EV_MPU-3050
EV_MPU-3050
    TDK(东电化)
    BOARD EVAL FOR MPU-3050
EV_MPU-3050 数据手册
MPU-3000 & MPU-3050 EV Board User Guide Document Number: AN-MPU-30x0EVB-00 Revision: 2.0 Release Date: 07/15/2011 MPU-3000 & MPU-3050 3-Axis Evaluation Board User Guide Revision 2.0 InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, Ca 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 1 AN-MPU-30x0EVB-00 ©2011 InvenSense, Inc. All rights reserved. MPU-3000 & MPU-3050 EV Board User Guide Document Number: AN-MPU-30x0EVB-00 Revision: 2.0 Release Date: 07/15/2011 CONTENTS 1. REVISION HISTORY ....................................................................................................................................... 3 2. PURPOSE ..................................................................................................................................................... 4 3. MPU-3000 & MPU-3050 3-AXIS EV BOARD OVERVIEW ................................................................................ 5 4. MPU-3000 & MPU-3050 3-AXIS EVB SCHEMATICS ..................................................................................... 7 5. DATA GATHERING OPTIONS ........................................................................................................................ 11 6. SPECIAL INSTRUCTIONS .............................................................................................................................. 12 7. DIMENSION DRAWING ................................................................................................................................. 12 InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, Ca 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 2 AN-MPU-30x0EVB-00 ©2011 InvenSense, Inc. All rights reserved. MPU-3000 & MPU-3050 EV Board User Guide Document Number: AN-MPU-30x0EVB-00 Revision: 2.0 Release Date: 07/15/2011 1. Revision History Date Revision Description 10/01/2010 1.0 Initial release 07/15/2011 2.0 Added compatibility for MPU-3050 InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, Ca 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 3 AN-MPU-30x0EVB-00 ©2011 InvenSense, Inc. All rights reserved. MPU-3000 & MPU-3050 EV Board User Guide Document Number: AN-MPU-30x0EVB-00 Revision: 2.0 Release Date: 07/15/2011 2. Purpose This document describes the hardware and circuitry on the MPU-3000™ & MPU-3050™ 3-Axis Evaluation (EV) Board. It covers applying the EV board to a larger system, understanding key signals and circuit functions, hardware jumper settings, and port connectors. 2.1 Usage This evaluation board provides three axes of motion sensing, comprised of:  X-, Y- and Z-Axis gyros with ±250°/sec, ±500°/sec, ±1000°/sec, ±2000°/sec selectable full-scale range.  Digital data measured using on-chip ADCs, is transmitted over I²C or SPI interfaces. The Evaluation board may be used by itself using SPI or I²C serial communications interfaces. Alternatively, it may be connected to InvenSense‟s ARM Evaluation Board (INVARMEVB) for connectivity to a host computer using USB interface. 2.2 Related Documents The following documents are recommended for additional information regarding the products and systems described in this Application Note.  MPU-3000 & MPU-3050 Product Specification  MPU-3000 & MPU-3050 Register Map and Register Descriptions  MPU-3000 & MPU-3050 EVB schematics InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, Ca 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 4 AN-MPU-30x0EVB-00 ©2011 InvenSense, Inc. All rights reserved. MPU-3000 & MPU-3050 EV Board User Guide Document Number: AN-MPU-30x0EVB-00 Revision: 2.0 Release Date: 07/15/2011 3. MPU-3000 & MPU-3050 3-Axis EV Board Overview The MPU-3000 & MPU-3050 3-Axis EV Board contains the MPU-3000 or MPU-3050 Digital Motion Processing Unit. It contains a number of „solder-across‟ jumper points that permit several circuit configurations. Refer to Figure 1. The EV Board is populated on its top side only for easy of measurement access. The 10x2 customer header connector is designed to connect with the InvenSense ARM Evaluation Board (INVARMEVB), which is a host microcontroller board useful for adapting the MPU-3000 & MPU-3050 3Axis EV Board to a personal computer via its USB port. Factory Header Power Selection MPU-3000 or MPU-3050 User Header Figure 1. Top side of the MPU-3050 3-Axis EV Board The 5x2 extension factory header is intended for connecting additional devices to the EV Board, such as a camera image stabilization processor, or a digital-output compass, etc. The 3-pin power selection headers are used to select which voltage supply is fed to the MPU-3000 & MPU-3050. InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, Ca 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 5 AN-MPU-30x0EVB-00 ©2011 InvenSense, Inc. All rights reserved. MPU-3000 & MPU-3050 EV Board User Guide 3.1 Document Number: AN-MPU-30x0EVB-00 Revision: 2.0 Release Date: 07/15/2011 MPU-3000 & MPU-3050 Key Function and Pin-outs The MPU-3000 & MPU-3050 EVB is a fully-tested evaluation board, providing for quick evaluation of the MPU-3000 & MPU-3050‟s X- , Y- , and Z-axis angular rate gyroscope. The MPU-3000 & MPU-3050 use InvenSense‟s proprietary MEMS technology with vertically driven vibrating masses to produce a functionally complete, low-cost motion sensor. All required conditioning electronics are integrated into a single chip measuring 4 x 4 x 0.9mm. It incorporates X- , Y- and Z-axis low-pass filters and an EEPROM for on-chip factory calibration of the sensor. Factory trimmed scale factors eliminate the need for external active components and end-user calibration. A built-in Proportional-To-AbsoluteTemperature (PTAT) sensor provides temperature compensation information. The product is lead-free and Green Compliant. RESV CPOUT RESV CLKOUT SCL SDA RESV CPOUT RESV CLKOUT SCL / SCLK SDA / SDI 24 23 22 21 20 19 24 23 22 21 20 19 CLKIN 1 18 GND CLKIN 1 18 GND NC 2 17 NC NC 2 17 NC NC 3 16 NC NC 3 NC 4 15 NC NC 4 NC 5 14 NC NC 5 AUX_DA 6 AUX_DA 6 MPU-3000 13 VDD 14 NC 13 VDD INT REGOUT 10 11 12 FSYNC AD0 / SDO 9 REGOUT /CS 8 AD0 AUX_CL 7 VLOGIC 10 11 12 15 NC AUX_CL 9 INT 8 FSYNC 7 16 NC MPU-3050 Figure 2. MPU-3000 & MPU-3050 QFN Package (Top View) 24-pin 4mm x 4mm x 0.9mm +Z M MP PUU- 300 30 50 0 +Y +X Figure 3. Orientation of Axes of Sensitivity and Polarity of Rotation InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, Ca 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 6 AN-MPU-30x0EVB-00 ©2011 InvenSense, Inc. All rights reserved. Document Number: AN-MPU-30x0EVB-00 Revision: 2.0 Release Date: 07/15/2011 MPU-3000 & MPU-3050 EV Board User Guide 3.2 MPU-3000 & MPU-3050 Bus Connection 2 The MPU-3000 communicates to a system processor using either SPI or I C serial interfaces. The 2 MPU-3050 communicates to a system processor using an I C serial interface. The device always acts as a slave when communicating to the system processor. 4. MPU-3000 & MPU-3050 3-Axis EVB Schematics LDO_V_OUT M1 V_LOGIC 1 2 3 JP2 HEADER 3, 80mil, 180D, Male 0.1uF BP1 M3 R1 1K M6 U1 R2 2K R3 2K VCC MPU-3000/3050 6 7 CLK_O 22 12 11 FSY NC_I SELECTED_VDD 13 18 21 19 BP2 0.1uF CLK_O CS/V_LOGIC SDO/ ADDR SDA/ SDI SCL/ SCLK INT FSY NC CLK_I CP_OUT REG_O VDD GND NC NC NC NC RESV2 RESV1 8 9 24 23 /MCU_CS MCU_SDO MCU_SDA MCU_SCL 1 1 20 10 TP1 CP_O REG_O 2 3 4 5 BP3 0.1uF C1 2200pF/50V/0402 17 16 15 14 NC NC NC NC M7 MPU_SDA MPU_SCL I2C V_logic Voltage Select VCC 0R M5 VCC LDO_V_OUT MCU_SCL MCU_SDA MCU_SDO FSY NC 3 2 1 R9 M4 FSY NC 2 4 6 8 10 1 3 5 7 9 JP7 JP8 HEADER 14X2, Male, 90D, 2.54mmx2.54mm JP6 HEADER 5X2, Male, 180D, 2.0mmx2.0mm HEADER 3, 80mil, 180D, Male Voltage Select SDA SCL RSV1 INT RSV2 CLK_I CP_O LDO_V_OUT FSY NC R11 0R VCC 1 3 5 7 9 11 13 15 17 19 21 23 25 27 2 4 6 8 10 12 14 16 18 20 22 24 26 28 R10 0R /MCU_CS CLK_O LDO_EN REG_O MCU_SCL MCU_SDA MCU_SDO R4 100K User Header 1 TP2 VCC VCC R8 R5 2R2/0603 BP4 0.1uF C2 0.47uF/0603 1M R6 1 2 3 LDO Y B1210ST25R300 SOT235 U2 5 Vin OUT GND 4 EN NC 3V0 0R R7 DNS_100K LDO_V_OUT C3 0.47uF/0603 BP5 0.1uF DNS: Do-Not-Stuff C4 0.033uF/0402 Figure 4. Schematics InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, Ca 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 7 AN-MPU-30x0EVB-00 ©2011 InvenSense, Inc. All rights reserved. MPU-3000 & MPU-3050 EV Board User Guide 4.1 Document Number: AN-MPU-30x0EVB-00 Revision: 2.0 Release Date: 07/15/2011 Bill of Materials Table 1. Bill of Materials 4.2 Item Quantity Reference Part PCB Footprint 1 5 BP1,BP2,BP3,BP4,BP5 0.1uF C0402 2 1 C1 2200pF/50V C0402 3 2 C2,C3 0.47uF/0603 C0603 4 1 C4 0.033uF C0402 6 4 JP1,JP3,JP4,JP5 Solder JP2P1_8X1_3S 7 2 JP2,JP7 HEADER 3, 80mil, 180D, Male J79\3S 8 1 JP6 HEADER 5X2, Male, 180D, 2.0mmx2.0mm SIP2X5N2 9 1 JP8 HEADER 14X2, Male, 90D, 2.54mmx2.54mm HDB2X14NRA 11 2 R4,R1 100K R0402 12 2 R3,R2 10K R0402 13 1 R5 1M R0402 14 1 R8 2R2/0603 R0603 17 1 U1 MPU-3000, 24-Lead QFN (4mm x 4mm x 0.9mm) QFN5_5S24P0_5T 18 1 U2 YB1210ST25R300 SOT235 Power Supply Connections JP2 and JP7 are 3 header-pin plug-in jumpers which allow users to select between on-board LDO and external DC supply to the MPU-3000 & MPU-3050. For details, please refer Table 2. Power Selection Jumpers. The on-board 3.0V LDO (Low-dropout voltage regulator) is a low-noise version with stable enabledisable profile. Its output is called 3V0 on the schematic, and using it will assure that the gyroscope and accelerometer performance will meet intended specifications. Selecting the raw Vcc line to power the chip is generally done while designing and evaluating an embedded platform, where the host processor and related electronics needs full control over the motion processing chipset‟s power supply. When user intends to use on board LDO 3V0 power, external Vcc must be provided with higher than 3.7V to ensure that the LDO works properly. If user provides Vcc with 5V, JP2 and JP7 must be set as “1-2 short”. MPU-3000 & MPU-3050 VDD and VLOGIC operation range is 2.1V to 3.6V. InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, Ca 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 8 AN-MPU-30x0EVB-00 ©2011 InvenSense, Inc. All rights reserved. MPU-3000 & MPU-3050 EV Board User Guide 4.3 Document Number: AN-MPU-30x0EVB-00 Revision: 2.0 Release Date: 07/15/2011 MPU-3000 & MPU-3050 EVB connector signals description Table 2. Power Selection Jumpers JP2 Pin Number Signal description 1-2 short VLOGIC = 3V 2-3 short VLOGIC = Vcc (from external) JP7 Pin Number Signal description 1-2 short VDD = 3V 2-3 short VDD = Vcc (from external) Table 3. User Interface Connector Signals JP8 Pin Number Signal description 1 Reserved 3 Reserved 5 Reserved 7 INT, INT output to controller 9 Reserved 11 CLK_I 13 CPOUT 15 GND 17 GND 19 3V 21 FSYNC 23 Receive power from ARM-7 Controller Board or external. It should be 5V, with >200mA 25 NC 27 NC 2 NC 4 NC 6 NC 8 SPI CS 10 Reserved 12 NC InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, Ca 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 9 AN-MPU-30x0EVB-00 ©2011 InvenSense, Inc. All rights reserved. MPU-3000 & MPU-3050 EV Board User Guide Document Number: AN-MPU-30x0EVB-00 Revision: 2.0 Release Date: 07/15/2011 JP8 Pin Number Signal description 14 EVB on board LDO enable 16 NC 18 REGOUT 20 I²C SCL or SPI SCLK 22 I²C SDA or SPI SDI 24 I²C Addr or SPI SDO 26 NC 28 NC Table 4. Extended Factory Connector 4.4 JP6 Pin Number Signal description 1 VCC, power from ARM-7 controller board or external power. It should be 5V, with >200mA 3 GND 5 NC 7 NC 9 NC 2 3V 4 I²C SCL or SPI SCLK 6 I²C SDA or SPI SDI 8 I²C Addr or SPI SDO 10 FSYNC Connecting the FSYNC Line The FSYNC line is intended for use in a camera‟s image-stabilization system. It is an input from the camera platform to the EV Board, and is intended to synchronize the MPU-3000 & MPU-3050‟s serial bus transfer with the master timing set by the camera system. FSYNC can originate from the host processor via JP8 pin-21, or from JP6 pin-10. There is no external pull-up termination for the FSYNC line. InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, Ca 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 10 AN-MPU-30x0EVB-00 ©2011 InvenSense, Inc. All rights reserved. MPU-3000 & MPU-3050 EV Board User Guide 4.5 Document Number: AN-MPU-30x0EVB-00 Revision: 2.0 Release Date: 07/15/2011 Serial bus Levels, Speeds and Terminations The MPU-3000 & MPU-3050 support I²C up to 400kHz, and SPI (MPU-3000 only) up to 1MHz serial clock rates. The I²C bus open drain pull up resisters are connected to either 3.0V or external provided Vcc (3V or 5V depend on user). The pull up level is selected by JP2. Please refer to Table 2. Power Selection Jumpers. 5. Data Gathering Options The MPU-3000 & MPU-3050‟s Digital Sensor Data is available at the User Header. Alternatively, for connectivity with a host PC, an InvenSense ARM Processor Board may be used. 5.1 Connection to ARM EVB For communications via USB to a host computer, the MPU-3000 & MPU-3050 EVB can be connected to InvenSense‟s ARM processor board, the INV-ARMEVB. The photo below shows the connection of MPU-3000 & MPU-3050 to INV-ARMEVB. Connection between the two boards is made via the user header. Figure 5. Connect MPU-3000 & MPU-3050 EVB to ARM Board 1.1 Use of MPU-3000 & MPU-3050 without ARM EVB board I²C and SPI signals are available on JP8 and JP6. User can develop tools to communicate with the MPU-3000 & MPU-3050. There is no bus mode selection setting needed. InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, Ca 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 11 AN-MPU-30x0EVB-00 ©2011 InvenSense, Inc. All rights reserved. MPU-3000 & MPU-3050 EV Board User Guide Document Number: AN-MPU-30x0EVB-00 Revision: 2.0 Release Date: 07/15/2011 6. Special Instructions 6.1 Electrostatic Discharge Sensitivity The MPU-3000 & MPU-3050 gyro can be permanently damaged by an electrostatic discharge. ESD precautions for handling and storage are recommended. 7. Dimension Drawing The MPU-3000 & MPU-3050 EV board is a 4 layer PCB with 32mm x 38mm dimension. Figure 6. MPU-3000 & MPU-3050 EVB Dimensions InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, Ca 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 12 AN-MPU-30x0EVB-00 ©2011 InvenSense, Inc. All rights reserved. MPU-3000 & MPU-3050 EV Board User Guide Document Number: AN-MPU-30x0EVB-00 Revision: 2.0 Release Date: 07/15/2011 This information furnished by InvenSense is believed to be accurate and reliable. However, no responsibility is assumed by InvenSense for its use, or for any infringements of patents or other rights of third parties that may result from its use. Specifications are subject to change without notice. InvenSense reserves the right to make changes to this product, including its circuits and software, in order to improve its design and/or performance, without prior notice. InvenSense makes no warranties, neither expressed nor implied, regarding the information and specifications contained in this document. InvenSense assumes no responsibility for any claims or damages arising from information contained in this document, or from the use of products and services detailed therein. This includes, but is not limited to, claims or damages based on the infringement of patents, copyrights, mask work and/or other intellectual property rights. Certain intellectual property owned by InvenSense and described in this document is patent protected. No license is granted by implication or otherwise under any patent or patent rights of InvenSense. This publication supersedes and replaces all information previously supplied. Trademarks that are registered trademarks are the property of their respective companies. InvenSense sensors should not be used or sold in the development, storage, production or utilization of any conventional or mass-destructive weapons or for any other weapons or life threatening applications, as well as in any other life critical applications such as medical equipment, transportation, aerospace and nuclear instruments, undersea equipment, power plant equipment, disaster prevention and crime prevention equipment. InvenSense® is a registered trademark of InvenSense, Inc. MPU-3000™ and MPU-3050™ are trademarks of InvenSense, Inc. ©2011 InvenSense, Inc. All rights reserved. InvenSense, Inc., 1197 Borregas Ave., Sunnyvale, Ca 94089, USA Tel: +1 (408) 988-7339 Fax: +1 (408) 988-8104 Website: http//www.invensense.com 13 AN-MPU-30x0EVB-00 ©2011 InvenSense, Inc. All rights reserved.
EV_MPU-3050 价格&库存
很抱歉,暂时无法提供与“EV_MPU-3050”相匹配的价格&库存,您可以联系我们找货
