HAR3735DJ-A
HAR3735DJ-A
    TDK(东电化)
    SOIC-8
    霍尔效应 传感器 X,Y,Z 轴 8-SOIC-1
HAR3735DJ-A 数据手册
Hardware Documentation D at a S h e e t ® HAR 3715, HAR 372x, HAR 373x Robust Dual-Die Programmable 2D Position Sensor Family with Arbitrary Output Function Edition Oct. 25, 2019 DSH000175_003EN DATA SHEET HAR 3715, HAR 372x, HAR 373x Copyright, Warranty, and Limitation of Liability The information and data contained in this document are believed to be accurate and reliable. The software and proprietary information contained therein may be protected by copyright, patent, trademark and/or other intellectual property rights of TDK-Micronas. All rights not expressly granted remain reserved by TDK-Micronas. TDK-Micronas assumes no liability for errors and gives no warranty representation or guarantee regarding the suitability of its products for any particular purpose due to these specifications. By this publication, TDK-Micronas does not assume responsibility for patent infringements or other rights of third parties which may result from its use. Commercial conditions, product availability and delivery are exclusively subject to the respective order confirmation. Any information and data which may be provided in the document can and do vary in different applications, and actual performance may vary over time. All operating parameters must be validated for each customer application by customers’ technical experts. Any mention of target applications for our products is made without a claim for fit for purpose as this has to be checked at system level. Any new issue of this document invalidates previous issues. TDK-Micronas reserves the right to review this document and to make changes to the document’s content at any time without obligation to notify any person or entity of such revision or changes. For further advice please contact us directly. Do not use our products in life-supporting systems, military, aviation and aerospace applications! Unless explicitly agreed to otherwise in writing between the parties, TDK-Micronas’ products are not designed, intended or authorized for use as components in systems intended for surgical implants into the body, or other applications intended to support or sustain life, or for any other application in which the failure of the product could create a situation where personal injury or death could occur. No part of this publication may be reproduced, photocopied, stored on a retrieval system or transmitted without the express written consent of TDK-Micronas. TDK-Micronas Trademarks HAL, 3D HAL, HAR Third-Party Trademarks All other brand and product names or company names may be trademarks of their respective companies. License Note HAR 3715, HAR 372x, and HAR 373x use licenses of Fraunhofer Institute for Integrated Circuits IIS TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 2 HAR 3715, HAR 372x, HAR 373x DATA SHEET Contents Page Section Title 4 5 6 1. 1.1. 1.2. Introduction Major Applications Features 7 7 2. 2.1. Ordering Information Device-Specific Ordering Code 9 9 10 10 10 11 13 19 21 22 24 3. 3.1. 3.2. 3.2.1. 3.2.2. 3.2.2.1. 3.2.2.2. 3.3. 3.4. 3.5. 3.6. Functional Description General Function Signal Path and Register Definition Signal Path Register Definition RAM Registers EEPROM Registers Output Linearization NVRAM Register On-board Diagnostic Features SENT Output 26 26 27 27 27 27 28 29 30 31 37 4. 4.1. 4.2. 4.3. 4.4. 4.5. 4.6. 4.7. 4.8. 4.9. 4.10. Specifications Outline Dimensions Soldering, Welding, Assembly Storage and Shelf Life Size of Sensitive Area Definition of Magnetic-Field Vectors Pin Connections and Short Description Absolute Maximum Ratings Recommended Operating Conditions Characteristics Magnetic Characteristics 39 39 39 39 40 41 41 5. 5.1. 5.2. 5.3. 5.4. 5.5. 5.6. Application Notes Ambient Temperature EMC and ESD Application Circuit for HAR 3715 and HAR 372x Application Circuit for HAR 373x Measurement of a PWM Output Signal of HAR 373x Recommended Pad Size SOIC8 Package 42 42 43 44 6. 6.1. 6.2. 6.3. Programming of the Sensor Programming Interface Programming Environment and Tools Programming Information 45 7. Document History TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 3 HAR 3715, HAR 372x, HAR 373x DATA SHEET Robust Dual-Die Programmable 2D Position Sensor Family with Arbitrary Output Function Release Note: Revision bars indicate significant changes to the previous edition. 1. Introduction The HAR 37xy is the full redundant (dual-die) version of the well known HAL 37xy family using the TDK-Micronas’ proprietary 3D HAL technology. It provides full redundancy due to two independent dies stacked in a single package each bonded on a separate side of the package. The stacked-die architecture ensures that both dies occupy the same magnetic-field position, thus generating synchronous measurement outputs. This family has several members. HAR 372x provides linear, ratiometric analog output signals with integrated wire-break detection working with pull-up or pull-down resistors. Compared to the HAR 372x the HAR 3715 is splitting the 360° measurement range either into four repetitive 90° (MOD 90°) or three 120° (MOD 120°) segments. HAR 373x features digital output formats like PWM and SENT (according SAE J2716 release 2010). The digital output format is customer programmable. The PWM outputs are configurable with frequencies between 0.2 kHz and 2 kHz with up to 12-bit resolution. Conventional planar Hall technology is only sensitive to the magnetic field orthogonal to the chip surface. In addition to the orthogonal magnetic field, HAR 37xy is also sensitive to magnetic fields applied in parallel to the chip surface. This is possible by integrating vertical Hall plates into the standard CMOS process. The sensor cell can measure three magnetic-field components BX, BY, and BZ. This enables a new set of applications for position detection, like wide distance, angle or through-shaft angular measurements. The table below describes the different family members. Type Output Format Detectable Field Component HAR 3715 Analog/Modulo BX and BY HAR 3725 Analog BX and BY HAR 3726 Analog BY and BZ HAR 3727 Analog BX and BZ HAR 3735 PWM & SENT BX and BY HAR 3736 PWM & SENT BY and BZ HAR 3737 PWM & SENT BX and BZ TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 4 DATA SHEET HAR 3715, HAR 372x, HAR 373x On-chip signal processing calculates the angle out of two of the magnetic-field components and converts this value to an output signal. Due to the measurement method, the sensor exhibits excellent drift performance over the specified temperature range resulting in a new class of accuracy for angular or linear measurements. Additionally to the built-in signal processing, the sensor features an arbitrary programmable characteristic for linearization of the output signal (with up to 33 setpoints). Major characteristics like gain and temperature dependent offset of X/Y- and Z-channel, reference position, phase shift between X/Y- and Z-signal, hysteresis, low-pass filter frequency, output slope, and offset and clamping levels can be adjusted to the magnetic circuitry by programming the non-volatile memory. The sensor contains advanced on-board diagnostic features that enhance fail-safe detection. In addition to standard checks, such as overvoltage and undervoltage detection and wire break, internal blocks such as ROM and signal path are monitored during normal operation. For devices with a selected PWM output, the error modes are indicated by a change of PWM frequency and duty-cycle. For SENT output a dedicated error code will be transmitted. The devices are designed for automotive and industrial applications and operate with junction temperature from 40 °C up to 170 °C. The sensors are available in a very small 8-pin SOIC8 package. The package outlines and the X-Y position of the sensitive areas are identical to the single-die version HAL 37xy. 1.1. Major Applications Thanks to its redundancy capability, HAR 37xy can address safety-critical applications according to ISO 26262 rules. Sensor’s versatile programming characteristics and its high accuracy, make the HAR 37xy a potential solution for the following applications examples: – Linear movement measurement, • Dual-Clutch transmission • Engine stroke sensor • Clutch pedal position • Cylinder and valve position sensing – Rotary position measurement, like • Gear selector • Throttle valve position, etc. • Chassis position sensors (ride-height control) with HAR 3715 – Joystick – Non-contact potentiometer TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 5 HAR 3715, HAR 372x, HAR 373x DATA SHEET 1.2. Features Each die provides – Angular and position measurement extremely robust against temperature and stress influence – 12-bit ratiometric linear analog output for HAR 372x – Modulo 90°/120° for HAR 3715 – 0.2 kHz to 2 kHz PWM (up to 12 bits) or 12-bit SENT output for HAR 373x – Programmable arbitrary output characteristic with up to 33 setpoints – 8 kHz sampling frequency – Operates from 4.5 V up to 5.5 V supply voltage – Operates from 40 °C up to 170 °C junction temperature – Programming via the sensor’s output pin – Programmable characteristics in a non-volatile memory (EEPROM) with redundancy and lock function – Programmable first-order low-pass filter – Programmable hysteresis on X/Y or Z-channel – Programmable output gain and offset – X/Y- and Z-channel gain of signal path programmable – Second-order temperature dependent offset of signal path programmable for X/Y- or Z-channel – Phase shift between X/Y- and Z-channel programmable – Programmable offset before angle calculation block – Programmable output clamping for error band definition – Programmable reference position – Programmable magnetic detection range – 32-bit identification number for customer – 32-bit identification number with TDK-Micronas production information (like X,Y position on production wafer) – On-board diagnostics of different functional blocks of the sensor – Short-circuit protected push-pull output – Over- and reverse voltage protection at VSUP – Under- and overvoltage detection of VSUP – Wire-break detection with pull-up or pull-down resistor – EMC and ESD robust design TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 6 HAR 3715, HAR 372x, HAR 373x DATA SHEET 2. Ordering Information A Micronas device is available in a variety of delivery forms. They are distinguished by a specific ordering code: XXX NNNN PA-T-C-P-Q-SP Further Code Elements Temperature Range Package Product Type Product Group Fig. 2–1: Ordering Code Principle For a detailed information, please refer to the brochure: “Sensors and Controllers: Ordering Codes, Packaging, Handling”. 2.1. Device-Specific Ordering Code The HAR 37xy is available in the following package and temperature variant. Table 2–1: Available package Package Code (PA) Package Type DJ SOIC8-1 Table 2–2: Available temperature ranges Temperature Code (T) Temperature Range A TJ = 40 °C to 170 °C The relationship between ambient temperature (TA) and junction temperature (TJ) is explained in Section 5.1. on page 39. For available variants for Configuration (C), Packaging (P), Quantity (Q), and Special Procedure (SP) please contact TDK-Micronas. TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 7 HAR 3715, HAR 372x, HAR 373x DATA SHEET Table 2–3: Available ordering codes and corresponding package marking Available Ordering Codes Package Marking HAR3715DJ-A-[C-P-Q-SP] 3715A HAR3725DJ-A-[C-P-Q-SP] 3725A HAR3726DJ-A-[C-P-Q-SP] 3726A HAR3727DJ-A-[C-P-Q-SP] 3727A HAR3735DJ-A-[C-P-Q-SP] 3735A HAR3736DJ-A-[C-P-Q-SP] 3736A HAR3737DJ-A-[C-P-Q-SP] 3737A TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 8 HAR 3715, HAR 372x, HAR 373x DATA SHEET 3. Functional Description 3.1. General Function HAR 3715, HAR 372x and HAR 373x are 2D position sensors based on TDK-Micronas’ 3D HAL technology. They are dual-die integrated circuits with full redundant output signals. Each sensor die includes two vertical and one horizontal Hall plate with spinning current offset compensation for the detection of X, Y or Z magnetic-field components, a signal processor for calculation and signal conditioning of two magnetic-field components, protection devices, and a ratiometric linear analog, PWM or SENT output. The spinning current offset compensation minimizes the errors due to supply voltage and temperature variations as well as external package stress. The signal path of each die of HAR 37xy consist of two channels (CH1 and CH2). Depending on the product variant two out of the three magnetic-field components are connected to Channel 1 and Channel 2. The sensors can be used for angle measurements in a range between 0° and 360° (end of shaft and through shaft setup) as well as for robust position detection (linear movement or position). The in-system calibration can be utilized by the system designer to optimize performance for a specific system. The calibration information is stored in an on-chip EEPROM. The HAR 37xy is programmable by modulation of the output voltage. No additional programming pin is needed. VSUP1 VSUP2 Internally Stabilized Supply and Protection Devices Temperature Dependent Bias Open-Circuit, Overvoltage, Undervoltage Detection Oscillator Protection Devices TEST1 TEST2 DSP X/Y/Z Hall Plate 33 Setpoints Linearization A/D Analog Output OUT1 D/A Converter A/D PWM/SENT Module OUT2 X/Y/Z Hall Plate EEPROM Memory Temperature Sensor A/D Converter GND1 Digital Output Lock Control GND2 Fig. 3–1: HAR 37xy block diagram TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 9 HAR 3715, HAR 372x, HAR 373x DATA SHEET 3.2. Signal Path and Register Definition 3.2.1. Signal Path fsample CUST_OFFSET CH1/CH2_GAIN CH1_COMP GAIN_CH1 X Channel 1 (CH1) CUST_OFFSETCH1 Adjusted Values LP D 1 st order LP + X + X CUST_OFFSETCH2 BCH2 A LP D 1st order LP Adjusted Values + X Hysteresis BCH1 A ANGLE_IN_CH2 ANGLE_IN_CH1 X Angle calculation ANGLE_AMP LP_FILTER + Channel 2 (CH2) MAG_LOW MAG_HIGH OUT_ZERO GAIN_CH2 Tw (temp.) TADC A D CH2_COMP ADJ TADJ MOD 90°/120° D/A scale CI ANGLE_OUT Linearization 33 Setpoints CP D A VOUT ANGLE_OUT DAC MOD_REG (HAR 3715 only) OUT_OFFSET SP0 to SP32 CLAMP-HIGH OUT_GAIN CLAMP-LOW PRE_OFFSET SENT SENTOUT PWM PWMOUT PWM FREQUENCY d Fig. 3–2: Signal path of HAR 37xy (equal for both dies) 3.2.2. Register Definition The DSP part of this sensor performs the signal conditioning. The parameters for the DSP are stored in the EEPROM/NVRAM register. Details of the signal path are shown in Fig. 3.2. Terminology: GAIN: name of the register or register value Gain: name of the parameter Blue color: register names The sensor signal path contains two kinds of registers. Registers that are readout only (RAM) and programmable registers EEPROM/NVRAM. The RAM registers contain measurement data at certain steps of the signal path and the EEPROM/NVRAM registers have influence on the sensors signal processing. TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 10 DATA SHEET HAR 3715, HAR 372x, HAR 373x 3.2.2.1. RAM Registers TADJ The TADJ register contains the digital value of the sensor junction temperature. It has a length of 16 bits and is binary coded. From the 16 bits only the range between 0 and 32767 is used for the temperature information. Typically the temperature sensor is calibrated in the way that at 40°C the register value is 100 LSB and at 160°C it is 12000 LSB. CH1_COMP and CH2_COMP CH1_COMP and CH2_COMP register contain the temperature compensated magneticfield information of channel 1 and channel 2. Both registers have a length of 16 bits each and are two’s-complement coded. Therefore, the register values can vary between 32768 and 32767. ANGLE_IN_CH1 and ANGLE_IN_CH2 ANGLE_IN_CH1 and ANGLE_IN_CH2 register contain the customer compensated magnetic-field information of channel 1 and channel 2 used for the angle calculation. These registers include already customer phase-shift, gain and offset correction as well as an hysteresis. Both registers have a length of 16 bits each and are two’s-complement coded. Therefore, the register values can vary between 32768 and 32767. ANGLE_OUT The ANGLE_OUT register contains the digital value of the position calculated by the angle calculation algorithm. It has a length of 16 bits and is binary. From the 16 bits only the range between 0 and 32767 is used for the position information. Position can either be an angular position (angle) or a virtual angle calculated out of two magnetic-field directions in case of linear position measurements. DAC The DAC register contains the digital equivalent of the output voltage, PWM output duty-cycle or the SENT data. It has a length of 16 bits and is binary. From the 16 bits only the range between 0 and 32767 is used for the position information. Position can either be an angular position (angle) or a virtual angle calculated out of two magneticfield directions in case of linear position measurements. TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 11 HAR 3715, HAR 372x, HAR 373x DATA SHEET ANGLE_AMP The ANGLE_AMP register contains the digital value of the magnetic-field amplitude calculated by the angle calculation algorithm. From mathematical point of view the amplitude can be calculated out of the signals in channel 1 and channel 2 (X-/Y-/Z-components). Example: Amplitude = 2 CH1 + CH2 2 The angle calculation algorithm adds a factor of roughly 1.6 to the equation for the magnetic amplitude. So the equation for the amplitude is defined as follows: 2 ANGLE_AMP  1.6  CH1 + CH2 2 DIAGNOSIS The DIAGNOSIS register identifies certain failures detected by the sensor. HAR 37xy performs self-tests during power-up of the sensor and also during normal operation. The result of these self tests is stored in the DIAGNOSIS register. DIAGNOSIS register is a 16-bit register. Bit no. Function Description 15:10 None Reserved 9 DAC Output High Clamping This bit is set to 1 in case that the high clamping value of the DAC is reached. 8 DAC Output Low Clamping This bit is set to 1 in case that the low clamping value of the DAC is reached. 7 Channel 1 Clipping 6 Channel 2 Clipping These bits are set to 1 in case that the A/D converter in channel 1 and/or 2 detects an under- or overflow 5 DSP Self Test1) The DSP is doing the internal signal processing like angle calculation, temperature compensation, etc. This bit is set to 1 in case that the DSP self test fails. (Continuously running) Test1) 4 EEPROM Self 3 ROM Check This bit is set to 1 in case that ROM parity check fails. (Continuously running) 2 None Reserved 1 MAGHI This bit is set to 1 in case that the magnetic field is exceeding the MAG-HI register value (magnetic field too high) 0 MAGLO This bit is set to 1 in case that the magnetic field is below the MAG-LOW register value (magnetic field too low) This bit is set to 1 in case that the EEPROM self test fails. (Performed during power-up or continuously running) 1) Details on the sensor self tests can be found in Section 3.5. on page 21. TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 12 HAR 3715, HAR 372x, HAR 373x DATA SHEET PROG_DIAGNOSIS The PROG_DIAGNOSIS register allows the customer to identify errors occurring during programming and writing of the EEPROM or NVRAM memory. The customer must check the first and second acknowledge. To enable debugging of the production line it is recommended to read back the PROG_DIAGNOSIS register in case of a missing second acknowledge. Please check the Programming Guide for HAR 37xy for further details. The PROG_DIAGNOSIS register is a 16-bit register. The following table shows the different bits indicating certain error possibilities. Bit no. Function Description 15:11 None Reserved 10 Charge Pump Error This bit is set to 1 in case that the internal programming voltage was too low 9 Voltage Error during Program/Erase This bit is set to 1 in case that the internal supply voltage was too low during program or erase 8 NVRAM Error This bit is set to 1 in case that the programming of the NVRAM failed 5:0 Programming These bits are used for programming the memory 3.2.2.2. EEPROM Registers Note For production and qualification tests it is mandatory to set the LOCK bit after final adjustment and programming. Note Please refer to the “HAL 37xy, HAR 372x, HAR 373x User Manual” for further details on register settings/calculation and programming of the device. TDK-Micronas ID’s The MIC_ID1 and MIC_ID2 registers are both 16-bit organized. They are read only and contain TDK-Micronas production information, like X/Y position on the wafer, wafer number, etc. Customer ID’s The CUST_ID1 and CUST_ID2 registers are both 16-bit organized. These two registers can be used to store customer production information, like serial number, project information, etc. TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 13 HAR 3715, HAR 372x, HAR 373x DATA SHEET CH1/CH2_GAIN CH1/CH2_GAIN can be used to compensate a phase shift between channel 1 and channel 2. The register has a length of 16 bits. It is possible to make a phase-shift correction of ±75°. The step size and therefore the smallest possible correction is 0.002°. The register is two’s-complement coded and ranges from 32768 to 32767. The register value is sin function based. Neutral value for this register is zero (no phase-shift correction). Note In case the phase-shift correction is used, then it is necessary to adapt the settings of GAIN_CH2 too. For details see definition of GAIN_CH2. GAIN_CH1 and GAIN_CH2 GAIN_CH1 and GAIN_CH2 can be used to compensate amplitude mismatches between channel 1 and channel 2. TDK-Micronas delivers pre calibrated sensors with compensated gain mismatch between channel 1 and channel 2. Nevertheless it is possible that due to the magnetic circuit a mismatch between channel 1 and channel 2 gain occurs. This can be compensated with GAIN_CH1 and GAIN_CH2. Both registers have a length of 16 bits and are two’s-complement coded. Therefore, they can have values between 32768 and 32767 (2 to 2). For neutral settings both register values have to be set to 1 (register value 16384). In case that the phase-shift correction is used it is necessary to change also the gain of channel 2 (see also CH1/CH2_GAIN). If phase-shift correction is used the corresponding register has to be set to 16384 GAIN_CH2 = ---------------------------------------cos  phase shift  Note In case GAIN_CH1 or GAIN_CH2 exceed the range of 2 to 2 (32768 to 32767), then it is possible to reduce the gain of the opposite channel for compensation. TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 14 DATA SHEET HAR 3715, HAR 372x, HAR 373x CUST_OFFSET CUST_OFFSET can be used to compensate an offset in channel 1 and channel 2. TDK-Micronas delivers pre calibrated sensors. Nevertheless it is possible that due to the magnetic circuit an offset in channel 1 and channel 2 occurs. This can be compensated with CUST_OFFSET. The customer offset can also have a temperature coefficient to follow the temperature coefficient of a magnet. The customer offset consists of a polynomial of second-order represented by the three registers CUST_OFFSET1...3. The customer offset can be added to channel 1 and/or channel 2 by the selection coefficients CUST_OFFSETCH1 and CUST_OFFSETCH2. Additionally these two registers can be used to scale the temperature dependent offset between 0% and 100% All five registers have a length of 16 bits and are two’s-complement coded. Therefore, they can have values between 32768 and 32767. HYSTERESIS HYSTERESIS defines the number of digital codes used as an hysteresis on channel 1 and channel 2 before the angle calculation. The purpose of this register is to avoid angle variation on the ANGLE_OUT register and finally on the output signal due to the noise on the ANGLE_IN_CH1 and ANGLE_IN_CH2 signals. The register has a length of 16 bits and is two’s complement number. It is possible to program a hysteresis between 1 LSB and 16383 LSB. The register value itself must be stored as a negative value. The hysteresis function is deactivated by setting the register value to zero. TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 15 HAR 3715, HAR 372x, HAR 373x DATA SHEET OUT_ZERO OUT_Zero defines the reference position for the angle output. It can be set to any value of the output range. It is the starting point/reference for the 33 setpoints. OUT_ZERO has a register length of 16 bits and it is two’s-complement coded. Note Before reading ANGLE_OUT it is necessary to set OUT_ZERO to 0. 360° 270° 90° 0° 180° Fig. 3–3: Example definition of zero degree point Secondly this angle can be used to shift the PI discontinuity point of the angle calculation to the maximum distance from the required angular range in order to avoid the 360°-wrapping of the output due to noise. PRE_OFFSET The PRE_OFFSET register allows to shift the angular range to avoid an overflow of the internal 16-bit calculation/signal path. The PRE_OFFSET register has a length of 16 bits and is two’s-complement coded. OUT_GAIN OUT_GAIN defines the gain of the output signal. The register has a length of 16 bits and is two’s-complement coded. OUT_GAIN = 1 is neutral setting and leads to a change of the output signal from 0% to 100% for an angle change from 0° to 360° (if OUT_OFFSET is set to 0). OUT_GAIN can be changed between 64 and 64. TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 16 DATA SHEET HAR 3715, HAR 372x, HAR 373x OUT_OFFSET OUT_OFFSET defines the offset of the output signal. The register has a length of 16 bits and is two’s complement coded. OUT_OFFSET = 0 is neutral setting and leads to a change of the output signal from 0% to 200% of full scale for an angle change from 0° to 360° (If OUT_GAIN is set to 1). OUT_Offset can be changed between 200% and 200% of full scale. OUT_OFFSET = 0 leads to a voltage offset of 0% of full scale and OUT_OFFSET = 32768 leads to a offset of 200% of VSUP. Clamping Levels (CLAMP-LOW & CLAMP-HIGH) The clamping levels CLAMP_LOW and CLAMP_HIGH define the maximum and minimum output voltage of the analog output. The clamping levels can be used to define the diagnosis band for the sensor output. Both registers have a length of 16 bits and are two’s-complemented coded. Both clamping levels can have values between 0% and 100% of full scale. Magnetic Range Check The magnetic range check uses the magnitude output and compares it with an upper and lower limit threshold defined by the registers MAG-LOW and MAG-HIGH. If either low or high limit is exceeded then the sensor will indicate it with an overflow on the sensors output (output high clamping). MAG-LOW MAG-LOW defines the low level for the magnetic-field range check function. This register has a length of 16 bits and is two’s complement number. MAG-HIGH MAG-HIGH defines the high level for the magnetic-field range check function. This register has a length of 16 bits and is two’s complement number. TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 17 HAR 3715, HAR 372x, HAR 373x DATA SHEET Low-Pass Filter With the LP_Filter register it is possible to select different 3dB frequencies for HAR 37xy. The low-pass filter is a first-order digital filter and the register is 16-bit organized. Various typical filter frequencies between 4 kHz (no filter) and 10 Hz are available. 35000 30000 25000 LP_FILTER [LSB] 20000 15000 10000 5000 0 0 500 1000 1500 2000 2500 3000 3500 4000 3 dB frequency [Hz] Fig. 3–4: 3dB filter frequency vs. LP_FILTER codes Modulo Select The MODULO_Select register is only available in HAR 3715. With this register, the customer can switch between Modulo 90° and 120° output. HAR 3715 is splitting the 360° measurement range either into four repetitive 90° (MOD 90°) or three 120° (MOD 120°) segments. TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 18 HAR 3715, HAR 372x, HAR 373x DATA SHEET 3.3. Output Linearization In certain applications (e.g. through shaft applications or position measurements) it is required to linearize the output characteristic. The resulting output characteristic “value vs. angle/position” is not a linear curve as in the ideal case. But it can be linearized by applying an inverse nonlinear compensation curve. 4 Output Signal [counts] 4 x 10 3 2 1 0 -1 -2 Linearized Distorted Compensation -3 -4 -4 -3 -2 -1 0 1 Input signal [counts] 2 3 4 4 x 10 Fig. 3–5: Example for output linearization For this purpose the compensation curve will be divided into 33 segments with equal distance. Each segment is defined by two setpoints, which are stored in EEPROM. Within the interval, the output is calculated by linear interpolation according to the position within the interval. TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 19 HAR 3715, HAR 372x, HAR 373x output DATA SHEET xnl: non linear distorted input value yl: linearized value e: remaining error ysn+1 e yl ysn xsn xnl xsn+1 input Fig. 3–6: Linearization - detail The constraint of the linearization is that the input characteristic has to be a monotonic function. In addition, it is recommended that the input does not have a saddle point or inflection point, i.e. regions where the input is nearly constant. This would require a high density of set points. To do a linearization the following steps are necessary: – Measure output characteristics over full range – Find the inverse (point-wise mirroring the graph on the bisectrix) – Do a spline fit on the inverse – Insert digital value of set point position into spline fit function for each set point (0, 1024, 2048 ... 32768) – Resulting values can be directly entered into the EEPROM TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 20 HAR 3715, HAR 372x, HAR 373x DATA SHEET 3.4. NVRAM Register Customer Setup The CUST_SETUP register is a 16-bit register that enables the customer to activate various functions of the sensor like diagnosis modes, functionality mode, customer lock, communication protocol speed, etc. Table 3–1: Customer Setup Register Bit no. Function Description 15 None Reserved 14 EEPROM Self-Test EEPROM Self-Test Mode (latched) 0: Running during Power-Up 1: Continuously 13 Communication speed BiPhase-M protocol speed 0: typ. 1 ms 1: typ. 0.25 ms 12 DIGMOD Output format for HAR 373x devices 0: PWM output 1: SENT output 11:10 PWMFREQ Defines the frequency of the PWM output for HAR 373x devices only 0: 1 kHz 1: 500 Hz 2: 200 Hz 3: 2 kHz (11 bits) 9:8 Output Short Detection 0: Disabled 1: High & low side over current detect. Error Band = High: OUT = VSUP Error Band = Low: OUT = GND 2: High & low side over current detect. Error Band = High: OUT = GND Error Band = Low: OUT = VSUP 3: Low side over current detection OUT = Tristate in error case 7 Error Band Error band selection for locked devices (Customer Lock bit set). 0: High error band (VSUP) 1: Low error band (GND) The sensor will always go to high error band as long as it is not locked (Customer Lock bit not set). 6 Burn-In Mode 0: Disabled 1: Enabled 5 Functionality Mode 0: Extended 1: Normal (see Section 4.9. on page 31) 4 Communication Mode (POUT) Communication via output pin 0: Disabled 1: Enabled 3 Overvoltage Detection 0: Overvoltage detection active 1: Overvoltage detection disabled TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 21 HAR 3715, HAR 372x, HAR 373x DATA SHEET Table 3–1: Customer Setup Register, continued Bit no. Function Description 2 Latching of diagnosis bits Diagnosis Latch 0: No latching 1: Latched till next POR (Power-On Reset) 1 Diagnosis 0: Diagnosis errors force output to error band 1: Diagnosis errors do not force output to error band 0 Customer Lock Bit must be set to 1 to lock the sensor memory The Output Short Detection feature is implemented to detect a short circuit between two sensor outputs. The customer can define how the sensor should signalize a detected short circuit (see table above). The time interval in which the sensor is checking for an output short and the detectable short circuit current are defined in Section 4.9. on page 31. This feature should only be used in case that two sensors are used in one module to detect a short between their outputs. In case that the Output Short Detection is not active both sensors will try to drive their output voltage and the resulting voltage will be within the valid signal band. Note The Output Short Detection feature is only active after setting the Customer Lock bit and a power-on reset. 3.5. On-board Diagnostic Features The HAR 37xy features two groups of diagnostic functions. The first group contains basic functions that are always active. The second group can be activated by the customer and contains supervision and self-tests related to the signal path and sensor memory. Diagnostic features that are always active: – – – – Wire break detection for supply and ground line Undervoltage detection Thermal supervision of output stage (overcurrent, short circuit, etc.) EEPROM self-test at power-on Diagnostic features that can be activated by customer: – – – – – – – continuous EEPROM self-test ROM parity check Output signal clamping A/D converter clipping Continuous DSP self-test Magnetic range detection Overvoltage detection TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 22 HAR 3715, HAR 372x, HAR 373x DATA SHEET In case of HAR 3715 and HAR 372x, the sensor indicates a fault immediately by switching the output signal to the selected error band in case that the diagnostic mode is activated by the customer. The customer can select if the output goes to the upper or lower error band by setting bit number 7 in the CUST_SETUP register (Table on page 21). An output short drives the output to VSUP, GND or tristate depending of the customer settings as described in Table 3–1 on page 21. Further details can be found in Section 4.9. on page 31. The sensor switches the output to tristate if an over temperature is detected by the thermal supervision. The sensor switches the output to ground in case of a VSUP wire break and to VSUP in case of a GND wire break. HAR 373x indicates a failure by changing the PWM frequency. The different errors are then coded in different duty-cycles. Table 3–2: Failure indication for HAR 373x Failure Mode Frequency Duty-Cycle EEEPROM, ROM and DSP self-test 50% 95% Magnetic field too low 50% 62.5% Magnetic field too high 50% 55% Overvoltage 50% 75% Undervoltage No PWM n.a. A/D converter clipping 50% 70% In case of undervoltage, the PWM signal will be constantly 'high' or 'low' depending on the setting of bit number 7 in the CUST_SETUP register. Default setting is 'high' level. Note In case of an error the sensor changes the selected PWM frequency. Example: During normal operation the PWM frequency is 1 kHz, in case of an error 500 Hz. TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 23 DATA SHEET HAR 3715, HAR 372x, HAR 373x 3.6. SENT Output The implementation of the SENT (Single Edge Nibble Transmission) interface of HAR 373x is according SAE J2716 release 2010-01. Fig. 3–7 shows the general SENT protocol format. Every transmission starts with a low pulse. The signal is transmitted by the sensor as a series of pulses and data measured as falling to falling edge times. The SENT telegram consists of a synchronization / calibration period, a status & communication nibble, three data nibbles, and a CRC nibble and a pause period. See Section 4.9. on page 31 for the timing parameters of a telegram. All timing values in a SENT protocol are referenced to the clock tick time ttick. After reset the output is recessive high. The transmission starts with a low pulse of the synchronization phase (Fig. 3–7). Every low pulse has the same length specified by the parameter tnlow. The synchronization period has always the same length of clock cycles. The clock variation is included in the parameter tsync. The following status and data nibbles always start with a low pulse with tnlow. The nibble high time of the status tstat, the data td3,2,1 and the CRC tcrc depends on the transmitted value. Therefore, the message time of a SENT message depends on the tick time and the value which is transmitted by the message. In order to synchronize the SENT messages to the measurement sampling rate an additional pause period is added, which is transmitted after the checksum nibble. The time to transmit one message is calculated by: tmessage = tsync + tstat + td3 + td2 + td1 + tcrc The checksum nibble is a 4-bit CRC of the data nibbles only. The status & communication nibble is not included in the CRC calculation. The CRC is calculated using polynomial x4 + x3 + x2 + 1 with seed value of 5. See SAE J2716 for further CRC implementation details. As recommended by the SAE J2716 an additional zero nibble in addition to the 3 data nibbles for the CRC calculation has been implemented. This is a safety measure against common errors in the last data nibble and the checksum. In HAR 373x the transmitted data nibbles are generated based on the DAC register value. Special data codes have been implemented for error indication via the SENT interface. The angular or linear position information is coded in the signal range from 2 to 4087 LSB in the 12-bit range. Table 3–3 gives an overview on the data nibble content. HAR 373x is not using the status nibble for additional information transmission. TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 24 HAR 3715, HAR 372x, HAR 373x DATA SHEET Table 3–3: Data Nibble Content SENT 12-bit value Definition 4092 to 4095 Reserved 4091 Device Error: Device is failing in one of the self tests (EEPROM, ROM, DSP, Overvoltage) 4090 Signal Path Error: MAG-HIGH or -LOW are exceeded, adder overflow or clipping of channel 1 or 2 4089 Reserved 4088 Clamp-High: Upper signal range violation 2 to 4087 Angular or Position information 1 Clamp-Low: Lower signal range violation 0 During Initialization - Power Up The SENT protocol starts after the initialization time of the sensor to ensure valid data after power-up. tnlow tnlow tsync PAUSE (previous telegram) calibr. / synchron. tnibble tnibble status D[11:8] tnibble tnibble D[7:4] D[3:0] tnibble CRC tnibble PAUSE tmessage Fig. 3–7: SENT protocol format with 3 data nibbles and pause period TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 25 HAR 3715, HAR 372x, HAR 373x DATA SHEET 4. Specifications 4.1. Outline Dimensions 4.9 B0.1 Product A D 3 1 2 PIN 1 INDEX 0 X2 0 Y1 0 Y2 0 D 0.3 A1 0.65 A2 0.24 B ( 20 : 1 ) Y2 6 B0.2 3.9 B0.1 Y1 4 HAR371x/HAR 372x/HAR 373x X1 X2 X1 D L center of sensitive area 6 8 7 0.25 5 0.42 B gauge plane L 0,25O C A-B 0.6 B0.18 D 1.27 0.38x45° 0.22 B0.05 Sn plated A1 A2 Y2 8.5° B2° 4° B4° 0.175 B0.075 1.42 B0.1 0.65 B0.11 Y1 8.5° B2° F 0 2.5 0.1 B C seating plane seating plane C 5 mm scale TOP VIEW All dimensions are in mm. Physical dimensions do not include moldflash. Sn-thickness might be reduced by mechanical handling. PACKAGE ISSUE DATE JEDEC STANDARD (YY-MM-DD) ITEM NO. SOIC8-1 18-07-19 MS-012 BOTTOM VIEW ANSI REVISION DATE (YY-MM-DD) REV.NO. DRAWING-NO. ISSUE F SPECIFICATION TYPE 19-06-25 3 CSOIC0083002.1 ZG NO. 2099_Ver.03 c Copyright 2018 TDK-Micronas GmbH, all rights reserved Fig. 4–1: SOIC8-1: Plastic small outline IC package, 8 leads, gullwing bent, 150 mil Ordering code: DJ Weight approximately 0.076 g TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 26 HAR 3715, HAR 372x, HAR 373x DATA SHEET 4.2. Soldering, Welding, Assembly Information related to solderability, welding, assembly, and second-level packaging is included in the document “Guidelines for the Assembly of Micronas Packages”. It is available on the TDK-Micronas website (http://www.micronas.com/en/service-center/ downloads) or on the service portal (http://service.micronas.com). 4.3. Storage and Shelf Life Information related to storage conditions of Micronas sensors is included in the document “Guidelines for the Assembly of Micronas Packages”. It gives recommendations linked to moisture sensitivity level and long-term storage. It is available on the TDK-Micronas website (http://www.micronas.com/en/service-center/downloads) or on the service portal (http://service.micronas.com). 4.4. Size of Sensitive Area Hall plate are = 275 µm x 275 µm See Fig. 4-1 on page xy for more information on the Hall plate position. 4.5. Definition of Magnetic-Field Vectors Note Die 2 is 180° rotated in relation to die 1. There for the measurement values of X and Y components have opposite sign's compared to die 1. TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 27 HAR 3715, HAR 372x, HAR 373x DATA SHEET 4.6. Pin Connections and Short Description Pin No. Pin Name Type Short Description 1 VSUP1 SUPPLY Supply Voltage Pin1 2 GND1 GND Ground 1 3 TEST1 I/O Test 1 4 OUT1 I/O Push-Pull Output and Programming Pin 1 5 VSUP2 SUPPLY Supply Voltage Pin 2 6 GND2 GND Ground 2 7 TEST2 I/O Test 2 8 OUT2 I/O Push-Pull Output and Programming Pin 2 Die 1 Die 2 1 VSUP 1 5 VSUP 2 OUT 2 OUT 1 8 4 3 TEST 1 2 GND 1 6 GND 2 7 TEST 2 Fig. 4–2: Pin configuration Note It is recommended to connect the TEST1 pin to GND1 and to connect the TEST2 pin to GND2 TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 28 HAR 3715, HAR 372x, HAR 373x DATA SHEET 4.7. Absolute Maximum Ratings Stresses beyond those listed in the “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only. Functional operation of the device at these conditions is not implied. Exposure to absolute maximum rating conditions for extended periods will affect device reliability. This device contains circuitry to protect the inputs and outputs against damage due to high static voltages or electric fields; however, it is advised that normal precautions be taken to avoid application of any voltage higher than absolute maximum-rated voltages to this high-impedance circuit. All voltages listed are referenced to ground (GND). Symbol Parameter Pin Min. Max. Unit Condition VSUP Supply Voltage VSUPx 18 18 V t < 1 h 3) VOUT Output Voltage OUTx 6 18 V t < 1 h 3) VOUT  VSUP Excess of Output Voltage over Supply Voltage VSUPx, OUTx  2 V IOUT Continuous Output Current OUTx 10 10 mA TJ Junction Temperature under Bias  50 190 °C 1) Tstorage Transportation/Short Term Storage Temperature  50 150 °C Device only without packing material Bmax Magnetic Field  unlimited unlimited T VESD ESD Protection VSUPx, OUTx, GNDx, TESTx 2 2 kV 2) VSUP1, OUT1, GND1, TEST1 4 4 kV 2) VSUP2, OUT2, GND2, TEST2 4 4 kV 2) For all pin combinations (including die 1 to die 2) For all pin combinations (die 1 only) For all pin combinations (die 2 only) 1) For 96 h - Please contact TDK-Micronas for other temperature requirements AEC-Q100-002 (100 pF and 1.5 k) 3) No cumulated stress 2) TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 29 HAR 3715, HAR 372x, HAR 373x DATA SHEET 4.8. Recommended Operating Conditions Functional operation of the device beyond those indicated in the “Recommended Operating Conditions/Characteristics” is not implied and may result in unpredictable behavior, reduce reliability and lifetime of the device. All voltages listed are referenced to ground (GNDx). Symbol Parameter Pin Min. Typ. Max. Unit Condition VSUP Supply Voltage of one die VSUPx 4.5 5.7 5.0 6.0 5.5 6.5 V V Normal Operation During Programming IOUT Continuous Output Current OUTx 1.2  1.2 mA  5.5 mA HAR 3715 and HAR 372x HAR 373x 5 10  k HAR 3715 and HAR 372x pull-up & pull-down resistor 1   k HAR 373x pull-up resistor 0.33 47 330 nF   1 nF HAR 3715 and HAR 372x HAR 373x 0 °C < Tamb < 55 °C RL CL Load Resistor Load Capacitance OUTx OUTx NPRG Number of Memory Programming Cycles1)    100 cycles BAMP Recommended MagneticField Amplitude  20  100 mT TJ Junction Temperature 2)  40  170 °C for 1000 h 1) The EEPROM is organized in three banks. Each bank contains up to 32 addresses. It is not allowed to program only one single address within one of the three banks. In case of programming one single address the complete bank has to be programmed. 2) Depends on the temperature profile of the application. Please contact TDK-Micronas for life time calculations. Note It is also possible to operate the sensor with magnetic fields down to ±5 mT. For magnetic fields below ±20 mT the sensor performance will be reduced. TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 30 HAR 3715, HAR 372x, HAR 373x DATA SHEET 4.9. Characteristics at TJ = 40 °C to 170 °C, VSUPx = 4.5 V to 5.5 V, GNDx = 0 V, after programming and locking of the sensor, at Recommended Operation Conditions if not otherwise specified in the column “Conditions”. Typical Characteristics for TJ = 25 °C and VSUPx = 5 V. Symbol Parameter Pin Limit Values Min. ISUP tStartup Test Conditions Typ. Max. 8 13 mA Current consumption of each die  12  bit  12  bit For HAR 3715/HAR 372x ratiometric to VSUPx For HAR 373x (depends on PWM Period)   1.7 ms CL = 10 nF (see Fig. 4–3 on page 35) VSUPx 3.3 3.9 4.3 V Functionality Mode: Normal 3.1 3.7 4.1 V Functionality Mode: Extended Supply Current over Temperature Range VSUPx  Resolution 1) OUTx Start-up Time2) Unit OUTx Overvoltage and Undervoltage Detection VSUP,UV Undervoltage Detection Level CUST_SETUP register bit 5 VSUP,UVhyst Undervoltage Detection Level Hysteresis2) VSUPx  200  mV VSUP,OV Overvoltage Detection Level VSUPx 5.6 6.2 6.9 V Functionality Mode: Normal 8.5 9.5 10.4 V Functionality Mode: Extended CUST_SETUP register bit 5 VSUP,OVhyst Overvoltage Detection Level Hysteresis2) VSUPx  225  mV Output Voltage in Case of Error Detection VSUP,DIAG Supply Voltage required to get defined Output Voltage Level2) VSUPx  2.3  V VError,Low Output Voltage Range of Lower Error Band2) OUTx 0  4 %VSUP VSUP > VSUP,DIAG Analog Output 5 k  RL VSUP,DIAG Analog Output 5 k  RL = RL4) < 10k VOUT Output voltage at open GNDx line OUTx 4.85 4.9 5.0 V VSUP = 5 V RL4) = 10 kto 200k 4.8 4.9 5.0 V VSUP = 5 V 5 k>= RL4) < 10k HAR 373x (Digital Output) VOUTH Output High Voltage OUTx 4.8 4.9  V VSUP = 5 V RLpull-up/-down = 5 k VOUTL Output Low Voltage OUTx  0.1 0.2 V VSUP = 5 V RLpull-up/-down = 5 k  0.4 0.65 V 2)  0.2 0.4 µs VSUP = 5 V, RL Pull-up= 1 k CL = 1 nF trise Rise Time of Digital Output2) OUTx VSUP = 5 V RLpull-up = 1 k 2) Characterized on small sample size, not tested. Signal band area with full accuracy is located between VOUTL and VOUTH. The sensors accuracy is reduced below VOUTL and above VOUTH 4) RL can be pull-up or pull-down resistor 5) 4 kHz digital low-pass filter (LP-Filter = off): +/ 20 mT min. magnetic-field amplitude; f BW = 22.5 kHz 3) TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 33 HAR 3715, HAR 372x, HAR 373x DATA SHEET Symbol Parameter Pin Limit Values Min. Typ. Max. Unit Test Conditions VSUP = 5 V, RL Pull-up= 1 k CL = 1 nF Fall Time of Digital Output2) OUTx  0.25 0.4 µs ROUT_DIG On Resistance of Digital PullUp Driver OUTx  100 200  tfall PWM Output tstartup Start-up Time OUTx  1.3 1.7 ms tOSD Overall Signal Delay1) OUTx  0.312 0.343 ms Overall signal delay from magnetic-field input to sensor output. Transmission time of selected PWM frequency to be added. Based on 8 kHz sample frequency OUTNoise Output Noise RMS 1)2) OUTx  0.03 0.074 % Output range 100% DC fPWM PWM Frequency OUTx 1800 900 450 180 2000 1000 500 200 2200 1100 550 220 Hz Customer programmable JPWM RMS PWM Jitter 1) OUTx  1 2 LSB12 fPWM = 1 kHz ttick Clock Tick Time OUTx  2.75  µs tnlow Nibble Low Time OUTx  5  ttick tsync Calibration / Synchronization Period OUTx  56  ttick tnibble Status & Communication Nibble, Data Nibbles and CRC Nibble Period OUTx 12  27 ttick tmessage Message Time OUTx 116  176 ttick tpause Pause Period Time OUTx 12  70 ttick SENT Output 1) 2) tnibble = 12 + [status|data|CRC] Characterized on small sample size, not tested 4 kHz digital low-pass filter (LP-Filter = off): +/ 20 mT min. magnetic-field amplitude; fBW = 22.5 kHz TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 34 HAR 3715, HAR 372x, HAR 373x DATA SHEET Symbol Parameter Pin Limit Values Min. Typ. Max. Unit Test Conditions SOIC8 Package Thermal Resistance Junction to Air    116 K/W Determined with a 1S1P board    111 K/W Determined with a 2S2P board Rthjc Thermal Resistance Junction to Case    30 K/W Determined with a 1S1P and a 2S2P board RISOL Isolation Resistance1) GND1 GND2 4   M Between two dies Rthja 1) GND’s galvanic isolation not tested VSUP VSUP final value VOUT tStartup Fig. 4–3: POR timing Vout [V] VSUP,DIAG VSUP,UV 5 VSUP,OV VSUP [V] : Output Voltage will be between VSUP and GND : CUST_SETUP Register bit 7 set to 1 : CUST_SETUP Register bit 7 set to 0 Fig. 4–4: Behavior of HAR 3715 and HAR 372x for different VSUP TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 35 HAR 3715, HAR 372x, HAR 373x DATA SHEET Voltage [V] 5.0 Typ. 4.2 V Typ. 2.3 V VSUP First PWM period shall be disgarded. Might be invalid. PWM high duty PWM low duty 0 5.0 Error Band = 1 Customer Lock = 1 OUT 0 Drive Low 1/PWMF (2kHz-200Hz) 5.0 Drive High Error Band = X Customer Lock = 0 Or Error Band = 0 Customer Lock = 1 OUT 0 1/PWMF (2kHz-200Hz) tStartup time Start-up behavior customer programmable (high or low) Fig. 4–5: Start-up behavior of HAR 373x with PWM output TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 36 HAR 3715, HAR 372x, HAR 373x DATA SHEET 4.10. Magnetic Characteristics at TJ = 40 °C to 170 °C, VSUPx = 4.5 V to 5.5 V, GNDx = 0 V, after programming and locking of the sensor, at Recommended Operation Conditions if not otherwise specified in the column “Conditions”. Typical characteristics for TJ = 25 °C and VSUPx = 5 V. Symbol Parameter Pin No. Min. Typ. Max. Unit RANGE Detectable angle range OUTx 0  360 ° res Angle resolution OUTx   0.09 ° (360°/4096) Elinxy XY angle linearity error (on output of CORDIC) OUTx 0.5  0.5 ° Min. BAMP =±30 mT, X/Y angle linearity error over temperature (on output of CORDIC) OUTx Elinxy Test Conditions TJ =25 °C1) 2) 3) 1.0 1.7   1.0 1.7 ° ° Min. BAMP =±30 mT1) 2) 3) TJ = 40 ... 150°C TJ > 150 ...170°C 1.5 2.4   1.5 2.4 ° ° Min. BAMP =±20 mT1) 2) 3) TJ = 40 ...150°C TJ > 150 ...170°C ASMmX/Y_Z Absolute sensitivity mismatch on raw signals between X/ Y and Z channel OUTx 3  3 % TJ =25 °C SenseXYZ Sensitivity of X/Y and Z Hall Plate OUTx 118 128 138 LSB/ mT TJ =25 °C SMmX/Y_Z Thermal sensitivity mismatch drift of calibrated signals between X/Y and Z channel OUTx % related to 25 °C1) TJ = 40 ...150°C TJ > 150 ...170°C Thermal sensitivity mismatch drift of calibrated signals between X and Y channel OUTx Offset of calibrated signals of X or Y channel OUTx Offset of calibrated signal of Z channel OUTx SMmXY OffsetXY OffsetZ 2.5 3.5   2.5 3.5 % 2.0 3.0   2.0 3.0 % % related to 25 °C1) TJ = 40 ...150°C TJ > 150 ...170°C 20  20 LSB15 TJ =25 °C1) Can be compensated in customer application 12  12 LSB15 TJ =25 °C1) Can be compensated in customer application 1) Characterized on sample base, 3-sigma values, not tested for each device angular error based on characterization and not on single error summation 3) After optimal EOL calibration at room temperature 2) Calculated TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 37 HAR 3715, HAR 372x, HAR 373x DATA SHEET Symbol Parameter Pin No. Min. Typ. Max. Unit Test Conditions OffsetXY Offset drift of calibrated signals of X or Y channel OUTx 50 100   50 100 LSB15 LSB15 over full temperature range related to 25 °C1) TJ = 40 ...150°C TJ > 150 ...170°C OffsetZ Offset drift of calibrated signals of Z channel OUTx 10  10 LSB15 over full temperature range related to 25 °C1) SMmXYZlife OUTx Relative sensitivity mismatch drift of calibrated signals between X or Y channel and Z channel over life time  1.0  % after 1000h HTOL1) OffsetXYlife Offset drift of calibrated signals of X or Y channel OUTx  30  LSB15 after 1000h HTOL1) OffsetZlife Offset drift of calibrated signal of Z channel OUTx  5  LSB15 after 1000h HTOL1) 1) Characterized on sample base, 3-sigma values, not tested for each device Fig. 4–6: Angular error versus magnetic-field amplitude over full temperature range for devices using X and Y magnetic-field component (for digital output) TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 38 HAR 3715, HAR 372x, HAR 373x DATA SHEET 5. Application Notes 5.1. Ambient Temperature Due to the internal power dissipation, the temperature on the silicon chip (junction temperature TJ) is higher than the temperature outside the package (ambient temperature TA). TJ = TA + T The maximum ambient temperature is a function of power dissipation, maximum allowable die temperature and junction to ambient thermal resistance (Rthja). With a maximum of 5.5 V operating supply voltage the power dissipation P is 0.0825  per die, for a total of 0.165 . The junction to ambient thermal resistance Rthja is specified in Section 4.9. on page 31. The difference between junction and ambient air temperature is expressed by the following equation: T = P * Rthja Note The calculated self-heating of the devices is only valid for the Rth test boards. Depending on the application setup the final results in an application environment might deviate from these values. 5.2. EMC and ESD Please contact TDK-Micronas for detailed information on EMC and ESD results. 5.3. Application Circuit for HAR 3715 and HAR 372x For EMC protection, it is recommended to connect one ceramic 47 nF capacitor each between ground and the supply voltage, respectively the output voltage pin. VSUP 1 OUT1 VSUP 2 HAR 3715 OUT2 HAR 372x 47 nF 47 nF 47 nF 47 nF GND1 GND2 Fig. 5–1: Recommended application circuit for HAR 3715 and HAR 372x If the two dies are operated in parallel to the same supply and ground line, they can be programmed individually as the communication with the sensors is done via their output pins. Note It is recommended to connect TEST1 to GND1 and TEST2 to GND2. TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 39 HAR 3715, HAR 372x, HAR 373x DATA SHEET 5.4. Application Circuit for HAR 373x PWM Output In case of PWM output mode, it is recommended to connect one ceramic 47 nF capacitor between ground and the supply voltage and one ceramic 1 nF capacitor between the output pin and ground for EMC protection. VSUP1 VSUP2 OUT1 OUT2 HAR 373x 47 nF 47 nF 1 nF 1 nF GND1 GND2 Fig. 5–2: Recommended application circuit for HAR 373x in PWM mode SENT Output In case of SENT output mode, it is recommended to connect one ceramic 47 nF capacitor between ground and the supply voltage and a filter structure at the output pin for EMC protection as well for having a SENT standard compliant output slew rate. Following two setups have been tested: – C01 = 180 pF, C02 = 2.2 nF, R01 = 120  – C01 = 180 pF, C02 = 3.3 nF, R01 = 180  OUT1 VSUP2 R01 R01 OUT2 HAR373x C02 C01 GND1 C01 47 nF 47 nF VSUP1 C02 GND2 Fig. 5–3: Recommended application circuit for HAR 373x If the two dies are operated in parallel to the same supply and ground line, they can be programmed individually as the communication with the sensors is done via their output pins. Note It is recommended to connect TEST1 to GND1 and TEST2 to GND2. TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 40 HAR 3715, HAR 372x, HAR 373x DATA SHEET 5.5. Measurement of a PWM Output Signal of HAR 373x In case of the PWM output, the magnetic-field information is coded in the duty cycle of the PWM signal. The duty cycle is defined as the ratio between the high time “s” and the period “d” of the PWM signal (see Fig. 5–4). Note The PWM signal is updated with the rising edge. Hence, for signal evaluation, the trigger-level must be the rising edge of the PWM signal. V(OUTx) d s VHigh VLow time Update Fig. 5–4: Definition of PWM signal 5.6. Recommended Pad Size SOIC8 Package 2.200 0.600 1.270 5.200 Fig. 5–5: Recommended Pad Size dimensions in mm TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 41 HAR 3715, HAR 372x, HAR 373x DATA SHEET 6. Programming of the Sensor HAR 37xy features two different customer modes. In Application Mode the sensors provide a ratiometric analog output voltage or a digital output signal (PWM or SENT). In Programming Mode it is possible to change the register settings of the sensor. After power-up the sensor is always operating in the Application Mode. It is switched to the Programming Mode by a pulse at the sensor output pin. 6.1. Programming Interface In Programming Mode HAR 37xy is addressed by modulating a serial telegram on the sensors output pin. Both sensors answer with a modulation of the output voltage. A logical “0” is coded as no level change within the bit time. A logical “1” is coded as a level change of typically 50% of the bit time. After each bit, a level change occurs (see Fig. 6–1). The serial telegram is used to transmit the EEPROM content, error codes and digital values of the angle information from and to the sensor. tbittime tbittime or logical 0 tbittime tbittime or logical 1 50% 50% 50% 50% Fig. 6–1: Definition of logical 0 and 1 bit A description of the communication protocol and the programming of the sensor is available in a separate document (HAL/HAR 37xy Programming Guide). TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 42 HAR 3715, HAR 372x, HAR 373x DATA SHEET Table 6–1: Telegram parameters (All voltages are referenced to GNDx.) Symbol VOUTL Parameter Pin No. Voltage for Output Low Level during Programming through Sensor Output Pin OUTx Voltage for Output High Level during Programming through Sensor Output Pin OUTx VSUPProgram VSUP Voltage for EEPROM & NVRAM programming (during Programming) VSUPx tbittime Biphase Bit Time OUTx VOUTH Slew rate Limit Values Min. Typ. Max. 0  0.2*VSUP V 1 V 0 OUTx Unit Test Conditions for VSUP = 5 V 0.8*VSUP  VSUP V 4  5.0 V for VSUP = 5 V 5.7 6.0 6.5 V Supply voltage for bidirectional communication via output pin as well as for 3-wire communication via supply voltage modulation 900 225 1000 250 1100 275 µs µs  2  V/µs Cust. programmable, TJ = 25°C Bit 13 of Customer Setup = 0 Bit 13 of Customer Setup = 1 6.2. Programming Environment and Tools For the programming of HAR 37xy during product development a programming tool including hardware and software is available on request. It is recommended to use the TDK-Micronas’ tool kit (TDK-MSP V1.x or USB-Kit and LabVIEW Programming Environment) in order to facilitate the product development. The details of programming sequences are described in the “HAL 37xy, HAR 372x, HAR 373x User Manual”. TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 43 HAR 3715, HAR 372x, HAR 373x DATA SHEET 6.3. Programming Information For production and qualification tests, it is mandatory to set the LOCK bit to one and the POUT bit to zero after final adjustment and programming of HAR 37xy. Before locking the device, it is recommended to read back all register values to ensure that the intended data is correctly stored in the sensor’s memory. Alternatively, it is also possible to cross-check the sensor output signal with the intended output behavior. The success of the LOCK process shall be checked by reading the status of the LOCK bit after locking. It is also mandatory to check the acknowledge (first and second) of the sensor after each write and store sequence to verify if the programming of the sensor was successful. To enable debugging of the production line, it is recommended to read back the PROG_DIAGNOSIS register in case of a missing second acknowledge. Please check “HAL/HAR 37xy Programming Guide” for further details. Electrostatic Discharges (ESD) may disturb the programming pulses. Please take precautions against ESD. Note Please check also the “HAL 37xy, HAR 372x, HAR 373x User Manual” and relevant documentation for the TDK-MSP V1.x or USB-Kit. It contains additional information and instructions about the programming of the devices. TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 44 HAR 3715, HAR 372x, HAR 373x DATA SHEET 7. Document History 1. “HAR 3715, HAR 372x, HAR 373x Robust Dual-Die Programmable 2D Position Sensor Family with Arbitrary Output Function”, June 17, 2015, AI000180_001EN. First release of the advance information. 2. “HAR 3715, HAR 372x, HAR 373x Robust Dual-Die Programmable 2D Position Sensor Family with Arbitrary Output Function”, Jan. 18, 2016, DSH000175_001EN. First release of the data sheet. Major changes: – Assembly and storage information changed – Absolute maximum ratings: ESD protection voltages changed – Magnetic characteristics: values changed 3. “HAR 3715, HAR 372x, HAR 373x Robust Dual-Die Programmable 2D Position Sensor Family with Arbitrary Output Function”, May 5, 2017, DSH000175_002EN. Second release of the data sheet. Major changes: – Update of some electrical parameters – Storage temperature added – Graph with start-up behavior in PWM mode added 4. “HAR 3715, HAR 372x, HAR 373x Robust Dual-Die Programmable 2D Position Sensor Family with Arbitrary Output Function”, Oct. 25, 2019, DSH000175_003EN. Second release of the data sheet. Major changes: – – – – – – – – – – – – – – Disclaimer updated Figure 2-1 “Ordering Code Principle” updated Figure 3-2 “Signal path of HAR 37xy (equal for both dies)” updated Figure 4-1 “Package Drawing” updated Section 4.4 “Size of Sensitive Area” Section 4.5 “Definition of Magnetic-Field Vectors” updated Section 4.3.3 “Package Parameters and Position” deleted Table “Pin Connections and Short Description” updated Table “Absolute Maximum Ratings” updated Recommended Operating Condition TJ updated Table “Characteristic Parameters” updated Table “Magnetic Characteristics” updated Section 6.2 “Programming Environment and Tools” updated Section 6.3 “Programming Information” updated TDK-Micronas GmbH Hans-Bunte-Strasse 19  D-79108 Freiburg  P.O. Box 840  D-79008 Freiburg, Germany Tel. +49-761-517-0  Fax +49-761-517-2174  www.micronas.com TDK-Micronas GmbH Oct. 25, 2019; DSH000175_003EN 45
HAR3735DJ-A 价格&库存
很抱歉,暂时无法提供与“HAR3735DJ-A”相匹配的价格&库存,您可以联系我们找货
HAR3735DJ-A
  • 1+48.049891+6.16292
  • 5+43.169995+5.53702
  • 10+41.3550110+5.30423
  • 25+39.1796025+5.02521
  • 50+37.6963750+4.83497
  • 100+36.33620100+4.66051
  • 500+33.59779500+4.30928
  • 1000+32.577661000+4.17844
库存:24797
HAR3735DJ-A
  • 3500+30.942733500+3.96874
库存:24797
