HAL1507 UA
HAL1507 UA
    TDK(东电化)
    TO-92-3
    数字开关 单极开关 开路漏极 霍尔效应 TO-92UA
HAL1507 UA 数据手册
Hardware Documentation D at a S h e e t ® HAL 150y Hall-Effect Switch with Open-Drain Output (3-wire) in SOT23 Package Edition June 15, 2016 DSH000179_002EN HAL 150y DATA SHEET Copyright, Warranty, and Limitation of Liability The information and data contained in this document are believed to be accurate and reliable. The software and proprietary information contained therein may be protected by copyright, patent, trademark and/or other intellectual property rights of Micronas. All rights not expressly granted remain reserved by Micronas. Micronas assumes no liability for errors and gives no warranty representation or guarantee regarding the suitability of its products for any particular purpose due to these specifications. By this publication, Micronas does not assume responsibility for patent infringements or other rights of third parties which may result from its use. Commercial conditions, product availability and delivery are exclusively subject to the respective order confirmation. Any information and data which may be provided in the document can and do vary in different applications, and actual performance may vary over time. All operating parameters must be validated for each customer application by customers’ technical experts. Any new issue of this document invalidates previous issues. Micronas reserves the right to review this document and to make changes to the document’s content at any time without obligation to notify any person or entity of such revision or changes. For further advice please contact us directly. Do not use our products in life-supporting systems, military, aviation, or aerospace applications! Unless explicitly agreed to otherwise in writing between the parties, Micronas’ products are not designed, intended or authorized for use as components in systems intended for surgical implants into the body, or other applications intended to support or sustain life, or for any other application in which the failure of the product could create a situation where personal injury or death could occur. No part of this publication may be reproduced, photocopied, stored on a retrieval system or transmitted without the express written consent of Micronas. Micronas Trademarks – HAL Third-Party Trademarks All other brand and product names or company names may be trademarks of their respective companies. Micronas June 15, 2016; DSH000179_002EN 2 HAL 150y DATA SHEET Contents, continued Page Section Title 4 5 1. 1.1. Introduction Features of HAL 150y 6 6 2. 2.1. Ordering Information Device-Specific Ordering Codes 8 9 9 10 3. 3.1. 3.1.1. 3.2. Functional Description of HAL 150y Functional Safety According to ISO 26262 Diagnostic Features Power-On Self-Test 12 12 14 14 15 16 17 17 18 19 21 23 25 27 29 31 33 4. 4.1. 4.2. 4.3. 4.3.1. 4.4. 4.5. 4.6. 4.7. 4.8. 4.9. 4.10. 4.11. 4.12. 4.13. 4.14. 4.15. Specifications Outline Dimensions Soldering, Welding and Assembly Pin Connections (from Top Side, example HAL 1502) and Short Descriptions Dimension and Position of Sensitive Area Absolute Maximum Ratings ESD and Latch-up Storage and Shelf Life Recommended Operating Conditions Characteristics HAL 1501 Magnetic Characteristics HAL 1502 Magnetic Characteristics HAL 1503 Magnetic Characteristics HAL 1506 Magnetic Characteristics HAL 1507 Magnetic Characteristics HAL 1508 Magnetic Characteristics HAL 1509 Magnetic Characteristics 35 35 36 37 38 38 5. 5.1. 5.1.1. 5.2. 5.3. 5.4. Application Notes Application Circuits ESD System Level Application Circuit (ISO10605-2008) Ambient Temperature Start-Up Behavior EMC and ESD 39 6. Data Sheet History Micronas June 15, 2016; DSH000179_002EN 3 HAL 150y DATA SHEET Hall-Effect Switch with Open-Drain Output (3-wire) in SOT23 Package Release Note: Revision bars indicate significant changes to the previous edition. 1. Introduction The HAL 150y Hall-switch family members produced in CMOS technology as 3-wire device with open-drain output transistor include a temperature-compensated Hall plate with active offset compensation, a comparator, and an output stage. The comparator compares the actual magnetic flux through the Hall plate (Hall voltage) with the fixed reference values (switching points). Accordingly the output transistor is switched on or off. The active offset compensation leads to constant magnetic characteristics over supply voltage and temperature range. In addition, the magnetic parameters are robust against mechanical stress effects. The sensor is designed for industrial and automotive applications and operates with supply voltages from 2.7 V to 24 V in the junction temperature range from 40 C up to 170 C. HAL 150y is available in a JEDEC TO236-compliant SMD-package 3-lead SOT23. Micronas June 15, 2016; DSH000179_002EN 4 HAL 150y DATA SHEET 1.1. Features of HAL 150y – SOT23-3L JEDEC TO236-compliant package – ISO 26262 compliant as ASIL A ready device – Short-circuit protected open-drain output and thermal shutdown – Low current consumption of typ. 1.6 mA – Operates with supply voltages from 2.7 V to 24 V – Overvoltage protection capability up to 40 V – Reverse-voltage protected VSUP-pin (18 V) – High ESD performance of ±8 kV (HBM) – Diagnostic features: power-on self test – Sample frequency of 500 kHz, 2 µs output refresh time – Operates with static and dynamic magnetic fields up to 12 kHz – High resistance to mechanical stress by active offset compensation – Constant switching points over a wide supply voltage and temperature range – Wide junction temperature range from 40 °C to 170 °C – Built-in temperature coefficient – Optimized for applications in extreme automotive and industrial environments – Qualified according to AEC-Q100 test standard for automotive electronics industry to provide high-quality performance – Robust EMC performance, corresponding to different standards, such as ISO 7637, ISO 16750, IEC 61967, ISO 11452, and ISO 62132 Micronas June 15, 2016; DSH000179_002EN 5 HAL 150y DATA SHEET 2. Ordering Information A Micronas device is available in a variety of delivery forms. They are distinguished by a specific ordering code: XXX NNNN PA-T-C-P-Q-SP Further Code Elements Temperature Range Package Product Type Product Group Fig. 2–1: Ordering Code Principle For detailed information, please refer to the brochure: “Hall Sensors: Ordering Codes, Packaging, Handling”. 2.1. Device-Specific Ordering Codes HAL 150y is available in the following package and temperature range. Table 2–1: Available packages Package Code (PA) Package Type SU SOT23 Table 2–2: Available temperature ranges Temperature Code (T) Temperature Range A TJ = 40 °C to +170 °C The relationship between ambient temperature (TA) and junction temperature (TJ) is explained in Section 5.2. on page 37. For available variants for Configuration (C), Packaging (P), Quantity (Q), and Special Procedure (SP) please contact Micronas. Micronas June 15, 2016; DSH000179_002EN 6 HAL 150y DATA SHEET Table 2–3: Available ordering codes and corresponding package marking Available Ordering Codes Package Marking HAL1501SU-A-[C-P-Q-SP] 1501 HAL1502SU-A-[C-P-Q-SP] 1502 HAL1503SU-A-[C-P-Q-SP] 1503 HAL1506SU-A-[C-P-Q-SP] 1506 HAL1507SU-A-[C-P-Q-SP] 1507 HAL1508SU-A-[C-P-Q-SP] 1508 HAL1509SU-A-[C-P-Q-SP] 1509 Micronas June 15, 2016; DSH000179_002EN 7 HAL 150y DATA SHEET 3. Functional Description of HAL 150y The HAL 150y sensors are monolithic integrated circuits which switch in response to magnetic fields. If a magnetic field with flux lines perpendicular to the sensitive area is applied to the sensor, the biased Hall plate forces a Hall voltage proportional to this field. The Hall voltage is compared with the actual threshold level in the comparator. If the magnetic field exceeds the threshold levels, the output stage is switched to the appropriate state. The built-in hysteresis eliminates oscillation and provides switching behavior of the output without bouncing. Offsets caused by mechanical stress are compensated by using the “switching offset compensation technique”. A diode on the supply line is not required thanks to the built-in reverse voltage protection. The open drain output is forced to a safe, High-Z (high-impedance) state, in any of the following fault conditions: overtemperature, undervoltage and functional safety related diagnoses (see Section 3.1.). In addition, the output current is limited (short-circuit protection). The device is able to withstand a maximum supply voltage of 24 V for unlimited time and features overvoltage capability (40 V load dump). VSUP Reverse Voltage & ESD Protection Temperature Dependent Bias Hall Plate Hysteresis Control Short Circuit Overtemperature ESD Protection Comparator Output Filter OUT Functional Safety Features GND Fig. 3–1: HAL 150y block diagram Micronas June 15, 2016; DSH000179_002EN 8 HAL 150y DATA SHEET 3.1. Functional Safety According to ISO 26262 The HAL 150y is ISO 26262 compliant as an ASIL A ready device. Magnetic and switching performance is defined as a hardware safety requirement. The safe state is defined as High-Z output. 3.1.1. Diagnostic Features Internal states are monitored and in an error condition flagged with a High-Z at the output: – Internal voltage regulator: under and over voltage detection – Monitoring of internal bias and current levels – Monitoring of the internal reference voltage – Monitoring of the Hall plate voltage Note Micronas For further documentation regarding functional safety please contact Micronas. June 15, 2016; DSH000179_002EN 9 HAL 150y DATA SHEET 3.2. Power-On Self-Test The power-on self-test allows the customer to execute a functional check of the device, as well as to detect wire breaks as long as the host controls the power supply of the device. The self-test can be enabled only once after power-on. In order to start the test, the host has to power off the sensor and to pull down its output pin. Afterwards, the host needs to power on the sensor again (sensor in High-Z mode, after waking up) and then to release its output pin. This order of events is the criteria for the sensor to start the power-on self-test. After releasing the output pin, the sensor simulates a magnetic field for a pre-defined period of time (see first observation window in Fig. 3–2), driving the sensor’s output to low level, detected by the host. Subsequently, the sensor simulates an opposite magnetic field during the second observation window (see Fig. 3–2), driving the sensor’s output to high level, also detected by the host. The described self-test behavior is not impacted by external magnetic fields up to about 300 mT. After self-test completion, the sensor always returns to normal operation regardless of the test result. By positioning the pull-up resistor close to the control unit, wire breaks at all pins VSUP, OUT, and GND can be detected. It is also possible to enable the power-on self-test in application systems, consisting of several HAL 150y sensors, as long, as the output pins are not connected to each other. Micronas June 15, 2016; DSH000179_002EN 10 HAL 150y DATA SHEET VSUP tstrtno VSUPsens tflxn tstrtn tflxp 0V tstrtp Host driver Sensor driver VIO Host sampling First window Second window Fig. 3–2: Self-test timing diagram Host Sensor VSUPsens VSUP SUPOUT VSUP Cp RL OUT VIO I/O GND GND Fig. 3–3: External circuit diagram with switchable supply Micronas June 15, 2016; DSH000179_002EN 11 HAL 150y DATA SHEET 4. Specifications 4.1. Outline Dimensions D A H x Bd B Center of sensitive area 3 c B (L1) L E E1 y B 1 2 3x b 0 e 0.25 BASE METAL A3 SECTION "B-B" 0.10 C 3x c c1 A2 A A4 GAUGE PLANE e1 b1 b SEATING PLANE A1 WITH PLATING C 0 physical dimensions do not include moldflash. 1.25 2.5mm scale A4, Bd, x, y= these dimensions are different for each sensor type and are specified in the data sheet. UNIT A A1 A2 A3 b b1 c c1 D E E1 e e1 L L1 0 mm 1.10 max. 0.05 0.10 0.88 1.02 0.5 0.3 0.48 0.3 0.45 0.1 0.18 0.1 0.15 2.8 3.0 2.1 2.5 1.2 1.4 0.95 1.9 0.4 0.6 0.55 0° 8° JEDEC STANDARD ANSI ISSUE ITEM NO. - TO-236 ISSUE DATE YY-MM-DD DRAWING-NO. ZG-NO. 13-05-10 06902.0001.4 ZG001101_Ver.01 © Copyright 2007 Micronas GmbH, all rights reserved Fig. 4–1: SOT23: Plastic Small Outline Transistor package, 3 leads Ordering code: SU Weight approximately 0.01094 g Micronas June 15, 2016; DSH000179_002EN 12 HAL 150y DATA SHEET user direction of feed Ø 10 2 18.2 max Ø330 3 Ø1 12 min Devices per Reel: 10 000 IEC STANDARD ANSI ISSUE ITEM NO. 4th 60286-3 ISSUE DATE YY-MM-DD DRAWING-NO. ZG-NO. 15-09-23 06839.0001.4 ZG002042_001_01 © Copyright 2012 Micronas GmbH, all rights reserved Fig. 4–2: SOT23: Tape & Reel Finishing Micronas June 15, 2016; DSH000179_002EN 13 HAL 150y DATA SHEET 4.2. Soldering, Welding and Assembly Information related to solderability, welding, assembly, and second-level packaging is included in the document “Guidelines for the Assembly of Micronas Packages”. It is available on the Micronas website (http://www.micronas.com/en/service-center/ downloads) or on the service portal (http://service.micronas.com). 4.3. Pin Connections (from Top Side, example HAL 1502) and Short Descriptions GND 3 1502 1 2 VSUP OUT 1 VSUP 2 OUT 3 GND Fig. 4–3: Pin configuration Table 4–1: Pin assignment. Pin number Name Function 1 VSUP Supply voltage 2 OUT Output 3 GND Ground Micronas June 15, 2016; DSH000179_002EN 14 HAL 150y DATA SHEET 4.3.1. Dimension and Position of Sensitive Area Parameter Min. Dimension of sensitive area A4 (denotes the distance of die to top package surface in Z-direction) Typ. Max. Unit  100 x 100  µm2 0.24 0.27 0.37 mm x (denotes the nominal distance of the center of the Bd circle to the package border in x-direction) 1.45 mm y (denotes the nominal distance of the center of the Bd circle to the package border in y-direction) 0.65 mm Bd (denotes the diameter of the circuit in which the center of the sensitive area is located) Micronas  June 15, 2016; DSH000179_002EN  0.23 mm 15 HAL 150y DATA SHEET 4.4. Absolute Maximum Ratings Stresses beyond those listed in the “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only. Functional operation of the device at these conditions is not implied. Exposure to absolute maximum rating conditions for extended periods will affect device reliability. This device contains circuitry to protect the inputs and outputs against damage due to high static voltages or electric fields; however, it is advised that normal precautions be taken to avoid application of any voltage higher than absolute maximum-rated voltages to this circuit. All voltages listed are referenced to ground (GND). Symbol Parameter Pin No Min. Max. Unit Conditions TJ Junction temperature range A  40 190 °C t < 96 h1) VSUP Supply voltage 1 18 28 V t < 96 h1)  32 V t < 5 min1)  40 V t < 10 x 400 ms “Load-Dump”1) with series resistor RV > 100 . t < 96 h1) VOUT Output voltage 2 0.5 28 V IO Output current 2  65 mA IOR Reverse output current 2 50 1) mA No cumulative stress Micronas June 15, 2016; DSH000179_002EN 16 HAL 150y DATA SHEET 4.5. ESD and Latch-up The output pin has to be in High-Z for ESD measurements. Table 4–2: ESD and latch-up Symbol Parameter Min. Max. Unit Ilatch Maximum latch-up free current at any pin (measurement according to AEC Q100-004), class 1 100 100 mA VHBM Human body model (according to AEC Q100-002) 8 8 kV VCDM Charged device model (according to AEC Q100-011) 1 1 kV VSYSTEM_LEVEL Unpowered Gun Test (150 pF / 330  or 330 pF / 2 k) according to ISO 10605-20081) 15 15 kV 1)only valid with ESD System Level Application Circuit (see Fig. 5–2 on page 34) 4.6. Storage and Shelf Life Information related to storage conditions of Micronas sensors is included in the document “Guidelines for the Assembly of Micronas Packages”. It gives recommendations linked to moisture sensitivity level and long-term storage. It is available on the Micronas website (http://www.micronas.com/en/service-center/ downloads) or on the service portal (http://service.micronas.com). Micronas June 15, 2016; DSH000179_002EN 17 HAL 150y DATA SHEET 4.7. Recommended Operating Conditions Functional operation of the device beyond those indicated in the “Recommended Operating Conditions” of this specification is not implied, may result in unpredictable behavior of the device, and may reduce reliability and lifetime. All voltages listed are referenced to ground (GND). Symbol Parameter Pin No Min. VSUP Supply voltage 1 2.7 1  40 VSUP / t Power-down slope1) Typ.  Max. Unit 24 V 0.1 V/µs VSUP below 2.7 V 170 150 125 °C t < 1000 h3) t < 2500 h3) t < 8000 h3) TJ Junction temperature range A 2)  VOUT Output voltage 2 24 V IOUT Output current 2 25 mA Conditions 1) This parameter is relevant for ISO26262 applications: In order to ensure the defined output state (High-Z) during power-up in the range below the recommended supply voltage, the preceding power down slope is required to be slower than the maximum VSUP / t value. 2) Depends on the temperature profile of the application. Please contact Micronas for life time calculations. 3) No cumulative stress Micronas June 15, 2016; DSH000179_002EN 18 HAL 150y DATA SHEET 4.8. Characteristics at TJ = 40 C to +170 C, VSUP = 2.7 V to 24 V, at Recommended Operating Conditions if not otherwise specified in the column “Conditions”. Typical Characteristics for TJ = 25 C and VSUP = 12 V Symbol Parameter Pin No. Min. Typ. Max. Unit Conditions ISUP Supply current 1 1.1 1.6 2.4 mA ISUPR Reverse current 1 1  mA for VSUP = -18 V 0.4 V IO = 20 mA 0.5 V IO = 25 mA 10 µA Supply Port Output Vol Port low output voltage 2 0.13 Ioleak Output leakage current tf Output fall time1)  1 µs tr Output rise time1)  1 µs Bnoise Effective noise of magnetic switching points (RMS)2)  72 tj Output jitter (RMS)1)  0.58 td Delay time2) 3)  tsamp Output refresh period2)  ten Enable time of output after settling of VSUP 4)  1) 2) 3) 4) 0.1 1.6 VSUP = 12 V; RL = 820 ; CL = 20 pF µT For square wave signal with 12 kHz 0.72 µs For square wave signal with 1 kHz. Jitter is evenly distributed between 1 µs and +1 µs 16 21 µs 2.2 3.0 µs 50 60 µs VSUP = 12 V B > Bon + 2 mT or B < Boff - 2 mT Not tested, characterized only Guaranteed by design Systematic delay between magnetic threshold reached and output switching If power-on self-test is executed, ten will be extended by power-on self-test period (see Section ) Micronas June 15, 2016; DSH000179_002EN 19 HAL 150y DATA SHEET Symbol Parameter Pin No. Min. Typ. Max. Unit Conditions Power-on Self-Test tdsamp Double sample period2)  3.2 4.4 6.0 µs tstrtp Start of first sampling window2)    4 tdsamp tflxp End of first sampling window2)  9   tdsamp tstrtn Start of second sampling window2)    10 tdsamp tflxn End of second sampling window2)  31   tdsamp tstrtno Start of first normal operation value2)   36.5 37 tdsamp Thermal Resistance junction to air    300 K/W Measured with a 1s0p board    250 K/W Measured with a 1s1p board    210 K/W Measured with a 2s2p board    30 K/W Measured with a 1s0p board    50 K/W Measured with a 1s1p board    40 K/W Measured with a 2s2p board Package Rthja Rthjc 2) Thermal Resistance junction to case Guaranteed by design Micronas June 15, 2016; DSH000179_002EN 20 HAL 150y DATA SHEET 4.9. HAL 1501 Magnetic Characteristics The HAL 1501 bipolar Hall-switch provides highest sensitivity (see Fig. 4–4 on page 21). The output turns low with the magnetic south pole on the top side of the package and turns high with the magnetic north pole on the top side. The output state is not defined if the magnetic field is removed again. For correct functioning in the application, the sensor requires both magnetic polarities (north and south) on the top side of the package. Magnetic Features: – switching type: bipolar – very high sensitivity – typical BON: 0.4 mT at room temperature – typical BOFF: 0.4 mT at room temperature – operates with static magnetic fields and dynamic magnetic fields up to 12 kHz – typical temperature coefficient of magnetic switching points is 0 ppm/K at room temperature Applications The HAL 1501 is the optimal sensor for all applications with alternating magnetic signals and weak magnetic amplitude at the sensor position such as: – applications with large air gap or weak magnets – revolutions per minute (RPM) or other counting measurement, e.g. window lifter and sunroof – commutation of brushless DC motors – position detection, such as for gear-shift lever and electric parking brake – magnetic encoders Output Voltage High-Z BHYS Low-Z BOFF 0 BON B Fig. 4–4: Definition of magnetic switching points for the HAL 1501 Micronas June 15, 2016; DSH000179_002EN 21 HAL 150y DATA SHEET Magnetic Characteristics at TJ = 40 C to +170 C, VDD = 2.7 V to 24 V, Typical Characteristics for VDD = 12 V Magnetic flux density values of switching points: Positive flux density values refer to the magnetic south pole at the top side of the package. Parameter On point BON Off point BOFF Hysteresis BHYS Unit TJ Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. 40 C -0.6 0.5 1.6 -1.6 -0.5 0.6  1.0  mT 25 C -0.5 0.4 1.5 -1.5 0.4 0.5  0.8  mT 170 C -1 0.35 2 -2 -0.35 1  0.7  mT The hysteresis is the difference between the switching points BHYS = BON  BOFF  Note Micronas Regarding switching points, temperature coefficients, and B-field switching frequency, customized derivatives via mask option are possible. For more information contact Micronas. June 15, 2016; DSH000179_002EN 22 HAL 150y DATA SHEET 4.10.HAL 1502 Magnetic Characteristics The HAL 1502 Hall-latch provides highest sensitivity (see Fig. 4–5 on page 24). The output turns low with the magnetic south pole on the top side of the package and turns high with the magnetic north pole on the top side. The output does not change if the magnetic field is removed. For changing the output state, the opposite magnetic field polarity must be applied. For correct functioning in the application, the sensor requires both magnetic polarities (north and south) on the top side of the package. Magnetic Features: – switching type: latching – high sensitivity – typical BON: 2.5 mT at room temperature – typical BOFF: 2.5 mT at room temperature – operates with static magnetic fields and dynamic magnetic fields up to 12 kHz – typical temperature coefficient of magnetic switching points is 1000 ppm/K at room temperature Applications The HAL 1502 is the optimal sensor for all applications with alternating magnetic signals and weak magnetic amplitude at the sensor position such as: – applications with large air gap or weak magnets – revolutions per minute (RPM) or other counting measurement, e.g. window lifter and sunroof – commutation of brushless DC motors – position detection, such as for adaptive front lighting and electric parking brake – magnetic encoders Micronas June 15, 2016; DSH000179_002EN 23 HAL 150y DATA SHEET Output Voltage High-Z BHYS Low-Z BOFF 0 B BON Fig. 4–5: Definition of magnetic switching points for the HAL 1502 Magnetic Characteristics at TJ = 40 C to +170 C, VDD = 2.7 V to 24 V, Typical Characteristics for VDD = 12 V Magnetic flux density values of switching points: Positive flux density values refer to the magnetic south pole at the top side of the package. Parameter On point BON Off point BOFF Hysteresis BHYS Unit TJ Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. 40 C 1.3 2.8 4.3 4.3 2.8 1.3  5.6  mT 25 C 1 2.5 4 4 2.5 1  5  mT 170 C 0.8 2.3 3.8 3.8 2.3 0.8  4.6  mT The hysteresis is the difference between the switching points BHYS = BON  BOFF  Note Micronas Regarding switching points, temperature coefficients, and B-field switching frequency, customized derivatives via mask option are possible. For more information contact Micronas. June 15, 2016; DSH000179_002EN 24 HAL 150y DATA SHEET 4.11.HAL 1503 Magnetic Characteristics The HAL 1503 unipolar Hall-switch provides high sensitivity (see Fig. 4–6 on page 25). The output turns low with the magnetic south pole on the top side of the package and turns high if the magnetic field is removed. The sensor does not respond to the magnetic north pole on the top side of the package. For correct functioning in the application, the sensor requires only the magnetic south pole on the top side of the package. Magnetic Features: – switching type: unipolar – high sensitivity – typical BON: 5.5 mT at room temperature – typical BOFF: 3.7 mT at room temperature – operates with static magnetic fields and dynamic magnetic fields up to 12 kHz – typical temperature coefficient of magnetic switching points is 1000 ppm/K at room temperature Applications The HAL 1503 is the optimal sensor for all applications with one magnetic polarity and weak magnetic amplitude at the sensor position, such as: – clutch position detection – electric parking brake – brake light switch – brake pedal position detection – steering wheel lock – door handle Output Voltage High-Z BHYS Low-Z 0 BOFF BON B Fig. 4–6: Definition of magnetic switching points for the HAL 1503 Micronas June 15, 2016; DSH000179_002EN 25 HAL 150y DATA SHEET Magnetic Characteristics at TJ = 40 C to +170 C, VDD = 2.7 V to 24 V, Typical Characteristics for VDD = 12 V Magnetic flux density values of switching points: Positive flux density values refer to the magnetic south pole at the top side of the package. Parameter On point BON Off point BOFF Hysteresis BHYS Unit TJ Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. 40 C 4.4 6.1 7.6 2.4 4 5.7  2.1  mT 25 C 3.8 5.5 7.1 2.1 3.7 5.5  1.8  mT 170 C 3 5 6.7 1.8 3.6 5.5  1.4  mT The hysteresis is the difference between the switching points BHYS = BON  BOFF  Note Micronas Regarding switching points, temperature coefficients, and B-field switching frequency, customized derivatives via mask option are possible. For more information contact Micronas. June 15, 2016; DSH000179_002EN 26 HAL 150y DATA SHEET 4.12.HAL 1506 Magnetic Characteristics The HAL 1506 unipolar Hall-switch provides medium sensitivity (see Fig. 4–7 on page 27). The output turns low with the magnetic south pole on the top side of the package and turns high if the magnetic field is removed. The sensor does not respond to the magnetic north pole on the top side of the package. For correct functioning in the application, the sensor requires only the magnetic south pole on the top side of the package. Magnetic Features: – switching type: unipolar – medium sensitivity – typical BON: 18.9 mT at room temperature – typical BOFF: 17.3 mT at room temperature – operates with static magnetic fields and dynamic magnetic fields up to 12 kHz – typical temperature coefficient of magnetic switching points is 1200 ppm/K at room temperature Applications The HAL 1506 is the optimal sensor for applications with one magnetic polarity, such as: – clutch pedal position – wiper position – door lock – trunk lock Output Voltage High-Z BHYS Low-Z 0 BOFF BON B Fig. 4–7: Definition of magnetic switching points for the HAL 1506 Micronas June 15, 2016; DSH000179_002EN 27 HAL 150y DATA SHEET Magnetic Characteristics at TJ = 40 C to +170 C, VDD = 2.7 V to 24 V, Typical Characteristics for VDD = 12 V Magnetic flux density values of switching points: Positive flux density values refer to the magnetic south pole at the top side of the package. Parameter On point BON Off point BOFF Hysteresis BHYS Unit TJ Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. 40 C 16.5 20.8 24.8 14 18.9 22.5 - 1.9 - mT 25 C 15.4 18.9 22.6 13.8 17.3 21 - 1.6 - mT 170 C 13 17 19.5 11.8 15.8 18.2 - 1.2 - mT The hysteresis is the difference between the switching points BHYS = BON  BOFF  Note Micronas Regarding switching points, temperature coefficients, and B-field switching frequency, customized derivatives via mask option are possible. For more information contact Micronas. June 15, 2016; DSH000179_002EN 28 HAL 150y DATA SHEET 4.13.HAL 1507 Magnetic Characteristics The HAL 1507 unipolar Hall-switch provides low sensitivity (see Fig. 4–8 on page 30). The output turns low with the magnetic south pole on the top side of the package and turns high if the magnetic field is removed. The sensor does not respond to the magnetic north pole on the top side of the package. For correct functioning in the application, the sensor requires only the magnetic south pole on the top side of the package. Magnetic Features: – switching type: unipolar – low sensitivity – typical BON: 28.2 mT at room temperature – typical BOFF: 23.9 mT at room temperature – operates with static magnetic fields and dynamic magnetic fields up to 12 kHz – typical temperature coefficient of magnetic switching points is 300 ppm/K at room temperature Applications The HAL 1507 is the optimal sensor for applications with one magnetic polarity and strong magnetic fields at the sensor position, such as: – gear position detection – rooftop open/close – sliding door Micronas June 15, 2016; DSH000179_002EN 29 HAL 150y DATA SHEET Output Voltage High-Z BHYS Low-Z 0 BOFF BON B Fig. 4–8: Definition of magnetic switching points for the HAL 1507 Magnetic Characteristics at TJ = 40 C to +170 C, VDD = 2.7 V to 24 V, Typical Characteristics for VDD = 12 V Magnetic flux density values of switching points: Positive flux density values refer to the magnetic south pole at the top side of the package. Parameter On point BON Off point BOFF Hysteresis BHYS Unit TJ Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. 40 C 24 29.5 35 18.7 24.7 30.7  4.8  mT 25 C 23.7 28.2 32.7 19 23.9 28.8  4.3  mT 170 C 22.5 27.7 32.9 18.6 23.9 29.2  3.8  mT The hysteresis is the difference between the switching points BHYS = BON  BOFF  Note Micronas Regarding switching points, temperature coefficients, and B-field switching frequency, customized derivatives via mask option are possible. For more information contact Micronas. June 15, 2016; DSH000179_002EN 30 HAL 150y DATA SHEET 4.14.HAL 1508 Magnetic Characteristics The HAL 1508 a high-sensitive unipolar switch sensor only sensitive to the magnetic north polarity (see Fig. 4–9 on page 32). The output turns low with the magnetic north pole on the top side of the package and turns high if the magnetic field is removed. The sensor does not respond to the magnetic south pole. For correct functioning in the application, the sensor requires only the magnetic north pole on the top side of the package. Magnetic Features: – switching type: unipolar – high sensitivity – typical BON: 5.5 mT at room temperature – typical BOFF: 3.7 mT at room temperature – operates with static magnetic fields and dynamic magnetic fields up to 12 kHz – typical temperature coefficient of magnetic switching points is 1000 ppm/K at room temperature Applications The HAL 1508 is the optimal sensor for all applications with one magnetic polarity and weak magnetic amplitude at the sensor position. In combination with HAL 1503 it is often used for clutch pedal position detection, for instance. Other examples are: – electric parking brake – wiper position – door lock Micronas June 15, 2016; DSH000179_002EN 31 HAL 150y DATA SHEET Output Voltage High-Z BHYS Low-Z BON BOFF 0 B Fig. 4–9: Definition of magnetic switching points for the HAL 150y Magnetic Characteristics at TJ = 40 C to +170 C, VDD = 2.7 V to 24 V, Typical Characteristics for VDD = 12 V Magnetic flux density values of switching points: Positive flux density values refer to the magnetic south pole at the top side of the package. Parameter On point BON Off point BOFF Hysteresis BHYS Unit TJ Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. 40 C 7.6 6.1 4.4 5.7 4 2.4  2.1  mT 25 C 7.1 5.5 3.8 5.5 3.7 2.1  1.8  mT 170 C 6.7 5 3 5.5 3.6 1.8  1.4  mT The hysteresis is the difference between the switching points BHYS = BON  BOFF  Note Micronas Regarding switching points, temperature coefficients, and B-field switching frequency, customized derivatives via mask option are possible. For more information contact Micronas. June 15, 2016; DSH000179_002EN 32 HAL 150y DATA SHEET 4.15.HAL 1509 Magnetic Characteristics The HAL 1509 unipolar inverted Hall-switch provides high sensitivity (see Fig. 4–10 on page 34). The output turns high with the magnetic south pole on the top side of the package and turns low if the magnetic field is removed. The sensor does not respond to the magnetic north pole on the top side of the package. For correct functioning in the application, the sensor requires only the magnetic south pole on the top side of the package. Magnetic Features: – switching type: unipolar inverted – high sensitivity – typical BON: 3.7 mT at room temperature – typical BOFF: 5.5 mT at room temperature – operates with static magnetic fields and dynamic magnetic fields up to 12 kHz – typical temperature coefficient of magnetic switching points is 1000 ppm/K at room temperature Applications The HAL 1509 is the optimal sensor for all applications with one magnetic polarity and weak magnetic amplitude at the sensor position where an inverted output signal is required, such as: – electric valve actuation – door lock – brake position detection Micronas June 15, 2016; DSH000179_002EN 33 HAL 150y DATA SHEET Output Voltage High-Z BHYS Low-Z 0 BON BOFF B Fig. 4–10: Definition of magnetic switching points for the HAL 1509 Magnetic Characteristics at TJ = 40 C to +170 C, VDD = 2.7 V to 24 V, Typical Characteristics for VDD = 12 V Magnetic flux density values of switching points: Positive flux density values refer to the magnetic south pole at the top side of the package. Parameter On point BON Off point BOFF Hysteresis BHYS Unit TJ Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. 40 C 2.4 4 5.7 4.4 6.1 7.6  2.1  mT 25 C 2.1 3.7 5.5 3.8 5.5 7.1  1.8  mT 170 C 1.8 3.6 5.5 3 5 6.7  1.4  mT The hysteresis is the difference between the switching points BHYS = BON  BOFF  Note Micronas Regarding switching points, temperature coefficients, and B-field switching frequency, customized derivatives via mask option are possible. For more information contact Micronas. June 15, 2016; DSH000179_002EN 34 HAL 150y DATA SHEET 5. Application Notes 5.1. Application Circuits For applications with disturbances on the supply line or radiated disturbances, a series resistor RV and two capacitors CP and CL all placed close to the sensor are recommended (see Fig. 5–1). For example: RV =100  CP = 10 nF, and CL = 4.7 nF. VSUP RV RL OUT CP CL GND GND Fig. 5–1: Example for a recommended application circuit RL is the open-drain pull-up resistor and has to be placed close to the input of the host controller to enable wire-break detection. Micronas June 15, 2016; DSH000179_002EN 35 HAL 150y DATA SHEET 5.1.1. ESD System Level Application Circuit (ISO10605-2008) For an ESD system level application circuit according to ISO10605-2008 a 100 nF capacitor at VSUP and an additional TVS diode at OUT are necessary. VSUP RV =100  1) RL OUT CP = 100 nF TVS Diode 24 V GND 1) required for 40 V load dump capability Fig. 5–2: Application circuit with external resistor Micronas June 15, 2016; DSH000179_002EN 36 HAL 150y DATA SHEET 5.2. Ambient Temperature Due to the internal power dissipation, the temperature on the silicon chip (junction temperature TJ) is higher than the temperature outside the package (ambient temperature TA). T J = T A + T Under static conditions and continuous operation, the following equation applies: T =  I SUP  V SUP  R thja  +  I OUT  V OUT  R thja  For all sensors, the junction temperature range TJ is specified. The maximum ambient temperature TAmax can be calculated as: T Amax = T Jmax – T For typical values, use the typical parameters. For worst case calculation, use the max. parameters for ISUP , IOUT , and Rthja, and the max. value for VOUT and VSUP from the application. Micronas June 15, 2016; DSH000179_002EN 37 HAL 150y DATA SHEET 5.3. Start-Up Behavior The sensors have an initialization time (enable time ten) after applying the supply voltage. The parameter ten is specified in the Electrical Characteristics (see page 19). During the initialization time, the output state is defined as High-Z. After ten, the output will be Low-Z if the applied magnetic field B is above BON. The output will be High-Z if B is below BOFF. In case of sensors with an inverted switching behavior, the output state will be high if B > BOFF and low if B < BON. Note For non-inverting ICs and magnetic fields between BOFF and BON after applying VSUP , the output state of the device will be High-Z. For inverting and north-pole sensitive ICs and magnetic fields between BOFF and BON after applying VSUP , the output state of the device will be Low-Z. For further information see Application Notes for HAL 15xy. 5.4. EMC and ESD For applications with disturbances on the supply line or radiated disturbances, a series resistor and a capacitor are recommended. The series resistor and the capacitor should be placed as close as possible to the HAL sensor. Special application arrangements were evaluated to pass EMC tests according to different standards, such as ISO 7637, ISO 16750, IEC 61967, ISO 11452 and ISO 62132. Micronas June 15, 2016; DSH000179_002EN 38 HAL 150y DATA SHEET 6. Data Sheet History 1. Data Sheet: “HAL 150y, Hall-Effect Switch with Open-Drain Output (3-wire) in SOT23 Package”, March 23, 2016; DSH000179_001EN. First release of the Data Sheet. 2. Data Sheet: “HAL 150y, Hall-Effect Switch with Open-Drain Output (3-wire) in SOT23 Package”, June 15, 2016; DSH000179_002EN. Second release of the Data Sheet. Major changes: – ESD and Latch-up: Values updated – ESD System Level Application Circuit (ISO10605-2008) added Micronas GmbH Hans-Bunte-Strasse 19  D-79108 Freiburg  P.O. Box 840  D-79008 Freiburg, Germany Tel. +49-761-517-0  Fax +49-761-517-2174  E-mail: docservice@micronas.com  Internet: www.micronas.com Micronas June 15, 2016; DSH000179_002EN 39
HAL1507 UA 价格&库存
很抱歉,暂时无法提供与“HAL1507 UA”相匹配的价格&库存,您可以联系我们找货
HAL1507 UA
    • 1+1.87650
    • 200+0.72620
    • 500+0.70071
    • 1000+0.68807
