HF2018R-252Y1R3-01
HF2018R-252Y1R3-01
    TDK(东电化)
    HF2018R-252Y1R3-01
HF2018R-252Y1R3-01 数据手册
(1/9) 003-03 / 20050524 / e93_hf.fm EMC Components HF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Closed Magnetic Circuit Core Type TDK common mode choke coils(line filters) are used in a wide range of prevention of electromagnetic interference(EMI) and radio frequency interference(RFI) from power supply lines and for prevention of multifunctioning of products such as measuring equipment and system equipment. RATINGS Item Rated voltage(V) Dielectric withstanding voltage(V) Insulation resistance (MΩ) Temperature rise(°C) Operating temperature range(°C) Safety standard Standard value 80 to 280∗ Conditions Between each winding for 1 minute Between each winding for 100min. 1 minute, Edc 500V 45max.∗ With line resistance Including self-temperature –20 to +120 rise Japan Electric/Electronic Products Control Law, UL, CSA and IEC conformed(The safety standard is not acquired with the unit only.) 2000 PRODUCT IDENTIFICATION UF V – Y (1) (2) (3) (4) (5) R (6) – 01 (7) (1)Core shape UF: U-type core TF: Toroidal core HF: Square shaped closed magnetic circuit core type Double-square shaped closed magnetic circuit core type (2)Dimensional code(Length×Height) (3)External shape code (4)TDK’s internal code (5)Inductance value Example) 602: 60µH×102=6mH (6)Rated current value Example) 2R5: 2.5A (7)Product management number ∗ Except particular items. • Measuring equipment of inductance value: LCR meter(HP4261A, HP4263B or equivalent) FEATURES • Wide range of selection. • High impedance at applicable frequency. • High self-resonant frequency. SELECTION CHART Inductance value Rated current Handling power∗ L×I2(mH×A2) (mH)min. (A) HF2018R 1 to 33 0.3 to 2 4.5 HF2022R 1 to 33 0.3 to 2 4.5 HF2024 0.6 to 12 0.8 to 3 7.6 Closed magnetic circuit HF2422 2.4 to 68 0.4 to 2.5 15 HF core types HF2430 2.4 to 68 0.4 to 2.5 15 HF2826 1.8 to 35 1 to 4 35 HF2836 1.8 to 35 1 to 4 35 HF3545 4.7 to 33 1.5 to 4 75 ∗ Handling power=(Inductance value)×(Current)2. It is possible to design within the range below this value. [Example] The coil for 2A can make even the inductance of 2.5mH or less a product for handling power 10. Series Configuration Type • All specifications are subject to change without notice. Weight (g)typ. 10 10 10 19.5 19.5 28 30 65 Minimum package quantity (pieces/box) 840 840 800 540 400 480 400 140 (2/9) 003-03 / 20050524 / e93_hf.fm EMC Components HF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Closed Magnetic Circuit Core Type CLOSED MAGNETIC CIRCUIT CORE TYPE HF SERIES FEATURES • As closed magnetic circuit core as same as a toroidal core, even at its compact size, it offers large inductance and keeps the high impedance levels required in high frequency ranges. • Since it uses a closed magnetic circuit core, the leakage flux is relatively small, allowing designers to improve the mounting density of their circuits. HF2018R(SQUARE SHAPED CLOSED MAGNETIC CIRCUIT CORE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM 21max. 22max. 1000 17.5max. 3.5±1 TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS HF2018R-333Y0R3-01 HF2018R-253Y0R4-01 Impedance (kΩ) 10±0.5 1 4 L1 L2 2 10 3 HF2018R-103Y0R7-01 1 Weight: 10g typ. 13±0.5 Recommended hole diameter: ø1.3 Dimensions in mm 0.1 0.01 ELECTRICAL CHARACTERISTICS Part No. HF2018R-333Y0R3-01 HF2018R-253Y0R4-01 HF2018R-183Y0R5-01 HF2018R-103Y0R7-01 HF2018R-682Y0R8-01 HF2018R-402Y1R0-01 HF2018R-252Y1R3-01 HF2018R-202Y1R5-01 HF2018R-102Y2R0-01 Inductance (mH)min. 33 25 18 10 6.8 4 2.5 2 1 DC resistance (Ω)max. 4.2 2.9 2 1.1 0.9 0.5 0.3 0.2 0.2 Rated current (A)max. 0.3 0.4 0.5 0.7 0.8 1 1.3 1.5 2 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 • However, this product is not recognized by each regulations. PACKAGING QUANTITIES HF2018R HF2018R-183Y0R5-01 100 ø0.8 840pieces/box • All specifications are subject to change without notice. HF2018R-682Y0R8-01 HF2018R-402Y1R0-01 HF2018R-252Y1R3-01 HF2018R-202Y1R5-01 HF2018R-102Y2R0-01 0.1 1 Frequency (MHz) 10 100 (3/9) 003-03 / 20050524 / e93_hf.fm EMC Components HF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Closed Magnetic Circuit Core Type HF2022R(SQUARE SHAPED CLOSED MAGNETIC CIRCUIT CORE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM 22max. 16max. TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 22.5max. 1000 HF2022R-333Y0R3-01 HF2022R-253Y0R4-01 3.5±1 100 4 10±0.5 1 2 Impedance (kΩ) ø0.8 13±0.5 3 1 4 L1 L2 2 10 3 1 Weight: 10g typ. Recommended hole diameter: ø1.3 Dimensions in mm 0.1 0.01 ELECTRICAL CHARACTERISTICS Part No. HF2022R-333Y0R3-01 HF2022R-253Y0R4-01 HF2022R-183Y0R5-01 HF2022R-103Y0R7-01 HF2022R-682Y0R8-01 HF2022R-402Y1R0-01 HF2022R-252Y1R3-01 HF2022R-202Y1R5-01 HF2022R-102Y2R0-01 Inductance (mH)min. 33 25 18 10 6.8 4 2.5 2 1 DC resistance (Ω)max. 4.2 2.9 2 1.1 0.9 0.5 0.3 0.2 0.2 Rated current (A)max. 0.3 0.4 0.5 0.7 0.8 1 1.3 1.5 2 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 • However, this product is not recognized by each regulations. PACKAGING QUANTITIES HF2022R 840pieces/box • All specifications are subject to change without notice. HF2022R-183Y0R5-01 HF2022R-103Y0R7-01 HF2022R-682Y0R8-01 HF2022R-402Y1R0-01 HF2022R-252Y1R3-01 HF2022R-202Y1R5-01 HF2022R-102Y2R0-01 0.1 1 10 Frequency (MHz) 100 (4/9) 003-03 / 20050524 / e93_hf.fm EMC Components HF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Closed Magnetic Circuit Core Type HF2024(SQUARE SHAPED CLOSED MAGNETIC CIRCUIT CORE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM 22.5max. 24max. 4.5±1 100 1 10 2 L2 Impedance (kΩ) 10±0.5 18max. 3 Weight: 10g typ. Recommended hole diameter: ø1.3 Dimensions in mm 13±0.5 HF2024-123Y0R8-T01 4 L1 ø0.8 TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 1 HF2024-622Y1R0-T01 HF2024-242Y1R7-T01 0.1 ELECTRICAL CHARACTERISTICS Part No. HF2024-123Y0R8-T01 HF2024-622Y1R0-T01 HF2024-242Y1R7-T01 HF2024-601Y3R0-T01 Inductance (mH)min. 12 6.2 2.4 0.6 0.01 DC resistance (Ω)max. 0.92 0.5 0.18 0.06 Rated current (A)max. 0.8 1 1.7 3 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN"), CSA C22.2 • However, this product is not recognized by each regulations. PACKAGING QUANTITIES HF2024 800pieces/box • All specifications are subject to change without notice. HF2024-601Y3R0-T01 0.01 0.1 1 Frequency (MHz) 10 100 (5/9) 003-03 / 20050524 / e93_hf.fm EMC Components HF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Closed Magnetic Circuit Core Type CLOSED MAGNETIC CIRCUIT CORE TYPE HF SERIES FEATURES • This series employs two outer magnetic path limbs design with windings on the center magnetic path limb of double-square shaped closed magnetic circuit ferrite core to reduce leakage flux. • This filter uses the same closed magnetic circuit core as a toroidal core and therefore, even at its compact size, it offers large inductance and suppresses noise up to in high frequency ranges. HF2422(DOUBLE-SQUARE SHAPED CLOSED MAGNETIC CIRCUIT CORE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY 1 4 CHARACTERISTICS 26max. 15±0.5 1000 21±0.5 2 ø0.8x4 4 L1 Impedance (kΩ) 22max. 1 100 3 26max. L2 2 3 Weight: 19.5g typ. 4±1 HF2422-683Y0R4-T01 HF2422-453Y0R5-T01 HF2422-333Y0R6-T01 HF2422-253Y0R8-T01 Recommended hole diameter: ø1.3 Dimensions in mm 10 1 HF2422-203Y1R0-T01 HF2422-103Y1R2-T01 HF2422-452Y1R5-T01 HF2422-392Y1R8-T01 HF2422-332Y2R0-T01 HF2422-242Y2R5-T01 0.1 0.01 ELECTRICAL CHARACTERISTICS Part No. HF2422-683Y0R4-T01 HF2422-453Y0R5-T01 HF2422-333Y0R6-T01 HF2422-253Y0R8-T01 HF2422-203Y1R0-T01 HF2422-103Y1R2-T01 HF2422-452Y1R5-T01 HF2422-392Y1R8-T01 HF2422-332Y2R0-T01 HF2422-242Y2R5-T01 Inductance (mH)min. 68 45 33 25 20 10 4.5 3.9 3.3 2.4 DC resistance (Ω)max. 2.3 1.65 1.2 0.88 0.64 0.38 0.19 0.15 0.11 0.09 Rated current (A)max. 0.4 0.5 0.6 0.8 1 1.2 1.5 1.8 2 2.5 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 • However, this product is not recognized by each regulations. PACKAGING QUANTITIES HF2422 540pieces/box • All specifications are subject to change without notice. 0.1 1 Frequency (MHz) 10 100 (6/9) 003-03 / 20050524 / e93_hf.fm EMC Components HF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Closed Magnetic Circuit Core Type HF2430(DOUBLE-SQUARE SHAPED CLOSED MAGNETIC CIRCUIT CORE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY 26max. 19max. CHARACTERISTICS 4±1 31.5max. 1000 HF2430-683Y0R4-T01 HF2430-453Y0R5-T01 HF2430-333Y0R6-T01 HF2430-253Y0R8-T01 HF2430-203Y1R0-T01 HF2430-103Y1R2-T01 100 1 4 L1 2 13±0.5 Impedance (kΩ) 4 10±0.5 ø0.8x4 1 L2 2 3 Weight: 19.5g typ. 3 HF2430-452Y1R5-T01 HF2430-392Y1R8-T01 10 HF2430-332Y2R0-T01 1 HF2430-242Y2R5-T01 Recommended hole diameter: ø1.3 Dimensions in mm 0.1 0.01 ELECTRICAL CHARACTERISTICS Part No. HF2430-683Y0R4-T01 HF2430-453Y0R5-T01 HF2430-333Y0R6-T01 HF2430-253Y0R8-T01 HF2430-203Y1R0-T01 HF2430-103Y1R2-T01 HF2430-452Y1R5-T01 HF2430-392Y1R8-T01 HF2430-332Y2R0-T01 HF2430-242Y2R5-T01 Inductance (mH)min. 68 45 33 25 20 10 4.5 3.9 3.3 2.4 DC resistance (Ω)max. 2.3 1.65 1.2 0.88 0.64 0.38 0.19 0.15 0.11 0.09 Rated current (A)max. 0.4 0.5 0.6 0.8 1 1.2 1.5 1.8 2 2.5 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 • However, this product is not recognized by each regulations. PACKAGING QUANTITIES HF2430 400pieces/box • All specifications are subject to change without notice. 0.1 1 Frequency (MHz) 10 100 (7/9) 003-03 / 20050524 / e93_hf.fm EMC Components HF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Closed Magnetic Circuit Core Type 1000 20±0.5 30.5max. HF2826(DOUBLE-SQUARE SHAPED CLOSED MAGNETIC CIRCUIT CORE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY 1 4 CHARACTERISTICS 2 HF2826-353Y1R0-T01 HF2826-203Y1R5-T01 HF2826-123Y1R8-T01 HF2826-802Y2R0-T01 100 3 24.0±0.5 26max. 1 4 L1 2 ø0.8x4 Impedance (kΩ) 30.5max. L2 3 4±1 Weight: 28g typ. Recommended hole diameter: ø1.3 Dimensions in mm Part No. HF2826-353Y1R0-T01 HF2826-253Y1R2-T01 HF2826-203Y1R5-T01 HF2826-123Y1R8-T01 HF2826-802Y2R0-T01 HF2826-562Y2R5-T01 HF2826-472Y2R8-T01 HF2826-332Y3R0-T01 HF2826-182Y4R0-T01 Inductance (mH)min. 35 25 20 12 8 5.6 4.7 3.3 1.8 1 0.1 0.01 ELECTRICAL CHARACTERISTICS DC resistance (Ω)max. 0.78 0.56 0.41 0.27 0.18 0.13 0.1 0.088 0.05 Rated current (A)max. 1 1.2 1.5 1.8 2 2.5 2.8 3 4 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 • However, this product is not recognized by each regulations. PACKAGING QUANTITIES HF2826 10 480pieces/box • All specifications are subject to change without notice. HF2826-562Y2R5-T01 HF2826-472Y2R8-T01 HF2826-332Y3R0-T01 HF2826-182Y4R0-T01 0.1 1 Frequency (MHz) 10 100 (8/9) 003-03 / 20050524 / e93_hf.fm EMC Components HF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Closed Magnetic Circuit Core Type HF2836(DOUBLE-SQUARE SHAPED CLOSED MAGNETIC CIRCUIT CORE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY 30.5max. 22max. CHARACTERISTICS 4±1 36max. 1000 HF2836-253Y1R2-T01 HF2836-203Y1R5-T01 HF2836-123Y1R8-T01 HF2836-802Y2R0-T01 100 4 4 1 L1 2 13±0.5 Impedance (kΩ) 1 10±0.5 ø0.8x4 L2 3 2 Weight: 30g typ. 3 10 1 Recommended hole diameter: ø1.3 Dimensions in mm HF2836-182Y4R0-T01 0.1 0.01 ELECTRICAL CHARACTERISTICS Part No. HF2836-353Y1R0-T01 HF2836-253Y1R2-T01 HF2836-203Y1R5-T01 HF2836-123Y1R8-T01 HF2836-802Y2R0-T01 HF2836-562Y2R5-T01 HF2836-472Y2R8-T01 HF2836-332Y3R0-T01 HF2836-182Y4R0-T01 Inductance (mH)min. 35 25 20 12 8 5.6 4.7 3.3 1.8 DC resistance (Ω)max. 0.78 0.56 0.41 0.27 0.18 0.13 0.1 0.088 0.05 Rated current (A)max. 1 1.2 1.5 1.8 2 2.5 2.8 3 4 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 • However, this product is not recognized by each regulations. PACKAGING QUANTITIES HF2836 400pieces/box • All specifications are subject to change without notice. HF2836-562Y2R5-T01 HF2836-472Y2R8-T01 HF2836-332Y3R0-T01 0.1 1 Frequency (MHz) 10 100 (9/9) 003-03 / 20050524 / e93_hf.fm EMC Components HF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Closed Magnetic Circuit Core Type HF3545(DOUBLE-SQUARE SHAPED CLOSED MAGNETIC CIRCUIT CORE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY 37max. 26max. CHARACTERISTICS HF3545-333Y1R5-T01 4±1 45max. 1000 HF3545-183Y2R0-T01 HF3545-123Y2R5-T01 100 4 1 4 L1 L2 2 2 21±0.5 Impedance (kΩ) 1 15±0.5 ø1.2x6 3 HF3545-103Y2R7-T01 Weight: 65g typ. 3 10 1 HF3545-822Y3R0-T01 HF3545-562Y3R5-T01 HF3545-472Y4R0-T01 Recommended hole diameter: ø1.3 Dimensions in mm 0.1 0.01 ELECTRICAL CHARACTERISTICS Part No. HF3545-333Y1R5-T01 HF3545-183Y2R0-T01 HF3545-123Y2R5-T01 HF3545-103Y2R7-T01 HF3545-822Y3R0-T01 HF3545-562Y3R5-T01 HF3545-472Y4R0-T01 Inductance (mH)min. 33 18 12 10 8.2 5.6 4.7 DC resistance (Ω)max. 0.42 0.23 0.17 0.13 0.105 0.077 0.062 Rated current (A)max. 1.5 2 2.5 2.7 3 3.5 4 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 • However, this product is not recognized by each regulations. PACKAGING QUANTITIES HF3545 140pieces/box • All specifications are subject to change without notice. 0.1 1 Frequency (MHz) 10 100
HF2018R-252Y1R3-01 价格&库存
很抱歉,暂时无法提供与“HF2018R-252Y1R3-01”相匹配的价格&库存,您可以联系我们找货
