics do Brasil Ltda Tel: +55 11 3289-9599 sales.br@tdk-electronics.tdk.com www.tdk-electronics.tdk.com/en Netherlands tlf.nl.powersolutions@tdk.com www.emea.lambda.tdk.com/nl TDK-Lambda Germany GmbH TDK-Lambda Corporation Tel: +49 7841 666 0 tlg.powersolutions@tdk.com www.emea.lambda.tdk.com/de Tel: +81-3-6778-1113 www.jp.lambda.tdk.com TDK-Lambda (China) Electronics Co. Ltd. Tel: +86 21 6485-0777 tlc.powersolutions@tdk.com www.lambda.tdk.com.cn Austria Sales Office Tel: +43 2256 655 84 tlg.at.powersolutions@tdk.com TDK-Lambda Singapore Pte Ltd. Switzerland Sales Office Tel: +65 6251 7211 tls.marketing@tdk.com www.sg.lambda.tdk.com Tel: +41 44 850 53 53 tlg.ch.powersolutions@tdk.com TDK India Private Limited, Power Supply Division www.emea.lambda.tdk.com/at www.emea.lambda.tdk.com/ch Tel: +91 80 4039-0660 mathew.philip@tdk.com www.sg.lambda.tdk.com Nordic Sales Office Tel: +45 8853 8086 tlg.dk.powersolutions@tdk.com www.emea.lambda.tdk.com/dk TDK-Lambda UK Ltd. Tel: +44 (0) 12 71 85 66 66 tlu.powersolutions@tdk.com www.emea.lambda.tdk.com/uk TDK-Lambda Ltd. Tel: +9 723 902 4333 tli.powersolutions@tdk.com www.emea.lambda.tdk.com/il-en For Additional Information, please visit https://product.tdk.com/en/power/ EVS Series April18 v6 EVS Series 5
EVS36-8R4 价格&库存
很抱歉,暂时无法提供与“EVS36-8R4”相匹配的价格&库存,您可以联系我们找货
EVS36-8R4
    • 1+1745.379081+226.84666
    • 2+1704.204932+221.49526
    • 3+1690.485723+219.71218
    • 4+1683.621994+218.82010
    • 5+1679.500445+218.28442
    • 7+1674.800737+217.67360
    • 9+1672.182439+217.33330
    库存:18
