9332_HF
(1/5)
EMC Components
HF Series
Common-Mode Choke Coils for AC Power Supply
Closed Magnetic Circuit, High Impedance
FEATURES
Comprising double-square closed magnetic circuit ferrite cores
and windings on partitioned bobbins, these common-mode choke
coils are useful for noise suppression. With the small size and high
impedance that the use of closed magnetic circuit cores enables,
their benefits include compactness, high impedance at high
frequencies, and minimal flux leakage.
HF2022R TYPE
SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM
22max.
TYPICAL ELECTRICAL CHARACTERISTICS
IMPEDANCE vs. FREQUENCY CHARACTERISTICS
16max.
3.5±1
22.5max.
1000
ø0.8
100
253Y
4
1
10±0.5
2
Impedance (kΩ)
103Y
1
13±0.5
4
L1
L2
2
3
Weight: 10g typ.
Recommended hole diameter: ø1.2~1.3
Dimensions in mm
3
402Y
10
252Y
1
Part No.
Inductance
(mH)min.
HF2022R-333Y0R3-01
HF2022R-253Y0R4-01
HF2022R-183Y0R5-01
HF2022R-103Y0R7-01
HF2022R-682Y0R8-01
HF2022R-402Y1R0-01
HF2022R-252Y1R3-01
HF2022R-202Y1R5-01
HF2022R-102Y2R0-01
33
25
18
10
6.8
4
2.5
2
1
L1-L2 inductance
difference
(µH)max.
700
500
350
200
150
100
50
50
50
DC
resistance
(Ω)max.
4.2
2.9
2
1.1
0.9
0.5
0.3
0.2
0.2
Rated current
Iac
(A)max.
0.3
0.4
0.5
0.7
0.8
1
1.3
1.5
2
0.1
0.01
0.1
1
Frequency (MHz)
Specifications which provide more details for the proper and safe use of the described product are available upon request.
All specifications are subject to change without notice.
10
100
9332_HF
(2/5)
EMC Components
HF Series
HF2018R TYPE
These coils incorporate square closed magnetic circuit ferrite
cores and windings on partitioned bobbins to provide
compactness, high impedance, and other benefits.
21max.
22max.
3.5±1
17.5max.
1000
ø0.8
100
103Y
4
L1
2
Impedance (kΩ)
10±0.5
1
L2
3
Weight: 10g typ.
Dimensions in mm
13±0.5
Inductance
(mH)min.
HF2018R-333Y0R3-01
HF2018R-253Y0R4-01
HF2018R-183Y0R5-01
HF2018R-103Y0R7-01
HF2018R-682Y0R8-01
HF2018R-402Y1R0-01
HF2018R-252Y1R3-01
HF2018R-202Y1R5-01
HF2018R-102Y2R0-01
33
25
18
10
6.8
4
2.5
2
1
402Y
10
252Y
1
Part No.
253Y
L1-L2 inductance
difference
(µH)max.
700
500
350
200
150
100
50
50
50
DC
resistance
(Ω)max.
4.2
2.9
2
1.1
0.9
0.5
0.3
0.2
0.2
Rated current
Iac
(A)max.
0.3
0.4
0.5
0.7
0.8
1
1.3
1.5
2
0.1
0.01
0.1
1
Frequency (MHz)
10
100
9332_HF
(3/5)
EMC Components
HF Series
HF2422 TYPE
1
26max.
15±0.5
4
21±0.5
2
26max.
L2
2
ø0.8x4
1000
4
L1
3
4±1
Weight: 19.5g typ.
Dimensions in mm
100
Inductance
(mH)min.
68
45
33
25
4.5
3.9
3.3
2.4
Part No.
HF2422-683Y0R4-T01
HF2422-453Y0R5-T01
HF2422-333Y0R6-T01
HF2422-253Y0R8-T01
HF2422-203Y1R0-T01
HF2422-103Y1R2-T01
HF2422-452Y1R5-T01
HF2422-392Y1R8-T01
HF2422-332Y2R0-T01
HF2422-242Y2R5-T01
L1-L2 inductance
difference (µH)max.
700
600
500
400
350
250
150
150
100
90
DC resistance
(Ω)max.
2.3
1.65
1.2
0.88
0.64
0.38
0.19
0.15
0.11
0.09
453Y
203Y
Rated current
Iac (A)max.
0.4
0.5
0.6
0.8
1
1.2
1.5
1.8
2
2.5
103Y
Impedance (kΩ)
22max.
1
3
332Y
10
1
0.1
0.01
0.1
1
Frequency (MHz)
10
100
HF2430 TYPE
4±1
19max.
31.5max.
26max.
4
10±0.5
ø0.8x4
1
1
4
L1
2
13±0.5
3
1000
L2
2
3
Weight: 19.5g typ.
Dimensions in mm
100
203Y
HF2430-683Y0R4-T01
HF2430-453Y0R5-T01
HF2430-333Y0R6-T01
HF2430-253Y0R8-T01
HF2430-203Y1R0-T01
HF2430-103Y1R2-T01
HF2430-452Y1R5-T01
HF2430-392Y1R8-T01
HF2430-332Y2R0-T01
HF2430-242Y2R5-T01
Inductance
(mH)min.
68
45
33
25
4.5
3.9
3.3
2.4
L1-L2 inductance
difference (µH)max.
700
600
500
400
350
250
150
150
100
90
DC resistance
(Ω)max.
2.3
1.65
1.2
0.88
0.64
0.38
0.19
0.15
0.11
0.09
Rated current
Iac (A)max.
0.4
0.5
0.6
0.8
1
1.2
1.5
1.8
2
2.5
Impedance (kΩ)
Part No.
453Y
103Y
332Y
10
1
0.1
0.01
0.1
1
Frequency (MHz)
10
100
9332_HF
(4/5)
EMC Components
HF Series
HF2827 TYPE
22max.
4.5±1
27max.
31.5max.
4-ø0.8
100
4
1
2
19.5±0.5
4
L1
L2
2
3
3
10
183Y
Weight: 25g typ.
Dimensions in mm
Part No.
Inductance
(mH)min.
HF2827-303Y0R9-01
HF2827-183Y1R0-01
HF2827-123Y1R5-01
HF2827-602Y2R0-01
HF2827-442Y2R5-01
HF2827-252Y3R0-01
30
18
12
6
4.4
2.5
L1-L2 inductance
difference
(µH)max.
600
500
350
200
150
100
DC
resistance
(Ω)max.
0.8
0.5
0.4
0.16
0.12
0.1
Rated current
Iac
(A)max.
0.9
1
1.5
2
2.5
3
123Y
602Y
1 252Y
Impedance (kΩ)
11.5±0.5
1
0.1
0.01
0.01
0.1
1
Frequency (MHz)
10
100
HF2826 TYPE
1
20±0.5
30.5max.
4
2
3
24.0±0.5
30.5max.
L1
L2
2
4±1
ø0.8x4.
1000
4
3
Weight: 28g typ.
Dimensions in mm
Part No.
Inductance
(mH)min.
HF2826-353Y1R0-T01
HF2826-253Y1R2-T01
HF2826-203Y1R5-T01
HF2826-123Y1R8-T01
HF2826-802Y2R0-T01
HF2826-562Y2R5-T01
HF2826-472Y2R8-T01
HF2826-332Y3R0-T01
HF2826-182Y4R0-T01
35
25
8
5.6
4.7
3.3
1.8
L1-L2 inductance
difference
(µH)max.
650
500
400
300
200
150
150
100
40
DC
resistance
(Ω)max.
0.78
0.56
0.41
0.27
0.18
0.13
0.1
0.088
0.05
Rated current
Iac
(A)max.
1
1.2
1.5
1.8
2
2.5
2.8
3
4
100
203Y
802Y
Impedance (kΩ)
26max.
1
562Y
182Y
10
1
0.1
0.01
0.1
1
Frequency (MHz)
10
100
9332_HF
(5/5)
EMC Components
HF Series
HF2836 TYPE
22max.
4±1
36max.
30.5max.
4
1000
4
1
L1
2
13±0.5
L2
3
2
Weight: 30g typ.
Dimensions in mm
3
802Y
Part No.
Inductance
(mH)min.
HF2836-353Y1R0-T01
HF2836-253Y1R2-T01
HF2836-203Y1R5-T01
HF2836-123Y1R8-T01
HF2836-802Y2R0-T01
HF2836-562Y2R5-T01
HF2836-472Y2R8-T01
HF2836-332Y3R0-T01
HF2836-182Y4R0-T01
35
25
8
5.6
4.7
3.3
1.8
L1-L2 inductance
difference
(µH)max.
650
500
400
300
200
150
150
100
40
203Y
100
DC
resistance
(Ω)max.
0.78
0.56
0.41
0.27
0.18
0.13
0.1
0.088
0.05
Rated current
Iac
(A)max.
1
1.2
1.5
1.8
2
2.5
2.8
3
4
Impedance (kΩ)
1
10±0.5
ø0.8x4
562Y
182Y
10
1
0.1
0.01
0.1
1
Frequency (MHz)
10
100
HF3545 TYPE
26max.
4±1
1
4
15±0.5
ø1.2x6
1000
1
L2
2
2
21±0.5
3
333Y
4
L1
100 183Y
3
822Y
Weight: 65g typ.
Recommended hole diameter: ø1.5~1.6
Dimensions in mm
Part No.
Inductance
(mH)min.
HF3545-333Y1R5-T01
HF3545-223Y1R8-T01
HF3545-183Y2R0-T01
HF3545-153Y2R2-T01
HF3545-123Y2R5-T01
HF3545-103Y2R7-T01
HF3545-822Y3R0-T01
HF3545-562Y3R5-T01
HF3545-472Y4R0-T01
33
22
18
15
12
10
8.2
5.6
4.7
L1-L2 inductance
difference
(µH)max.
900
700
500
450
350
300
300
250
200
DC
resistance
(Ω)max.
0.42
0.29
0.23
0.21
0.17
0.13
0.105
0.077
0.062
Rated current
Iac
(A)max.
1.5
1.8
2
2.2
2.5
2.7
3
3.5
4
Impedance (kΩ)
45max.
37max.
472Y
10
1
0.1
0.01
0.1
1
Frequency (MHz)
10
100
9332_HF
000908
很抱歉,暂时无法提供与“HF2827-183Y1R0-01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+35.1226610+4.55828
