PRODUCT INFORMATION
HAR 3927
Sept/2021
HAR 3927
Programmable Dual-Die 2D Position Sensor
with Analog Output and SENT Interface
The HAR 3927 is a new member of the
2D position sensor family using the proprietary 3D HAL® technology of TDK-Micronas,
addressing the need for ISO 26262 compliant development. The device is a high-resolution position sensor for highly accurate
position measurement. It provides full
redundancy as it consists of two independent stacked dies in a very small eight-pin
SOIC8 SMD package.
HAR 3927 features a linear, ratiometric
analog output signal with integrated wirebreak detection working with pull-up or pulldown resistors as well as a SAE J2716
compliant SENT output according to rev. 4.
The SENT interface is customer configurable and supports various tick times
between 1.5 µs and 12 µs as well as several
frame formats, like secure sensor information, etc.
The sensor is able to measure horizontal
and vertical magnetic-field components BX,
BY, and BZ. On-chip signal processing calculates one angle out of two magnetic-field
components and converts this value into an
output signal. This enables a set of potential
applications for position detection, such as
wide distance, angle, or through-shaft angular measurements.
One key feature is the possibility to linearize
the sensor’s output characteristic for the
customer’s application with either 33 equidistant distributed setpoints or 17 variable
setpoints.
This product is defined as SEooC (Safety
Element out of Context) ASIL-B ready
according to ISO 26262.
Major characteristics like gain and offset,
reference position, etc. can be adjusted to
the magnetic circuitry by programming the
non-volatile memory.
The device is designed for operation in an
ambient temperature range of –40 °C up to
150 °C.
The HAR 3927 sensor is available in a very
small eight-pin SOIC8 package.
Features
◆ Accurate angular measurement up to
360° and linear position detection
◆ ASIL-B ready (SEooC according to
ISO 26262)
◆ Stacked-die architecture with full
redundancy (dual-die)
◆ Operates from 4.5 V up to 5.5 V supply
voltage
◆ Customer-selectable analog or SENT
output
◆ 12 bit ratiometric linear analog output
◆ SENT according to SAE J 2716 rev. 4
◆ Configurable output slew rates
◆ Programmable arbitrary output characteristic with 17 variable or 33 equidistant
◆ Support of three different SENT frames
– H.1: Two 12 bit fast channels (position
& temperature or magnetic amplitude)
– H.2: 12 bit fast channel
– H.4: 12 bit secure single sensor
◆ TA = –40 °C up to 150 °C
◆ Programming via the sensor’s output pin
PRODUCT INFORMATION
HAR 3927
Major Applications
HAR 3927 is a potential solution for the following application examples:
◆ Linear movement measurements in
dual-clutch transmissions, engine stroke
sensors, clutch pedal, as well as cylinder
and valve position measurements
Sept/2021
Available Types
Type
Output Format
Output Signals
HAR 3927
Analog/Modulo
Ratiometric analog
output voltage
proportional to the
position
Other Features
◆ Integrated wire-break detection
working with pull-up or pull-down
resistors
◆ Programmable interpolator for a
smoother DAC analog output and
reduced out-of-band noise
◆ Rotary position measurement in gear
selectors, rotary selectors with push
function, rear-axis steering, electronic
throttle control, accelerator pedal, etc.
SENT
According to
SAE J 2716 rev. 4
◆ Programmable tick time between
1.5 µs and 12 µs
◆ Transmission of OEM ID’s via slow
channel
Development Tools
Each die can be programmed during the
final manufacturing process by adjusting the
output signals directly to the input signal.
With this calibration procedure, the tolerances of the sensor, the magnet, and the
mechanical positioning can be compensated in the final assembly.
TDK-Micronas offers an easy-to-use evaluation kit for engineering:
◆ Micronas programmer board
(TDK-MSP V1.x)
◆ USB programming kit
◆ LabVIEWTM programming software for
Windows® including Sub VIs
VSUP1
VSUP2
Internally
Stabilized
Supply and
Protection
Temperature
Dependent
Bias
Devices
Open-Circuit,
Overvoltage,
Undervoltage,
Detection
OSC
Protection
Devices
TEST1
TEST2
Pixel
Cell
X/Y/Z
MUX
MUX
A
D
GND1
A
D
DSP
A
17/33
Setpoints
Linearization
D
Interpolator
D
A
Analog
Output
SENT
formatter
μC
OUT1
OUT2
EEPROM Memory
Programming
Interface
OTP
Temperature
Sensor
Lock Control
GND2
License Note: HAR 3927 uses licenses of
Fraunhofer Institute for Integrated Circuits IIS.
Fig. 1: Block diagram of the HAR 3927
All information and data contained in this product information are without any commitment, are not to be considered as an offer for conclusion of a contract, nor shall they be construed as to create any liability. Product or
development sample availability and delivery are exclusively subject to our respective order confirmation form. By
this publication, TDK-Micronas GmbH does not assume responsibility for patent infringements or other rights of
third parties which may result from its use.
No part of this publication may be reproduced,
photocopied, stored on a retrieval system, or transmitted without the express written consent of
TDK-Micronas GmbH.
Edition Sept. 28, 2021; Order No. PI000167_001EN
TDK-Micronas GmbH Hans-Bunte-Strasse 19D-79108 Freiburg (Germany)P.O. Box 840D-79008 Freiburg (Germany)
Tel. +49-761-517-0Fax +49-761-517-2174www.micronas.tdk.com
很抱歉,暂时无法提供与“HAR3927DJ-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+53.088751+6.80970
- 5+47.771335+6.12764
- 10+45.7834410+5.87265
- 25+43.4075825+5.56790
- 50+41.7841650+5.35966
- 100+40.29564100+5.16873
- 500+37.30097500+4.78460
- 1000+36.220801000+4.64605
- 国内价格 香港价格
- 3500+34.396973500+4.41211
- 国内价格
- 1+13.91040
- 200+5.55120
- 500+5.36760
- 1000+5.28120
