EVS Series
www.emea.tdk-lambda.com/evs
,QGXVWULDO
&RPP
5HQHZDEOH
300 and 600W
Constant Current Power Supplies
$XWRPDWLRQ
Features
Benefits
• 300W Convection cooled and 600W fan model
• CC (constant current) mode
• CV (constant voltage) mode
• 5 Year warranty
• Silent fanless chargers
• Quick recharge, avoid battery overcharging
• Supports charging of 12, 24 and 48V batteries
• Provides high reliability for battery charger
and electrical storage system
Specification
Model
Input Voltage
Input Current
Inrush Current (100/200VAC)
Power Factor (100/200VAC)
PFHC
Leakage Current
Temperature Coefficient
Constant Current Setting Accuracy
Overvoltage Protection
Hold Up Time (Typ)
Efficiency (100/200VAC)
Remote On/Off
Series & Parallel Operation
Operating Temperature
(No external airflow)
External airflow (1.4m/s)
Storage Temperature
Humidity (non condensing)
Cooling
Withstand Voltage
Isolation Resistance
Vibration (non operating)
Shock
Safety Agency Certifications
Conducted & Radiated EMI
Immunity
Weight (Typ)
Size (WxHxD)
Warranty
EVS300
EVS600
V
85-265VAC (47-63Hz)
85-265VAC (47-63Hz)
A
3.6 / 1.8
7.2 / 4.0
A
15 / 30
20 / 40
0.97/0.93
0.95/0.9
Meets EN61000-3-2
mA
< 0.5mA
< 0.75mA
%/°C
100MΩ at 25°C & 70%RH, Output to Ground 500VDC
10 - 55Hz (1 minute sweep), 19.6m/s2 constant, X, Y, Z 1 hour each
< 196.1 m/s2
UL60950-1, CSA60950-1, EN60950-1, CE Mark
EN55011/EN55022-B, FCC Class B, VCCI-B
EN61000-4-2, -3, -4, -5, -6, -8, -11; EN61000-6-2
g
540g (open frame)
1600g
mm
84 x 42 x 180mm
120 x 61 x 190mm
yrs
5
EVS Series
1
Model Selector
Model
Nominal
Voltage
Output
Adjust
Range
(V)
Max
Current
(100VAC)
EVS18-16R7
18V
12 - 18V
16.7A
EVS36-8R4
36V
24 - 36V
8.4A
EVS36-16R7
36V
24 - 36V
EVS57-5R3
57V
48 - 57V
EVS57-10R6
57V
48 - 57V
15.3A
Max
Current
(200VAC)
16.7A
Current Adjust
Range
(100VAC)
5.3A
9.7A
10.6A
Description
None
Cover & L Bracket (Standard on EVS600)
Remote On/Off
EVS57-5R3/RA
Note: * without suffix
2
Ripple &
Noise
(mV)
8.35 - 16.70A
72
144
200
4.20 - 8.40A
144
252
250
144
288
200
228
285
250
228
456
200
5.30 - 9.70A
Options
/A
/R
Example
CV Load
Reg
(mV)
8.35 - 16.70A
2.65 - 5.30A
Outline Drawing EVS300W Series
Suffix
CV Line
Reg
(mV)
8.35 - 15.30A
Current Adjust
Range
(200VAC)
EVS Series
5.30 - 10.60A
Outline Drawing EVS600W Series
I.ADJ
H
H
+V
OUTPUT : 36 V
V.ADJ
+V
16.7 A
-V
EVS 36 - 16R7
N
EHFP
INPUT : 100-240VAC 7.0 A
50-60Hz
16.7 A
OUTPUT : 36 V
L
Max. surrounding air temperature : 70°C
Use wires rating at least 75°C
Pollution Degree : 2
-V
Accessory
Model
Description
RP-60-20
RP-60-20/L
20A Reverse current Prevention module for battery charging use (PCB type) *
20A Reverse current Prevention module for battery charging use (on L bracket) *
* The Reverse current Protection modules RP can also be used as replacement for Diode-modules (as e.g. DLP-PU)
- For power up in parallel operation
- For Back-up diode (N + I redundant operation)
(Note: as from April 1st 2018 the EVS-RP6020 has been renamed RP-60-20)
Outline Drawing RP-60-20 (Open frame)
EVS -RP6020/L
INPUT VOLTAGE
: 7 - 60 VDC
INPUT CURRENT : 0 - 20 A
EHFP
EVS Series
3
Outline Drawing RP-60-20/L Series
EVS -RP6020/L
INPUT VOLTAGE
: 7 - 60 VDC
EHFP
Notes:
A: M3 embossed tapped and countersink holes (6) are for customer’s chassis mounting
B: Dia 3.5mm holes (2) and R1.75 slot holes (2) are for customer’s chassis mounting holes
C: Model name, input range and input current are shown here in accordance with the specifications
EVS -RP6020/L
D: Country of manufacture will be shown here
INPUT VOLTAGE
: 7 - 60 VDC
Accessories:
* Terminal cover for barrier terminal strip –––2 (attached on terminal TB1 and TB2 at shipment)
EHFP
4
EVS Series
TDK-Lambda France SAS
TDK-Lambda Americas
Tel: +33 1 60 12 71 65
tlf.fr.powersolutions@tdk.com
Tel: +1 800-LAMBDA-4 or 1-800-526-2324
tla.powersolutions@tdk.com
www.us.lambda.tdk.com
www.emea.lambda.tdk.com/fr
Italy Sales Office
Tel: +39 02 61 29 38 63
tlf.it.powersolutions@tdk.com
www.emea.lambda.tdk.com/it
TDK Electronics do Brasil Ltda
Tel: +55 11 3289-9599
sales.br@tdk-electronics.tdk.com
www.tdk-electronics.tdk.com/en
Netherlands
tlf.nl.powersolutions@tdk.com
www.emea.lambda.tdk.com/nl
TDK-Lambda Germany GmbH
TDK-Lambda Corporation
Tel: +49 7841 666 0
tlg.powersolutions@tdk.com
www.emea.lambda.tdk.com/de
Tel: +81-3-6778-1113
www.jp.lambda.tdk.com
TDK-Lambda (China) Electronics Co. Ltd.
Tel: +86 21 6485-0777
tlc.powersolutions@tdk.com
www.lambda.tdk.com.cn
Austria Sales Office
Tel: +43 2256 655 84
tlg.at.powersolutions@tdk.com
TDK-Lambda Singapore Pte Ltd.
Switzerland Sales Office
Tel: +65 6251 7211
tls.marketing@tdk.com
www.sg.lambda.tdk.com
Tel: +41 44 850 53 53
tlg.ch.powersolutions@tdk.com
TDK India Private Limited, Power Supply Division
www.emea.lambda.tdk.com/at
www.emea.lambda.tdk.com/ch
Tel: +91 80 4039-0660
mathew.philip@tdk.com
Nordic Sales Office
Tel: +45 8853 8086
tlg.dk.powersolutions@tdk.com
www.emea.lambda.tdk.com/dk
TDK-Lambda UK Ltd.
Tel: +44 (0) 12 71 85 66 66
tlu.powersolutions@tdk.com
www.emea.lambda.tdk.com/uk
TDK-Lambda Ltd.
Tel: +9 723 902 4333
tli.powersolutions@tdk.com
www.emea.lambda.tdk.com/il-en
For Additional Information, please visit
https://product.tdk.com/en/power/
EVS Series April18 v6
EVS Series
5
很抱歉,暂时无法提供与“EVS57-5R3/R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1869.433401+242.61834
