FHV-7AN
FHV-7AN
    TDK(东电化)
    Disk
    贴片电容(MLCC) - 850pF ±10% 40KV Y5S
FHV-7AN 数据手册
C A P A C I T O R S Ultra high voltage ceramic capacitors For high voltage power supplies/lasers FHV series FEATURES Lineup of rated voltage Edc: 15 to 50kV High capacitance and excellent temperature, bias characteristics Low loss and low distortion factor Metal screw terminals for easy mounting Uses high-reliability mold resin APPLICATION High-voltage power circuits (for medical devices, lithography, industrial analyzers) PART NUMBER CONSTRUCTION 607 50 YS 702 K 4C D A Product category Internal code Temperature characteristic Nominal capacitance 701 700pF 851 850pF 132 1300pF 702 7000pF Capacitance tolerance K ±10% Rated voltage 4C 15kV 4D 20kV 4F 30kV 4G 40kV 4H 50kV Voltage classification DC voltage D specification Insulation structure Ultra high voltage ceramic capacitors  YS Y5S(–30 to +85°C, ±22%) A Mold type Please refer to P-3 about the product dimensions. OPERATING TEMPERATURE RANGE Series FHV Operating temperature(°C) –30 to +85 Storage temperature(°C) –30 to +85 The maximum operating temperature of +85°C includes capacitor self-generated heat of up to 20°C. PRODUCT APPEARANCE Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20210928 uhv_fhv_en.fm C A P A C I T O R S FHV series ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Class 2 (Temperature stable) Temperature characteristic:Y5S (–30 to +85°C, ±22%) Part numbers 60750YS702K4CDA 60729YS172K4DDA 60739YS302K4DDA 60750YS522K4DDA 60729YS122K4FDA 60739YS212K4FDA 60750YS352K4FDA 60729YS851K4GDA 60739YS152K4GDA 60750YS262K4GDA 60729YS701K4HDA 60739YS132K4HDA 60750YS212K4HDA  Rated voltage Capacitance Withstanding voltage (kVDC) 15 20 20 20 30 30 30 40 40 40 50 50 50 (pF) 7,000±10% 1,700±10% 3,000±10% 5,200±10% 1,200±10% 2,100±10% 3,500±10% 850±10% 1,500±10% 2,600±10% 700±10% 1,300±10% 2,100±10% [1min, in insulating liquid] (kVDC) 22.5 30 30 30 45 45 45 60 60 60 75 75 75 Sub part numbers FHV-153AN FHV-1AN FHV-2AN FHV-3AN FHV-4AN FHV-5AN FHV-6AN FHV-7AN FHV-8AN FHV-9AN FHV-10AN FHV-11AN FHV-12AN Dissipation factor(tan) Insulation resistance (%) max. 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1 (M) min. 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 10,000 AC corona starting voltage [3pC ] (kVAC) min. 7.5 10 10 10 15 15 15 20 20 20 25 25 25 pC:Pico coulomb TEMPERATURE CHARACTERISTIC DC VOLTAGE CHARACTERISTIC 50 10 30 Capacitance change rate(%) 0 Capacitance change rate(%) Y5S 10 –10 –30 –50 –50 –10 –20 –30 0 50 Temperature(°C) 100 –40 100%=Rated voltage 0 50 100 Rated voltage(%) 150 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/4) 20210928 uhv_fhv_en.fm C A P A C I T O R S FHV series SHAPE & DIMENSIONS ISO M5 female thread MARKINGS FHV-5AN 212K DC30kV TDK 1234 ø15±0.5 T±2 øD±1 L±1 Part numbers 60750YS702K4CDA 60729YS172K4DDA 60739YS302K4DDA 60750YS522K4DDA 60729YS122K4FDA 60739YS212K4FDA 60750YS352K4FDA 60729YS851K4GDA 60739YS152K4GDA 60750YS262K4GDA 60729YS701K4HDA 60739YS132K4HDA 60750YS212K4HDA Sub part numbers FHV-153AN FHV-1AN FHV-2AN FHV-3AN FHV-4AN FHV-5AN FHV-6AN FHV-7AN FHV-8AN FHV-9AN FHV-10AN FHV-11AN FHV-12AN øD (mm) 60 38 48 60 38 48 60 38 48 60 38 48 60 T (mm) 16.5 18.5 18.5 18.5 22 22 22 26 26 26 29 29 29 Sub part number Nominal capacitance and tolerance code Rated voltage Manufacturer’s name (TDK or TDK logo mark) Lot number L (mm) 20.5 22.5 22.5 22.5 26 26 26 30 30 30 33 33 33 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20210928 uhv_fhv_en.fm C A P A C I T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS (1) During transportation and storage • Do not transport or store where the prodcuts will be exposed to high temperature or high humidity. • Do not expose to poisonous gases such as H2SO4, HCl, or HNO3. • Avoid excessive impact such as that caused by falling. (2) During operation • Avoid contact with electrolytes such as perspiration. Do not touch with bare hands. • Avoid excessive impact such as that caused by falling. • Do not apply solder to stud terminals. • Do not re-machine the terminals. (3) Usage • Make sure that the prodcuts are not exposed to radiant heat from chambers or transformers. • Please contact us when using in SF6 gas. (4) Others The products listed on this catalog are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (excepting Pharmaceutical Affairs Law classification Class1,2) (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20210928 uhv_fhv_en.fm
FHV-7AN 价格&库存
很抱歉,暂时无法提供与“FHV-7AN”相匹配的价格&库存,您可以联系我们找货
