C A P A C I T O R S
Ultra high voltage ceramic capacitors
For high voltage power supplies/lasers
FHV series
FEATURES
Lineup of rated voltage Edc: 15 to 50kV
High capacitance and excellent temperature, bias characteristics
Low loss and low distortion factor
Metal screw terminals for easy mounting
Uses high-reliability mold resin
APPLICATION
High-voltage power circuits (for medical devices, lithography, industrial analyzers)
PART NUMBER CONSTRUCTION
607
50
YS
702
K
4C
D
A
Product category
Internal
code
Temperature
characteristic
Nominal
capacitance
701
700pF
851
850pF
132 1300pF
702 7000pF
Capacitance
tolerance
K ±10%
Rated
voltage
4C
15kV
4D
20kV
4F
30kV
4G
40kV
4H
50kV
Voltage
classification
DC voltage
D
specification
Insulation
structure
Ultra high voltage
ceramic capacitors
YS
Y5S(–30 to +85°C,
±22%)
A Mold type
Please refer to P-3 about the product dimensions.
OPERATING TEMPERATURE RANGE
Series
FHV
Operating
temperature(°C)
–30 to +85
Storage
temperature(°C)
–30 to +85
The maximum operating temperature of +85°C includes capacitor self-generated heat of up to 20°C.
PRODUCT APPEARANCE
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/4)
20220808
uhv_fhv_en.fm
C A P A C I T O R S
FHV series
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
Class 2 (Temperature stable)
Temperature characteristic:Y5S
(–30 to +85°C, ±22%)
Part numbers
60750YS702K4CDA
60729YS172K4DDA
60739YS302K4DDA
60750YS522K4DDA
60729YS122K4FDA
60739YS212K4FDA
60750YS352K4FDA
60729YS851K4GDA
60739YS152K4GDA
60750YS262K4GDA
60729YS701K4HDA
60739YS132K4HDA
60750YS212K4HDA
Rated voltage
Capacitance
Withstanding voltage
(kVDC)
15
30
30
40
40
40
50
50
50
(pF)
7,000±10%
1,700±10%
3,000±10%
5,200±10%
1,200±10%
2,100±10%
3,500±10%
850±10%
1,500±10%
2,600±10%
700±10%
1,300±10%
2,100±10%
[1min, in insulating liquid]
(kVDC)
22.5
30
30
30
45
45
45
60
60
60
75
75
75
Sub part
numbers
FHV-153AN
FHV-1AN
FHV-2AN
FHV-3AN
FHV-4AN
FHV-5AN
FHV-6AN
FHV-7AN
FHV-8AN
FHV-9AN
FHV-10AN
FHV-11AN
FHV-12AN
Dissipation
factor(tan)
Insulation
resistance
(%) max.
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
(M) min.
10,000
10,000
10,000
10,000
10,000
10,000
10,000
10,000
10,000
10,000
10,000
10,000
10,000
AC corona
starting voltage
[3pC ]
(kVAC) min.
7.5
10
10
10
15
15
15
25
25
pC:Pico coulomb
TEMPERATURE CHARACTERISTIC
DC VOLTAGE CHARACTERISTIC
50
10
30
Capacitance change rate(%)
Y5S
10
–10
–30
–50
–50
–10
–20
–30
Temperature(°C)
100
–40
100%=Rated voltage
100
Rated voltage(%)
150
(2/4)
20220808
uhv_fhv_en.fm
C A P A C I T O R S
FHV series
SHAPE & DIMENSIONS
ISO M5 female
thread
MARKINGS
FHV-5AN
212K
DC30kV
TDK
1234
ø15±0.5
T±2
øD±1
L±1
Sub part number
Nominal capacitance and tolerance code
Rated voltage
Manufacturer’s name (TDK or TDK logo mark)
Lot number
Effective female thread depth: 5+1/0mm
Part numbers
60750YS702K4CDA
60729YS172K4DDA
60739YS302K4DDA
60750YS522K4DDA
60729YS122K4FDA
60739YS212K4FDA
60750YS352K4FDA
60729YS851K4GDA
60739YS152K4GDA
60750YS262K4GDA
60729YS701K4HDA
60739YS132K4HDA
60750YS212K4HDA
Sub part
numbers
FHV-153AN
FHV-1AN
FHV-2AN
FHV-3AN
FHV-4AN
FHV-5AN
FHV-6AN
FHV-7AN
FHV-8AN
FHV-9AN
FHV-10AN
FHV-11AN
FHV-12AN
øD
(mm)
60
38
48
60
38
48
60
38
48
60
38
48
60
T
(mm)
16.5
18.5
18.5
18.5
22
22
22
26
26
26
29
29
29
L
(mm)
20.5
22.5
22.5
22.5
26
26
26
30
30
30
33
33
33
(3/4)
20220808
uhv_fhv_en.fm
C A P A C I T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
(1) During transportation and storage
• Do not transport or store where the prodcuts will be exposed to high temperature or high humidity.
• Do not expose to poisonous gases such as H2SO4, HCl, or HNO3.
• Avoid excessive impact such as that caused by falling.
(2) During operation
• Avoid contact with electrolytes such as perspiration. Do not touch with bare hands.
• Do not apply solder to stud terminals.
• Do not re-machine the terminals.
(3) Usage
• Make sure that the prodcuts are not exposed to radiant heat from chambers or transformers.
• Please contact us when using in SF6 gas.
(4) Others
The products listed on this catalog are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious
damage to society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set
forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment (excepting Pharmaceutical Affairs Law
classification Class1,2)
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
(4/4)
20220808
uhv_fhv_en.fm
很抱歉,暂时无法提供与“FHV-153AN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+741.08790
- 2+721.46319
- 3+701.82662
- 5+682.19004
- 10+662.55347
- 20+642.91689
- 国内价格 香港价格
- 1+718.528851+92.86929
