C A P A C I T O R S
Ultra high voltage ceramic capacitors
For distribution lines
FD series, MD series
FEATURES
FD series (rated voltage Eac:10 to 25 kV) and MD series (rated voltage Eac:7.2kV) are available
Molded type metal screw terminals for easy mounting
Uses high-reliability mold resin
Extremely stable temperature characteristics
APPLICATION
Distribution line switches (zero-phase detection, demarcation point), traded volume detection
PART NUMBER CONSTRUCTION
607
10
YP
101
Product
category
Ultra high
voltage ceramic
capacitors
Internal
code
Temperature
characteristics
Y5P (–30 to +85°C,
YP
±10%)
CH (–30 to +85°C,
CH
0±60ppm/°C)
Nominal
capacitance
500
50pF
101 100pF
251 250pF
102 1000pF
K
4A
A
Capacitance
Rated voltage Voltage classification
tolerance
J
±5%
3K
7.2kV
AC voltage
A
specifications
K ±10%
4A
10kV
4C
13kV
4D
20kV
4E
25kV
A
Insulation
structure
A Mold type
Please refer to P-3 to 4 about the product dimensions.
OPERATING TEMPERATURE RANGE
Series
FD
MD
Operating
temperature(°C)
–30 to +85
–30 to +85
Storage
temperature(°C)
–30 to +85
–30 to +85
The maximum operating temperature of +85°C includes capacitor self-generated heat of up to 20°C.
PRODUCT APPEARANCE
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/5)
20220713
uhv_fd-md_en.fm
C A P A C I T O R S
FD series
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
Class 2 (Temperature stable)
Temperature characteristic: Y5P(–30 to +85°C, ±10%)
Part numbers
60710YP101K4AAA
60715YP251K4AAA
60722YP501K4AAA
60731YP102K4AAA
60718YP251K4CAA
60726YP501K4CAA
60737YP102K4CAA
60723YP251K4DAA
60732YP501K4DAA
60726YP251K4EAA
60736YP501K4EAA
Rated voltage
Capacitance
Withstanding voltage
(kVAC)
10
10
10
10
13
13
13
25
(pF)
100±10%
250±10%
500±10%
1,000±10%
250±10%
500±10%
1,000±10%
250±10%
500±10%
250±10%
500±10%
[1min, in insulating liquid]
(kVAC)
15
15
15
15
30
40
40
Sub part
numbers
FD-9A
FD-10A
FD-11A
FD-12A
FD-16A
FD-18A
FD-20A
FD-22A
FD-24A
FD-33A
FD-36A
Dissipation
factor (tan)
Insulation
resistance
(%) max.
0.3
0.3
0.3
0.3
0.3
0.3
0.3
0.3
0.3
0.3
0.3
(M) min.
10,000
10,000
10,000
10,000
10,000
10,000
10,000
10,000
10,000
10,000
10,000
AC corona
starting voltage
[3pC ]
(kVAC) min.
12
12
12
12
16
16
16
24
24
32
32
pC : Pico coulomb
● In addition to the above, products of secondary-molded type are also available.
AC VOLTAGE CHARACTERISTIC
50
1
30
Capacitance change rate(%)
TEMPERATURE CHARACTERISTIC
Y5P
10
–10
–30
–50
–50
–1
–2
–3
Temperature(°C)
100
–4
100
Rated voltage(%)
150
(2/5)
20220713
uhv_fd-md_en.fm
C A P A C I T O R S
FD series
SHAPE & DIMENSIONS
FD-9A to FD-16A
ISO M3
screw thread
ISO M3 internal
screw thread
MARKINGS
ø5±0.2
FD-9A
101K
AC10kV
TDK
1234
Sub part number
Nominal capacitance and tolerance code
Rated voltage
Manufacturer’s name (TDK or TDK logo mark)
Lot number
T±2
øD±1
L±1
Part numbers
Sub part
numbers
øD
(mm)
T
(mm)
L
(mm)
60710YP101K4AAA
60715YP251K4AAA
60722YP501K4AAA
60731YP102K4AAA
60718YP251K4CAA
FD-9A
FD-10A
FD-11A
FD-12A
FD-16A
16
21
28
38
26
15
15
15
15
18.5
27
27
27
27
30.5
Effective male
thread size
(mm)
4 min.
4 min.
4 min.
4 min.
4 min.
Effective female
thread depth
(mm)
6+1/0
6+1/0
6+1/0
6+1/0
6+1/0
FD-18A to FD-36A
Female
thread
MARKINGS
ød±0.5
FD-22A
251K
AC20kV
TDK
1234
Sub part number
Rated voltage
Lot number
T±2
øD±1
L±1
Part numbers
Sub part
numbers
øD
(mm)
T
(mm)
L
(mm)
ød
(mm)
60726YP501K4CAA
60737YP102K4CAA
60723YP251K4DAA
60732YP501K4DAA
60726YP251K4EAA
60736YP501K4EAA
FD-18A
FD-20A
FD-22A
FD-24A
FD-33A
FD-36A
34
48
30
40
34
48
23.5
23.5
29.2
29
35
34.5
27.5
27.5
33.2
33
39
38.5
10
15
10
15
10
15
Effective female
Internal screw thread depth
(mm)
ISO M4
5+1/0
ISO M5
5+1/0
ISO M4
5+1/0
ISO M5
5+1/0
ISO M4
5+1/0
ISO M5
5+1/0
(3/5)
20220713
uhv_fd-md_en.fm
C A P A C I T O R S
MD series
Class 1 (Temperature compensating)
Temperature characteristic: CH(–25 to +85°C, 0±60ppm/°C)
Part number
60729CH500J3KAA
Rated voltage
Capacitance
(kVAC)
7.2
(pF)
50±5%
(kVAC)
(%) max.
30
0.2
Sub part
number
MD-1A
Dissipation
factor(tan)
Insulation
resistance
(M) min.
10,000
AC corona
starting voltage
[3pC ]
(kVAC) min.
15
pC : Pico coulomb
1
0.5
1
CH
–0.5
–1
–2
–3
–1
–1.5
–50
Temperature(°C)
100
–4
100
Rated voltage(%)
150
SHAPE & DIMENSIONS
MARKINGS
ø15±0.5
Female
thread
MD-1A
500J
AC7.2kV
TDK
1234
Sub part number
Rated voltage
Lot number
25±2
ø38±1
29±1
Effective female thread depth: 5+1/0mm
(4/5)
20220713
uhv_fd-md_en.fm
C A P A C I T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
(1) During transportation and storage
• Do not transport or store where the prodcuts will be exposed to high temperature or high humidity.
• Do not expose to poisonous gases such as H2SO4, HCl, or HNO3.
• Avoid excessive impact such as that caused by falling.
(2) During operation
• Avoid contact with electrolytes such as perspiration. Do not touch with bare hands.
• Do not apply solder to stud terminals.
• Do not re-machine the terminals.
(3) Usage
• Make sure that the prodcuts are not exposed to radiant heat from chambers or transformers.
• Please contact us when using in SF6 gas.
(4) Others
The products listed on this catalog are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious
damage to society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set
forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment (excepting Pharmaceutical Affairs Law
classification Class1,2)
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
(5/5)
20220713
uhv_fd-md_en.fm
很抱歉,暂时无法提供与“FD-10AU”相匹配的价格&库存,您可以联系我们找货
