HAL2455UT-A
HAL2455UT-A
    TDK(东电化)
    TO-92-3
    传感器 轴 TO-92-3
HAL2455UT-A 数据手册
Hardware Documentation D at a S h e e t ® HAL 2455 High-Precision Programmable Linear Hall-Effect Sensor with PWM Output Edition May 20, 2021 DSH000173_003EN HAL 2455 DATA SHEET Copyright, Warranty, and Limitation of Liability The information and data contained in this document are believed to be accurate and reliable. The software and proprietary information contained therein may be protected by copyright, patent, trademark and/or other intellectual property rights of TDK-Micronas. All rights not expressly granted remain reserved by TDK-Micronas. TDK-Micronas assumes no liability for errors and gives no warranty representation or guarantee regarding the suitability of its products for any particular purpose due to these specifications. By this publication, TDK-Micronas does not assume responsibility for patent infringements or other rights of third parties which may result from its use. Commercial conditions, product availability and delivery are exclusively subject to the respective order confirmation. Any information and data which may be provided in the document can and do vary in different applications, and actual performance may vary over time. All operating parameters must be validated for each customer application by customers’ technical experts. Any mention of target applications for our products is made without a claim for fit for purpose as this has to be checked at system level. Any new issue of this document invalidates previous issues. TDK-Micronas reserves the right to review this document and to make changes to the document’s content at any time without obligation to notify any person or entity of such revision or changes. For further advice please contact us directly. Do not use our products in life-supporting systems, military, aviation, or aerospace applications! Unless explicitly agreed to otherwise in writing between the parties, TDK-Micronas’ products are not designed, intended or authorized for use as components in systems intended for surgical implants into the body, or other applications intended to support or sustain life, or for any other application in which the failure of the product could create a situation where personal injury or death could occur. No part of this publication may be reproduced, photocopied, stored on a retrieval system or transmitted without the express written consent of TDK-Micronas. TDK-Micronas Trademarks – HAL Third-Party Trademarks All other brand and product names or company names may be trademarks of their respective companies. TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 2 HAL 2455 DATA SHEET Contents Page Section Title 4 5 5 1. 1.1. 1.2. Introduction Major Applications Features 6 6 2. 2.1. Ordering Information Device-Specific Ordering Codes 7 7 9 9 9 10 13 17 18 19 20 3. 3.1. 3.2. 3.2.1. 3.2.2. 3.2.2.1. 3.2.2.2. 3.2.2.3. 3.2.2.4. 3.3. 3.4. Functional Description General Function Signal Path and Register Definition Signal Path Register Definition RAM registers EEPROM Registers NVRAM Registers Setpoint Linearization Accuracy On-Board Diagnostic Features Calibration of the Sensor 21 21 27 27 27 27 28 29 29 30 31 31 32 4. 4.1. 4.2. 4.3. 4.4. 4.4.1. 4.5. 4.5.1. 4.6. 4.7. 4.8. 4.9. 4.9.1. Specifications Outline Dimensions Soldering, Welding and Assembly Pin Connections and Short Descriptions Sensitive Area Dimensions Absolute Maximum Ratings Storage and Shelf Life Recommended Operating Conditions Characteristics Overvoltage and Undervoltage Detection Magnetic Characteristics Definition of Sensitivity Error ES 33 33 33 34 34 34 5. 5.1. 5.2. 5.3. 5.4. 5.5. Application Notes Application Circuit Measurement of a PWM Output Signal of HAL 2455 Use of two HAL 2455 in Parallel Ambient Temperature EMC and ESD 35 35 37 37 6. 6.1. 6.2. 6.3. Programming of the Sensor Programming Interface Programming Environment and Tools Programming Information 38 7. Document History TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 3 HAL 2455 DATA SHEET High-Precision Programmable Linear Hall-Effect Sensor with PWM Output Release Note: Revision bars indicate significant changes to the previous edition. 1. Introduction The HAL 2455 is a member of the HAL 24xy family of programmable linear Hall-effect sensors from TDK-Micronas. The device is a universal magnetic-field sensor based on the Hall effect featuring a PWM output. Major characteristics like magnetic-field range, and sensitivity are programmable in a non-volatile memory. The sensor offers wire-break detection. The HAL 2455 offers 16 setpoints to change the output characteristics from linear to arbitrary or vice versa. The HAL 2455 features a temperature-compensated Hall plate with spinning-current offset compensation, an A/D converter, digital signal processing, a PWM output module, an EEPROM with redundancy and lock function for calibration data, a serial interface for programming the EEPROM, and protection devices at all pins. The internal digital signal processing prevents the signal being influenced by analog offsets, temperature shifts, and mechanical stress. The easy programmability allows a 2-point calibration by adjusting the output signal directly to the input signal (like mechanical angle, distance, or current). Individual adjustment of each sensor during the final manufacturing process is possible. With this calibration procedure, the tolerances of the sensor, the magnet and the mechanical positioning can be compensated in the final assembly. In addition, the temperature compensation of the Hall IC can be fit to all common magnetic materials by programming first- and second-order temperature coefficients of the Hall sensor sensitivity. It is also possible to compensate offset drift over temperature generated by the customer application with a first-order temperature coefficient for the sensor’s offset. This enables operation over the full temperature range with high accuracy. The calculation of the individual sensor characteristics and the programming of the EEPROM can easily be done with a PC and the application kit from TDK-Micronas. The sensor is designed for stringent industrial and automotive applications and is AECQ100 qualified. It operates with typically 5 V supply voltage in the junction temperature range from 40 °C up to 170 °C. The HAL 2455 is available in the 3-pin package TO92UT-1/-2 and SOIC8 SMD packages. TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 4 HAL 2455 DATA SHEET 1.1. Major Applications Due to the sensor’s versatile programming characteristics and low temperature drifts, the HAL 2455 is the optimal system solution for applications such as: – Contactless potentiometers, – Angle sensors (e.g. for transmission applications) – Distance and linear movement measurements 1.2. Features – High-precision linear Hall-effect sensor with 12-bit accuracy and PWM output up to 2 kHz – 16 setpoints for various output signal shapes – 16 bit digital signal processing – Multiple customer-programmable magnetic characteristics in a non-volatile memory with redundancy and lock function – Programmable temperature compensation for sensitivity and offset – Magnetic field measurements in the range up to 200 mT – Active open-circuit (ground and supply line break detection) with 5 k pull-up and pull-down resistor, overvoltage and undervoltage detection – Programmable clamping function – Digital readout of temperature and magnetic field information in calibration mode – Programming and operation of multiple sensors at the same supply line – High immunity against mechanical stress, ESD, and EMC – Operates from TJ =40 °C up to 170 °C – Operates from 4.5 V up to 5.5 V supply voltage in specification and functions up to 8.5 V – Operates with static magnetic fields and dynamic magnetic fields up to 2 kHz – Overvoltage and reverse-voltage protection at all pins TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 5 HAL 2455 DATA SHEET 2. Ordering Information A Micronas device is available in a variety of delivery forms. They are distinguished by a specific ordering code: XXX NNNN PA-T-C-P-Q-SP Further Code Elements Temperature Range Package Product Type Product Group Fig. 2–1: Ordering Code Principle For a detailed information, please refer to the brochure: “Micronas Sensors and Controllers: Ordering Codes, Packaging, Handling”. 2.1. Device-Specific Ordering Codes HAL 2455 is available in the following package and temperature variants. Table 2–1: Available packages Package Code (PA) Package Type UT TO92UT-1/-2 DJ SOIC8-1 Table 2–2: Available temperature range Temperature Code (T) Temperature Range A TJ = 40 °C to +170 °C The relationship between ambient temperature (TA) and junction temperature (TJ) is explained in Section 5.4. on page 34. For available variants for Configuration (C), Packaging (P), Quantity (Q), and Special Procedure (SP) please contact TDK-Micronas. Table 2–3: Available ordering codes and corresponding package marking Available Ordering Codes Package Marking HAL2455UT-A-[C-P-Q-SP] 2455A HAL2455DJ-A-[C-P-Q-SP] 2455A TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 6 HAL 2455 DATA SHEET 3. Functional Description 3.1. General Function The HAL 2455 is an integrated circuit which provides a PWM output signal proportional to the magnetic flux through the Hall plate. The external magnetic field component perpendicular to the branded side of the package generates a Hall voltage. The Hall IC is sensitive to magnetic north and south polarity. This voltage is converted to a digital value, processed in the Digital Signal Processing Unit (DSP) according to the settings of the EEPROM registers, and output as PWM signal. The setting of a LOCK bit disables the programming of the EEPROM memory for all time. This bit cannot be reset by the customer. As long as the LOCK bit is not set, the output characteristic can be adjusted by programming the EEPROM registers. The IC is addressed by modulating the output voltage. In the supply voltage range from 4.5 V up to 5.5 V, the sensor generates a PWM signal. After detecting a command, the sensor reads or writes the memory and answers with a digital signal on the output pin. Several sensors in parallel to the same supply and ground line can be programmed individually. The selection of each sensor is done via its output pin. See “Programming Guide HAL 24xy and HAR 24xy”. The open-circuit detection provides a defined output voltage if the VSUP or GND line is broken. Internal temperature compensation circuitry and the spinning-current offset compensation enable operation over the full temperature range with minimal changes in accuracy and high offset stability. The circuitry also reduces offset shifts due to mechanical stress from the package. In addition, the sensor IC is equipped with devices for overvoltage and reverse-voltage protection at all pins. TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 7 HAL 2455 DATA SHEET VSUP Internally Stabilized Supply and Protection Devices Temperature Dependent Bias Oscillator Switched Hall Plate A/D Converter Digital Signal Processing Temperature Sensor A/D Converter Open-circuit, Overvoltage, Undervoltage Detection Linearization 16 Setpoints EEPROM Memory Protection Devices PWM Output OUT Programming Interface Lock Control GND Fig. 3–1: HAL 2455 block diagram TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 8 HAL 2455 DATA SHEET 3.2. Signal Path and Register Definition 3.2.1. Signal Path D Output Clamping A (Magnetic Ranges) Hall-Plate Barrel Shifter CFX MIC_COMP Micronas Offset & Gain Trimming CUST_COMP Customer Offset & Gain Trimming Gain & Offset Scaling block SETPT_IN SETPT DAC Gain & Offset Scaling Setpoint Linearization TEMP_ADJ -C- Micronas Temp-Sensor Trimming Output Clamping PWM Modulator OUT GAINOFF Temp-Sensor DAC Fig. 3–2: Signal path of HAL 2455 3.2.2. Register Definition The DSP is the major part of this sensor and performs the signal conditioning. The parameters for the DSP are stored in the EEPROM registers. The details are shown in Fig. 3–2 and Fig. 3–3. Terminology: GAIN: Name of the register or register value Gain: Name of the parameter The sensors signal path contains two kinds of registers. Registers that are readout only (RAM) and programmable registers (EEPROM & NVRAM). The RAM registers contain measurement data at certain positions of the signal path and the EEPROM registers have influence on the sensors signal processing. TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 9 HAL 2455 DATA SHEET 3.2.2.1. RAM registers TEMP_ADJ The TEMP_ADJ register contains the calibrated temperature sensor information. TEMP_ADJ can be used for the sensor calibration over temperature. This register has a length of 16 bit and it is two’s-complement coded. Therefore the register value can vary between 32768...32767. CFX The CFX register is representing the magnetic field information directly after A/D conversion, decimation filter and magnetic range (barrel shifter) selection. The register content is not temperature compensated. The temperature variation of this register is specified in Section 4.9. on page 31 by the parameter RANGEABS. Note During application design, it must be taken into consideration that CFX should never overflow in the operational range of the specific application and especially over the full temperature range. In case of a potential overflow the barrel shifter should be switched to the next higher range. This register has a length of 16 bit and it is two’s-complement coded. Therefore, the register value can vary between 32768...32767. CFX register values will increase for positive magnetic fields (south pole) on the branded side of the package (positive CFX values) and it will decrease with negative magnetic field polarity. MIC_COMP The MIC_COMP register is representing the magnetic field information directly after the Micronas temperature trimming. The register content is temperature compensated and has a typical gain drift over temperature of 0 ppm/k. Also the offset and its drift over temperature is typically zero. The register has a length of 16 bit and it is two’s-complement coded. Therefore the register value can vary between 32768...32767. CUST_COMP The CUST_COMP register is representing the magnetic field information after the customer temperature trimming. For HAL 2455 it is possible to set a customer specific gain of second order over temperature as well as a customer specific offset of first order over temperature. The customer gain and offset can be set with the EEPROM registers TCCO0, TCCO1 for offset and TCCG0...TCCG2 for gain. Details of these registers are described on the following pages. The register has a length of 16 bit and it is two’s-complement coded. Therefore the register value can vary between 32768...32767. TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 10 HAL 2455 DATA SHEET SETPT_IN The SETPT_IN register offers the possibility to read the magnetic field information after the scaling of the input signal to the input range of the linearization block. For further details see the description of the EEPROM registers SCALE_GAIN and SCALE_OFFSET that are described in the next chapter. The register has a length of 16 bit and it is two’s-complement coded. Therefor the register value can vary between 32768...32767. SETPT The SETPT register offers the possibility to read the magnetic field information after the linearization of the magnetic field information with 16 setpoints. This information is also required for the correct setting of the sensors DAC GAIN and OFFSET in the following block. The register has a length of 16 bit and it is two’s-complement coded. Therefore the register value can vary between 32768...32767. GAINOFF The GAINOFF register offers the possibility to read the magnetic field information after the DAC GAIN and OFFSET scaling. This register has a length of 16 bit and it is two’s-complement coded. Therefore the register value can vary between 32768...32767. MIC_ID1 and MIC_ID2 The two registers MIC_ID1 and MIC_ID2 are used by TDK-Micronas to store production information like, wafer number, die position on wafer, production lot, etc. Both registers have a length of 16 bit each and are readout only. TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 11 HAL 2455 DATA SHEET PWM Frequency The PWM frequency is selectable by 2 bits, which are part of the CUSTOMER SETUP register (bits 11:10). The CUSTOMER SETUP register is described on the following pages. The following four different frequencies can be used: Table 3–1: Selectable PWM frequencies PWM_FREQ Frequency Resolution Bit 11 Bit 10 1 1 2 kHz 11 bit 0 0 1 kHz 12 bit 0 1 500 Hz 12 bit 1 0 250 Hz 12 bit DIAGNOSIS The DIAGNOSIS register enables the customer to identify certain failures detected by the sensor. HAL 2455 performs certain self tests during power-up of the sensor and also during normal operation. The result of these self tests is stored in the DIAGNOSIS register. DIAGNOSIS register is a 16 bit register. Bit No. Function Description 15:6 None Reserved 5 State Machine (DSP) Self test This bit is set to 1 in case that the statemachine self test fails. (continuously running) 4 EEPROM Self test This bit is set to 1 in case that the EEPROM self test fails. (Performed during power-up only) 3 ROM Check This bit is set to 1 in case that ROM parity check fails. (continuously running) 2 AD converter overflow This bit is set to 1 in case the input signal is too high, indicating a problem with the magnetic range. 1:0 None Reserved Details on the sensor self tests can be found in Section 3.3. on page 19. TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 12 HAL 2455 DATA SHEET PROG_DIAGNOSIS The PROG_DIAGNOSIS register enables the customer to identify errors occurring during programming and writing of the EEPROM or NVRAM memory. The customer must either check the status of this register after each write or program command or alternatively the second acknowledge. Please check the Programming Guide for HAL 24xy. The PROG_DIAGNOSIS register is a 16 bit register. The following table shows the different bits indicating certain errors possibilities. Bit no. Function Description 15:11 None Reserved 10 Charge Pump Error This bit is set to 1 in case that the internal programming voltage was to low 9 Voltage Error during Program/Erase This bit is set to 1 in case that the internal supply voltage was to low during program or erase 8 NVRAM Error This bit is set to 1 in case that the programming of the NVRAM failed 7:0 Programming For further information please refer to the Programming Guide for HAL 24xy 3.2.2.2. EEPROM Registers EEPROM D Barrel Shifter A (Magnetic Ranges) Hall-Plate SCALE_GAIN SCALE_OFFSET SETPOINTx TCCOx TCCGx CUSTOMER SETUP Micronas Offset & Gain Trimming Customer Offset & Gain Trimming Offset & Gain Scaling DAC_GAIN DAC_OFFSET DAC Gain & Offset Scaling Setpoint Linearization Digital Signal Processing Temp-Sensor -C- Micronas Temp-Sensor Trimming Output Clamping PWM Out DAC_CMPLO DAC_CMPHI Fig. 3–3: Details of EEPROM and Digital Signal Processing TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 13 HAL 2455 DATA SHEET CUST_ID1 and CUST_ID2 The two registers CUST_ID1 and CUST_ID2 can be used to store customer information. Both registers have a length of 16 bit each. Barrel Shifter (Magnetic Ranges) The signal path of HAL 2455 contains a Barrel Shifter to emulate magnetic ranges. The customer can select between different magnetic ranges by changing the Barrel shifter setting. After decimation filter the signal path has a word length of 22 bit. The Barrel Shifter selects 16 bit out of the available 22 bit. Table 3–2: Relation between Barrel Shifter setting and emulated magnetic range BARREL SHIFTER Used bits Typ. magnetic range 0 22...7 not used 1 21...6 200 mT 2 20...5 100 mT 3 19...4  50 mT 4 18...3  25 mT 5 17...2 12 mT 6 16...1  6 mT The Barrel Shifter bits are part of the CUSTOMER SETUP register (bits 14...12). The CUSTOMER SETUP register is described on the following pages. Note In case that the external field exceeds the magnetic field range, the CFX register will be clamped either to 32768 or 32767 depending on the sign of the magnetic field. TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 14 HAL 2455 DATA SHEET Magnetic Sensitivity TCCG The TCCG (Sensitivity) registers (TCCG0...TCCG2) contain the customer setting temperature dependant gain factor. The multiplication factor is a second order polynomial of the temperature. All three polynomial coefficients have a bit length of 16 bit and they are two’s-complement coded. Therefore the register values can vary between 32768...32767. In case that the target polynomial is based on normalized values, then each coefficient can vary between 4 ... +4. To store each coefficient into the EEPROM it is necessary to multiply the normalized coefficients with 32768. Example: – Tccg0 = 0.5102 => TCCG0 = 16719 – Tccg1 = 0.0163 => TCCG1 = 536 – Tccg2 = 0.0144 => TCCG2 = 471 In case that the polynomial was calculated based on not normalized values of TEMP_ADJ and MIC_COMP, then it is not necessary to multiply the polynomial coefficients with a factor of 32768. Magnetic Offset TCCO The TCCO (Offset) registers (TCCO0 and TCCO1) contain the parameters for temperature dependant offset correction. The offset value is a first order polynomial of the temperature. Both polynomial coefficients have a bit length of 16 bit and they are two’s-complement coded. Therefore the register values can vary between 32768...32767. In case that the target polynomial is based on normalized values, then each coefficient can vary between 4 ... +4. To store each coefficient into the EEPROM it is necessary to multiply the normalized coefficients with 32768. In case that the polynomial was calculated based on not normalized values of TEMP_ADJ and MIC_COMP, then it is not necessary to multiply the polynomial coefficients. SETPOINTS HAL 2455 features a linearization function based on 16 setpoints. The setpoint linearization in general allows to linearize a given output characteristic by applying the inverse compensation curve. Each of the 16 setpoints (SETPT) registers has a length of 16 bit. The setpoints have to be computed and stored in a differential way. This means that if all setpoints are set to 0, then the linearization is set to neutral and a linear curve is used. TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 15 HAL 2455 DATA SHEET Sensitivity and Offset Scaling before Setpoint Linearization SCALE_GAIN/ SCALE_OFFSET The setpoint linearization uses the full 16 bit number range 0...32767 (only positive values possible). So the signal path should be properly scaled for optimal usage of all 16 setpoints. For optimum usage of the number range an additional scaling stage is added in front of the set point algorithm. The setpoint algorithm allows positive input numbers only. The input scaling for the linearization stage is done with the EEPROM registers SCALE_GAIN and SCALE_OFFSET. The register content is calculated based on the calibration angles. Both registers have a bit length of 16 bit and are two’s-complemented coded. Output Signal Scaling with DAC_GAIN/DAC_OFFSET The required output duty cycle of the output is defined by the registers DAC_GAIN (Gain of the output) and DAC_OFFSET (Offset of the output signal). Both register values can be calculated based on the angular range and the required output PWM duty cycle range. They have a bit length of 16 bit and are two’s-complemented coded. Clamping Levels DAC_CMPHI/DAC_CMPLO The clamping levels DAC_CMPHI and DAC_CMPLO define the duty cycle of the output and define the diagnosis band for the sensor output. Both registers have a bit length of 16 bit and are two’s-complemented coded. Both clamping levels can have values between 0% and 100% of full scale. TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 16 HAL 2455 DATA SHEET 3.2.2.3. NVRAM Registers Customer Setup The CUST_SETUP register is a 16 bit register that enables the customer to activate various functions of the sensor like customer burn-in mode, diagnosis modes, functionality mode, customer lock, etc. Bit OP configures the PWM output polarity: a PWM period starts either with a high pulse (OP = 0) or with a low pulse (OP = 1). Please note that OP set to 1 is only effective after the device had been locked (LC=1) Table 3–3: Functions in CUST_SETUP register Bit No. Function Description 15 None Reserved 14:12 Barrel Shifter Magnetic Range (see Section Table 3–2: on page 14) 11:10 PWM frequency setting PWM frequency selection (see Table 3–1 on page 12) 9:8 None Reserved 7 PWM Output Polarity (OP) 0: PWM period starts with a high pulse 1: PWM period starts with a low pulse (effective after LC=1) 6 None Reserved 5 Functionality Mode 1: Normal 4 Communication Mode (POUT) Communication via output pin 0: Disabled 1: Enabled 3 Overvoltage Detection 0: Overvoltage detection active 1: Overvoltage detection disabled 2 Diagnosis Latch Latching of diagnosis bits 0: No latching 1: Latched till next POR (power-on reset) 1 Diagnosis 0: Diagnosis errors force the PWM output into error mode (see Table 3–4) 1: Diagnosis errors do not force the PWM output into error mode 0 TDK-Micronas GmbH Customer Lock (LC) Bit must be set to 1 to lock the sensor memory May 20, 2021; DSH000173_003EN 17 HAL 2455 DATA SHEET 3.2.2.4. Setpoint Linearization Accuracy The set point linearization in general allows to linearize a given output characteristic by applying the inverse compensation curve. For this purpose the compensation curve will be divided into 16 segments with equal distance. Each segment is defined by two setpoints, which are stored in EEPROM. Within the interval, the output is calculated by linear interpolation according to the position within the interval. 4 4 x 10 3 2 1 0 -1 -2 Linearized Distorted Compensation -3 -4 -4 -3 -2 -1 0 1 2 3 4 4 x 10 output Fig. 3–4: Linearization - Principle ysn+1 yl ysn  xnl: non linear distorted input value yl: linearized value  remaining error xsn xnl xsn+1 input Fig. 3–5: Linearization - Detail The constraint of the linearization is that the input characteristic has to be a monotonic function. In addition to that it is recommended that the input does not have a saddle point or inflection point, i.e. regions where the input is nearly constant. This would require a high density of setpoints. TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 18 HAL 2455 DATA SHEET 3.3. On-Board Diagnostic Features The HAL 2455 features two groups of diagnostic functions. The first group contains basic functions that are always active. The second group can be activated by the customer and contains supervision and self-tests related to the signal path and sensor memory. Diagnostic Features that are Always Active: – Wire break detection for supply and ground line – Undervoltage detection – Thermal supervision of output stage: overcurrent, short circuit, etc. Diagnostic Features that can be Activated by Customer: – Overvoltage detection – EEPROM self-test at power-on – Continuous ROM parity check – Continuous state machine self-test – Adder overflow Failure Indication The HAL 2455 indicates a failure by changing the PWM frequency. The different errors are then coded in different duty-cycles. Table 3–4: Failure indication for HAL 2455 Failure Mode Frequency Duty-Cycle EEPROM and state machine self-test 50% 95% Adder overflow 50% 85% Overvoltage 50% 75% Undervoltage 50% 100% Note In case of an error, the sensor changes the selected PWM frequency. Example: During normal operation, the PWM frequency is 1 kHz, in case of an error 500 Hz. TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 19 HAL 2455 DATA SHEET 3.4. Calibration of the Sensor For calibration in the system environment, the application kit from TDK-Micronas is recommended. It contains the hardware for the generation of the serial telegram for programming and the corresponding LabViewTM based programming environment for the input of the register values (see Section 6.2. on page 37). For the individual calibration of each sensor in the customer application, a two point calibration is recommended. A detailed description of the calibration software example provided by TDK-Micronas, calibration algorithm, programming sequences and register value calculation can be found in the Application Note “HAL 24xy Programming Guide”. TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 20 HAL 2455 DATA SHEET 4. Specifications 4.1. Outline Dimensions Product 4.9 B0.1 A HAL24xy X related to center of package 0 Y related to center of package -0.13 D D X 3 4 1 2 0.3 A 0.48 weight 0.076 g PIN 1 INDEX +Y Y B ( 20 : 1 ) 6 B0.2 -X +X gauge plane D L center of sensitive area 5 6 0.25 -Y 8 7 0.6 B0.18 B 1.27 0.42 0,25O C A-B D 8.5° B2° Y 0.22 B0.05 Sn plated A 0.38x45° 8.5° B 2° 4° B4° 0.175 B0.075 1.42 B0.1 0.65 B0.11 L 0.6 B0.18 F 0 2.5 0.1 C seating plane 5 mm scale TOP VIEW All dimensions are in mm. Physical dimensions do not include moldflash. Sn-thickness might be reduced by mechanical handling. PACKAGE ISSUE DATE JEDEC STANDARD (YY-MM-DD) ITEM NO. SOIC8-1 20-07-09 B C seating plane MS-012 BOTTOM VIEW ANSI REVISION DATE (YY-MM-DD) REV.NO. DRAWING-NO. F SPECIFICATION TYPE ISSUE 20-11-19 3 CSOIC0083011.1 ZG NO. 2115_Ver.03 c Copyright 2018 TDK-Micronas GmbH, all rights reserved Fig. 4–1: SOIC8-1: Plastic Small Outline IC package, 8 leads, gullwing bent, 150 mil Ordering code: DJ TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 21 HAL 2455 DATA SHEET user direction of feed Ø 10 2 18.2 max Ø330 3 Ø1 12 min Devices per Reel: 3500 IEC STANDARD ANSI ISSUE ITEM NO. 4th 60286-3 ISSUE DATE YY-MM-DD DRAWING-NO. ZG-NO. 12-01-31 06836.0001.4 ZG002036_001_01 © Copyright 2012 Micronas GmbH, all rights reserved Fig. 4–2: SOIC8: Tape and Reel Finishing TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 22 HAL 2455 DATA SHEET Product 5° aro u nd HAL 242x/HAL 245x 14.7B0.2 short lead L gate remain standard 1.55 Y A 0.295B0.09 D 0.2 weight 0.12 g 45° 1.5 B0.05 4.06 B0.05 1 L + 0.2 D connected to PIN 2 0.7 center of sensitive area 2 5° aroun 1 A 3 d 1 B0.2 4.2 max. 4.05 B0.05 Y connected to PIN 2 dambar cut, not Sn plated (6x) L 0.36 B0.05 Sn plated 0-0,5 solder or welding area 0.51 +- 0.1 0.08 0.43 B0.05 Sn plated 1.27 B0.4 1.27 B0.4 lead length, not Sn plated (3x) 0 2.5 5 mm scale All dimensions are in mm. Physical dimensions do not include moldflash. Sn-thickness might be reduced by mechanical handling. PACKAGE ISSUE DATE JEDEC STANDARD (YY-MM-DD) ITEM NO. TO92UT-2 18-02-22 FRONT VIEW ANSI REVISION DATE (YY-MM-DD) REV.NO. BACK VIEW DRAWING-NO. ISSUE SPECIFICATION TYPE 19-12-05 2 CUTI00032507.1 ZG NO. 2090_Ver.02 c Copyright 2018 TDK-Micronas GmbH, all rights reserved Fig. 4–3: TO92UT-2 Plastic Transistor Standard UT package, 3 leads, non-spread TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 23 HAL 2455 DATA SHEET 5° ar ou nd gate remain Product HAL 242x/HAL 245x 14.7B0.2 short lead L standard Y 1.55 A 0.295B0.09 D 0.2 weight 0.12 g 45° 4.06 B0.05 1.5 B0.05 1 +0.2 connected to PIN 2 L connected to PIN 2 D 0.7 2 1 5° arou nd 0.1 0.51 +- 0.08 A 1 B0.2 4.2 max. 4.05 B0.05 Y center of sensitive area 3 L 0.36 B0.05 Sn plated 0-1,5 solder or welding area 2-4 dambar cut, not Sn plated (6x) 0.43 B0.05 Sn plated 2.54 B0.4 2.54 B0.4 lead length cut not Sn plated (3x) 0 2.5 5 mm scale All dimensions are in mm. Physical dimensions do not include moldflash. Sn-thickness might be reduced by mechanical handling. PACKAGE ISSUE DATE JEDEC STANDARD (YY-MM-DD) ITEM NO. TO92UT-1 18-02-22 BACK VIEW FRONT VIEW ANSI REVISION DATE (YY-MM-DD) REV.NO. DRAWING-NO. ISSUE SPECIFICATION NO. TYPE 19-12-06 2 CUTS00032506.1 ZG 2089_Ver.02 c Copyright 2018 TDK-Micronas GmbH, all rights reserved Fig. 4–4: TO92UT-1 TO92UT-1 Plastic Transistor Standard UT package, 3 leads, spread TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 24 HAL 2455 DATA SHEET Δp Δh Δp W2 B A W1 W L W0 H H1 Δh D0 P2 F1 feed direction P0 F2 T1 T view A-B H all dimensions in mm other dimensions see drawing of bulk Short leads Long leads max. allowed tolerance over 20 hole spacings ±1.0 18 - 20 24 - 26 H1 TO92UA TO92UT 21 - 23.1 22 - 24.1 27 - 29.1 28 - 30.1 UNIT D0 F1 F2 Δh L P0 P2 Δp T T1 W W0 W1 W2 mm 4.0 1.47 1.07 1.47 1.07 ±1.0 11.0 max 13.2 12.2 7.05 5.65 ±1.0 0.5 0.9 18.0 6.0 9.0 0.3 STANDARD ANSI ISSUE ITEM NO. - IEC 60286-2 ISSUE DATE YY-MM-DD DRAWING-NO. ZG-NO. 16-07-18 06631.0001.4 ZG001031_Ver.05 © Copyright 2007 Micronas GmbH, all rights reserved Fig. 4–5: TO92UA/UT: Dimensions ammopack inline, not spread TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 25 HAL 2455 DATA SHEET Δp Δh Δp W2 B A W0 W L W1 H H1 Δh D0 P2 F1 feed direction P0 F2 T1 T view A-B H all dimensions in mm Short leads Long leads max. allowed tolerance over 20 hole spacings ±1.0 H1 18 - 20 24 - 26 TO92UA 21 - 23.1 27 - 29.1 TO92UT 22 - 24.1 28 - 30.1 other dimensions see drawing of bulk UNIT D0 F1 F2 Δh L P0 P2 Δp T T1 W W0 W1 W2 mm 4.0 2.74 2.34 2.74 2.34 ±1.0 11.0 max 13.2 12.2 7.05 5.65 ±1.0 0.5 0.9 18.0 6.0 9.0 0.3 JEDEC STANDARD ANSI ISSUE ITEM NO. - ICE 60286-2 ISSUE DATE YY-MM-DD DRAWING-NO. ZG-NO. 16-07-18 06632.0001.4 ZG001032_Ver.06 © Copyright 2007 Micronas GmbH, all rights reserved Fig. 4–6: TO92UA/UT: Dimensions ammopack inline, spread TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 26 HAL 2455 DATA SHEET 4.2. Soldering, Welding and Assembly Information related to solderability, welding, assembly, and second-level packaging is included in the document “Guidelines for the Assembly of Micronas Packages”. It is available on the TDK-Micronas website (http://www.micronas.com/en/service-center/downloads) or on the service portal (http://service.micronas.com). 4.3. Pin Connections and Short Descriptions Table 4–1: SOIC8 package Pin No Pin Name Type Short Description 1 VSUP SUPPLY Supply Voltage 2 GND GND Ground 4 OUT I/O Output and Programming Pin All remaining pins (3, 5, 6, 7, 8) must be connected to ground Table 4–2: TO92UT package Pin No Pin Name Type Short Description 1 VSUP SUPPLY Supply Voltage 2 GND GND Ground 3 OUT I/O Output and Programming Pin 1 VSUP 1 VSUP OUT OUT Pin 3 4 2 GND (3, 5, 6, 7, 8) SOIC8 package 2 GND TO92UT package Fig. 4–7: Pin configuration in SOIC8 and TO92UT package 4.4. Sensitive Area 4.4.1. Dimensions 250 µm x 250 µm TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 27 HAL 2455 DATA SHEET 4.5. Absolute Maximum Ratings Stresses beyond those listed in the “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only. Functional operation of the device at these conditions is not implied. Exposure to absolute maximum rating conditions for extended periods will affect device reliability. This device contains circuitry to protect the inputs and outputs against damage due to high static voltages or electric fields; however, it is advised that normal precautions must be taken to avoid application of any voltage higher than absolute maximum-rated voltages to this circuit. All voltages listed are referenced to ground (GND). Symbol Parameter Pin Min. Max. Unit Condition VSUP Supply Voltage VSUP 8.5 18 10 18 V V t < 96 h4) t < 1 h4) VOUT Output Voltage OUT 61) 18 V t < 1 h4) VOUT  VSUP Excess of Output Voltage over Supply Voltage VSUP, OUT  2 V TJ Junction Temperature under Bias 50 1902) °C Tstorage Transportation/ShortTerm Storage Temperature 50 150 °C Device only without packing material VESD_SOIC8 ESD Protection for SOIC8 package3) All Pins 2 2 kV VSUP vs. GND 8 8 kV HBM AEC-Q-100-002 (100 pF / 1.5 k) OUT vs. GND 8 8 kV VSUP vs. OUT 8 8 kV All Pins 8 8 kV VESD_TO92 1) 2) 3) 4) ESD Protection for TO92UT package3) HBM AEC-Q-100-002 (100 pF / 1.5 k) internal protection resistor = 50  For 96h, please contact TDK-Micronas for other temperature requirements. For system ESD robustness, pins not used have to be connected to GND. No cumulated stress TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 28 HAL 2455 DATA SHEET 4.5.1. Storage and Shelf Life Information related to storage conditions of Micronas sensors is included in the document “Guidelines for the Assembly of Micronas Packages”. It gives recommendations linked to moisture sensitivity level and long-term storage. It is available on the TDK-Micronas website (http://www.micronas.com/en/service-center/downloads) or on the service portal (http://service.micronas.com). 4.6. Recommended Operating Conditions Functional operation of the device beyond those indicated in the “Recommended Operating Conditions/Characteristics” is not implied and may result in unpredictable behavior, reduce reliability and lifetime of the device. All voltages listed are referenced to ground (GND). Symbol Parameter Pin Min. Typ. Max. Unit Remarks VSUP Supply Voltage VSUP 4.5 5.7 5 6 5.5 6.5 V Normal operation During programming IOUT Continuous Output Current OUT 1.2  5 mA RL Load Resistor OUT 1.0   k CL Load Capacitance OUT  0.18 10 nF NPRG Number of Memory Programming Cycles1)    100 cycles 0°C < Tamb < 55°C TJ Junction Temperature2)  40 40 40  125 150 170 °C Pull-up resistor only for 8000 h3) for 2000 h3) for 1000 h3) 1) In the EEPROM, it is not allowed to program only one single address within a 'bank' in the memory. In case of programming one single address the complete bank has to be programmed 2) Depends on the temperature profile of the application. Please contact TDK-Micronas for life time calculations. Time values are not cumulative 3) TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 29 HAL 2455 DATA SHEET 4.7. Characteristics at TJ = 40 °C to +170 °C, VSUP = 4.5 V to 5.5 V, GND = 0 V, after programming and locking of the sensor, at Recommended Operating Conditions if not otherwise specified in the column “Conditions”. Typical Characteristics for TJ = 25 °C and VSUP = 5 V. Symbol Parameter Limit Values Pin Min. Typ. Max. Unit Test Conditions Supply Current over Temperature Range VSUP  7 11 mA Resolution 1) OUT  12  bit depends on PWM Period tr(O) Response Time of Output 2) OUT - 1.5 2.5 4.5 8.5 1.8 3 5.4 10.2 ms fPWM = 2 kHz fPWM = 1 kHz fPWM = 500 Hz fPWM = 250 Hz tVs Wake-up time2) OUT   1.7 ms CL = 10 nF VOUTL Output Low Voltage OUT  0.5  V VSUP = 5 V, IOUT < 5 mA OUT  0.05 0.1 % BARREL SHIFTER=3 Overall gain in signal path =1 External circuitry according to Fig. 5–1 with low-noise supply ISUP OUTNOISErms Output Noise RMS 2) Related to 12 bit full scale fPWM PWM Frequency 2) OUT 1.7 0.85 0.425 0.213 2 1 0.5 0.25 2.3 kHz 1.15 0.575 0.288 Customer programmable JPWM RMS PWM Jitter 2) OUT  1 2 LSB12 fPWM = 1 kHz trise Rise Time of Digital Output 2) OUT  0.4  µs RL Pull-up = 1 k, CL = 1 nF tfall Fall Time of Digital Output 2) OUT  0.5  µs RL Pull-up = 1 k, CL = 1 nF ROUT_DIG On Resistance of Digital Pull-Up Driver 2) OUT  100 200  Includes 25  series pull-up resistor and 50  pull-down    142 K/W Determined with a 1s0p board    88 K/W Determined with a 1s1p board    33 K/W Determined with a 1s0p board    22 K/W Determined with a 1s1p board    232 K/W Determined with a 1s0p board    136 K/W Determined with a 2s2p board    40 K/W Determined with a 1s0p board    36 K/W Determined with a 2s2p board SOIC8 Package Thermal Resistance Rthja Rthjc Junction to Air Junction to Case TO92UT Package Thermal Resistance Rthja Rthjc 1) 2) Junction to Air Junction to Case Guaranteed by Design Characterized on small sample size, not tested. TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 30 HAL 2455 DATA SHEET 4.8. Overvoltage and Undervoltage Detection at TJ = 40 °C to +170 °C, Typical Characteristics for TJ = 25 °C, after programming and locking Symbol Parameter Pin Min. Typ. Max. Unit VSUP,UV Undervoltage Detection Level VSUP 3.3 3.9 4.3 V VSUP,UVhyst Undervoltage Detection Level Hysteresis1) VSUP  200  mV VSUP,OV Overvoltage Detection Level VSUP 5.6 6.2 6.9 V VSUP,OVhyst Overvoltage Detection Level Hysteresis1) VSUP  225  mV 1) Characterized Test Conditions on small sample size, not tested 4.9. Magnetic Characteristics at TJ = 40 °C to +170 °C, VSUP = 4.5 V to 5.5 V, GND = 0 V after programming and locking, at Recommended Operating Conditions if not otherwise specified in the column “Conditions”. Typical Characteristics for TJ = 25 °C and VSUP = 5 V. Symbol Parameter Pin No. Min. Typ. Max Unit . SENS Magnetic Sensitivity DC/(2xRANGEABS) Test Conditions %DC Example: /mV2) For Barrel_shifter=5 and DC = 100% RANGEABS = 12 mT Sensitivity=100%/(2x12 mT= 4.2%DC/mT max.  6  200 mT Programmable: See Table 3–2 for relation between barrel shifter and Magnetic Range. OUT 0.4 0 0.4 mT B = 0 mT, IOUT = 0 mA, TJ = 25 °C, unadjusted sensor OUT 5 0 5 T/K B = 0 mT, IOUT = 0 mA BARREL SHIFTER = 3 (±50 mT) Error in Magnetic Sensi- OUT tivity 1 0 +1 % TO92 package, VSUP = 5 V, BARREL SHIFTER = 3 (±50 mT) RANGEABS Absolute Range of CFX Register (Magnetic Range)1) BOffset Magnetic Offset1) BOffset/T Magnetic Offset Change due to TJ1) ES 1.5 0 1) Characterized on 2) DC = duty cycle +1.5 SOIC8 package, VSUP = 5 V, BARREL SHIFTER = 3 (±50 mT) small sample size, not tested TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 31 HAL 2455 DATA SHEET 4.9.1. Definition of Sensitivity Error ES ES is the maximum of the absolute value of the quotient of the normalized measured value1 over the normalized ideal linear value2 minus 1: meas ES = max  abs  ------------ – 1  ideal  Tmin, Tmax  In the below example, the maximum error occurs at 10 °C: 1.001 ES = ------------- – 1 = 0.8% 0.993 ideal 200 ppm/k 1.03 relative sensitivity related to 25 °C value least-squares method straight line of normalized measured data 1.02 measurement example of real sensor, normalized to achieve a value of 1 of its least-squares method straight line at 25 °C 1.01 1.001 1.00 0.992 0.99 0.98 -50 -25 -10 0 25 50 75 100 temperature [°C] 125 150 175 Fig. 4–8: ES definition example 1. normalized to achieve a least-squares method straight-line that has a value of 1 at 25 °C 2. normalized to achieve a value of 1 at 25 °C TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 32 HAL 2455 DATA SHEET 5. Application Notes 5.1. Application Circuit For EMC protection, it is recommended to connect one ceramic 47 nF capacitor between ground and the supply voltage pin, and a 180 pF capacitor between ground and the output pin. VSUP OUT HAL 2455 47 nF 180 pF GND Fig. 5–1: Recommended application circuit 5.2. Measurement of a PWM Output Signal of HAL 2455 In case of the PWM output, the magnetic field information is coded in the duty cycle of the PWM signal. The duty cycle is defined as the ratio between the high time “s” and the period “d” of the PWM signal (see Fig. 5–2). Note The PWM signal is updated with the rising edge. Hence, for signal evaluation, the trigger-level must be the rising edge of the PWM signal. Out d VHigh s VLow Update time Fig. 5–2: Definition of PWM signal TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 33 HAL 2455 DATA SHEET 5.3. Use of two HAL 2455 in Parallel Two different HAL 2455 sensors which are operated in parallel to the same supply and ground line can be programmed individually as the communication with the sensors is done via their output pins. VSUP OUT A 47 nF HAL2455 Sensor A HAL2455 Sensor B 180 pF OUT B 180 pF GND Fig. 5–3: Parallel operation of two HAL 2455 5.4. Ambient Temperature Due to the internal power dissipation, the temperature on the silicon chip (junction temperature TJ) is higher than the temperature outside the package (ambient temperature TA). TJ = TA + T At static conditions and continuous operation, the following equation applies: T = ISUP * VSUP * RthjX The X represents junction-to-air or junction-to-case. In order to estimate the temperature difference T between the junction and the respective reference (e.g. air, case, or solder point) use the max. parameters for ISUP, RthX, and the max. value for VSUP from the application. The following example shows the result for junction-to -air conditions. VSUP = 5.5 V, Rthja = 250 K/W and ISUP = 10 mA the temperature difference T = 13.75 K. The junction temperature TJ is specified. The maximum ambient temperature TAmax can be estimated as: TAmax = TJmax T Please contact TDK-Micronas for the detailed investigation reports with the EMC and ESD results. 5.5. EMC and ESD Please contact TDK-Micronas for the detailed investigation reports with the EMC and ESD results. TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 34 HAL 2455 DATA SHEET 6. Programming of the Sensor HAL 2455 features two different customer modes. In Application Mode the sensor provides a PWM output signal. In Programming Mode it is possible to change the register settings of the sensor. After power-up the sensor is always operating in the Application Mode. It is switched to the Programming Mode by a pulse on the sensor output pin. 6.1. Programming Interface In Programming Mode the sensor is addressed by modulating a serial telegram on the sensors output pin. The sensor answers with a modulation of the output voltage. A logical “0” is coded as no level change within the bit time. A logical “1” is coded as a level change of typically 50% of the bit time. After each bit, a level change occurs (see Fig. 6–1). The serial telegram is used to transmit the EEPROM content, error codes and digital values of the angle information from and to the sensor. tbittime tbittime or logical 0 tbittime tbittime or logical 1 50% 50% 50% 50% Fig. 6–1: Definition of logical 0 and 1 bit A description of the communication protocol and the programming of the sensor is available in a separate document (Application Note: HAL 24xy Programming Guide). TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 35 HAL 2455 DATA SHEET Table 6–1: Telegram parameters (All voltages are referenced to GND.) Symbol VOUTL VOUTH Parameter Voltage for Output Low Level during Programming through Sensor Output Pin Pin No. Limit Values Min. Typ. Max. OUT 0  0.2*VSUP V 0  1.0 V VSUP V Voltage for Output High Level OUT during Programming through Sensor Output Pin 0.8*VSUP  Unit Test Conditions 4.0  5.0 V for VSUP = 5 V Supply voltage for bidirectional communication via output pin. VSUPProgram VSUP Voltage for EEPROM programming (after PROG and ERASE) 1 5.7 6.0 6.5 V tbittime Biphase Bit Time 3 900 1000 1100 µs Slew rate 3  2  V/ µs TDK-Micronas GmbH for VSUP = 5 V May 20, 2021; DSH000173_003EN 36 HAL 2455 DATA SHEET 6.2. Programming Environment and Tools For the programming of HAL 2455 it is possible to use the Micronas tool kit (TDK-MSP V1.x & LabVIEWTM Programming Environment) or the USB kit in order to ease the product development. The details of programming sequences are also available at service.micronas.com. 6.3. Programming Information For reliability in service, it is mandatory to set the LOCK bit to one and the POUT bit to zero after final adjustment and programming of HAL 2455. The success of the LOCK process must be checked by reading the status of the LOCK bit after locking and by a negative communication test after a power on reset. It is also mandatory to check the acknowledge (first and second) of the sensor or to read/check the status of the PROG_DIAGNOSIS register after each write and store sequence to verify if the programming of the sensor was successful. Please check HAL 242x Programming Guide for further details. Electrostatic Discharges (ESD) may disturb the programming pulses. Please take precautions against ESD. Note Please check also the “HAL 24xy Programming Guide”. It contains additional information and instructions about the programming of the devices. TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 37 HAL 2455 DATA SHEET 7. Document History 1. Preliminary Data Sheet: “HAL 2455 High-Precision Programmable Linear Hall-Effect Sensor with PWM Output”, July 8, 2014, Pd000215_001EN. First release of the Preliminary Data Sheet. 2. Preliminary Data Sheet: “HAL 2455 High-Precision Programmable Linear Hall-Effect Sensor with PWM Output”, Sept. 19, 2014, PD000215_002EN. Second release of the Preliminary Data Sheet. Major Changes: – SOIC8 package drawing updated – Absolute Maximum Ratings – Specification of ESD Protection for SOIC8 package 3. Data Sheet: “HAL 2455 High-Precision Programmable Linear Hall-Effect Sensor with PWM Output”, Jan. 14, 2016, DSH000173_001EN. First release of the Data Sheet. Major Changes: – SOIC8 package drawing updated – Corrected position A4 value for SOIC8 package – Updated condition (CL=1 nF) for rise time and fall time of digital output – Characteristics: Supply Current over Temperature Range (ISUP): values updated – Assembly and storage information changed 4. Data Sheet: “HAL 2455 High-Precision Programmable Linear Hall-Effect Sensor with PWM Output”, Sept. 9, 2020, DSH000173_002EN. Second release of the Data Sheet. Major changes: – SOIC8 package drawing updated – TO92UT package and tape drawings updated – Maximum Ratings: Tstorage added – Magnetic Characteristics: new values for parameters SENS and RANGEABS 5. Data Sheet: “HAL 2455 High-Precision Programmable Linear Hall-Effect Sensor with PWM Output”, May 20, 2021, DSH000173_003EN. Third release of the Data Sheet. Major changes: – Thermal resistance values for TO92UT package updated – SOIC8-1 package drawing updated TDK-Micronas GmbH Hans-Bunte-Strasse 19  D-79108 Freiburg  P.O. Box 840  D-79008 Freiburg, Germany Tel. +49-761-517-0  Fax +49-761-517-2174  www.micronas.tdk.com TDK-Micronas GmbH May 20, 2021; DSH000173_003EN 38
HAL2455UT-A 价格&库存
很抱歉,暂时无法提供与“HAL2455UT-A”相匹配的价格&库存,您可以联系我们找货
HAL2455UT-A
  • 1+24.556011+3.06224
  • 5+21.879305+2.72845
  • 10+20.8981210+2.60609
  • 25+19.7081625+2.45770
  • 50+18.9009050+2.35703
  • 100+18.15869100+2.26447
  • 500+16.66787500+2.07856
  • 1000+16.112701000+2.00933
库存:5476
HAL2455UT-A
  • 2000+15.603482000+1.94583
  • 4000+15.136464000+1.88759
  • 6000+14.881386000+1.85578
库存:5476
