(1/9)
003-03 / 20050524 / e93_hf.fm
EMC Components
HF Series
Common Mode Choke Coils(Line Filters) for AC Power Supply
Closed Magnetic Circuit Core Type
TDK common mode choke coils(line filters) are used in a wide
range of prevention of electromagnetic interference(EMI) and radio
frequency interference(RFI) from power supply lines and for prevention of multifunctioning of products such as measuring equipment and system equipment.
RATINGS
Item
Rated voltage(V)
Dielectric withstanding
voltage(V)
Insulation resistance
(MΩ)
Temperature rise(°C)
Operating temperature
range(°C)
Safety standard
Standard value
80 to 280∗
Conditions
Between each winding for
1 minute
100min.
1 minute, Edc 500V
45max.∗
With line resistance
Including self-temperature
–20 to +120
rise
Japan Electric/Electronic Products Control Law,
UL, CSA and IEC conformed(The safety
standard is not acquired with the unit only.)
2000
PRODUCT IDENTIFICATION
UF
V
Y
(1)
(2)
(3) (4)
(5)
R
(6)
– 01
(7)
(1)Core shape
UF: U-type core
TF: Toroidal core
HF: Square shaped closed magnetic circuit core type
Double-square shaped closed magnetic circuit core type
(2)Dimensional code(Length×Height)
(3)External shape code
(4)TDK’s internal code
(5)Inductance value
Example) 602: 60µH×102=6mH
(6)Rated current value
Example) 2R5: 2.5A
(7)Product management number
∗ Except particular items.
• Measuring equipment of inductance value:
LCR meter(HP4261A, HP4263B or equivalent)
FEATURES
• Wide range of selection.
• High impedance at applicable frequency.
• High self-resonant frequency.
SELECTION CHART
Inductance value Rated current
Handling power∗
L×I2(mH×A2)
(mH)min.
(A)
HF2018R
1 to 33
0.3 to 2
4.5
HF2022R
1 to 33
0.3 to 2
4.5
HF2024
0.6 to 12
0.8 to 3
7.6
Closed magnetic circuit
HF2422
2.4 to 68
0.4 to 2.5
15
HF
core types
HF2430
2.4 to 68
0.4 to 2.5
15
HF2826
1.8 to 35
1 to 4
35
HF2836
1.8 to 35
1 to 4
35
HF3545
4.7 to 33
1.5 to 4
75
∗ Handling power=(Inductance value)×(Current)2. It is possible to design within the range below this value.
[Example] The coil for 2A can make even the inductance of 2.5mH or less a product for handling power 10.
Series Configuration
Type
• All specifications are subject to change without notice.
Weight
(g)typ.
10
10
10
19.5
19.5
28
30
65
Minimum package quantity
(pieces/box)
840
840
800
540
400
480
400
140
(2/9)
EMC Components
HF Series
CLOSED MAGNETIC CIRCUIT CORE TYPE
HF SERIES
FEATURES
• As closed magnetic circuit core as same as a toroidal core, even
at its compact size, it offers large inductance and keeps the high
impedance levels required in high frequency ranges.
• Since it uses a closed magnetic circuit core, the leakage flux is
relatively small, allowing designers to improve the mounting
density of their circuits.
HF2018R(SQUARE SHAPED CLOSED MAGNETIC CIRCUIT CORE) TYPE
SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM
21max.
22max.
1000
17.5max.
3.5±1
TYPICAL ELECTRICAL CHARACTERISTICS
IMPEDANCE vs. FREQUENCY
CHARACTERISTICS
HF2018R-333Y0R3-01
HF2018R-253Y0R4-01
Impedance (kΩ)
10±0.5
1
4
L1
L2
2
10
3
HF2018R-103Y0R7-01
1
Weight: 10g typ.
13±0.5
Recommended hole diameter: ø1.3
Dimensions in mm
0.1
0.01
Part No.
HF2018R-333Y0R3-01
HF2018R-253Y0R4-01
HF2018R-183Y0R5-01
HF2018R-103Y0R7-01
HF2018R-682Y0R8-01
HF2018R-402Y1R0-01
HF2018R-252Y1R3-01
HF2018R-202Y1R5-01
HF2018R-102Y2R0-01
Inductance
(mH)min.
33
25
18
10
6.8
4
2.5
2
1
DC resistance
(Ω)max.
4.2
2.9
2
1.1
0.9
0.5
0.3
0.2
0.2
Rated current
(A)max.
0.3
0.4
0.5
0.7
0.8
1
1.3
1.5
2
APPLICABLE SAFETY STANDARD
Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2
• However, this product is not recognized by each regulations.
PACKAGING QUANTITIES
HF2018R
HF2018R-183Y0R5-01
100
ø0.8
840pieces/box
HF2018R-682Y0R8-01
HF2018R-402Y1R0-01
HF2018R-252Y1R3-01
HF2018R-202Y1R5-01
HF2018R-102Y2R0-01
0.1
1
Frequency (MHz)
10
100
(3/9)
EMC Components
HF Series
HF2022R(SQUARE SHAPED CLOSED MAGNETIC CIRCUIT CORE) TYPE
22max.
16max.
CHARACTERISTICS
22.5max.
1000
HF2022R-333Y0R3-01
HF2022R-253Y0R4-01
3.5±1
100
4
10±0.5
1
2
Impedance (kΩ)
ø0.8
13±0.5
3
1
4
L1
L2
2
10
3
1
Weight: 10g typ.
Dimensions in mm
0.1
0.01
Part No.
HF2022R-333Y0R3-01
HF2022R-253Y0R4-01
HF2022R-183Y0R5-01
HF2022R-103Y0R7-01
HF2022R-682Y0R8-01
HF2022R-402Y1R0-01
HF2022R-252Y1R3-01
HF2022R-202Y1R5-01
HF2022R-102Y2R0-01
Inductance
(mH)min.
33
25
18
10
6.8
4
2.5
2
1
DC resistance
(Ω)max.
4.2
2.9
2
1.1
0.9
0.5
0.3
0.2
0.2
Rated current
(A)max.
0.3
0.4
0.5
0.7
0.8
1
1.3
1.5
2
HF2022R
840pieces/box
HF2022R-183Y0R5-01
HF2022R-103Y0R7-01
HF2022R-682Y0R8-01
HF2022R-402Y1R0-01
HF2022R-252Y1R3-01
HF2022R-202Y1R5-01
HF2022R-102Y2R0-01
0.1
1
10
Frequency (MHz)
100
(4/9)
EMC Components
HF Series
HF2024(SQUARE SHAPED CLOSED MAGNETIC CIRCUIT CORE) TYPE
22.5max.
24max.
4.5±1
100
1
10
2
L2
Impedance (kΩ)
10±0.5
18max.
3
Weight: 10g typ.
Dimensions in mm
13±0.5
HF2024-123Y0R8-T01
4
L1
ø0.8
CHARACTERISTICS
1
HF2024-622Y1R0-T01
HF2024-242Y1R7-T01
0.1
Part No.
HF2024-123Y0R8-T01
HF2024-622Y1R0-T01
HF2024-242Y1R7-T01
HF2024-601Y3R0-T01
Inductance
(mH)min.
12
6.2
2.4
0.6
0.01
DC resistance
(Ω)max.
0.92
0.5
0.18
0.06
Rated current
(A)max.
0.8
1
1.7
3
Electrical Appliance and Material Safety Law ("DENAN"), CSA C22.2
HF2024
800pieces/box
HF2024-601Y3R0-T01
0.01
0.1
1
Frequency (MHz)
10
100
(5/9)
EMC Components
HF Series
HF SERIES
FEATURES
• This series employs two outer magnetic path limbs design with
windings on the center magnetic path limb of double-square
shaped closed magnetic circuit ferrite core to reduce leakage
flux.
• This filter uses the same closed magnetic circuit core as a
toroidal core and therefore, even at its compact size, it offers
large inductance and suppresses noise up to in high frequency
ranges.
HF2422(DOUBLE-SQUARE SHAPED CLOSED MAGNETIC CIRCUIT CORE) TYPE
1
4
CHARACTERISTICS
26max.
15±0.5
1000
21±0.5
2
ø0.8x4
4
L1
Impedance (kΩ)
22max.
1
100
3
26max.
L2
2
3
Weight: 19.5g typ.
4±1
HF2422-683Y0R4-T01
HF2422-453Y0R5-T01
HF2422-333Y0R6-T01
HF2422-253Y0R8-T01
Dimensions in mm
10
1
HF2422-203Y1R0-T01
HF2422-103Y1R2-T01
HF2422-452Y1R5-T01
HF2422-392Y1R8-T01
HF2422-332Y2R0-T01
HF2422-242Y2R5-T01
0.1
0.01
Part No.
HF2422-683Y0R4-T01
HF2422-453Y0R5-T01
HF2422-333Y0R6-T01
HF2422-253Y0R8-T01
HF2422-203Y1R0-T01
HF2422-103Y1R2-T01
HF2422-452Y1R5-T01
HF2422-392Y1R8-T01
HF2422-332Y2R0-T01
HF2422-242Y2R5-T01
Inductance
(mH)min.
68
45
33
25
4.5
3.9
3.3
2.4
DC resistance
(Ω)max.
2.3
1.65
1.2
0.88
0.64
0.38
0.19
0.15
0.11
0.09
Rated current
(A)max.
0.4
0.5
0.6
0.8
1
1.2
1.5
1.8
2
2.5
HF2422
540pieces/box
0.1
1
Frequency (MHz)
10
100
(6/9)
EMC Components
HF Series
HF2430(DOUBLE-SQUARE SHAPED CLOSED MAGNETIC CIRCUIT CORE) TYPE
26max.
19max.
CHARACTERISTICS
4±1
31.5max.
1000
HF2430-683Y0R4-T01
HF2430-453Y0R5-T01
HF2430-333Y0R6-T01
HF2430-253Y0R8-T01
HF2430-203Y1R0-T01
HF2430-103Y1R2-T01
100
1
4
L1
2
13±0.5
Impedance (kΩ)
4
10±0.5
ø0.8x4
1
L2
2
3
Weight: 19.5g typ.
3
HF2430-452Y1R5-T01
HF2430-392Y1R8-T01
10
HF2430-332Y2R0-T01
1
HF2430-242Y2R5-T01
Dimensions in mm
0.1
0.01
Part No.
HF2430-683Y0R4-T01
HF2430-453Y0R5-T01
HF2430-333Y0R6-T01
HF2430-253Y0R8-T01
HF2430-203Y1R0-T01
HF2430-103Y1R2-T01
HF2430-452Y1R5-T01
HF2430-392Y1R8-T01
HF2430-332Y2R0-T01
HF2430-242Y2R5-T01
Inductance
(mH)min.
68
45
33
25
4.5
3.9
3.3
2.4
DC resistance
(Ω)max.
2.3
1.65
1.2
0.88
0.64
0.38
0.19
0.15
0.11
0.09
Rated current
(A)max.
0.4
0.5
0.6
0.8
1
1.2
1.5
1.8
2
2.5
HF2430
400pieces/box
0.1
1
Frequency (MHz)
10
100
(7/9)
EMC Components
HF Series
1000
20±0.5
30.5max.
HF2826(DOUBLE-SQUARE SHAPED CLOSED MAGNETIC CIRCUIT CORE) TYPE
IMPEDANCE
vs. FREQUENCY
1
4
CHARACTERISTICS
2
HF2826-353Y1R0-T01
HF2826-203Y1R5-T01
HF2826-123Y1R8-T01
HF2826-802Y2R0-T01
100
3
24.0±0.5
26max.
1
4
L1
2
ø0.8x4
Impedance (kΩ)
30.5max.
L2
3
4±1
Weight: 28g typ.
Dimensions in mm
Part No.
HF2826-353Y1R0-T01
HF2826-253Y1R2-T01
HF2826-203Y1R5-T01
HF2826-123Y1R8-T01
HF2826-802Y2R0-T01
HF2826-562Y2R5-T01
HF2826-472Y2R8-T01
HF2826-332Y3R0-T01
HF2826-182Y4R0-T01
Inductance
(mH)min.
35
25
8
5.6
4.7
3.3
1.8
1
0.1
0.01
DC resistance
(Ω)max.
0.78
0.56
0.41
0.27
0.18
0.13
0.1
0.088
0.05
Rated current
(A)max.
1
1.2
1.5
1.8
2
2.5
2.8
3
4
HF2826
10
480pieces/box
HF2826-562Y2R5-T01
HF2826-472Y2R8-T01
HF2826-332Y3R0-T01
HF2826-182Y4R0-T01
0.1
1
Frequency (MHz)
10
100
(8/9)
EMC Components
HF Series
HF2836(DOUBLE-SQUARE SHAPED CLOSED MAGNETIC CIRCUIT CORE) TYPE
IMPEDANCE
vs. FREQUENCY
30.5max.
22max.
CHARACTERISTICS
4±1
36max.
1000
HF2836-253Y1R2-T01
HF2836-203Y1R5-T01
HF2836-123Y1R8-T01
HF2836-802Y2R0-T01
100
4
4
1
L1
2
13±0.5
Impedance (kΩ)
1
10±0.5
ø0.8x4
L2
3
2
Weight: 30g typ.
3
10
1
Dimensions in mm
HF2836-182Y4R0-T01
0.1
0.01
Part No.
HF2836-353Y1R0-T01
HF2836-253Y1R2-T01
HF2836-203Y1R5-T01
HF2836-123Y1R8-T01
HF2836-802Y2R0-T01
HF2836-562Y2R5-T01
HF2836-472Y2R8-T01
HF2836-332Y3R0-T01
HF2836-182Y4R0-T01
Inductance
(mH)min.
35
25
8
5.6
4.7
3.3
1.8
DC resistance
(Ω)max.
0.78
0.56
0.41
0.27
0.18
0.13
0.1
0.088
0.05
Rated current
(A)max.
1
1.2
1.5
1.8
2
2.5
2.8
3
4
HF2836
400pieces/box
HF2836-562Y2R5-T01
HF2836-472Y2R8-T01
HF2836-332Y3R0-T01
0.1
1
Frequency (MHz)
10
100
(9/9)
EMC Components
HF Series
HF3545(DOUBLE-SQUARE SHAPED CLOSED MAGNETIC CIRCUIT CORE) TYPE
IMPEDANCE
vs. FREQUENCY
37max.
26max.
CHARACTERISTICS
HF3545-333Y1R5-T01
4±1
45max.
1000
HF3545-183Y2R0-T01
HF3545-123Y2R5-T01
100
4
1
4
L1
L2
2
2
21±0.5
Impedance (kΩ)
1
15±0.5
ø1.2x6
3
HF3545-103Y2R7-T01
Weight: 65g typ.
3
10
1
HF3545-822Y3R0-T01
HF3545-562Y3R5-T01
HF3545-472Y4R0-T01
Dimensions in mm
0.1
0.01
Part No.
HF3545-333Y1R5-T01
HF3545-183Y2R0-T01
HF3545-123Y2R5-T01
HF3545-103Y2R7-T01
HF3545-822Y3R0-T01
HF3545-562Y3R5-T01
HF3545-472Y4R0-T01
Inductance
(mH)min.
33
18
12
10
8.2
5.6
4.7
DC resistance
(Ω)max.
0.42
0.23
0.17
0.13
0.105
0.077
0.062
Rated current
(A)max.
1.5
2
2.5
2.7
3
3.5
4
HF3545
140pieces/box
0.1
1
Frequency (MHz)
10
100
很抱歉,暂时无法提供与“HF2018R-102Y2R0-01”相匹配的价格&库存,您可以联系我们找货
