FS1406-0800-AS
FS1406-0800-AS
    TDK(东电化)
    SMD-17P,3.3x3.3mm
FS1406-0800-AS 数据手册
FS1406 µPOL™ DATASHEET 6A Rated µPOL™ Buck Regulator with Integrated Inductor and Digital Power System Management Features              µPOL™ package with output inductor included Small size: 3.3mm x 3.3mm x 1.5mm Continuous 6A load capability Plug and play: no external compensation required Programmable operation using the I2C serial bus Wide input voltage range: 4.5–16V Adjustable output voltage: 0.6–2.64V, ±0.5% initial accuracy Enabled input, programmable under-voltage lock-out (UVLO) circuit Open-drain power-good indicator Built-in protection features Operating temperature from -40°C to +125°C Lead-free and halogen-free Compliant with EU Directives REACH and RoHS 6 Applications        Storage applications Telecom and networking applications Industrial applications Server applications Distributed point-of-load power architectures Computing peripheral voltage regulation General DC-DC conversion Description The FS1406 is an easy-to-use, fully integrated and highly efficient micro-point-of-load (µPOL™) voltage regulator. The on-chip pulse-width modulation (PWM) controller and integrated MOSFETs, plus incorporated inductor and capacitors, result in an extremely compact and accurate regulator. The low-profile package is suitable for automated assembly using standard surface-mount equipment. Developed by a cross-functional engineering team, the design exemplifies best practice and uses class-leading technologies. From early in the integrated circuit design phase, designers worked with application and packaging engineers to select compatible technologies and implement them in ways that reduce compromise. The ability to program aspects of the FS1406’s operation using the Inter-Integrated Circuit (I2C) protocol is unique in this class of product. Developing and optimizing all of these elements together has yielded the smallest, most efficient and fully featured 6A µPOL™ currently available. The built-in protection features include pre-biased start-up, soft-start protection, over-voltage protection, thermally compensated over-current protection with hiccup mode, thermal shut-down with auto-recovery. Page 1 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Pin configuration Figure 1 Pin layout (top view) Figure 2 Pin layout (bottom view) Pin functions Pin Name Number 1 SDA 2 PG 3 En 4 5 6 7 SCL VOS ADDR VOUT 8, 16 PGnd 9 AGnd 10 VCC 11 VIN 12,13,14, PVIN 17 15 VSW Description I2C Data Serial Input/Output line. Pull up to bus voltage with a 4.99kΩ resistor. If unused tie to AGnd. Power Good status. Open drain of an internal MOSFET. Pull up to VCC – pin 10 or an external bias voltage (Figure 7) – with a 49.9kΩ resistor. Enable. Switches the FS1406 on and off. Can be used with two external resistors to set an external UVLO (Figure 6). I2C Clock line. Pull up to bus voltage with a 4.99kΩ resistor. If unused, tie to AGnd. VOUT sense pin. Connect directly to the regulator output (VOUT). Address. Connect to AGnd through a resistor to program FS1406 address (page 16). Regulator output voltage. Place output capacitors between this pin and PGnd (pin 8). Power ground. Serves as a separate ground for the MOSFETs. Connect to the power ground plane in the application. Signal ground. Serves as the ground for the internal reference and control circuitry. Supply voltage. May be an input bias for an external VCC voltage or the output of the internal LDO regulator. Input voltage. Input for the internal LDO regulator. Power input voltage. Input for the MOSFETs. Test point for internal VSW. Connect to an isolated pad on the PCB. Page 2 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Block diagram Figure 3 FS1406 µPOL™ Typical applications 2.5–16V 5V Figure 4 Single supply applications circuit Figure 5 PVIN VIN SDA SCL ADDR PG En VOUT VOS VOUT PGnd AGnd Dual supply applications circuit Page 3 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Absolute maximum ratings Warning: Stresses beyond those shown may cause permanent damage to the FS1406. Note: Functional operation of the FS1406 is not implied under these or any other conditions beyond those stated in the FS1406 specification. Reference Range PVIN, VIN, En to PGnd VCC to PGnd VOS to AGnd PG to AGnd PGnd to AGnd ESD Classification Moisture Sensitivity Level -0.3V to 18V (Note 1, page 9) -0.3V to 6V (Note 2, page 9) -0.3V to VCC (Note 2, page 9) -0.3V to VCC (Note 2, page 9) -0.3V to +0.3V 2kV (HBM JESD22-A114) MSL 3 (JEDEC J-STD-020D) Thermal Information Range Junction-to-Ambient Thermal Resistance ƟJA 22.6°C/W Junction to PCB Thermal Resistance ƟJ-PCB 2.36°C/W Storage Temperature Range -55°C to 150°C Junction Temperature Range -40°C to 150°C Note: ƟJA : FS1406 evaluation board and JEDEC specifications JESD 51-2A ƟJ-c (bottom) : JEDEC specification JESD 51-8 Page 4 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Order information Package details The FS1406 uses a µPOL™ 3.3 mm x 3.3 mm package delivered in tape-and-reel format (Figure 33), with either 250 or 4000 devices on a reel. Standard part numbers Output voltages of 0.6V to 2.64V are available. VOUT 0.60 0.70 0.75 0.80 0.90 1.00 1.05 1.10 1.20 1.80 2.50 2.64 Part numbers 250 devices on a reel 4000 devices on a reel FS1406-0600-AS FS1406-0600-AL FS1406-0700-AS FS1406-0700-AL FS1406-0750-AS FS1406-0750-AL FS1406-0800-AS FS1406-0800-AL FS1406-0900-AS FS1406-0900-AL FS1406-1000-AS FS1406-1000-AL FS1406-1050-AS FS1406-1050-AL FS1406-1100-AS FS1406-1100-AL FS1406-1200-AS FS1406-1200-AL FS1406-1800-AS FS1406-1800-AL FS1406-2500-AS FS1406-2500-AL FS1406-2640-AS FS1406-2640-AL Page 5 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Recommended operating conditions Definition Symbol Min Max Input Voltage Range with External VCC (Note 3, Note 5) PVIN 2.5 16 Input Voltage Range with Internal LDO (Note 4, Note 5) PVIN, VIN 4.5 16 Supply Voltage Range (Note 2) VCC 4.5 5.5 Output Voltage Range VO 0.6 2.64 Continuous Output Current Range Operating Junction Temperature IO TJ 0 -40 6 125 Units V A °C Electrical characteristics ELECTRICAL CHARACTERISTICS Unless otherwise stated, these specifications apply over: 4.5V < PVIN = VIN < 16V, 0°C < T < 125°C Typical values are specified at TA = 25°C Parameter Symbol Conditions Supply Current VIN Supply Current (Standby) IIN (STANDBY) Enable low VIN Supply Current (Static) IIN (STATIC) No switching, En = 2V En high, VIN = 12V, VOUT = 1.8V, VIN Supply Current (Dynamic) IIN (DYN) FSW=2MHz Soft-Start Soft-Start Rate SSRATE (default) (Note 7) Output Voltage VOUT (default) Output Voltage Range VOUT ≤ 1.8V V (resolution) VOUT > 1.8V TJ = 25°C, PVIN = 12V, VOUT = 1.8V (Note 6) 25°C < TJ < 125°C, PVIN = 12V, Accuracy 0.6V ≤ VOUT < 1.0V (Note 6) 25°C < TJ < 125°C, PVIN = 12V, 1.0V ≤ VOUT ≤ 2.64V (Note 6) On-Time Timer Control On Time TON PVIN = 12V, VOUT = 1.8V, FSW=2MHz Minimum On-Time TON(MIN) (Note 7) Minimum Off-Time TOFF(MIN) PVIN = 1.8V, VOUT = 1.8V, FSW=2MHz Internal Low Drop-Out (LDO) Regulator 5.5V < VIN = 16V, 0 – 20mA LDO Regulator Output Voltage VCC 4.5V 2 V, (open-drain or opencollector) at 2mA sink current; VDD ≤ 2 V, VOL = 0.4 V, VOL = 0.6 V Fast-mode Fast-mode Plus Min Max Min Max 1.8 −0.5 0.7VBUS 0.05VBUS 5.5 0.3VBUS 1.8 −0.5 0.7VBUS 0.05VBUS 5.5 0.3VBUS 0 0.4 0 0.4 0 0.2VBUS 0 0.2VBUS 3 6 - 3 6 - Page 7 Unit V mA Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ ELECTRICAL CHARACTERISTICS Unless otherwise stated, these specifications apply over: 4.5V < PVIN = VIN < 16V, 0°C < T < 125°C Typical values are specified at TA = 25°C Parameter Symbol Conditions (Note 7 for all parameters) I2C parameters Output fall time Fast-mode Plus Min Max Min Max 20 × (VBUS/5.5 V) 250 20 × (VBUS/5.5 V) 125 TSP 0 50 0 50 II CI FSCL −10 0 10 10 400 −10 0 10 10 1000 0.6 - 0.26 - TLOW THIGH 1.3 0.6 - 0.5 0.26 - TSU;STA 0.6 - 0.26 - THD;DAT I2C-bus devices TSU;DAT 0 100 - 0 50 - TR 20 300 - 120 TF 20 × (VDD/5.5 V) 300 20 × (VDD/5.5 V) 120 TSU;STO 0.6 - 0.26 - TOF Pulse width of spikes that must be suppressed by the input filter Input current each I/O pin Capacitance for each I/O pin SCL clock frequency Hold time (repeated) START condition LOW period of the SCL clock HIGH period of the SCL clock Set-up time for a repeated START condition Data hold time Data set-up time Rise time of SDA and SCL signals Fall time of SDA and SCL signals Set-up time for STOP condition Bus free time between a STOP and START condition Capacitive load for each bus line Data valid time Data valid acknowledge time Noise margin at the LOW level Noise margin at the HIGH level SDA timeout Fast-mode From VIHmin to VILmax Unit ns THD;STA After this time, the first clock pulse is generated μA pF kHz μs ns μs TBUF 1.3 - 0.5 - CB - 400 - 550 pF TVD;DAT TVD;ACK - 0.9 0.9 - 0.45 0.45 μs 0.1VDD - 0.1VDD - 0.2VDD - 0.2VDD - VNL VNH TTO For each connected device, including hysteresis V 200 Page 8 200 μs Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Notes 1 PGnd pin and AGnd pin are connected together 2 Must not exceed 6V 3 VIN is connected to VCC to bypass the internal Low Drop-Out (LDO) regulator 4 VIN is connected to PVIN (for single-rail applications with PVIN=VIN=4.5V-5.5V) 5 Maximum switch node voltage should not exceed 22V 6 Hot and cold temperature performance is assured by correlation using statistical quality control, but not tested in production; performance at 25°C is tested and guaranteed in production environment 7 Guaranteed by design but not tested in production Page 9 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Temperature characteristics Output Voltage VIN Supply Current (Dynamic) Enable Start Threshold Enable Stop Threshold VCC Start Threshold VCC Stop Threshold Page 10 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ On Time Switching Frequency Soft-Start Rate Current Limit Threshold Page 11 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Efficiency characteristics Typical efficiency and power loss at PVIN = 12V PVIN = 12V, Internal LDO used, IO = 0A-6A, room temperature, no air flow, all losses included Page 12 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Typical efficiency and power loss at PVIN = 5V PVIN = VIN = VCC = 5V, IO = 0A-6A, room temperature, no air flow, all losses included Page 13 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Typical load regulation PVIN = 12V, internal LDO used, IO = 0A-6A, room temperature, no air flow PVIN = VIN = VCC = 5V, IO = 0A-6A, room temperature, no air flow, all losses included Page 14 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Applications information Overview The FS1406 is an easy-to-use, fully integrated and highly efficient DC/DC regulator. Aspects of its operation, including output voltage and system optimization parameters, can be programmed using the I2C protocol. It uses a proprietary modulator to deliver fast transient responses. The modulator has internal stability compensation so that it can be used in a wide range of applications, with various types of output capacitors, without loop stability issues. The I2C bus may be pulled up either to VCC or to a system I2C bus voltage. The FS1406 offers two ranges for the I2C bus voltage, defined by the user register bit Bus_voltage_sel. Register 0x1A Bits [1] Name/Description Bus_voltage_sel 0:1.8–2.5V, 1: 3.3–5V Bias voltage The FS1406 has an integrated Low Drop-Out (LDO) regulator, providing the DC bias voltage for the internal circuitry. The typical LDO regulator output voltage is 5.2V. For internally biased single-rail operation, the VIN pin should be connected to the PVIN pin (Figure 6). If an external bias voltage is used, the VIN pin should be connected to the VCC pin to bypass the internal LDO regulator (Figure 7). Figure 6 Single supply configuration: internal LDO regulator, adjustable PVIN_UVLO Figure 7 Using an external bias voltage The supply voltage (internal or external) rises with VIN and does not need to be enabled using the En pin. Consequently, I2C communication can begin as soon as:  VCC_UVLO start threshold is exceeded  Memory contents are loaded  Initialization is complete  Address offset is read Note: Until initialization is complete, a small leakage current (≈3.4µA) will flow from the device into the output. This may significantly pre-bias the output voltage in applications with long VIN/VCC rise times. To prevent this, a small load capable of sinking 3.4µA should be connected in such applications. Page 15 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ I2C base address and offsets The FS1406 has a user register called Base_address[7:0] stored in memory that sets its base I2C address. The default base address is 0x08. An offset of 0-3 is then defined by connecting the ADDR pin to the AGnd pin either directly or through a resistor. An address detector reads the resistance of the connection at startup and uses it to set the offset, which is added to the base I2C address to set the address at which the I2C master device will communicate with the FS1406. To select offsets of 0 to 3, connect the pins as follows:     0 +1 +2 +3 – – – – 0Ω (short ADDR to AGnd) 10kΩ 20kΩ >30.1kΩ Figure 8 Soft-start and target output voltage The FS1406 has an internal digital soft-start circuit to control output voltage rise-time and limit current surge at start-up. When VCC exceeds its start threshold (VCC_UVLO(START)), the FS1406 exits reset mode; this initiates loading of the contents of the non-volatile memory into the working registers and calculates the address offset as described above. Once initialization is complete and the Enable (En) pin has been asserted (Figure 8), the internal reference soft-starts to the target output voltage at the rate defined by the user register bit SS_rate. Register 0x14 Bits [3] Name/Description SS_rate 0:0.5mV/µs (default), 1: 1 mV/µs Theoretical operational waveforms during soft-start Register 0x12 0x13 Bits [0] [7:0] Name/Description Vout_high_byte Vout_low_byte VOUT is set in increments of 5mV for target voltages up to 1.8V, and 10mV increments for target output voltages from 1.8V to 2.64V. Use the following equation to calculate the VOUT code to enter into Vout_high_byte and Vout_low_byte[7:0]: 𝑉𝑜𝑢𝑡𝑐𝑜𝑑𝑒 = 0.4 × 𝑟𝑒𝑠𝑜𝑙𝑢𝑡𝑖𝑜𝑛 0.005 𝑟𝑒𝑠𝑜𝑙𝑢𝑡𝑖𝑜𝑛 𝑉𝑜𝑢𝑡𝑡𝑎𝑟𝑔𝑒𝑡 − All voltages and resolutions are in Volts. For example: To set VOUT =1V (≤1.8V, resolution of 5mV): During initial start-up, the FS1406 operates with a minimum of high-drive (HDrv) pulses until the output voltage increases (see Switching frequency and minimum values for on-time, off-time on page 18). On-time is increased until VOUT reaches the target value defined by the user register bit Vout_ high_byte and user register Vout_low_byte[7:0]. 0.4 × 0.005 0.005 𝑉𝑜𝑢𝑡𝑐𝑜𝑑𝑒 = = 120 0.005 120 is 078 in hexadecimal, therefore: 1− Set Vout_high_byte to 0 Set Vout_low_byte to 78 or (01111000)b Page 16 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ To set VOUT =2.5V (>1.8V, resolution of10mV): 0.4 × 0.01 0.005 = 170 𝑉𝑜𝑢𝑡𝑐𝑜𝑑𝑒 = 0.01 170 is 0AA in hexadecimal, therefore: 2.5 − Set Vout_high_byte to 0 Set Vout_low_byte to AA or (10101010)b Over-current protection (OCP) and over-voltage protection (OVP) is enabled during soft-start to protect the FS1406 from short circuits and excess voltages respectively. For maximum system accuracy, the recommended way to set the output voltage is by programming the user registers with the appropriate code. For optimum performance when using this approach, the change in output voltage should not exceed ±20% of the pre-set default output voltage. However, another option is to combine an FS1406 pre-programmed to 0.6V with a feedback resistor divider (Figure 9). This gives system designers the flexibility to design all the power rails in the system across the output voltage range from 0.6V to 2.5V using a single part, at the expense of a worst-case error of no more than an additional -1%. Figure 9 Setting the output voltage with an external resistor divider The equation below describes the appropriate resistor divider selection to set the output voltage using a FS1406 programmed to 0.6V. 𝑅𝑇𝑂𝑃 𝑅𝐵𝑂𝑇𝑇𝑂𝑀 = 1.745𝑉𝑂𝑈𝑇 − 1.047 It is recommended that system designers place a capacitor of 4.7pF to 47pF in parallel with RTOP, for which a value of 40.2kΩ is recommended. The recommended value for RBOTTOM depends on the output voltage, as shown in the following table. If RBOTTOM > 100kΩ, it is recommended to use a lower RTOP such as 4.02kΩ, with the compensation capacitor in the 47pF to 470pF range. VOUT (V) 0.65 0.7 0.72 0.75 0.78 0.8 0.85 0.88 0.9 0.95 1 1.05 1.1 1.15 1.2 1.25 1.3 1.35 1.4 1.45 1.5 RTOP /RBOTTOM 0.08725 0.1745 0.2094 0.26175 0.3141 0.349 0.4363 0.489 0.524 0.611 0.698 0.785 0.873 0.96 1.047 1.135 1.222 1.309 1.397 1.484 1.571 VOUT (V) 1.55 1.6 1.65 1.7 1.75 1.8 1.85 1.9 1.95 2 2.05 2.1 2.15 2.2 2.25 2.3 2.35 2.4 2.45 2.5 RTOP /RBOTTOM 1.658 1.745 1.833 1.92 2.008 2.095 2.182 2.27 2.357 2.445 2.532 2.619 2.706 2.794 2.881 2.968 3.056 3.143 3.222 3.318 For output voltages over 1.8V, the output current and input voltage ranges are restricted by minimum off-time (the shortest time for which the FS1406 can be switched off). FS1406-2500 and FS1406-2640 are recommended for 2.5V and 2.64V applications respectively. Page 17 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Pre-biased start-up The FS1406 can start up into a pre-charged output smoothly, without causing oscillations and disturbances of the output voltage. When it starts up in this way, the Control and Synchronous MOSFETs are forced off until the internal Soft-Start (SS) signal exceeds the sensed output voltage at the VOS pin. Only then is the first gate signal of the Control MOSFET generated, followed by complementary turn on of the Synchronous MOSFET. The Power Good (PG) function is not active until this point. Shut-down mechanisms The FS1406 has two shut-down mechanisms:   Hard shut-down or decay according to load Initiated by de-asserting the En pin. Both drivers switch off and the digital-toanalog converter (DAC) and soft-start are pulled down instantaneously. Soft-Stop or controlled ramp down Initiated by setting user register bit SoftStopEnable to 1 and user register bit SoftDisable to 1. The SS signal falls to 0 at the same rate as it rises during start-up; the drivers are disabled only when it reaches 0. The output voltage then follows the SS signal down to 0. The SoftDisable bit must not be toggled while the part is enabled and switching. Instead, for applications requiring soft-stop, this bit must be set to 1 and, with the En pin asserted, the SoftStopEnable bit must be toggled to softstart or soft-stop the device. By default, both the SoftDisable bit and the SoftStopEnable bit are 0, which means that soft-stop operation is disabled by default. Register 0x14 0x1C Bits [2] [3] Name/Description SoftStopEnable SoftDisable Switching frequency and minimum values for on-time, off-time and PVIN The switching frequency of the FS1406 depends on the output voltage. For an output voltage of 1.8V, the switching frequency is nominally 2MHz. When the output voltage is set by programming the user registers, the appropriate switching frequency is also programmed at the factory. When the output voltage is set using an external resistor divider, the switching frequency automatically adjusts to the appropriate value: 𝑉𝑂𝑈𝑇 0.6 Therefore, with either method, system designers need not concern themselves with selecting the switching frequency and have one fewer design task to manage. 𝐹𝑠𝑤 = 650𝑘𝐻𝑧 × When input voltage is high relative to target output voltage, the Control MOSFET is switched on for shorter periods. The shortest period for which it can reliably be switched on is defined by minimum on-time (TON(MIN)). During start-up, when the output voltage is very small, the FS1406 operates with minimum on-time. When input voltage is low relative to target output voltage, the Control MOSFET is switched on for longer periods. The shortest period for which it can be switched off is defined by minimum off-time (TOFF(MIN)). The Synchronous MOSFET stays on during this period and its current is detected for over-current protection. This dictates the minimum input voltage that can still allow the device to regulate its output at the target voltage. Figure 10 shows the minimum input voltage required for some typical output voltages. This curve assumes typical efficiency numbers; since it is affected by efficiency, system designers should validate the values in their own applications. Page 18 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Note: VIN = VCC = 5V for PVIN < 4.2V Figure 10 Minimum input voltage requirements Figure 11 En pin used to monitor other rails for sequencing purposes Enable (En) pin The Enable (En) pin has several functions:     It is used to switch the FS1406 on and off. It has a precise threshold, which is internally monitored by the UVLO circuit. If it is left floating, an internal 1MΩ resistor pulls it down to prevent the FS1406 being switched on unintentionally. It can be used to implement a precise input voltage UVLO. The input of the En pin is derived from the PVIN voltage by a set of resistive dividers, REN1 and REN2 (Figure 6). Users can program the UVLO threshold voltage by selecting different ratios. This is a useful feature that stops the FS1406 regulating when PVIN is lower than the desired voltage. It can be directly connected to PVIN without external resistive dividers for some spaceconstrained designs. This is a useful feature for standalone start-up, when no logic signal is available to enable the FS1406. It can be used to monitor other rails for a specific power sequencing scheme (Figure 11). Figure 12 Start-up: PVIN, VIN and En pins tied together, PG pin pulled up to an external supply Page 19 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ The OCP threshold is defined by the user register bits OCSet. Register 0x15 Bits [2:0] Name/Description OCSet 2:8A (default), 1:6A, 0: 4A The threshold is internally compensated so that it remains almost constant at different ambient temperatures. Figure 13 Start-up: En pin asserted after PVIN and VIN, When the current exceeds the OCP threshold, the PG and SS signals are pulled low. The Synchronous MOSFET remains on until the current falls to 0, then the FS1406 enters hiccup mode (Figure 14). Both the Control MOSFET and the Synchronous MOSFET remain off for the hiccup-blanking time. After this time, the FS1406 tries to restart. If an over-current fault is still detected, the preceding actions are repeated. The FS1406 remains in hiccup mode until the over-current fault is remedied. PG pin pulled up to an external supply For VOUT to start up as defined by the soft-start rate requires correct sequencing:   PVIN must start up before VCC and/or Enable. PVIN must ramp down only after VCC has ramped down below its UVLO threshold and/or Enable has been de-asserted. Over-current protection (OCP) Over-current protection (OCP) is provided by sensing the current through the RDS(on) of the Synchronous MOSFET. When this current exceeds the OCP threshold, a fault condition is generated. This method provides several benefits:    Figure 14 Illustration of OCP in hiccup mode Provides accurate overcurrent protection without reducing converter efficiency (the current sensing is lossless) Reduces cost by eliminating a current-sense resistor Reduces any layout-related noise issues. Page 20 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Over-voltage protection (OVP) Over-temperature protection (OTP) Over-voltage protection (OVP) is provided by sensing the voltage at the VOS pin. When VOS exceeds the output OVP threshold for longer than the output OVP delay (typically 5μs), a fault condition is generated. Temperature sensing is provided inside the FS1406. The OTP threshold is defined by the user register bits OT_Threshold. Register 0x19 Bits [1:0] The OVP threshold is defined by the user register bits OV_Threshold. Register 0x17 Bits [1:0] Name/Description OV_Threshold 0:105% of VOUT 1:110% of VOUT 2:115% of VOUT 3:120% of VOUT (default) The Control MOSFET is switched off immediately and the PG pin is pulled low. The Synchronous MOSFET is switched on to discharge the output capacitor. The Control MOSFET remains latched off until reset by cycling either VCC or En. The voltage at the VOS pin falling below the output OVP threshold (with 5% hysteresis) does not switch on the Control MOSFET but it does switch off the Synchronous MOSFET to prevent build-up of negative current. Name/Description OT_Threshold 0:75°C 1: 85°C 2: 125°C 3: 145°C (default) When the threshold is exceeded, thermal shutdown switches off both MOSFETs and resets the internal soft-start, but the internal LDO regulator is still in operation. Automatic restart is initiated when the sensed temperature drops within the operating range. There is a 20°C hysteresis in the OTP threshold. Power Good (PG) Power Good (PG) behavior is defined by the user register bits PGControl and PG_Threshold. Register 0x18 Bits [1:0] 0x14 [0] Figure 15 shows a timing diagram for over-voltage protection. Name/Description PG_Threshold 0:80% of VOUT 1: 85% of VOUT 2: 90% of VOUT (default) 3: 95% of VOUT PG_Control 1:Threshold based (default) 0: DAC based Figure 15 Illustration of latched OVP Page 21 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ PG_Threshold bit PGControl bit set to 0 The user register bit PG_Threshold defines the PG threshold as a percentage of VOUT. Hysteresis of 5% is applied to this, giving a lower threshold. Figure 17 shows PG behavior in this situation. When VOS rises above the upper threshold, the PG signal is pulled high. When VOS drops below the lower threshold, the PG signal is pulled low. PGControl bit set to 1 (default) Figure 16 shows PG behavior in this situation. The behavior is the same at start-up and during normal operation. The PG signal is asserted when:    En and VCC are both above their thresholds No fault has occurred (including over-current, over-voltage and over-temperature) VOUT is within the target range (determined by continuously monitoring whether VOS is above the PG threshold) In normal operation, the PG signal behaves in the same way as when the PGControl bit is 1. At start-up, however, the PG signal is asserted after soft-start is within 2% of target output voltage, not when VOS exceeds the upper PG threshold. For pre-biased start-up, the PG signal is not active until the first gate signal of the Control MOSFET is generated. FS1406 also integrates an additional PMOS in parallel to the NMOS internally connected to the PG pin (Figure 3). This PMOS allows the PG signal to stay at logic low, even if VCC is low and the PG pin is pulled up to an external voltage not VCC (Figure 12 and Figure 13). Figure 17 PG signal when PGControl bit=0 Figure 16 PG signal when PGControl bit=1 Page 22 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Design example Output voltage and output capacitor Let us now consider a simple design example, using the FS1406 for the following design parameters: The FS1406 is supplied pre-programmed and factory-trimmed in a closed loop to the target voltage specified for the part number. As a result, no external resistor divider is required and resistor tolerances are eliminated from the error budget.        PVIN = VIN = 12V VOUT = 1.8V FSW = 2MHz COUT = 2 x 22μF CIN = 2 x 22μF Ripple Voltage = ± 1% * VOUT ΔVOUT(MAX) = ±3% * VOUT (for 50% load transient) The design requires minimal output capacitance to meet the target output voltage ripple and target maximum output voltage deviation under load transient conditions. For the FS1406, the minimum number of output capacitors required to achieve target peak-to-peak VOUT ripple is: Input capacitor The input capacitor selected for this design must:   Handle the peak and root mean square (RMS) input currents required by the FS1406 Have low equivalent series resistance and inductance (ESR and ESL) to reduce input voltage ripple MLCCs (multi-layer ceramic capacitors) are ideal. Typically, in 0805 case size, they can handle 2A RMS current with less than 5°C temperature rise. For a buck converter operating at duty cycle D and output current IO, the RMS value of the input current is: 𝑉𝑂𝑈𝑇 𝑃𝑉𝐼𝑁 where:        𝐼𝑅𝑀𝑆 = 𝐼𝑜√𝐷(1 − 𝐷) In this application, IO = 6A and 𝐷 = (𝟏 − 𝑫) 𝑬𝑺𝑳 × 𝑭𝑺𝑾 × (𝟏 − 𝑫)𝟐 + 𝑬𝑺𝑹(𝟏 − 𝑫) + 𝟖𝑪𝑭𝑺𝑾 𝑫 𝑵𝑴𝑰𝑵 = 𝟒. 𝟎𝟗 × ∆𝑉𝑂𝑈𝑇𝑟𝑖𝑝𝑝𝑙𝑒(𝑝−𝑝) = 0.15 Therefore, IRMS = 2.14A and we can select two 22μF 16V ceramic capacitors for the input capacitors (C3216X5R1C226M160AB from TDK). If the FS1406 is not located close to the 12V power supply, a bulk capacitor (68–330μF) may be used in addition to the ceramic capacitors. NMIN = minimum number of output capacitors D = duty cycle C = equivalent capacitance of each output capacitor FSW = switching frequency ESR = equivalent series resistance of each output capacitor ESL = equivalent series inductance of each output capacitor ∆𝑉𝑂𝑈𝑇𝑟𝑖𝑝𝑝𝑙𝑒(𝑝−𝑝) = target peak-to-peak VOUT ripple This design uses C2012X5R0J226K125AB from TDK; this is a 22μF MLCC, 0805 case size, rated at 6.3V. At 1.8V, accounting for DC bias and AC ripple derating, it has an equivalent capacitance of 12μF (C). Equivalent series resistance is 3mΩ (ESR) and equivalent series inductance is 0.44nH (ESL). Putting these parameters into the equation gives: NMIN = 1.27 For VIN, which is the input to the LDO, it is recommended to use a 1μF capacitor very close to the pin. The VIN pin should be connected to PVIN through a 2.7Ω resistor. Together, the 2.7Ω resistor and 1μF capacitor filter noise on PVIN. Page 23 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ To meet the maximum voltage deviation ΔVomax under a ∆𝐼𝑜 load transient, the minimum required number of output capacitors is: transient. These waveforms show that the selection of two 22μF capacitors meets the design criteria. 𝟎. 𝟐𝟒𝟒 × ∆𝑰𝟐𝒐 ∆𝑉𝑜𝑚𝑎𝑥 × 𝐹𝑠𝑤 × 𝐶 It should be noted that even in the absence of a target VOUT ripple or target maximum voltage deviation under load transient, at least one 22μF capacitor is still required in order to ensure stable operation without excessive jitter. where:     ∆𝐼𝑜 = load step ∆𝑉𝑂𝑈𝑇𝑚𝑎𝑥 = target maximum voltage deviation 𝐹𝑠𝑤 = switching frequency C = equivalent capacitance of each output capacitor Again, using C = 12μF, it can be seen that the minimum number of output capacitors required is 0.4. In our design intended for space-constrained applications, therefore, we use two C2012X5R0J226K125AB capacitors. It should be noted here that the calculation for the minimum number of output capacitors under a load transient makes some assumptions: a) No ESR or ESL b) Converter can saturate its duty cycle instantly c) No latency d) Step load (infinite slew rate) Assumptions (a), (b) and (c) are liberal, whereas (d) is conservative. Therefore, in a real application, additional capacitance may be required to meet transient requirements and should be carefully considered by the system designer. The typical application waveforms in Figure 26 and Figure 27 show the steady state VOUT ripple as well as the voltage deviation in response to a 50% load Up to six 22μF capacitors may be used in the design. If more capacitance is required, it is recommended to use a capacitor with relatively high ESR (>3mΩ). Note: The above discussion applies to designs that use FS1406-1800 devices with VOUT tied to VOS and no feedback divider. If an FS1406-0600 is used to generate 1.8V, with a resistive voltage divider between VOUT and VOS, the feedforward capacitor in parallel with the top resistor will allow greater flexibility in choice of output capacitance. Figure 18 shows the minimum required output capacitance as a function of the output voltage. For an output voltage of 1V, the minimum capacitor requirement is dictated by the load transient specifications (< ±3% VOUT). For output voltages above 1V, the output voltage ripple specification dominates (< ±1%). VCC capacitor selection FS1406 uses an on-package VCC capacitor to ensure effective high-frequency bypassing. However, especially for applications that use an external VCC supply, it is recommended that system designers place a 2.2μF/0603/X7R/10V capacitor on the application board as close as possible to the VCC pin. Page 24 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Figure 18 Minimum output capacitance Figure 19 Application circuit for a single supply, PVIN=12V, VOUT=1.8V, 6A Page 25 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Typical operating waveforms Figure 20 Startup with no load (Ch1:PVIN, Ch2: VOUT, Ch3: PGood, Ch4:VCC, Ch5: Enable) Figure 21 Startup with 6 A load (Ch1:PVIN, Ch2: VOUT, Ch3: PGood, Ch4:VCC, Ch5: Enable) Page 26 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Figure 22 Shutdown with Enable de-assertion at 6A load (Ch1:PVIN, Ch2: VOUT, Ch3: PGood, Ch4:VCC, Ch5: Enable) Figure 23 Soft turn off at no load (Ch1:PVIN, Ch2: VOUT, Ch3: PGood, Ch4:VCC, Ch5: Enable) Page 27 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Figure 24 Startup with no load (Ch1:PVIN, Ch2: VOUT, Ch3: PGood, Ch4:VCC, Ch5: Enable) Figure 25 Startup with 6 A load (Ch1:PVIN, Ch2: VOUT, Ch3: PGood, Ch4:VCC, Ch5: Enable) Page 28 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Figure 26 VO ripple at 0A (Ch8:IO, Ch1: Sw, Ch2: VOUT), Peak-Peak VO ripple=12mV Figure 27 VO ripple at 6A (Ch8:IO, Ch1: Sw, Ch2: Vout), Peak-Peak VO ripple=15.19mV Page 29 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Figure 28 Transient response 0A to 3A (Ch6:IO, Ch2: VOUT), peak-peak deviation=62mV Figure 29 Thermal image at PVIN = 12V, VOUT = 1.8V, IO = 6A, room temperature, no airflow, FS1406 maximum temperature = 69°C Page 30 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Layout recommendations Thermal considerations FS1406 is a highly integrated device with very few external components, which simplifies PCB layout. However, to achieve the best performance, these general PCB design guidelines should be followed: The FS1406 has been thermally tested and modelled in accordance with JEDEC specifications JESD 51-2A and JESD 51-8. It has been tested using a 4-layer application PCB, with thermal vias under the device to assist cooling (for details of the PCB, refer to the application notes).        Bypass capacitors, including input/output capacitors and the VCC bypass capacitor (if used), should be placed as close as possible to the FS1406 pins. Output voltage should be sensed with a separated trace directly from the output capacitor. Analog ground and power ground are connected through a single-point connection. To aid thermal dissipation, the PGnd pad should be connected to the power ground plane using vias. Copper-filled vias are preferred but plated-through-hole vias are acceptable, provided that they are not filled with resin or covered with solder mask. Adequate numbers of vias should be used to make connections between layers, especially for the power traces. To minimize power losses and thermal dissipation, wide copper polygons should be used for input and output power connections. SCL and SDA traces must be at least 10mil wide, with 20–30mil spacing between them. The FS1406 has two significant sources of heat:   The power MOSFET section of the IC The inductor The IC is well coupled to the PCB, which provides its primary cooling path. Although the inductor is also connected to the PCB, its primary cooling path is through convection. The cooling process for both heat sources is ultimately through convection. The PCB can be seen as a heat-spreader or, to some degree, a heat-sink. Figure 30 Heat sources in the FS1406 Page 31 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Figure 31 shows the thermal resistances in the FS1406, where:    ϴJA is the measure of natural convection from the assembled test sample within a confined enclosure of approximately 30x30x30cm. The air is passive within this environment and the only air movement is due to convection from the device on test. ϴJCbottom is the heat flow from the IC to the bottom of the package, to which it is well coupled. The testing method adopts the method outlined in JESD 51-8, where the test PCB is clamped between cold plates at defined distances from the device. ϴJCtop is theoretically the heat flow from the IC to the top of the package. This is not representative for the FS1406 for two reasons: firstly, it is not the primary conduction path of the IC and, more importantly, the inductor is positioned directly over the IC. As the inductor is a heat source, generating a similar amount of heat to the IC, a meaningful value for junction-to-case (top) cannot be derived. The values of the thermal resistances are:   ϴJA = 22.6°C/W ϴJCbottom = 2.36°C/W Although these values indicate how the FS1406 compares with similar point-of-load products tested using the same conditions and specifications, they cannot be used to predict overall thermal performance. For accurate modeling of the µPOL™’s interaction with its environment, computational fluid dynamics (CFD) simulation software is needed to calculate combined routes of conduction and convection simultaneously. Note: In all tests, airflow has been considered as passive or static; applications using forced air may achieve a greater cooling effect. Figure 31 Thermal resistances of the FS1406 Page 32 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ I2C protocol S P A N = = = = Start bit Stop bit Ack Nack W R Sr = = = Write bit (‘1’) Read (‘0’) Repeated start White bits Grey bits = = Issued by master Sent by slave (FS140x) Write transaction 1 7 1 1 8 1 8 1 1 S Slave Address W A Register Address A Data Byte A P Read transaction 1 7 1 1 8 1 1 7 1 1 8 1 1 S Slave Address W A Register Address A Sr Slave Address R A Data Byte N P Page 33 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Package description The FS1406 is designed for use with standard surfacemount technology (SMT) population techniques. It has a positive (raised) footprint, with the pads being higher than the surrounding substrate. The finish on the pads is ENiG (Electroless Nickel Immersion Gold). As a result of these properties, the FS1406 works extremely well in lead-free environments. The surface wets easily and the positive footprint accommodates processing variations. Note: Refer to the Design Guidelines for more information about TDK’s µPOL™ package series, including important guidance on checking the compatibility of manufacturing processes such as cleanable flux systems. Figure 32 Dimensioned drawings Page 34 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ Figure 33 Tape and reel pack Page 35 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice. FS1406 µPOL™ REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDER The products listed on this specification sheet are intended for use in general electric equipment (AV equipment, telecommunication equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal condition and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to sociality, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. 1. Aerospace/Aviation equipment 2. Transportation equipment (cars, electric trains, ships, etc.) 3. Medical equipment 4. Power-generation control equipment 5. Atomic energy related equipment 6. Seabed equipment 7. Transportation control equipment 8. Public Information-processing equipment 9. Military equipment 10. Electric heating apparatus, burning equipment 11. Disaster prevention/crime prevention equipment 12. 13. Safety equipment Other applications that are not considered general-purpose applications When using this product in general-purpose application, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. This product is subject to a license from Power One, Inc. related to digital power technology patents owned by Power One, Inc. Power One, Inc. technology is protected by patents including: AU 3287379M 3287437AA 3290643AA 3291357AA CN 10371856C 10452610C 10458656C 10459360C 10465848C 1069332A 11124619A 11346682A 1685299A 1685459A 1685582A 1685583A 1698023A 1802619A EP 1561156A1 1561268A2 1576710A1 1576711A1 1604254A4 1604264A4 1714369A2 1745536A4 1769382A4 1899789A2 1984801A2 US 20040246754 2004090219A1 2004093533A1 2004123164A1 2004123167A1 2004178780A1 2004179382A1 20050200344 20050223252 2005209373A1 20060061214 2006015619A1 20060174145 20070226526 20070234095 20070240000 20080052551 20080072080 20080186006 6741099 6788036 6936999 6949916 7000125 7049798 7069021 7080265 7249267 7266709 7315156 7372682 7373527 7394445 7456617 7459892 7493504 7526660 WO 04044718A1 04045042A3 04045042C1 04062061A1 04062062A1 04070780A3 04084390A3 04084391A3 05079227A3 05081771A3 06019569A3 2007001584A3 2007094935A3 Page 36 Rev 3.5, Dec 2, 2021 Patent Protected: US 9,729,059 B1; US 10,193,442 B2 Copyright© 2018–20 TDK Corporation. All rights reserved. All registered trademarks and trademarks are the property of their respective owners. Data and specifications subject to change without notice.
FS1406-0800-AS 价格&库存
很抱歉,暂时无法提供与“FS1406-0800-AS”相匹配的价格&库存,您可以联系我们找货
FS1406-0800-AS
    库存:500
    FS1406-0800-AS
    • 1+86.916461+11.29502
