EV_T4086
EV_T4086
    TDK(东电化)
    EV_T4086
EV_T4086 数据手册
AN‐000245    T4086 Flex EVB User Guide        GENERAL DESCRIPTION  EVALUATION BOARD CIRCUIT  The T4086 is an analog single‐ended MEMS microphone.  This  user guide provides information on how to use the flexible  evaluation board for this part, EV_T4086‐FX.    This is a simple evaluation board that allows quick evaluation of  the performance of single‐ended analog MEMS microphones.  The small size and low profile of the flexible PCB enables direct  placement of the microphone into a prototype or an existing  design for an in situ evaluation. The evaluation board consists of  a bottom port microphone soldered to a flexible PCB with color‐ coded wires attached. The only other component on the board  is a 0.1 μF supply bypass capacitor.   Figure 1 shows the schematic of the evaluation board, and  Figure 2 shows the flex board layout. See the respective  microphone data sheets for complete descriptions and  specifications of the microphones.   Figure 3 shows the dimensions of the flex board and identifies  the location of the sound port.  Figure 4 shows the top and bottom views of the flex board.    VDD 0.1µF   OUTPUT Table 1 describes the functions of the three connection wires.  Table 2 describes the performance specifications of the  microphone flex board.  MICROPHONE GND      TABLE 1. PIN FUNCTION DESCRIPTIONS  Figure 1. EV_T4086‐FX Schematic    Wire  Color  Microphone  Pin  Description  Red  VDD    Power Supply. 1.6 V DC to 3.6 V DC  White  OUTPUT  Analog Output Signal  Black  Ground  GND    Figure 2. EV_T4086‐FX Layout (Top View)      TABLE 2. MICROPHONE PERFORMANCE  SPECIFICATIONS  15mm   1.27mm  Sensitivity  ‐38 dBV +/‐  1  Maximum  Maximum  Supply  Output  Output  Current  Voltage  Impedance  140 µA  0.63  Vrms                              1.52mm  DC  Offset  0.74 V    Figure 3. EV_T4086‐FX Dimensions in Millimeters (Wires Not  Included)      Figure 4. EV_T4086‐FX Top and Bottom View    TDK, Inc. reserves the right to change the detail  specifications as may be required to permit  improvements in the design of its products.    250 Ω  3.14mm TDK Corporation   1745 Technology Drive, San Jose, CA 95110 U.S.A  +1(408) 988–7339  www.tdk.com    Document Number: AN‐000245  Revision: 1.0  Release Date: 10/20/2020  AN‐000245        REVISION HISTORY  REVISION  DATE  REVISION  DESCRIPTION  10/20/2020  1.0  Initial release      Page 2 of 3  Document Number: AN‐000245  Revision: 1.0             AN‐000245    COMPLIANCE DECLARATION DISCLAIMER  TDK believes the environmental and other compliance information given in this document to be correct but cannot guarantee  accuracy or completeness. Conformity documents substantiating the specifications and component characteristics are on file. TDK  subcontracts manufacturing, and the information contained herein is based on data received from vendors and suppliers, which has  not been validated by TDK.        This information furnished by TDK, Inc. (“TDK”) is believed to be accurate and reliable. However, no responsibility is assumed by TDK for its use, or for any infringements  of patents or other rights of third parties that may result from its use. Specifications are subject to change without notice. TDK reserves the right to make changes to  this product, including its circuits and software, in order to improve its design and/or performance, without prior notice. TDK makes no warranties, neither expressed  nor implied, regarding the information and specifications contained in this document. TDK assumes no responsibility for any claims or damages arising from information  contained in this document, or from the use of products and services detailed therein. This includes, but is not limited to, claims or damages based on the infringement  of patents, copyrights, mask work and/or other intellectual property rights.   Certain intellectual property owned by TDK and described in this document is patent protected. No license is granted by implication or otherwise under any patent or  patent rights of TDK. This publication supersedes and replaces all information previously supplied. Trademarks that are registered trademarks are the property of their  respective companies. TDK sensors should not be used or sold in the development, storage, production or utilization of any conventional or mass‐destructive weapons  or for any other weapons or life threatening applications, as well as in any other life critical applications such as medical equipment, transportation, aerospace and  nuclear instruments, undersea equipment, power plant equipment, disaster prevention and crime prevention equipment.   ©2020 TDK. All rights reserved. TDK, MotionTracking, MotionProcessing, MotionProcessor, MotionFusion, MotionApps, DMP, AAR, and the TDK logo are trademarks  of TDK, Inc. The TDK logo is a trademark of TDK Corporation. Other company and product names may be trademarks of the respective companies with which they are  associated.    ©2020 TDK. All rights reserved.  Page 3 of 3  Document Number: AN‐000245  Revision: 1.0
EV_T4086 价格&库存
很抱歉,暂时无法提供与“EV_T4086”相匹配的价格&库存,您可以联系我们找货
