PRODUCT INFORMATION
HAL 15xy
Nov/2018
HAL 15xy
First ISO 26262 Compliant Low-Power Hall Switch
The HAL 15xy family consists of different
Hall switches containing a temperaturecompensated Hall plate with active offset
compensation and comparator, available
optionally with open-drain or current output.
As global Hall switch supplier with long-term
experience since 1993, 1.5 billion shipped
automotive switches and leading expertise
in high-quality Hall-effect sensor solutions,
TDK-Micronas expands its switch portfolio
with the new HAL 15xy family.
All CMOS wafer processing is done in
TDK-Micronas’
facilities
in
Freiburg
(Germany) to ensure best quality control
and highest flexibility.
With different switching-point versions, the
HAL 15xy switch family serves a broad variety of automotive and industrial applications
under harsh temperature conditions.
HAL 15xy fulfills the latest quality and
functional safety standards as AEC-Q100
qualified and ISO 26262 ASIL ready device,
enabling our customers to target even the
most safety-critical applications.
Features
◆ Sampling and output refresh time of 2 s
◆ 3-wire version with a short-circuit protected open-drain output
◆ 2-wire version with current output
As improved successor of the well-known
HAL 5xy family, the HAL 15xy is available
as 3-wire version with short-circuit protected open-drain output and 2-wire version
with current output. HAL 15xy is available in
the smallest SOT23 as well as TO92UA
package and provides lowest power consumption, fast response times, and special
safety features like a unique power-on selftest for greater customer benefit at an
excellent price-performance ratio.
◆ Low current consumption of typ. 1.6 mA
◆ Wide supply voltage operation from
2.7 V to 24 V
◆ Overvoltage protection capability
up to 40 V
◆ Available in the small SOT23 and
TO92UA package
◆ High HBM ESD performance
of up to 8 kV
◆ Reverse-voltage protection at supply pin
◆ Operating with static and dynamic magnetic fields up to 12 kHz with low output
jitter. Customized versions are possible
up to 93 kHz.
◆ AEC-Q100 qualification
◆ ASIL A ready device (SPFM 60%)
◆ Additional diagnostic features e.g.:
– Power on self-test (signal path test
and wire-break detection)
– Monitoring of internal bias and
current levels
– Overtemperature protection
– Output current limitation
– Defined fail safe state
◆ Wide junction temperature range from
40 °C to 170 °C, specially designed for
operation in harsh environments
◆ High robustness of magnetic characteristics against mechanical stress
◆ Broad portfolio of temperature-compensated constant switching points
PRODUCT INFORMATION
HAL 15xy
Major Applications
Our new switch family HAL 15xy is the
optimal system solution for key applications
such as:
◆ Position detection e.g. for seat belt and
gear shift
Nov/2018
Available Types and Behavior
Version
3-wire
◆ Index counting e.g. for window lift
◆ Brushless DC motor commutation e.g.
for pumps and fans
2-wire
System Architecture
HAL 15xy sensors are monolithic integrated
circuits which switch in response to magnetic fields. If a magnetic field with flux lines
perpendicular to the sensitive area is
applied to the sensor, the biased Hall plate
forces a Hall voltage proportional to this
field. The Hall voltage is compared with the
actual threshold level in the comparator. If
the magnetic field exceeds the threshold
levels, the output stage (open drain output
for 3-wire devices or current source for
2-wire devices) is switched to the appropriate state.
Type
Switching
Behavior
Switching Points (typ.)
Temp.
2-Wire
PreBOFF [mT] Coefficient ISUPlow decessor
[mA]
[ppm/K]
BON [mT]
HAL1501 bipolar
0.4
–0.4
HAL501
HAL1502 latching
2.5
–2.5
–1000
HAL502
HAL1503 unipolar
5.5
3.7
–1000
HAL506
HAL1504 latching
7.6
–7.6
–1200
HAL503
HAL1505 latching
13.5
–13.5
–1200
HAL505
HAL1506 unipolar
18.9
17.3
–1200
HAL508
HAL1507 unipolar
28.2
23.9
–300
HAL509
HAL1508 unipolar
–5.5
–3.7
–1000
HAL549
HAL1509 unipolar inverted
3.7
5.5
–1000
HAL516
HAL1510 unipolar
12
7
–1200
HAL504
HAL1561 latching
4
–4
5 to 7
HAL575
HAL1562 latching
12
–12
5 to 7
HAL579
HAL1563 unipolar inverted
7.6
9.4
5 to 7
HAL584
HAL1564 unipolar inverted
4.1
6
–1000
2 to 5
HAL566
HAL1565 unipolar
6
4.1
–1000
2 to 5
HAL556
HAL1566 unipolar
9.4
7.6
5 to 7
HAL574
VSUP
Reverse
Voltage &
ESD
Protection
Temperature
Dependent
Bias
Hall Plate
Switch Point
Hysteresis
Control
Comparator
Filter
The built-in hysteresis eliminates oscillation
and provides switching behavior of the output without toggling. Magnetic offset caused
by mechanical stress is compensated by
using the “switching offset compensation
technique”.
Current
Source
(2-wire
version)
OUT
Output
(3-wire
version)
Functional
Safety
Features
The device is able to withstand a maximum
supply voltage of 24 V for unlimited time
and features overvoltage capability up to
40 V load dump.
Overtemperature
Protection
GND
Fig. 1: Block diagram of the HAL 15xy
All information and data contained in this product information are without any commitment, are not to be considered as an offer for conclusion of a contract, nor shall they be construed as to create any liability. Product or
development sample availability and delivery are exclusively subject to our respective order confirmation form. By
this publication, TDK-Micronas GmbH does not assume responsibility for patent infringements or other rights of
third parties which may result from its use.
No part of this publication may be reproduced, photocopied, stored on a retrieval system, or transmitted
without
the
express
written
consent
of
TDK-Micronas GmbH.
Edition Nov. 8, 2018; Order No. PI000148_005EN
TDK-Micronas GmbH Hans-Bunte-Strasse 19D-79108 Freiburg (Germany)P.O. Box 840D-79008 Freiburg (Germany)
Tel. +49-761-517-0Fax +49-761-517-2174www.micronas.com
很抱歉,暂时无法提供与“HAL1562 UA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7.142171+0.92200
- 5+6.276585+0.81026
- 10+5.9503910+0.76815
- 25+5.5645025+0.71833
- 50+5.3018450+0.68443
- 100+5.06028100+0.65324
- 500+4.57557500+0.59067
- 1000+4.395461000+0.56742
- 国内价格 香港价格
- 2000+4.230442000+0.54612
- 4000+4.079154000+0.52659
- 6000+3.996596000+0.51593
- 10000+3.8983310000+0.50324
- 14000+3.8369614000+0.49532
- 20000+3.7746520000+0.48728
