EV_T3902-FX
EV_T3902-FX
    TDK(东电化)
    EV_T3902-FX
EV_T3902-FX 数据手册
 T3902    Bottom Port PDM Low‐Power Multi‐Mode  Microphone With High AOP Mode      GENERAL DESCRIPTION  APPLICATIONS  The T3902 is a low‐power, low‐noise digital MEMS  microphone in a small package. The T3902 consists of a  MEMS microphone element and an impedance converter  amplifier followed by a fourth‐order Σ‐Δ modulator. The pulse  density modulated (PDM) interface allows two microphones  to be time multiplexed on a data line using a single clock.     The T3902 has multiple modes of operation: High  Performance, Low Power (AlwaysOn), Standard and Sleep.  The T3902 has low power and high SNR in all operational  modes. It has 126 dB SPL AOP in High Performance mode, and  120 dB SPL AOP in Standard and Low‐Power modes.    The T3902 is available in a small 3.5 × 2.65 × 0.98 mm  surface‐mount package. It is reflow solder compatible with  no sensitivity degradation.   FEATURES         Smartphones   Microphone Arrays  Tablets  Cameras  Bluetooth Headsets  Notebook PCs  Security and Surveillance  SPEC  LOW‐POWER  MODE  STANDARD  MODE  HIGH  PERFORMANCE  MODE  Sensitivity  SNR  Current  AOP  Clock  −26 dB FS ±1 dB  63 dBA  185 µA  120 dB SPL  400 – 800 kHz  −26 dB FS ±1 dB  64.5 dBA  430 µA  120 dB SPL  1.0 – 3.3 MHz  −32 dB FS ±1 dB  64 dBA  650 µA  126 dB SPL  4.1 – 4.8 MHz                 3.5 × 2.65 × 0.98 mm surface‐mount package  Low power: 185 µA in Low‐Power Mode  Extended frequency response from 36 Hz to >20 kHz  Sleep Mode: 12 µA  High power supply rejection (PSR): −97 dB FS  Fourth‐order Σ‐Δ modulator  Digital pulse density modulation (PDM) output  Compatible with Sn/Pb and Pb‐free solder processes  RoHS/WEEE compliant   FUNCTIONAL BLOCK DIAGRAM  ORDERING INFORMATION      PART  MMICT3902‐00‐012  EV_T3902‐FX  TEMP RANGE  PACKAGING  −40°C to +85°C  —  13” Tape and Reel          InvenSense, Inc. reserves the right to change the detail  specifications as may be required to permit  improvements in the design of its products.    InvenSense Inc.  1745 Technology Drive, San Jose, CA 95110 U.S.A  +1(408) 988–7339  www.invensense.com  Document Number: DS‐000357  Revision: 1.0  Rev Date: 4/15/2020   T3902      TABLE OF CONTENTS  General Description ..................................................................................................................................................................... 1  Applications ................................................................................................................................................................................. 1  Features ....................................................................................................................................................................................... 1  Functional Block Diagram ............................................................................................................................................................ 1  Ordering Information ................................................................................................................................................................... 1  Table of Contents .................................................................................................................................................................................... 2  Specifications .......................................................................................................................................................................................... 4  Table 1. Acoustical/Electrical Characteristics – General .............................................................................................................. 4  Table 2. Acoustical/Electrical Characteristics – High‐Performance Mode ................................................................................... 4  Table 3. Acoustical/Electrical Characteristics – Standard Mode .................................................................................................. 5  Table 4. Acoustical/Electrical Characteristics – Low‐Power Mode .............................................................................................. 5  Table 5. Digital Input/Output Characteristics .............................................................................................................................. 6  Table 6. PDM Digital Input/Output .............................................................................................................................................. 6  Timing Diagram ............................................................................................................................................................................ 7  Absolute Maximum Ratings .................................................................................................................................................................... 8  Table 7. Absolute Maximum Ratings ........................................................................................................................................... 8  ESD Caution ................................................................................................................................................................................. 8  Soldering Profile ........................................................................................................................................................................... 9  Table 8. Recommended Soldering Profile* .................................................................................................................................. 9  Pin Configurations And Function Descriptions ..................................................................................................................................... 10  Table 9. Pin Function Descriptions ............................................................................................................................................. 10  Typical Performance Characteristics ..................................................................................................................................................... 11  Theory Of Operation ............................................................................................................................................................................. 12  PDM Data Format ...................................................................................................................................................................... 12  Table 10. T3902 Channel Setting ............................................................................................................................................... 12  PDM Microphone Sensitivity ..................................................................................................................................................... 12  Applications Information ...................................................................................................................................................................... 14  Low Power Mode ....................................................................................................................................................................... 14  Dynamic Range Considerations ................................................................................................................................................. 14  Connecting PDM Microphones .................................................................................................................................................. 14  Sleep Mode ................................................................................................................................................................................ 16  Start‐Up Time ............................................................................................................................................................................. 16  Supporting Documents ......................................................................................................................................................................... 17  Application Notes ...................................................................................................................................................................... 17  PCB Design And Land Pattern Layout ................................................................................................................................................... 18  PCB Material And Thickness ...................................................................................................................................................... 18  Handling Instructions ............................................................................................................................................................................ 19  Pick And Place Equipment ......................................................................................................................................................... 19  Page 2 of 22  Document Number: DS‐000357  Revision: 1.0     T3902      Reflow Solder ............................................................................................................................................................................. 19  Board Wash ............................................................................................................................................................................... 19  Outline Dimensions ............................................................................................................................................................................... 20  Ordering Guide .......................................................................................................................................................................... 20  Revision History ......................................................................................................................................................................... 21  Compliance Declaration Disclaimer ...................................................................................................................................................... 22  Page 3 of 22  Document Number: DS‐000357  Revision: 1.0     T3902      SPECIFICATIONS   TABLE 1. ACOUSTICAL/ELECTRICAL CHARACTERISTICS – GENERAL  TA = 25°C, VDD = 1.8 to 3.3 V, SCK = 2.4 MHz, 50× decimation, CLOAD = 30 pF unless otherwise noted. Typical specifications are not  guaranteed.  PARAMETER    CONDITIONS  MIN  TYP  MAX  UNITS  NOTES  PERFORMANCE  Directionality    Omni      Output Polarity  Input acoustic pressure vs.    Non‐Inverted    output data  Supply Voltage (VDD)    1.65    3.63  V    Sleep Mode Current (IS)  SCK
EV_T3902-FX
物料型号: - 型号:T3902 - 封装:3.5 × 2.65 × 0.98 mm 表面贴装封装 - 工作温度范围:-40°C 至 +85°C - 包装:13"卷带和卷盘
器件简介: - T3902是一款低功耗、低噪声的数字MEMS麦克风,包含MEMS麦克风元件和阻抗转换放大器,以及四阶Σ-Δ调制器。 - 支持多种工作模式:高性能模式、低功耗(AlwaysOn)模式、标准模式和睡眠模式。 - 在所有工作模式下都具有低功耗和高信噪比(SNR)。
引脚分配: - 引脚1:DATA - 数字输出信号(DATA1或DATA2) - 引脚2:SELECT - 左/右声道选择:DATA 1(右):SELECT接地;DATA 2(左):SELECT接VDD。 - 引脚3:GND - 接地 - 引脚4:CLK - 麦克风时钟输入 - 引脚5:VDD - 电源供电
参数特性: - 灵敏度:在低功耗模式下为-26 dB FS+1 dB,在标准模式和高性能模式下分别为-26 dB FS+1 dB和-32 dB FS+1 dB。 - 信噪比:在低功耗模式下为63 dBA,在标准模式下为64.5 dBA,在高性能模式下为64 dBA。 - 电流消耗:在低功耗模式下为185 µA,在标准模式下为430 µA,在高性能模式下为650 µA。 - 声学过载点(AOP):在高性能模式下为126 dB SPL,在标准和低功耗模式下为120 dB SPL。 - 时钟频率:在低功耗模式下为400-800kHz,在标准模式下为1.0-3.3 MHz,在高性能模式下为4.1-4.8 MHz。
功能详解: - T3902具有数字脉冲密度调制(PDM)输出,与Sn/Pb和无铅焊接工艺兼容。 - 支持RoHS和WEEE合规性。 - 具有高电源抑制比(PSR):-97 dB FS。 - 支持睡眠模式,电流消耗仅为12 µA。
应用信息: - 适用于智能手机麦克风阵列、平板电脑、相机、蓝牙耳机、笔记本电脑、安全监控设备等。 - 低功耗模式适用于AlwaysOn监听模式,用于关键词识别和环境声音分析。
封装信息: - 封装类型:5端子LGA_CAV - 封装尺寸:3.5 mm × 2.65 mm × 0.98 mm
EV_T3902-FX 价格&库存
很抱歉,暂时无法提供与“EV_T3902-FX”相匹配的价格&库存,您可以联系我们找货
EV_T3902-FX
  • 1+284.892621+36.90356
