HAL2425DJ-A
HAL2425DJ-A
    TDK(东电化)
    8-SOIC (0.154", 3.90mm Width)
    SENSOR LINEAR ANALOG 8SOIC
HAL2425DJ-A 数据手册
Hardware Documentation D at a S h e e t ® HAL 2420, HAL 2425 High-Precision Programmable Linear Hall-Effect Sensors with Arbitrary Output Characteristics Edition Nov. 3, 2020 DSH000174_003EN HAL 2420, HAL 2425 DATA SHEET Copyright, Warranty, and Limitation of Liability The information and data contained in this document are believed to be accurate and reliable. The software and proprietary information contained therein may be protected by copyright, patent, trademark and/or other intellectual property rights of TDK-Micronas. All rights not expressly granted remain reserved by TDK-Micronas. TDK-Micronas assumes no liability for errors and gives no warranty representation or guarantee regarding the suitability of its products for any particular purpose due to these specifications. By this publication, TDK-Micronas does not assume responsibility for patent infringements or other rights of third parties which may result from its use. Commercial conditions, product availability and delivery are exclusively subject to the respective order confirmation. Any information and data which may be provided in the document can and do vary in different applications, and actual performance may vary over time. All operating parameters must be validated for each customer application by customers’ technical experts. Any mention of target applications for our products is made without a claim for fit for purpose as this has to be checked at system level. Any new issue of this document invalidates previous issues. TDK-Micronas reserves the right to review this document and to make changes to the document’s content at any time without obligation to notify any person or entity of such revision or changes. For further advice please contact us directly. Do not use our products in life-supporting systems, military, aviation, or aerospace applications! Unless explicitly agreed to otherwise in writing between the parties, TDK-Micronas’ products are not designed, intended or authorized for use as components in systems intended for surgical implants into the body, or other applications intended to support or sustain life, or for any other application in which the failure of the product could create a situation where personal injury or death could occur. No part of this publication may be reproduced, photocopied, stored on a retrieval system or transmitted without the express written consent of TDK-Micronas. TDK-Micronas Trademarks – HAL Third-Party Trademarks All other brand and product names or company names may be trademarks of their respective companies. TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 2 HAL 2420, HAL 2425 DATA SHEET Contents Page Section Title 4 5 6 1. 1.1. 1.2. Introduction Features Major Applications 6 7 2. 2.1. Ordering Information Device-Specific Ordering Codes 8 8 10 10 10 11 15 19 20 21 21 3. 3.1. 3.2. 3.2.1. 3.2.2. 3.2.2.1. 3.2.2.2. 3.2.2.3. 3.2.2.4. 3.3. 3.4. Functional Description General Function Signal path and Register Definition Signal path Register Definition RAM registers EEPROM register NVRAM Registers Setpoint linearization accuracy On-board Diagnostic features Calibration of the sensor 22 22 28 28 29 29 30 31 31 32 34 34 35 36 4. 4.1. 4.2. 4.3. 4.4. 4.4.1. 4.5. 4.6. 4.7. 4.8. 4.9. 4.10. 4.11. 4.11.1. Specifications Outline Dimensions Solderability, Welding, Assembly Pin Connections and Short Descriptions Physical Dimensions Dimensions of Sensitive Area Absolute Maximum Ratings Storage and Shelf Life Recommended Operating Conditions Characteristics Open-Circuit Detection Overvoltage and Undervoltage Detection Magnetic Characteristics Definition of Sensitivity Error ES 37 37 37 38 5. 5.1. 5.2. 5.3. Application Notes Application Circuit Use of two HAL 242x in Parallel Ambient Temperature 39 39 41 41 6. 6.1. 6.2. 6.3. Programming of the Sensor Programming Interface Programming Environment and Tools Programming Information 42 7. Document History TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 3 HAL 2420, HAL 2425 DATA SHEET High-Precision Programmable Linear Hall-Effect Sensors with Arbitrary Output Characteristics Note Revision bars indicate significant changes to the previous edition. 1. Introduction HAL 242x is a family of programmable linear Hall-effect sensors consisting of two members: the HAL 2420 and the HAL 2425. Both devices are universal magnetic-field sensors with a linear output based on the Hall effect. Major characteristics like magnetic-field range, sensitivity, output quiescent voltage (output voltage at B=0 mT), and output voltage range are programmable in a nonvolatile memory. The sensors have a ratiometric output characteristic, which means that the output voltage is proportional to the magnetic flux and the supply voltage. Additionally, both sensors offer wire-break detection. The HAL 2425 offers 16 setpoints to change the output characteristics from linear to arbitrary or vice versa. Table 1–1: HAL 242x family members Device Key Function HAL 2420 2 Setpoints (calibration points) HAL 2425 16 Setpoints The HAL 242x features a temperature-compensated Hall plate with chopper offset compensation, an A/D converter, digital signal processing, a D/A converter with output driver, an EEPROM with redundancy and lock function for the calibration data, a serial interface for programming the EEPROM, and protection devices at all pins. The internal digital signal processing is of great benefit because analog offsets, temperature shifts, and mechanical stress do not degrade digital signals. The easy programmability allows a 2-point calibration by adjusting the output signal directly to the input signal (like mechanical angle, distance, or current). Individual adjustment of each sensor during the final manufacturing process is possible. With this calibration procedure, the tolerances of the sensor, the magnet, and the mechanical positioning can be compensated in the final assembly. In addition, the temperature compensation of the Hall IC can be fit to all common magnetic materials by programming first and second order temperature coefficients of the Hall sensor sensitivity. TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 4 HAL 2420, HAL 2425 DATA SHEET It is also possible to compensate offset drift over temperature generated by the customer application with a first order temperature coefficient for the sensor offset. This enables operation over the full temperature range with high accuracy. The calculation of the individual sensor characteristics and the programming of the EEPROM can easily be done with a PC and the application kit from TDK-Micronas. The sensors are designed for hostile industrial and automotive applications and operate with typically 5 V supply voltage in the junction temperature range from 40 °C up to 170 °C. The HAL 242x is available in the very small leaded package TO92UT-1/-2 and in the SOIC8-1 package. 1.1. Features – High-precision linear Hall-effect sensors with 12-bit analog output – 16 setpoints for various output signal shapes (HAL 2425) – Multiple customer programmable magnetic characteristics in a non-volatile memory with redundancy and lock function – Programmable temperature compensation for sensitivity and offset – Magnetic-field measurements in the range of 200 mT – Low output voltage drifts over temperature – Active open-circuit (ground and supply line break detection) with 5 k pull-up and pull-down resistor, overvoltage and undervoltage detection – Programmable clamping function – Digital readout of temperature and magnetic-field information in calibration mode – Programming and operation of multiple sensors at the same supply line – Active detection of output short between two sensors – High immunity against mechanical stress, ESD, EMC – Operates from TJ = 40 °C up to 170 °C – Operates from 4.5 V up to 5.5 V supply voltage in specification and functions up to 8.5 V – Operates with static magnetic fields and dynamic magnetic fields up to 2 kHz – Overvoltage and reverse-voltage protection at all pins – Short-circuit protected push-pull output – Qualified according to AEC-Q100 TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 5 HAL 2420, HAL 2425 DATA SHEET 1.2. Major Applications Due to the sensors’ versatile programming characteristics and low temperature drifts, the HAL 242x is the optimal system solution for applications such as: – Contactless potentiometers, – Angle sensors (like throttle position, pedal position and EGR applications), – Distance and linear movement measurements, – Magnetic-field and current measurement. 2. Ordering Information A Micronas device is available in a variety of delivery forms. They are distinguished by a specific ordering code: XXX NNNN PA-T-C-P-Q-SP Further Code Elements Temperature Range Package Product Type Product Group Fig. 2–1: Ordering Code Principle For a detailed information, please refer to the brochure: “Micronas Sensors and Controllers: Ordering Codes, Packaging, Handling”. TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 6 HAL 2420, HAL 2425 DATA SHEET 2.1. Device-Specific Ordering Codes HAL 242x is available in the following package and temperature variants. Table 2–1: Available packages Package Code (PA) Package Type UT TO92UT-1/-2 DJ SOIC8-1 Table 2–2: Available temperature ranges Temperature Code (T) Temperature Range A TJ = 40 °C to +170 °C The relationship between ambient temperature (TA) and junction temperature (TJ) is explained in Section 5.4. on page 29. For available variants for Configuration (C), Packaging (P), Quantity (Q), and Special Procedure (SP) please contact TDK-Micronas. Table 2–3: Available ordering codes and corresponding package marking Available Ordering Codes Package Marking HAL2420UT-A-[C-P-Q-SP] 2420A HAL2420DJ-A-[C-P-Q-SP] 2420A HAL2425UT-A-[C-P-Q-SP] 2425A HAL2425DJ-A-[C-P-Q-SP] 2425A TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 7 HAL 2420, HAL 2425 DATA SHEET 3. Functional Description 3.1. General Function The HAL 242x is a monolithic integrated circuit which provides an output voltage proportional to the magnetic flux through the Hall plate and proportional to the supply voltage (ratiometric behavior). The external magnetic-field component perpendicular to the branded side of the package generates a Hall voltage. The Hall IC is sensitive to magnetic north and south polarity. This voltage is converted to a digital value, processed in the Digital Signal Processing Unit (DSP) according to the settings of the EEPROM registers, converted back to an analog voltage with ratiometric behavior, and buffered by a push-pull output transistor stage. The setting of a LOCK bit disables the programming of the EEPROM memory for all time. This bit cannot be reset by the customer. As long as the LOCK bit is not set, the output characteristic can be adjusted by programming the EEPROM registers. The IC is addressed by modulating the output voltage. In the supply voltage range from 4.5 V up to 5.5 V, the sensor generates an analog output voltage. After detecting a command, the sensor reads or writes the memory and answers with a digital signal on the output pin. The analog output is switched off during the communication. Several sensors in parallel to the same supply and ground line can be programmed individually. The selection of each sensor is done via its output pin. The open-circuit detection provides a defined output voltage if the VSUP or GND line is broken. Internal temperature compensation circuitry and the spinning-current offset compensation enables operation over the full temperature range with minimal changes in accuracy and high offset stability. The circuitry also reduces offset shifts due to mechanical stress from the package. The non-volatile memory consists of redundant EEPROM cells. In addition, the sensor IC is equipped with devices for overvoltage and reversevoltage protection at all pins. TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 8 HAL 2420, HAL 2425 DATA SHEET VSUP Internally Stabilized Supply and Protection Devices Temperature Dependent Bias Oscillator Switched Hall Plate A/D Converter Digital Signal Processing Temperature Sensor A/D Converter Open-circuit, Overvoltage, Undervoltage Detection Linearization 16 Setpoints (HAL 2425) EEPROM Memory D/A Converter Protection Devices Analog Output OUT Programming Interface Lock Control GND Fig. 3–1: HAL 242x block diagram TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 9 HAL 2420, HAL 2425 DATA SHEET 3.2. Signal path and Register Definition 3.2.1. Signal path D Output Clamping A (Magnetic Ranges) Hall-Plate Barrel Shifter CFX MIC_COMP Micronas Offset & Gain Trimming SETPT CUST_COMP Customer Offset & Gain Trimming Setpoint Linearization DAC Gain & Offset Scaling TEMP_ADJ -C- Micronas Temp-Sensor Trimming DAC Drift Compensation Output Clamping DAC GAINOFF Temp-Sensor DAC Fig. 3–2: Signal path of HAL 242x 3.2.2. Register Definition The DSP is the major part of this sensor and performs the signal conditioning. The parameters for the DSP are stored in the EEPROM registers. The details are shown in Fig. 3–2. Terminology: GAIN: Name of the register or register value Gain: Name of the parameter The sensors signal path contains two kinds of registers. Registers that are readout only (RAM) and programmable registers (EEPROM & NVRAM). The RAM registers contain measurement data at certain positions of the signal path and the EEPROM registers have influence on the sensors signal processing. TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 10 HAL 2420, HAL 2425 DATA SHEET 3.2.2.1.RAM registers TEMP_ADJ The TEMP_ADJ register contains the calibrated temperature sensor information. TEMP_ADJ can be used for the sensor calibration over temperature. This register has a length of 16 bit and it is two’s-complemented coded. Therefor the register value can vary between 32768 ... 32767. CFX The CFX register represents the magnetic-field information directly after A/D conversion, decimation filter and magnetic range (barrel shifter) selection. The register content is not temperature compensated. The temperature variation of this register is specified in Section 4.11. on page 35 by the parameter RANGEABS. Note During application design, it must be taken into consideration that CFX should never overflow in the operational range of the specific application and especially over the full temperature range. In case of a potential overflow the barrels shifter should be switched to the next higher range. This register has a length of 16 bit and it is two’s-complemented coded. Therefor the register value can vary between 32768 ... 32767. CFX register values will increase for positive magnetic fields (south pole) on the branded side of the package (positive CFX values) and it will decrease with negative magnetic-field polarity. MIC_COMP The MIC_COMP register is representing the magnetic-field information directly after the Micronas temperature trimming. The register content is temperature compensated and has a typical gain drift over temperature of 0 ppm/k. Also the offset and its drift over temperature is typically zero. The register has a length of 16 bit and it is two’s-complemented coded. Therefor the register value can vary between 32768 ... 32767. CUST_COMP The CUST_COMP register is representing the magnetic-field information after the customer temperature trimming. For HAL 242x it is possible to set a customer specific gain of second order over temperature as well as a customer specific offset of first order over temperature. The customer gain and offset can be set with the EEPROM registers TCCO0, TCCO1 for offset and TCCG0 ... TCCG2 for gain. Details of these registers are described on the following pages. The register has a length of 16 bit and it is two’s-complemented coded. Therefor the register value can vary between 32768 ... 32767. TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 11 DATA SHEET HAL 2420, HAL 2425 SETPT The SETPT register offers the possibility to read the magnetic-field information after the linearization of the magnetic-field information with 16 setpoints. This information is also required for the correct setting of the sensors DAC GAIN and OFFSET in the following block. The register has a length of 16 bit and it is two’s-complemented coded. Therefor the register value can vary between 32768 ... 32767. GAINOFF The GAINOFF register offers the possibility to read the magnetic-field information after the DAC GAIN and OFFSET scaling. This register has a length of 16 bit and it is two’s-complemented coded. Therefor the register value can vary between 32768 ... 32767. DAC The DAC register offers the possibility to read the magnetic-field information at the end of the complete signal path. The value of this register is then converted into an analog output voltage. The register has a length of 16 bit and it is two’s-complemented coded. Therefor the register value can vary between 32768 ... 32767. MIC_ID1 and MIC_ID2 The two registers MIC_ID1 and MIC_ID2 are used by TDK-Micronas to store production information like, wafer number, die position on wafer, production lot, etc. Both registers have a length of 16 bit each and are readout only. TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 12 HAL 2420, HAL 2425 DATA SHEET DIAGNOSIS The DIAGNOSIS register enables the customer to identify certain failures detected by the sensor. HAL 242x performs certain self tests during power-up of the sensor and also during normal operation. The result of these self tests is stored in the DIAGNOSIS register. DIAGNOSIS register is a 16 bit register. Bit No. Function Description 15:6 None Reserved 5 State Machine (DSP) Self-test This bit is set to 1 in case that the state machine selftest fails. (continuously running) 4 EEPROM Self-test This bit is set to 1 in case that the EEPROM self-test fails. (Performed during power-up only) 3 ROM Check This bit is set to 1 in case that ROM parity check fails. (continuously running) 2 Adder overflow This bit is set to 1 in case that an overflow occurs during calculation of the Micronas temperature compensation 1:0 None Reserved Details on the sensor self-tests can be found in Section 3.3. on page 21. TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 13 HAL 2420, HAL 2425 DATA SHEET PROG_DIAGNOSIS The PROG_DIAGNOSIS register enables the customer to identify errors occurring during programming and writing of the EEPROM or NVRAM memory. The customer must either check the status of this register after each write or program command or alternatively the second acknowledge. Please check the Programming Guide for HAL 242x. The PROG_DIAGNOSIS register is a 16 bit register. The following table shows the different bits indicating certain errors possibilities. Bit No. Function Description 15:11 None Reserved 10 Charge Pump Error This bit is set to 1 in case that the internal programming voltage was to low 9 Voltage Error during Program/Erase This bit is set to 1 in case that the internal supply voltage was to low during program or erase 8 NVRAM Error This bit is set to 1 in case that the programming of the NVRAM failed 7:0 Memory Programming For further information please refer to the Programming Guide for HAL 242x TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 14 HAL 2420, HAL 2425 DATA SHEET 3.2.2.2.EEPROM register EEPROM TCCOx TCCGx Hall-Plate A D (Magnetic Ranges) Barrel Shifter CUSTOMER SETUP Micronas Offset & Gain Trimming Customer Offset & Gain Trimming SCALE_GAIN SCALE_OFFSET SETPOINTx DAC_GAIN DAC_OFFSET Setpoint Linearization DAC Gain & Offset Scaling Digital Signal Processing Temp-Sensor -C- Micronas Temp-Sensor Trimming DAC Drift Compensation Output Clamping DAC DAC_CMPLO DAC_CMPHI Fig. 3–3: Details of EEPROM and Digital Signal Processing CUST_ID1 and CUST_ID2 The two registers CUST_ID1 and CUST_ID2 can be used to store customer information. Both registers have a length of 16 bit each. Barrel Shifter (Magnetic ranges) The signal path of HAL 242x contains a Barrel Shifter to emulate magnetic ranges. The customer can select between different magnetic ranges by changing the Barrel shifter setting. After decimation filter the signal path has a word length of 22 bit. The Barrel Shifter selects 16 bit out of the available 22 bit. Note In case that the external field exceeds the magnetic-field range the CFX register will be clamped either to 32768 or 32767 depending on the sign of the magnetic field. TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 15 HAL 2420, HAL 2425 DATA SHEET Table 3–1: Relation between Barrel Shifter setting and emulated magnetic range BARREL SHIFTER Used bits Typ. magnetic range 0 22...7 not used 1 21...6 200 mT 2 20...5 100 mT 3 19...4  50 mT 4 18...3  25 mT 5 17...2 12 mT 6 16...1  6 mT The Barrel Shifter bits are part of the CUSTOMER SETUP register (bits 14...12). The CUSTOMER SETUP register is described on the following pages. TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 16 HAL 2420, HAL 2425 DATA SHEET Magnetic Sensitivity TCCG The TCCG (Sensitivity) registers (TCCG0 ... TCCG2) contain the customer setting for the multiplier in the DSP. The multiplication factor is a second order polynomial of the temperature. All three polynomial coefficients have a bit length of 16 bit and they are two’s-complemented coded. Therefor the register values can vary between 32768 ... 32767. In case that the target polynomial is based on normalized values, then each coefficient can vary between 1 ... +1. To store each coefficient into the EEPROM it is necessary to multiply the normalized coefficients with 32768. Example: – Tccg0 = 0.5102 => TCCG0 = 16719 – Tccg1 = 0.0163 => TCCG1 = 536 – Tccg2 = 0.0144 => TCCG2 = 471 In case that the polynomial was calculated based on not normalized values of TEMP_ADJ and MIC_COMP, then it is not necessary to multiply the polynomial coefficients with a factor of 32768. Magnetic Offset TCCO The TCCO (Offset) registers (TCCO0 and TCCO1) contain the parameters for the adder in the DSP of the sensor. The added value is a first order polynomial of the temperature. Both polynomial coefficients have a bit length of 16 bit and they are two’s-complemented coded. Therefor the register values can vary between 32768 ... 32767. In case that the target polynomial is based on normalized values, then each coefficient can vary between 1 ... +1. To store each coefficient into the EEPROM it is necessary to multiply the normalized coefficients with 32768. In case that the polynomial was calculated based on not normalized values of TEMP_ADJ and MIC_COMP, then it is not necessary to multiply the polynomial coefSETPOINTS HAL 2425 features a linearization function based on 16 setpoints. The setpoint linearization in general allows to linearize a given output characteristic by applying the inverse compensation curve. Each of the 16 setpoints (SETPT) registers have a length of 16 bit. The setpoints have to be computed and stored in a differential way. This means that if all setpoints are set to 0, then the linearization is set to neutral and a linear curve is used. TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 17 DATA SHEET HAL 2420, HAL 2425 Sensitivity and Offset Scaling before setpoint linearization SCALE_GAIN/ SCALE_OFFSET The setpoint linearization uses the full 16 bit number range 0...32767 (only positive values possible). So the signal path should be properly scaled for optimal usage of all 16 setpoints. For optimum usage of the number range an additional scaling stage is added in front of the set point algorithm. The setpoint algorithm allows positive input numbers only. The input scaling for the linearization stage is done with the EEPROM registers SCALE_GAIN and SCALE_OFFSET. The register content is calculated based on the calibration angles. Both registers have a bit length of 16 bit and are two’s-complemented coded. Analog output signal scaling with DAC_GAIN/DAC_OFFSET The required output voltage range of the analog output is defined by the registers DAC_GAIN (Gain of the output) and DAC_OFFSET (Offset of the output signal). Both register values can be calculated based on the angular range and the required output voltage range. They have a bit length of 16 bit and are two’s-complemented coded. Clamping Levels The clamping levels DAC_CMPHI and DAC_CMPLO define the maximum and minimum output voltage of the analog output. The clamping levels can be used to define the diagnosis band for the sensor output. Both registers have a bit length of 16 bit and are two’s-complemented coded. Both clamping levels can have values between 0% and 100% of VSUP. TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 18 HAL 2420, HAL 2425 DATA SHEET 3.2.2.3.NVRAM Registers Customer Setup The CUST_SETUP register is a 16 bit register that enables the customer to activate various functions of the sensor like, customer burn-in mode, diagnosis modes, functionality mode, customer lock, etc. Table 3–2: Functions in CUST_SETUP register Bit No. Function Description 15 None Reserved 14:12 Barrel Shifter Magnetic Range (see Section Table 3–1: on page 16) 11:10 None Reserved 9:8 Output Short Detection 0: Disabled 1: High & low side over current detection -> OUT = VSUP in error case 2: High & low side over current detection -> OUT = GND in error case 3: Low side over current detection -> OUT = Tristate in error case 7:6 None Reserved 5 Functionality Mode 1: Normal 4 Communication Mode (POUT) Communication via output pin 0: Disabled 1: Enabled 3 Overvoltage Detection 0: Overvoltage detection active 1: Overvoltage detection disabled 2 Diagnosis Latch Latching of diagnosis bits 0: No latching 1: Latched till next POR (power-on reset) 1 Diagnosis 0: Diagnosis errors force output to error band (VSUP) 1: Diagnosis errors do not force output to error band (VSUP) 0 Customer Lock TDK-Micronas GmbH Bit must be set to 1 to lock the sensor memory Nov. 3, 2020; DSH000174_003EN 19 HAL 2420, HAL 2425 DATA SHEET 3.2.2.4.Setpoint linearization accuracy The set point linearization in general allows to linearize a given output characteristic by applying the inverse compensation curve. For this purpose the compensation curve will be divided into 16 segments with equal distance. Each segment is defined by two setpoints, which are stored in EEPROM. Within the interval, the output is calculated by linear interpolation according to the position within the interval. 4 4 x 10 3 2 1 0 -1 -2 Linearized Distorted Compensation -3 -4 -4 -3 -2 -1 0 1 2 3 4 4 x 10 output Fig. 3–4: Linearization - Principle ysn+1  yl ysn xsn xnl xsn+1 input Fig. 3–5: Linearization - Detail xnl: non linear distorted input value yl: linearized value  remaining error TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 20 HAL 2420, HAL 2425 DATA SHEET The constraint of the linearization is that the input characteristic has to be a monotonic function. In addition to that it is recommended that the input does not have a saddle point or inflection point, i.e. regions where the input is nearly constant. This would require a high density of set points 3.3. On-board Diagnostic features The HAL 242x features two groups of diagnostic functions. The first group contains basic functions that are always active. The second group can be activated by the customer and contains supervision and self-tests related to the signal path and sensor memory. Diagnostic features that are always active: – Wire break detection for supply and ground line – Undervoltage detection – Thermal supervision of output stage (overcurrent, short circuit, etc.) Diagnostic features that can be activated by customer: – Overvoltage detection – EEPROM self-test at power-on – Continuous ROM parity check – Continuous state machine self-test – Adder overflow The sensor indicates a fault immediately by switching the output signal to the upper diagnosis level (max. Vout) in case that the diagnostic mode is activated by the customer. The sensor switches the output to tristate if an over temperature is detected by the thermal supervision. The sensor switches the output to ground in case of a VSUP wire break. 3.4. Calibration of the sensor For calibration in the system environment, the application kit from TDK-Micronas is recommended. It contains the hardware for the generation of the serial telegram for programming (HAL-APB V1.5) and the corresponding LabVIEWTM based programming environment for the input of the register values. For the individual calibration of each sensor in the customer application, a two point calibration is recommended. A detailed description of the calibration software, calibration algorithm, programming sequences and register value calculation can be found in the Application Note “HAL 242x Programming Guide”. TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 21 HAL 2420, HAL 2425 DATA SHEET 4. Specifications 4.1. Outline Dimensions Product 4.9 B0.1 A D X 3 4 1 2 HAL24xy X related to center of package 0 Y related to center of package -0.13 D 0.3 A 0.48 weight 0.076 g PIN 1 INDEX +Y 3.9 B0.1 6 B0.2 Y B ( 20 : 1 ) -X +X gauge plane D L center of sensitive area center of package x/y=0 5 6 0.25 -Y 8 7 0.6 B0.18 B 1.27 0.42 0,25O C A-B D 8.5° B2° Y 0.22 B0.05 Sn plated A 0.38x45° 1.42 B0.1 0.65 B0.11 L 0.175 B0.075 4° B4° 8.5° B 2° 0.6 B0.18 F 0 2.5 0.1 C seating plane 5 mm scale TOP VIEW All dimensions are in mm. Physical dimensions do not include moldflash. Sn-thickness might be reduced by mechanical handling. Tin and lead burr on the pins (outside the package body outlines): max. 0.25 PACKAGE ISSUE DATE JEDEC STANDARD (YY-MM-DD) ITEM NO. SOIC8-1 20-07-09 B C seating plane MS-012 ANSI REVISION DATE (YY-MM-DD) BOTTOM VIEW REV.NO. DRAWING-NO. F SPECIFICATION TYPE ISSUE 20-08-14 2 CSOIC0083011.1 ZG NO. 2115_Ver.02 c Copyright 2018 TDK-Micronas GmbH, all rights reserved Fig. 4–1: SOIC8-1: Plastic Small Outline IC package, 8 leads, gullwing bent, 150 mil Ordering code: DJ TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 22 HAL 2420, HAL 2425 DATA SHEET user direction of feed Ø 10 2 18.2 max Ø330 3 Ø1 12 min Devices per Reel: 3500 IEC STANDARD ANSI ISSUE ITEM NO. 4th 60286-3 ISSUE DATE YY-MM-DD DRAWING-NO. ZG-NO. 12-01-31 06836.0001.4 ZG002036_001_01 © Copyright 2012 Micronas GmbH, all rights reserved Fig. 4–2: SOIC8: Tape and Reel Finishing TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 23 HAL 2420, HAL 2425 DATA SHEET Product 5° aro u nd HAL 242x/HAL 245x 14.7B0.2 short lead L gate remain standard 1.55 Y A 0.295B0.09 D 0.2 weight 0.12 g 45° 1.5 B0.05 4.06 B0.05 1 L + 0.2 D connected to PIN 2 0.7 center of sensitive area 2 5° aroun 1 A 3 d 1 B0.2 4.2 max. 4.05 B0.05 Y connected to PIN 2 dambar cut, not Sn plated (6x) L 0.36 B0.05 Sn plated 0-0,5 solder or welding area 0.51 +- 0.1 0.08 0.43 B0.05 Sn plated 1.27 B0.4 1.27 B0.4 lead length, not Sn plated (3x) 0 2.5 5 mm scale All dimensions are in mm. Physical dimensions do not include moldflash. Sn-thickness might be reduced by mechanical handling. PACKAGE ISSUE DATE JEDEC STANDARD (YY-MM-DD) ITEM NO. TO92UT-2 18-02-22 FRONT VIEW ANSI REVISION DATE (YY-MM-DD) REV.NO. BACK VIEW DRAWING-NO. ISSUE SPECIFICATION TYPE 19-12-05 2 CUTI00032507.1 ZG NO. 2090_Ver.02 c Copyright 2018 TDK-Micronas GmbH, all rights reserved Fig. 4–3: TO92UT-2 Plastic Transistor Standard UT package, 3 leads, non-spread TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 24 HAL 2420, HAL 2425 DATA SHEET 5° ar ou nd gate remain Product HAL 242x/HAL 245x 14.7B0.2 short lead L standard Y 1.55 A 0.295B0.09 D 0.2 weight 0.12 g 45° 4.06 B0.05 1.5 B0.05 1 +0.2 connected to PIN 2 L connected to PIN 2 D 0.7 2 1 5° arou nd 0.1 0.51 +- 0.08 A 1 B0.2 4.2 max. 4.05 B0.05 Y center of sensitive area 3 L 0.36 B0.05 Sn plated 0-1,5 solder or welding area 2-4 dambar cut, not Sn plated (6x) 0.43 B0.05 Sn plated 2.54 B0.4 2.54 B0.4 lead length cut not Sn plated (3x) 0 2.5 5 mm scale All dimensions are in mm. Physical dimensions do not include moldflash. Sn-thickness might be reduced by mechanical handling. PACKAGE ISSUE DATE JEDEC STANDARD (YY-MM-DD) ITEM NO. TO92UT-1 18-02-22 BACK VIEW FRONT VIEW ANSI REVISION DATE (YY-MM-DD) REV.NO. DRAWING-NO. ISSUE SPECIFICATION TYPE 19-12-06 2 CUTS00032506.1 ZG NO. 2089_Ver.02 c Copyright 2018 TDK-Micronas GmbH, all rights reserved Fig. 4–4: TO92UT-1 Plastic Transistor Standard UT package, 3 leads, spread TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 25 HAL 2420, HAL 2425 DATA SHEET Δp Δh Δp W2 B A W1 W L W0 H H1 Δh D0 P2 F1 feed direction P0 F2 T1 T view A-B H all dimensions in mm other dimensions see drawing of bulk Short leads Long leads max. allowed tolerance over 20 hole spacings ±1.0 18 - 20 24 - 26 H1 TO92UA TO92UT 21 - 23.1 22 - 24.1 27 - 29.1 28 - 30.1 UNIT D0 F1 F2 Δh L P0 P2 Δp T T1 W W0 W1 W2 mm 4.0 1.47 1.07 1.47 1.07 ±1.0 11.0 max 13.2 12.2 7.05 5.65 ±1.0 0.5 0.9 18.0 6.0 9.0 0.3 STANDARD ANSI ISSUE ITEM NO. - IEC 60286-2 ISSUE DATE YY-MM-DD DRAWING-NO. ZG-NO. 16-07-18 06631.0001.4 ZG001031_Ver.05 © Copyright 2007 Micronas GmbH, all rights reserved Fig. 4–5: TO92UA/UT: Dimensions ammopack inline, not spread TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 26 HAL 2420, HAL 2425 DATA SHEET Δp Δh Δp W2 B A W0 W L W1 H H1 Δh D0 P2 F1 feed direction P0 F2 T1 T view A-B H all dimensions in mm Short leads Long leads max. allowed tolerance over 20 hole spacings ±1.0 H1 18 - 20 24 - 26 TO92UA 21 - 23.1 27 - 29.1 TO92UT 22 - 24.1 28 - 30.1 other dimensions see drawing of bulk UNIT D0 F1 F2 Δh L P0 P2 Δp T T1 W W0 W1 W2 mm 4.0 2.74 2.34 2.74 2.34 ±1.0 11.0 max 13.2 12.2 7.05 5.65 ±1.0 0.5 0.9 18.0 6.0 9.0 0.3 JEDEC STANDARD ANSI ISSUE ITEM NO. - ICE 60286-2 ISSUE DATE YY-MM-DD DRAWING-NO. ZG-NO. 16-07-18 06632.0001.4 ZG001032_Ver.06 © Copyright 2007 Micronas GmbH, all rights reserved Fig. 4–6: TO92UA/UT: Dimensions ammopack inline, spread TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 27 HAL 2420, HAL 2425 DATA SHEET 4.2. Solderability, Welding, Assembly Information related to solderability, welding, assembly, and second-level packaging is included in the document “Guidelines for the Assembly of Micronas Packages”. It is available on the TDK-Micronas website (http://www.micronas.com/en/service-center/downloads) or on the service portal (http://service.micronas.com). 4.3. Pin Connections and Short Descriptions Pin No. Pin Name Type Short Description 1 VSUP SUPPLY Supply Voltage 2 Gnd GND Ground 4 OUT I/O Output and Programming Pin SOIC8 Package All remaining pins (3, 5, 6, 7, 8) must be connected to ground Pin No. Pin Name Type Short Description 1 VSUP SUPPLY Supply Voltage 2 Gnd GND Ground 3 OUT I/O Output and Programming Pin TO92UT Package 1 VSUP OUT 4 2 GND (3, 5, 6, 7, 8) Fig. 4–7: Pin configuration (SOIC8) TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 28 HAL 2420, HAL 2425 DATA SHEET 1 VSUP OUT Pin 3 2 GND Fig. 4–8: Pin configuration (TO92UT) 4.4. Physical Dimensions 4.4.1. Dimensions of Sensitive Area 250 µm x 250 µm TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 29 HAL 2420, HAL 2425 DATA SHEET 4.5. Absolute Maximum Ratings Stresses beyond those listed in the “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only. Functional operation of the device at these conditions is not implied. Exposure to absolute maximum rating conditions for extended periods will affect device reliability. This device contains circuitry to protect the inputs and outputs against damage due to high static voltages or electric fields; however, it is advised that normal precautions must be taken to avoid application of any voltage higher than absolute maximum-rated voltages to this circuit. All voltages listed are referenced to ground (GND). Symbol Parameter Pin Min. Max. Unit Condition VSUP Supply Voltage VSUP 8.5 10 V t < 96 h4) 18 18 V t < 1h4) t < 1h4) VOUT Output Voltage OUT 61) 18 V VOUT  VSUP Excess of Output Voltage over Supply Voltage OUT, VSUP  2 V TJ Junction Temperature Range 50 1902) °C t < 96h4) Tstorage Transportation/Short-Term Storage Temperature  55 150 °C Device only without packing material VESD_SOIC8 ESD Protection for SOIC8 package3) All Pins 2 2 kV VSUP vs. GND 8 8 kV HBM AEC-Q-100-002 (100 pF / 1.5 k) OUT vs. GND 8 8 kV VSUP vs. OUT 8 8 kV All Pins 8 8 kV VESD_TO92 ESD Protection for TO92UT package3) HBM AEC-Q-100-002 (100 pF / 1.5 k) internal protection resistor = 50  for 96 hrs - Please contact TDK-Micronas for other temperature requirements. 3) For system ESD robustness, pins not used have to be connected to GND. 4) No cumulated stress 1) 2) TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 30 HAL 2420, HAL 2425 DATA SHEET 4.6. Storage and Shelf Life Information related to storage conditions of Micronas sensors is included in the document “Guidelines for the Assembly of Micronas Packages”. It gives recommendations linked to moisture sensitivity level and long-term storage. It is available on the TDK-Micronas website (http://www.micronas.com/en/service-center/downloads) or on the service portal (http://service.micronas.com). 4.7. Recommended Operating Conditions Functional operation of the device beyond those indicated in the “Recommended Operating Conditions/Characteristics” is not implied and may result in unpredictable behavior, reduce reliability and lifetime of the device. All voltages listed are referenced to ground (GND). Symbol Parameter Pin Min. Typ. Max. Unit Remarks VSUP Supply Voltage VSUP 4.5 5 5.5 V IOUT Continuous Output Current OUT 1.2  1.2 mA RL Load Resistor OUT 5.0 10  k CL Load Capacitance OUT 0.33 10 600 nF NPRG Number of EEPROM Programming Cycles1)    100 cycles 0 °C < Tamb < 55 °C    5 cycles 0 °C < Tamb < 55 °C  40 40 40  125 150 170 °C NPRGNV Number of NVRAM Programming Cycles TJ Junction Temperature Range2) Can be pull-up or pulldown resistor for 8000 h3) for 2000 h3) for 1000 h3) 1) In the EEPROM, it is not allowed to program only one single address within a 'bank' in the memory. In case of programming one single address the complete bank has to be programmed. 2) Depends on the temperature profile of the application. Please contact TDK-Micronas for lifetime calculations. 3) Time values are not cumulative. TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 31 HAL 2420, HAL 2425 DATA SHEET 4.8. Characteristics at TJ = 40 °C to +170 °C, VSUP = 4.5 V to 5.5 V, GND = 0 V after programming and locking, at Recommended Operation Conditions if not otherwise specified in the column “Conditions”. Typical Characteristics for TJ = 25 °C and VSUP = 5 V. Symbol Parameter Pin Min. Typ. Max. Unit Conditions ISUP Supply Current over Temperature Range VSUP  7 11 mA Resolution5) OUT  12  bit ratiometric to VSUP 1) DNL Differential Non-Linearity of D/ A Converter4) OUT 0.9 0 0.9 LSB Test limit at 25 °C ambient temperature INL Non-Linearity of Output Voltage over Temperature6) OUT 0.3 0 0.3 %VSUP 2)For V out = 0.35 V ... 4.65 V; VSUP = 5 V ; Linear Setpoint Characteristics ER Ratiometric Error of Output over Temperature (Error in VOUT / VSUP) OUT 0.25 0 0.25 % Max of [VOUT5  VOUT4.5 and VOUT5.5  VOUT5] at VOUT = 10% and 90% VSUP Voffset Offset Drift over Temperature Range6) VOUT (B = 0 mT)25°C VOUT (B = 0 mT)max OUT 0 0.1 0.2 %VSUP VSUP = 5 V ; BARREL SHIFTER = 3 (± 50 mT) VOUTCL Accuracy of Output Voltage at Clamping Low Voltage over Temperature Range5) OUT 11 0 11 mV VOUTCH Accuracy of Output Voltage at Clamping High Voltage over Temperature Range5) OUT 11 0 11 mV RL = 5 k, VSUP = 5 V Spec values are derived from resolution of the registers DAC_CMPHI/LO and Voffset. VOUTH Upper Limit of Signal Band3) OUT 93   %VSUP VSUP = 5 V, 1 mA IOUT 1mA VOUTL Lower Limit of Signal Band3) OUT   7 %VSUP VSUP = 5 V, 1 mA IOUT 1mA fOSC Internal Oscillator Frequency over Temperature Range   4  MHz tr(O) Step Response Time of Output6) OUT  0.4 0.6 ms CL = 10 nF, time from 10% to 90% of final output voltage for a step like signal Bstep from 0 mT to Bmax tPOD Power-Up Time (Time to Reach Certain Output Accuracy)6) OUT     1.7 8.0 ms ms Additional error of 1% Full-Scale Full accuracy BW Small Signal Bandwidth (3 dB)6) OUT  2  kHz VOUTrms Output Noise Voltage RMS6) OUT   1.5 mV BARREL SHIFTER=3 Overall gain in signal path =1 External circuitry according to Fig. 5–1 on page 38 with lownoise supply ROUT Output Resistance over Recommended Operating Range OUT  1 10  VOUTLmax VOUT VOUTHmin 1) Output DAC full scale = 5 V ratiometric, Output DAC offset = 0 V, Output DAC LSB = VSUP/4096 if more than 50% of the selected magnetic-field range is used and the temperature compensation is suitable. INL = VOUT - VOUTLSF with VOUTLSF = Least Square Fit through measured output voltage 3) Signal Band Area with full accuracy is located between V OUTL and VOUTH. The sensor accuracy is reduced below VOUTL and above VOUTH 4) External package stress or overmolding might change this parameter 5) Guaranteed by Design 6) Characterized on small sample size, not tested 2) TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 32 HAL 2420, HAL 2425 DATA SHEET Symbol Parameter Pin Min. Typ. Max. Unit Conditions    142 K/W Determined with a 1s0p board    88 K/W Determined with a 1s1p board    33 K/W Determined with a 1s0p board    22 K/W Determined with a 1s1p board    232 K/W Determined with a 1s0p board    136 K/W Determined with a 2s2p board    40 K/W Determined with a 1s0p board    36 K/W Determined with a 2s2p board SOIC8 Package Thermal Resistance Rthja Junction to Air Rthjc Junction to Case TO92UT Package Thermal Resistance Rthja Rthjc Junction to Air Junction to Case 1) Guaranteed 2) by Design Characterized on small sample size, not tested. TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 33 HAL 2420, HAL 2425 DATA SHEET 4.9.Open-Circuit Detection at TJ = 40 °C to +170 °C, Typical Characteristics for TJ = 25 °C Symbol Parameter Pin Min. Typ. Max. Unit Comment VOUT Output Voltage at Open VSUP Line OUT 0 0 0.15 V VSUP = 5 V RL = 10 kto 200 k 0 0 0.2 V VSUP = 5 V RL = 5 kto 10 k 4.85 4.9 5.0 V VSUP = 5 V RL = 10 kto 200 k 4.8 4.9 5.0 V VSUP = 5 V RL = 5 kto 10 k VOUT Output Voltage at Open GND Line OUT RL: Can be pull-up or pull-down resistor 4.10.Overvoltage and Undervoltage Detection at TJ = 40 °C to +170 °C, Typical Characteristics for TJ = 25 °C, after programming and locking Symbol Parameter Pin Min. Typ. Max. Unit VSUP,UV Undervoltage Detection Level VSUP 3.3 3.9 4.3 V VSUP,UVhyst Undervoltage Detection Level Hysteresis1) VSUP  200  mV VSUP,OV Overvoltage Detection Level VSUP 5.6 6.2 6.9 V VSUP,OVhyst Overvoltage Detection Level Hysteresis1) VSUP  225  mV 1)Characterized Test Conditions on small sample size, not tested TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 34 HAL 2420, HAL 2425 DATA SHEET 4.11.Magnetic Characteristics at TJ = 40 °C to +170 °C, VSUP = 4.5 V to 5.5 V, GND = 0 V after programming and locking, at Recommended Operation Conditions if not otherwise specified in the column “Conditions”. Typical Characteristics for TJ = 25 °C and VSUP = 5 V. Symbol Parameter Pin Min. Typ. Max. SENS Magnetic Sensitivity VOUT/(2xRANGEABS) Unit Test Conditions mV/mT Example: For Barrel_shifter=5 and VOUT = 4 V RANGEABS = 12 mT Sensitivity=4 V/ (2x12mT= 166 mV/mT typ. RANGEABS Absolute Range of  CFX Register (Magnetic Range)1) 6  200 mT Programmable: See Table 3–2 for relation between barrel shifter and Magnetic Range. BOffset Magnetic Offset1) OUT 0.4 0 0.4 mT B = 0 mT, IOUT = 0 mA, TJ = 25 °C, unadjusted sensor BOffset/T Magnetic Offset Change due to TJ1)  5 0 5 T/K B = 0 mT, IOUT = 0 mA BARREL SHIFTER = 3 (±50 mT) ES Error in Magnetic Sensitivity1) SOIC8 TO92UT OUT 1) VSUP = 5 V 1.5 1 0 0 1.5 1 % BARREL SHIFTER = 3 (±50 mT) Characterized on small sample size, not tested TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 35 HAL 2420, HAL 2425 DATA SHEET 4.11.1.Definition of Sensitivity Error ES ES is the maximum of the absolute value of the quotient of the normalized measured value1 over the normalized ideal linear2 value minus 1: meas ES = max  abs  ------------ – 1    ideal   Tmin, Tmax  In the example below, the maximum error occurs at 10 °C: 1.001 ES = ------------- – 1 = 0.8% 0.993 ideal 200 ppm/k 1.03 relative sensitivity related to 25 °C value least-squares method straight line of normalized measured data measurement example of real sensor, normalized to achieve a value of 1 of its least-squares method straight line at 25 °C 1.02 1.01 1.001 1.00 0.992 0.99 0.98 –50 –25 -10 0 25 50 75 100 temperature [°C] 125 150 175 Fig. 4–9: ES definition example 1. normalized to achieve a least-squares method straight line that has a value of 1 at 25 °C 2. normalized to achieve a value of 1 at 25 °C TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 36 HAL 2420, HAL 2425 DATA SHEET 5. Application Notes 5.1. Application Circuit For EMC protection, it is recommended to connect one ceramic 47 nF capacitor each between ground and the supply voltage, respectively the output voltage pin. VSUP OUT HAL242x 47 nF 47 nF GND Fig. 5–1: Recommended application circuit 5.2.Use of two HAL 242x in Parallel Two different HAL 242x sensors which are operated in parallel to the same supply and ground line can be programmed individually as the communication with the sensors is done via their output pins. VSUP OUT A 47 nF HAL242x Sensor A HAL242x Sensor B 47 nF OUT B 47 nF GND Fig. 5–2: Parallel operation of two HAL 242x TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 37 HAL 2420, HAL 2425 DATA SHEET 5.3. Ambient Temperature Due to the internal power dissipation, the temperature on the silicon chip (junction temperature TJ) is higher than the temperature outside the package (ambient temperature TA). T J = T A + T At static conditions and continuous operation, the following equation applies: T = I SUP  V SUP  R thjx For typical values, use the typical parameters. For worst case calculation, use the max. parameters for ISUP and Rthjx (x is representing the different Rth value, like junction to ambient Rthja), and the max. value for VSUP from the application. For VSUP = 5.5 V, Rth = 235 K/W, and ISUP = 10 mA, the temperature difference T = 12.93 K. For all sensors, the junction temperature TJ is specified. The maximum ambient temperature TAmax can be calculated as: T Amax = T Jmax – T TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 38 HAL 2420, HAL 2425 DATA SHEET 6. Programming of the Sensor HAL 242x features two different customer modes. In Application Mode the sensor provides a ratiometric analog output voltage. In Programming Mode it is possible to change the register settings of the sensor. After power-up the sensor is always operating in the Application Mode. It is switched to the Programming Mode by a pulse on the sensor output pin. 6.1. Programming Interface In Programming Mode the sensor is addressed by modulating a serial telegram on the sensors output pin. The sensor answers with a modulation of the output voltage. A logical “0” is coded as no level change within the bit time. A logical “1” is coded as a level change of typically 50% of the bit time. After each bit, a level change occurs (see Fig. 6–1). The serial telegram is used to transmit the EEPROM content, error codes and digital values of the angle information from and to the sensor. tbittime tbittime or logical 0 tbittime tbittime or logical 1 50% 50% 50% 50% Fig. 6–1: Definition of logical 0 and 1 bit A description of the communication protocol and the programming of the sensor is available in a separate document (Application Note Programming HAL 242x). TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 39 HAL 2420, HAL 2425 DATA SHEET Table 6–1: Telegram parameters (All voltages are referenced to GND.) Symbol Parameter Pin Limit Values Unit Test Conditions Min. Typ. Max. 0  0.2*VSUP V 0  1.0 V VSUP V  5.0 V for VSUP = 5 V 6.0 6.5 V Program VSUP Voltage for VSUP 5.7 EEPROM Programming (after PROG and ERASE) Supply voltage for bidirectional communication via output pin. tbittime Biphase Bit Time OUT 900 1000 1100 µs Slew rate OUT  2.0  V/µs VOUTL VOUTH VSUP- Voltage for Output Low OUT Level during Programming through Sensor Output Pin Voltage for Output OUT High Level during Programming through Sensor Output Pin TDK-Micronas GmbH 0.8*VSUP  4.0 Nov. 3, 2020; DSH000174_003EN for VSUP = 5 V 40 HAL 2420, HAL 2425 DATA SHEET 6.2. Programming Environment and Tools For the programming of HAL 242x during product development a programming tool including hardware and software is available on request. It is recommended to use the Micronas tool kit (TDK-MSP V1.x & LabViewTM Programming Environment) in order to ease the product development. The details of programming sequences are also available at service.micronas.com. 6.3. Programming Information For reliability in service, it is mandatory to set the LOCK bit to one and the POUT bit to zero after final adjustment and programming of HAL 242x. The success of the LOCK process must be checked by reading the status of the LOCK bit after locking and by a negative communication test after a power on reset. It is also mandatory to check the acknowledge (first and second) of the sensor or to read/check the status of the PROG_DIAGNOSIS register after each write and store sequence to verify if the programming of the sensor was successful. Please check HAL 242x Programming Guide for further details. Electrostatic Discharges (ESD) may disturb the programming pulses. Please take precautions against ESD. TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 41 HAL 2420, HAL 2425 DATA SHEET 7. Document History 1. Preliminary Data Sheet: “HAL 242x High-Precision Programmable Linear Hall-Effect Sensor”, May 3, 2013, PD000211_001EN. First release of the preliminary data sheet. 2. Preliminary Data Sheet: “HAL 242x High-Precision Programmable Linear Hall-Effect Sensor with Arbitrary Output Characteristics”, July 4 2014, PD000211_002EN. Second release of the preliminary data sheet. Major Change: SOIC8 package added 3. Preliminary Data Sheet: “HAL 242x High-Precision Programmable Linear Hall-Effect Sensor with Arbitrary Output Characteristics”, Sept. 19, 2014 PD000211_003EN. Third release of the preliminary data sheet. Major Changes: – SOIC8 package drawing updated – Absolute Maximum Ratings – Specification of ESD Protection for SOIC8 package 4. Preliminary Data Sheet: “HAL 242x High-Precision Programmable Linear Hall-Effect Sensor with Arbitrary Output Characteristics”, Nov. 26, 2014, PD000211_004EN. Fourth release of the preliminary data sheet. Major Changes: – SOIC8 package drawing updated – Position of Sensitive Areas: A4 value changed to 0.48 mm 5. Data Sheet: “HAL 242x High-Precision Programmable Linear Hall-Effect Sensor with Arbitrary Output Characteristics”, April 15, 2016, DSH000174_001EN. First release of the data sheet. Major Changes: –TO92UT package drawings updated – Ammopack drawings updated – Assembly and storage information changed 6. Data Sheet: “HAL 2420, HAL 2425 High-Precision Programmable Linear Hall-Effect Sensors with Arbitrary Output Characteristics”, May. 4, 2020, DSH000174_002EN. Second release of the data sheet. Major Changes: – SOIC package drawing updated – TO92UT package and tape drawings updated – Maximum Ratings: Tstorage added – Characteristics: new value for parameter VOUTrms – Magnetic Characteristics: new values for parameters SENS and RANGEABS 7. Data Sheet: “HAL 2420, HAL 2425 High-Precision Programmable Linear Hall-Effect Sensors with Arbitrary Output Characteristics”, Nov. 3, 2020, DSH000174_003EN. Third release of the data sheet. Major Changes: – SOIC8 package drawing updated – Thermal resistance values for TO92UT package updated TDK-Micronas GmbH Hans-Bunte-Strasse 19  D-79108 Freiburg  P.O. Box 840  D-79008 Freiburg, Germany Tel. +49-761-517-0  Fax +49-761-517-2174  www.micronas.tdk.com TDK-Micronas GmbH Nov. 3, 2020; DSH000174_003EN 42
HAL2425DJ-A 价格&库存
很抱歉,暂时无法提供与“HAL2425DJ-A”相匹配的价格&库存,您可以联系我们找货
HAL2425DJ-A
  • 2000+15.500752000+2.00671
