ICS-41351
Top Port PDM Digital Output Multi-Mode Microphone
GENERAL DESCRIPTION
APPLICATIONS
The ICS-41351 is a multi-mode, low noise digital MEMS
microphone in a small package. The ICS-41351 consists of a
MEMS microphone element and an impedance converter
amplifier followed by a fourth-order Σ-Δ modulator. The digital
interface allows the pulse density modulated (PDM) output of
two microphones to be time multiplexed on a single data line
using a single clock.
FEATURES
The ICS-41351 has multiple modes of operation: Low Power
(AlwaysOn), Standard and Sleep. The ICS-41351 has high SNR
and 120 dB SPL AOP in all operational modes.
The ICS-41351 is available in a standard 3.5 × 2.65 × 0.98 mm
surface-mount package. It is reflow solder compatible with
no sensitivity degradation.
FUNCTIONAL BLOCK DIAGRAM
SPEC
Sensitivity
SNR
Current
AOP
Clock
−26 dB FS ±1 dB
65 dBA
600 µA
120 dB SPL
2.4 MHz
LOW-POWER MODE
CLK
DATA
ICS-41351
EV_ICS-41351-FX
TEMP RANGE
−40°C to +85°C
CHANNEL
SELECT
InvenSense, Inc. reserves the right to change the detail
specifications as may be required to permit
improvements in the design of its products.
−26 dB FS ±1 dB
65 dBA
230 µA
120 dB SPL
768 kHz
3.5 × 2.65 × 0.98 mm surface-mount package
Extended frequency response from 50 Hz to >20 kHz
Low power: 230 µA in Low-Power Mode
Sleep Mode: 12 µA
High power supply rejection (PSR): −93 dB FS
Fourth-order Σ-Δ modulator
Digital pulse density modulation (PDM) output
Compatible with Sn/Pb and Pb-free solder processes
RoHS/WEEE compliant
PART
PDM
MODULATOR
STANDARD MODE
SELECT
VDD
GND
POWER
MANAGEMENT
Smartphones
Microphone Arrays
Tablets
Cameras
Bluetooth Headsets
Notebook PCs
Security and Surveillance
ORDERING INFORMATION
ICS-41351
ADC
InvenSense Inc.
1745 Technology Drive, San Jose, CA 95110 U.S.A
+1(408) 988–7339
www.invensense.com
Document Number: DS-000157
Revision: 1.3
Release Date: 11/15/2019
PACKAGING
13” Tape and Reel
ICS-41351
TABLE OF CONTENTS
General Description ..................................................................................................................................................................... 1
Applications ................................................................................................................................................................................. 1
Features ....................................................................................................................................................................................... 1
Functional Block Diagram ............................................................................................................................................................ 1
Ordering Information ................................................................................................................................................................... 1
Table of Contents .................................................................................................................................................................................... 2
Specifications .......................................................................................................................................................................................... 4
Table 1. Acoustical/Electrical Characteristics – General .............................................................................................................. 4
Table 2. Acoustical/Electrical Characteristics – Standard Mode.................................................................................................. 4
Table 3. Acoustical/Electrical Characteristics – Low-Power Mode .............................................................................................. 4
Table 4. Digital Input/Output Characteristics .............................................................................................................................. 5
Table 5. PDM Digital Input/Output .............................................................................................................................................. 5
Timing Diagram ............................................................................................................................................................................ 6
Absolute Maximum Ratings .................................................................................................................................................................... 7
Table 6. Absolute Maximum Ratings ........................................................................................................................................... 7
ESD Caution ................................................................................................................................................................................. 7
Soldering Profile........................................................................................................................................................................... 8
Table 7. Recommended Soldering Profile*.................................................................................................................................. 8
Pin Configurations And Function Descriptions ....................................................................................................................................... 9
Table 8. Pin Function Descriptions............................................................................................................................................... 9
Typical Performance Characteristics..................................................................................................................................................... 10
Theory Of Operation ............................................................................................................................................................................. 11
PDM Data Format ...................................................................................................................................................................... 11
Table 9. ICS-41351 Channel Setting ........................................................................................................................................... 11
PDM Microphone Sensitivity ..................................................................................................................................................... 12
Applications Information ...................................................................................................................................................................... 13
Low Power Mode ....................................................................................................................................................................... 13
Dynamic Range Considerations ................................................................................................................................................. 13
Connecting PDM Microphones .................................................................................................................................................. 13
Sleep Mode ................................................................................................................................................................................ 15
Start-Up Time ............................................................................................................................................................................. 15
Supporting Documents ......................................................................................................................................................................... 16
Application Notes – General ...................................................................................................................................................... 16
PCB Design And Land Pattern Layout ................................................................................................................................................... 17
PCB Material And Thickness ...................................................................................................................................................... 18
Handling Instructions ............................................................................................................................................................................ 19
Pick And Place Equipment ......................................................................................................................................................... 19
Reflow Solder ............................................................................................................................................................................. 19
Board Wash................................................................................................................................................................................ 19
Revision: 1.3
Page 2 of 23
ICS-41351
Outline Dimensions ............................................................................................................................................................................... 20
Ordering Guide .......................................................................................................................................................................... 21
Revision History ......................................................................................................................................................................... 22
Compliance Declaration Disclaimer ...................................................................................................................................................... 23
Revision: 1.3
Page 3 of 23
ICS-41351
SPECIFICATIONS
TABLE 1. ACOUSTICAL/ELECTRICAL CHARACTERISTICS – GENERAL
TA = 25°C, VDD = 1.8 to 3.3 V, SCK = 1.536 MHz, 32× decimation, CLOAD = 30 pF unless otherwise noted. Typical specifications are not
guaranteed.
PARAMETER
CONDITIONS
MIN
TYP
MAX
UNITS
NOTES
PERFORMANCE
Directionality
Omni
Output Polarity
Input acoustic pressure vs.
Non-Inverted
output data
Supply Voltage (VDD)
1.65
3.63
V
Sleep Mode Current (IS)
SCK < 200 kHz
12
µA
TABLE 2. ACOUSTICAL/ELECTRICAL CHARACTERISTICS – STANDARD MODE
TA = 25°C, VDD = 1.8 to 3.3 V, SCK = 2.4 MHz, 50× decimation, CLOAD = 30 pF unless otherwise noted. Typical specifications are not
guaranteed.
PARAMETER
CONDITIONS
MIN
TYP
MAX
UNITS
NOTES
Sensitivity
1 kHz, 94 dB SPL
−27
−26
−25
dB FS
1
Signal-to-Noise Ratio (SNR)
20 kHz bandwidth, A-weighted
65
dBA
Equivalent Input Noise (EIN)
29
dBA SPL
Dynamic Range
Derived from EIN and acoustic
91
dB
overload point
Total Harmonic Distortion (THD)
105 dB SPL
0.2
1
Power Supply Rejection (PSR)
217 Hz, 100 mV p-p square wave
superimposed on VDD = 1.8 V, A−93
dB FS
weighted
Power Supply Rejection—Swept
1 kHz sine wave
90
dB FS
Sine
Acoustic Overload Point
10% THD
120
dB SPL
Supply Current (IS)
VDD = 1.8 V, no load
600
700
µA
Note 1: Sensitivity is relative to the RMS level of a sine wave with positive amplitude equal to 100% 1s density and negative amplitude equal to 0% 1s density.
TABLE 3. ACOUSTICAL/ELECTRICAL CHARACTERISTICS – LOW-POWER MODE
TA = 25°C, VDD = 1.8 to 3.3 V, SCK = 768 kHz, 48× decimation, CLOAD = 30 pF unless otherwise noted. Typical specifications are not
guaranteed.
PARAMETER
CONDITIONS
MIN
TYP
MAX
UNITS
NOTES
Sensitivity
1 kHz, 94 dB SPL
−27
−26
−25
dB FS
1
65
dBA
29
dBA SPL
Dynamic Range
91
dB
overload point
105 dB SPL
0.2
1
dB FS
weighted
1 kHz sine wave
90
dB FS
Sine
10% THD
120
dB SPL
Supply Current (IS)
230
275
µA
Revision: 1.3
Page 4 of 23
ICS-41351
TABLE 4. DIGITAL INPUT/OUTPUT CHARACTERISTICS
TA = 25°C, 1.8 V < VDD < 3.3 V, unless otherwise noted.
PARAMETER
CONDITIONS
MIN
Input Voltage High (VIH)
TYP
MAX
UNITS
0.65 × VDD
V
Input Voltage Low (VIL)
0.35 × VDD
Output Voltage High (VOH)
ILOAD = 0.5 mA
Output Voltage Low (VOL)
ILOAD = 0.5 mA
Output DC Offset
Latency
Percent of full scale
NOTES
0.7 × VDD
V
V
VDD
0.3 × VDD
3
很抱歉,暂时无法提供与“EV_ICS-41351-FX”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+350.998631+45.30699
